- OLED monitor topic
- Milyen RAM-ot vegyek?
- Amazon Fire TV stick/box
- Bluetooth hangszórók
- DUNE médialejátszók topicja
- Na, milyen hardver kerül a fa alá?
old-dog
CPT.Pirk
#107770
laci@laci-UNLOCK-INSTALL:~$ v4l2-ctl --all
Driver Info:
Driver name : gspca_pac7302
Card type : USB Camera (093a:2627)
Bus info : usb-0000:00:1d.0-2
Driver version : 6.14.11
Capabilities : 0x85200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x05200001
Video Capture
Read/Write
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (gspca_pac7302: ok)
Format Video Capture:
Width/Height : 640/480
Pixel Format : 'PJPG' (GSPCA PJPG)
Field : None
Bytes per Line : 640
Size Image : 115790
Colorspace : JPEG
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Streaming Parameters Video Capture:
Frames per second: invalid (0/0)
Read buffers : 2
User Controls
brightness 0x00980900 (int) : min=0 max=32 step=1 default=16 value=16 flags=slider
contrast 0x00980901 (int) : min=0 max=255 step=1 default=127 value=127 flags=slider
saturation 0x00980902 (int) : min=0 max=255 step=1 default=127 value=127 flags=slider
red_balance 0x0098090e (int) : min=0 max=200 step=1 default=100 value=100 flags=slider
blue_balance 0x0098090f (int) : min=0 max=200 step=1 default=100 value=100 flags=slider
exposure 0x00980911 (int) : min=0 max=1023 step=1 default=66 value=66 flags=inactive
gain_automatic 0x00980912 (bool) : default=1 value=1 flags=update
gain 0x00980913 (int) : min=0 max=62 step=1 default=15 value=15 flags=inactive
horizontal_flip 0x00980914 (bool) : default=0 value=0
vertical_flip 0x00980915 (bool) : default=0 value=0
white_balance_temperature 0x0098091a (int) : min=0 max=255 step=1 default=55 value=55
sharpness 0x0098091b (int) : min=0 max=15 step=1 default=8 value=8 flags=slideraci@laci-UNLOCK-INSTALL:~$ v4l2-ctl --list-devices
USB Camera (093a:2627) (usb-0000:00:1d.0-2):
/dev/video0 -
Dißnäëß
CPT.Pirk
#107688
Nem először fordul elő a történelem során, hogy Ubuntuék lábon lövik magukat futás közben és nyilván a Lubuntu is az. Mint +1, kicsit "konzervatívabbak" - most nem csomagokra gondolok feltétlen, hanem nem követik az Ubuntut, amiből készül, telibe minden hülyeségbe.
LMDE nálam mostanság az új favorit, szvsz bitang jó lett, de még nyomkodom VM-ben, jön-e elő vmi hülyeség, ami nem tetszik, de amúgy "nagyon egyben van".
cigam
CPT.Pirk
#107685
Mert 1001 más dolog is okozhatta. Máshogy volt beállítva, más verziójú volt az X a kernel a Firefox,...
Valószínű a snap-es FF nem tudta használni megfelelően a va-api-t (ha egyáltalán telepítve volt), mert még elég kezdetleges állapotban van. Nem tudjuk, hogy a FF beállításait, mint pl.media.ffmpeg.vaapi.enabled = truemedia.hardware-video-decoding.enabled = true
Stb, stb, stb...
Persze megértem, hogy nincs idő napokig kísérletezni, bújni a doksikat, fórumokat, hogy mi a valódi oka. Egy reinstall előtt megnéztem volna a natív FF működését...
Így viszont megint a Cinnamonn van (érdemtelenül?) polírozva. -
CPT.Pirk
#107681
Láma ON : 1080p kijelzőn néztem, a próbapadnál az van, ott semmi gond Chrome alatt(a Win11 szinkron miatt a Chrome, nekem így egyszerűbb). 4k kijelzőn nemtom, de sztem Mint alatt ott is full problémamentes.
40 frissítés elérhető - most látom, ráklikkeltem az összes telepítésére, remélem nem lesz crack egyikkel sem...
CPT.Pirk
#107677
Megnéztem én is kíváncsiságból Mint alól, bár a gép még próbapadon van, 3 közfalon át az alaplapi wifivel.
YT : 1440p folyamatos, 2160p már szaggat, mert gyenge wifi térerő. UTP- ről nyilván jó lesz a 4k is.
Gép : HEDT félretró, 10C/20T i9/GTX1650.
Próbapados próbakép volt, itt pedig immár összeszerelve a vadállat. -
Dißnäëß
CPT.Pirk
#107675
Én pont fordítva látom, de lehet tévedek. Community disztrók előnye, hogy bár best effort mentén megy (gyakran), a fejlesztők motiváltabbak. Nincs annyi megkötés, kreténkedés, mint egy cégesnél, ahol meg van adva egy szűk csőként az irány, hogy "ezt akarjuk, a mi Linuxunk holnap ezt és ezt kell, hogy tudja, így és így" és utána az a kötelező.
Céges disztrókba vetett bizalmam eléggé lecsökkent az elmúlt 10 évben, ezek a variálások, eladok-átveszi-kiheréli-kinyírja-átalakítja és az összes hülyeség körülöttük elég szar tud lenni.
Oké, nem mondom, hogy egy Debian-Devuan "meccs" anno jót tett alapvetően a közösségnek, de valahogy a community cuccok fele vonzódom stabilitás szempontból is.
(DB-vel is így vagyok, inkább egy külsős, tényleg nagy nevű szakértő cég által supportált postgre vállalatban is élesre, mintsem egy maga a gyártó által fizetős proprietary).
CPT.Pirk
#107675
Felélesztették, abból lett az EndeavourOS. Az Arch klónokból meg azért van annyi, mert erre a koncepcióra igény van.
Félreértettél, a Chakra felélesztésére gondoltam. Biztosan van ennyire igény, ahogy egy adott mobilmárka egy évben kiadott 20 modelljére is!
De értelek amúgy és jogos is, amit írsz, de ettől még fájni tud, ha bejön valamelyik a sokszázból és épp az lesz kampeca. Kicsit fura egyes fejlesztőcsapatok gondolkodása vagy igényfelmérése, ha a Garuda változataira gondolunk, igaz most változtattak a palettán, de még mindig kegyetlen vízuális élmény a legtöbb ízben.
Azért akárhogyan is van, a mostani Zbook 15 G5-re szívesen felraknék egy friss Chakra-t! Épp a többitől eltérő volta miatt is, de emiatt próbáltam a Garudát is meg a CachyOS-t is megnézem, érdekes lehet összehasonlítani a default scheduler-ét egy SSD NAND-barát filesystem kiválasztásával. Igaz ezeket kiválaszthatnám a Mint install elején is...no mindegy.
De akit ez zavar, feltehet céges disztrót, aminél ennek az esélye jóval kisebb, persze cég is mehet csődbe...
Jogos, bár nem ezért használok Linux Min-et. (nem is erre gondoltál, mikor szofisztikáltan gonoszkodtál kicsit) -
CPT.Pirk
#107665
Régi öreg disztró volt...hát ugye ez önmagában inkább pozitívnak tűnik nálam.
De összességében én az user szempontjából írtam, amit írtam. Ha van egy létező disztró, ami jó és nekem kézreáll, akkor eszembe sem jut, hogy annak működtetése extra munkát igényel, gondolom ezzel tisztában voltak akkor is, amikor létrehozták. Valakik igazán feléleszthetnék, mert egyedi volt épp amiatt, amit leírtál, de ahogy látom ezernyi archklón nő ki inkább a földből, aminek lássuk be, nem túl sok értelme van. (de most ezzel nem Tibikomám alál akarom adni a lovat)
sicc_innen
CPT.Pirk
#107271
sudo apt remove nvidia-kernel-dkms nvidia-driver
sudo apt autoremove
sudo dpkg --configure -a
Köszönöm!
Most jutottam el, hogy kipróbáljam. Ezek a parancssorok visszahozták a distrót.
Újra neki kell futnom, hogy ne legyen szaggatott a mozgás a képernyőn, tehát valami gyári nvidia modult kellene feltenni, mivel úgy tűnik, hogy az alap csak ennyi tud, hogy tökéletes a kép állóképeknél. A kurzort minél gyorsabban mozgatom, annál jobban szaggat, vibrál. (Egy bizonyos sebesség felett nem is látszik már.)
Nvidia GTX1660 Super kártya van az asztali gépben, ezt kellene valahogy a lehető legjobban illeszteni. Ha valami kis vezérlőpultféleség is lenne hozzá, az még jobb lenne. Tudom, olyat nem várjunk tőle, amilyen a win alatt van. -
Albert.Tamas
Vasti74
CPT.Pirk
#107466
Köszi, a su - nem jutott eszembe ;-)
Egyébként nem árt a felhasználót a sudoers fájlba is felvenni - arra emlékeztem, csak ugye nem engedte írni ;-)
Ha nem virtuális gépen futna a Debian, akkor persze simán átváltottam volna konzolra, bejelentkezek root-ként, aztán meg is van oldva: de hirtelen azt sem tudom, hogy VirtualBox alatt van-e ilyen elehetőség?! ;-) -
CPT.Pirk
#107483
Nem is keverem a Tg és Modera ténykedéseket, most se gondoltam ilyesmire!
Egyrészt voltam Tg anno és eléggé meg is szerettek a Modera urak, olyannyira, hogy repültem is mindhárom topikból, mint Tg!Amikor itt törölnek hsz-t, akkor is tisztában vagyok vele, hogy azokhoz neked semmi közöd, most a szakmai szemedre gondolva írtam, hogy nem olvasol el mindent!
Necronom
sicc_innen
CPT.Pirk
#107271
"Hát, most jönne az nvidia csomagok kézi kigyomlálása, előbb-utóbb vissza kell jutnod az alapállapotba a nouveauval, de az igényel némi rutint. Talán ezzel jutsz valamire:
sudo apt autoremove
reboot"
Köszönöm!
Sajnos eddig már nem jutottam el, mivel az újraindítás után már nem indul el az MX.
A grub bejön a választási lehetőségekkel, majd amikor töltené be a rendszert sötét képernyő marad a "loading initial ramdisk..." kiírás után. Nem reagál semmire, csak a reset gombra. Ha grubban a systemd-s módot választom, akkor is ugyanez a helyzet.
Indításkor "Csökkentett mód" itt nincsen, mint a win-nél? -
Necronom
CPT.Pirk
#107386
Igen, tettem fel, de mivel 2eve volt mar nem emlekszem hogyan, de szerintm siman terminalbol
a file tartalmat nem tudta, mert nincsen olyan
de a masikra itt a valasz elvileg https://pastebin.com/NfvYm8kYokes, akkor ezen a gepen vegigcsinalom a frissiteseket, de az tobb oras lesz (vajh miert? a telepites 10 perces)
a masik diszrto maradhat az a gep csak HDD megosztasra van, belso halora, meg net se nincs neki...(de remelem nem unatkozik net nelkul
IstvánLászló
CPT.Pirk
#107393
Értelek ígazad van,részemről nem ajánlottam a 32bitet,azt mondtam el az MX kapcsán - tudom van még 32bites rendszere.
A véleményedet legalább most a még a most kezdők olvashatják és én is támógatlak-ebben,tehát kapnak egy nagyon jó írányt,hogy 64bites rendesznek a használalta a fontós.
Akik váltani akarnak,vagy csak éppen megismerkedni a linuxdisztroknak az eggyikével: LinuxMintet 64bit -est ajánlóm kezdésnek - ez a jó írányadó mindenkinek a részére.
A LinuxMintet 64bit -es tajánlóm kezdésnek. -
Necronom
Necronom
CPT.Pirk
#107378
igy akkor ezt irja
Csomaglisták olvasása... Kész
Függőségi fa építése
Állapotinformációk olvasása... Kész
Minden csomag naprakész.
N: A beállított „main/binary-i386/Packages” fájl beszerzésének kihagyása, mert a(z) „https://brave-browser-apt-release.s3.brave.com stable InRelease” tároló nem támogatja a(z) „i386” architektúrát
E: /var/lib/dpkg/lock-frontend zárolási fájl nem nyitható meg - open (13: Engedély megtagadva)
E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root? -
growler
CPT.Pirk
#107280
A Garuda a közelmúltban elég komoly fejlesztéseken esett át. [link]
(Garuda Rani, Garuda Health)
Ha a KDE a kedvenc felületed, akkor a "mokka"-t ajánlanám.
A kinézetét, (a mokkának nem is olyan "indiai") testre lehet szabni.
Szerintem, nézd meg liveban - valószínű nem fogsz nagyot csalódni. -
CPT.Pirk
#107280
Mondjuk egy autoremove meg nálad mehetne még oda.
Jogos, de azt szerintem elfelejtem mostanában, de boot tuán egyből lefuttattam a
sudo nala update && sudo nala upgradeparancsot és az csinál autoremove-ot, de nem talált semmit. Mármint a nala.Super a Garuda, szerencsére a YT lejátszása alatt nem néztem, csak hallottam, hogy fut, egyébként a szemem hamar kiugrik minden verziójától!
Már átállítottam normál KDE kinézetre, amennyire hirtelen sikerült, de az tény, hogy rettenet a default kinézete. Viszont csinált majd két giga upgrade-et, reboot után még mindig fut, lehet szereti a gép ezt a 6.17.1-zen1-1-zen kernelt. -
CPT.Pirk
#107271
Nemrég Debianon is leült a gyári drivertől a Zbook, mint a többi is, a legegyszerűbb módszer a konzolból kiadott
sudo apt remove nvidia*parancs volt, szépen felsorolt minden releváns nvidia csomagot és leszedte, utána bootolt is rendesen a nyílt nVidia driverral a rendszer. -
sicc_innen
CPT.Pirk
#107269
Köszönöm.
Megpróbáltam. Nem sikerült.Ez írta ki:Frontend:
Nvidia parancs = apt-get install --install-recommends --reinstall -y nvidia-driver nvidia-settings nvidia-kernel-dkms libnvidia-encode1
E: A dpkg megszakadt, saját kezűleg kell futtatnia a(z) „dpkg --configure -a” parancsot a probléma megoldásához.
POSTINSTALL
symlinks
KészMajd beírtam a sudo dpkg -- configure -a parancsot és ezt dobta ki:
$ sudo dpkg --configure -a
Beállítás: nvidia-kernel-dkms (535.216.03-2~bpo12+1) ...
Removing old nvidia-current-535.216.03 DKMS files...
/usr/sbin/dkms.mx remove -m nvidia-current -v 535.216.03 --all
Loading new nvidia-current-535.216.03 DKMS files...
Error! DKMS tree already contains: nvidia-current-535.216.03
You cannot add the same module/version combo more than once.
dpkg: error processing package nvidia-kernel-dkms (--configure):
installed nvidia-kernel-dkms package post-installation script subprocess returned error exit status 3
dpkg: függőségi gondok miatt nem beállítható e csomag: nvidia-driver:
nvidia-driver függőségek: nvidia-kernel-dkms (= 535.216.03-2~bpo12+1) | nvidia-kernel-535.216.03 | nvidia-open-kernel-535.216.03; ám:
nvidia-kernel-dkms csomag még beállítatlan.
`nvidia-kernel-535.216.03' csomag nincs telepítve.
, mely nvidia-kernel-535.216.03-t adja nincs beállítva.
`nvidia-open-kernel-535.216.03' csomag nincs telepítve.
dpkg: error processing package nvidia-driver (--configure):
függőségi hibák - e csomag beállítatlan maradt
Processing triggers for initramfs-tools (0.142) ...
update-initramfs: Generating /boot/initrd.img-6.1.0-17-amd64
Processing triggers for libc-bin (2.36-9+deb12u3) ...
Processing triggers for glx-alternative-mesa (1.2.2) ...
Processing triggers for update-glx (1.2.2) ...
Processing triggers for glx-alternative-nvidia (1.2.2) ...
update-alternatives: using /usr/lib/nvidia to provide /usr/lib/glx (glx) in auto mode
Hibák történtek a feldolgozáskor:
nvidia-kernel-dkms
nvidia-driver -
sicc_innen
CPT.Pirk
#107223
Az nVidia weboldaláról szedted le a .run fájlt és azt telepítetted anno?
Igen, onnan lett letöltve, de nem sikerült telepíteni, futtatni (futtathatóvá tenni a .run filet).
Sajnos nem ismerem ezeket a konzolparancsokat. Grafikus felületen a fájlra jobb klikkel pedig nem találtam olyan menüpontot, amivel futtathatóvá lehet tenni. -
sicc_innen
CPT.Pirk
#107217
Letöltöttem a gyárit, ami egy 141 MB-os .run file. Nem futtatható, csak a kwrite nyitotta meg. A nouveau most újra már nem települ fel, mert a hibaüzenet szerint ütközik egy 'non-free' nvidia kernelmodullal. A képakadozásos hibajelenség változatlan.
Hol lehetne megnézni, vagy kimenetet kérni az aktuális modulra? -
CPT.Pirk
#107139
Régebbi mérésekhez képest nekem is más-más értékek jönnek ki, de értelemszerűen a -T és a -t miatt főleg. Viszonyítani viszont lehet velük, nekem pont ugyanazon SSD típus jócskán más eredményt hozott a Dell és HP notikon, pedig kb azonos erejű gépekről van szó. A --direct eredmények viszont egész közel álltak egymáshoz.
Ezeknél mélyebbre én se megyek már, ahhoz nagyon kéne ismerni az NVMe controller lelkivilágát. Főleg OEM eszközöknél ez majdnem lehetetlen...
CPT.Pirk
#107132
Biztosan nem követted a threadet, mert akkor tudnád mire jönnek elő ezek a mérések.
Amúgy érdekes, amit írsz, csak éppen nem a --direct kapcsolóra jellemző, ill arra jóval kevésbé, mint a -T és -t kapcsolók eredményére, ott 2-3 mérést javasol inaktív rendszeren a hdparm man-ja is alapból.
IstvánLászló
CPT.Pirk
#107132
Értelek arra gondoltunk:Linuxdisztrokon megnézzűk mennyit számit a hardver,HDD SSD MVME meghajtóknak a teljesítménye és a tesztjét,én is csak tájékoztatóként készitettem mindenkinek.
A tesztek nekem is sokat segítettek,azt tapsztalhattam hogy más rendszereken is jól futnak az adatárólóink és nálam is jók az eredmények.
Amit most mondasz mindenel eggyetértek és ígen támogatom azt amit mondasz teljesmértékben. -
CPT.Pirk
#106850
Ez amikor aktívan elkezdtem Linuxozni, 7-7és fél éve volt, egy bizonyos pc-n.
Hónapokig ha nem 1 évig szenvedtem mire rátaláltam az Ubuntu 18.04-re és az azóta is egy hiba nélkül teszi a dolgát.
zekre kérnék magyarázatot, amiket az összes másik disztró produkált, erről írtam egy blogot (amiben a hozzászólások 90%-a azt próbálta kifejteni hogy én egy f@sz vagyok nem való nekm Linux, maradjak winen).
A blogból kiollózva a napi hibákat,
""Kis túlzással minden napra jut egy meglepetés,
Benedek Elek : Minden napra egy mese" című könyve jut eszembe.
Csak villanások amik beugranak,
Böngészőnek megadom a mentési könyvtárat, ami történetesen a háttértáram download könyvtára.
2-3 napig ebbe menti a netről leszedett fájlokat. Majd gondol egyet és elkezdi mentegetni a home/Felhasználónevem/Letöltések könyvtárba.
Miközben a böngészőbe továbbra is a háttérpartíció van megadva. Majd gondol egyet, és elkezd menteni a sima home/Felhasználónevem alá.
Este nyomtattam, másnap reggel gép indítás, nyomtatás nincs. Elvitte a cica.
Ennek a kijavítása volt a legnagyobb cumi, kb. 5 nap fórumozásba és sacc. 10-12 beleölt munkaórába telt.
Wine egyik nap még működik, másnap nem hajlandó, indul a szögelés.
Automatikusan induló alkalmazások random nem indulnak automatikusan, ha bejátszom a sleep paranccsal hogy szépen egymás után induljanak akkor kb. 2 hétig jó, majd megint kimarad 1-2 alkalmazás. Az összesen 5-ből... Megint megszögelem, más értékekkel késleltetem, felcserélem az alkalmazások sorrendjét és megint jó. De meddig...?
Bizonyos szoftverek a telepítés után képtelenek elindulni csak pörög az ikon a panelon, majd a program kilép. Az alkalmazás indítóját macerálva, az exec sorba fórumokról levadászott kiegészítőket beirkálva jó lesz. Hogy meddig, az első frissítésig mert akkor megint át kell írni.
Opera böngésző egyik percről a másikra összeomlik.
Hónapok óta jól működő képernyőbillentyűzet minden ok nélkül egyszer csak ékezetes betű beírásánál simán beborítja az egész rendszert, a rendszer minden ékezetes betű bevitelére szó nélkül újraindult.
Saját partíciómanagerrel létrehozott FAT32 fájlrendszerű partíciót a rendszer képtelen használni. Ez tényleg így volt, nem vicc, 1 nap szenvedés után reboot Win, abba megformáz, visszaboot Linux, a partíciót azonnal tudta használni.
Egyik napról a másikra megszűnt a pendrivek írási lehetősége. Minden erre létező alkalmazás, a saját lemezkezelők, saját image írók, az appimage Etcher, mind elszálltak ha telepítő pendrivot akartam írni vagy formázni. Ezt nem tudtam megoldani, a Manjaro ezzel a hibával szállt a sírba.
Az energiakezelés esetlegessége, random kitalálhatatlan működése.
A képernyő kikapcsolása 10 percre van állítva, és olyan orosz rulett féleség, 10-ből 3x kikapcsolta a monitort, 3-4x nem, 3-4x meg a monitor ment, totál fekete képpel, közepén az egérkurzor.
De bezzeg amikor benne vagyok nyakig egy teljesképernyős játékba (ePSXe emulátor) , AKKOR lelövi a monitort 10 perc múlva! Brilliáns.
Jpg képformátumot futtathatónak ítélt és megtiltotta hogy megnyissam. Egy képet.
Bluetooth szolgáltatás "véletlenül" nem indul el, vagy ha elindul, a hetek óta jól működő BT. adaptert nem ismeri fel, vagy ha felismeri, automatikusan már nem kezeli, közli hogy hiba van vele.
1-2 reboot és megint 1 hétig jó a BT.
Minden előjel nélkül a fájlkezelőből minden sorba hiányzik pár betű, vagy a helyére négyzeteket rak be, ezt csak egy reboot oldja meg.
Hetek óta jól működő játék emulátor elveszíti játék közben a joysticket, megoldás reboot.
Teljesképernyős játékból visszatérve az Asztal totál összekuszálva, egymás hegyén-hátán az ikonok a bal felső sarokba.
Sorolhatnám napestig.
Mielőtt valaki azt mondja hogy ez mind a fantáziám szüleménye, megadom a fórumok linkjeit ahol hónapokig mindenki ezekkel, és jó pár más problémámmal foglalkozott.
Ennyire megbízhatatlan rendszerrel életemben nem találkoztam még.""
Még annyi, ssd-ket cseréltam ramokat tápokat mindent hátha valamelyik rejtett hibája okozza az anomáliákat. és nem.
Te, vagy bárki, BÁRKI más aki úgy dönt hogy na mostaztán tényleg nekifekszek egy Linuxnak, és ezek az első tapasztalatai, ti mt csináltatok volna...? Hagytátok volna a franncba az egészet, pláne hogy még több fórumba nyíltan lehülyéznek?
Tehát mit tud a 18.04 Ubi, amit semelyik másik, kb. 7-8 disztró nem? Mivel azon a pc-n azóta is egyetlenegy hibajelenség nélkül 7. éve teljesít.
Ezt az Ubin kívül csak a W10 tudja
ha nekifeküdnék most és felrántanék arra a pc-re bármit, Mintet, bármit nagyobb összegbe fogadnék hogy ugyanazokat produkálná.
Lehet megcsinálom, az a mai napig az egyik melóhelyi gépem. -
Petya XT
CPT.Pirk
#106778
Éppen egy hajszálnyival. A Mintem, a konfigurált rendszerem, 4,1 GB, a Manjaro szinte ugyanennyi, a Windows 11 4,7 GB. A progik ugyanazok. Éppen nézegettem, hogy már ezek sem nevezhetőek éppen pehelysúlyú versenyzőknek. Nem is értettem a minap ezt a DE összehasonlítást. Ki az aki üresen használja a rendszerét? Szerintem nem érdemes ezzel foglalkozni.
CPT.Pirk
#106678
A retró topikban ezt javasolták. Jó lesz ez, amit a telepítő felpakolt, működik minden, sokat fejlődött 10 év alatt, mióta utoljára próbáltam a Pingvint. Elég komplex félmodern vasat pakoltam alá, felismert minden alkatrészt, 2 videókártya is van benne.
Nyilván a HD6870 csak retrózáshoz kell. A modernizált XP is látja jól az egész hóbeleváncot.A Debian telepítési gondok is csak addig gondok, míg ki nem alakul a tapasztalat, de ez általában máskor is így van.
CPT.Pirk
#106553
Jogos de azért valljuk be egy kellemes magától értetődő guin síkkezdőnek is kellemesebb egy partíció backup vegy egy os klónozás.
Használom a Zillát, megszoktam a felületét de mióta egy kedves számtekes ismerősöm adott egy (tényleg) csak nagyon picit okosított teljes verziós Acronis szoftvert, azóta eléggé hanyagolom a Clonezillát.
Mindent tud az Acronis, ég és föld. Kezelésben komfortban meg összehasonlíthatatlan, nincs is értelme -
Petya XT
CPT.Pirk
#106553
Nekem is kb olyan idős van. Valahol az utolsó free verzió környékén. Van rá egy dedikált pen, de elraktam a free verzió ISO-t és a telepítőt is, ha valakinek kell, szívesen megosztom. Én értem a Clonezillát, de a kérdés a Macrium-ra volt kihegyezve, azért írtam, hogy gond nélkül lehet használni linux esetében is.
Warton
CPT.Pirk
#106457
Linux Mint telepítő USB-vel rápróbáltam és azzal működik a wifi, úgyhogy hardver hiba kizárva, valami Archos hülyeség lesz.
Broadcom BCM43224
Az archban a drivernél N/A szerepel, míg a LinuxMintben bcma-pci-bridge.Ezalapján a driver eltűnt és valószínűleg a hiba megoldása ezen az oldalon lesz, de nem nagyon tudom mit kéne csinálni. Egy biztos, hogy a broadcom-wl fent van, eddig azzal működött.
Zolifarkas
CPT.Pirk
#106415
Köszönöm. Jelenleg ezek mind működnek a Wolfenstein New colossus kicsit nehézkesen a kevés dedikált video memória miatt de megoldja a játék maga. Jelenleg internetezésre is ezt a gépet használom csak játék alkalmával fizikailag leválasztom a netről. A játékok közül ezt a kettőt még nem próbáltam: Medal of Honor, Return The Wolfenstein Castle
CPT.Pirk
#106410
A szavazás az kb. Outlookban sem feltétlenül működik normálisan
Tündérbördhöz ha Exchange szerveres móka kell, akkor van nagyon jól működő plugin, 1 hónapig ingyen, aztán fizetős, de nem drága.@Zolifarkas : Pl. most szívtam olyat, hogy virtuális Windowson a Revolt nem megy DirectX hiányában, de Debianon pöcc-röff.
CPT.Pirk
#106386
és hcl.
Persze hogy alapból tiltott de kénytelen voltam engedélyezni.
Csak az ismerősi körömben 3 olyan NAS van amik még smb1. Nem őskövületek! És ez az Asus router is amit vettem használtan itt a HA-n. 2019-es gyártás és még ez is V1.
Sajnos ez van és erről nem az userek tehetnek hanem gyártók.
Itt a Wines fájlkezelő.
Beírom jelszót és nyitja-csukja írja-olvassa csatolja.
A Ubuntun meg az összes fájlkezelő eddig eljut, és innen nincs tovább, hiába irkálom be a jelszót.
Vagy visszadobja ezt az ablakot 100x, vagy megunja és nem létező könyvtárat meg időtúllépést produkál. -
CPT.Pirk
#106375
Nincs
Ezeken már túl vagyok, hogy pipewire restart, meg tedd fel a pipewire-t.
A másik laposom is 8. genes, azon is ez volt, megjavult magától (sima update után).A két gépen most az van, hogy
- A nem működőn bedugom a HDMI, és ugyanúgy csak egy "Internal source" van, amin lehet kapcsolgatni, hogy az Pro, sztereó, HDMI, vagy valami.- A működőn megjelenik még 3 HDMI kimenet, amiből egy a HDMI csati (a másik 2 a két USB-C lehet), és szól is
I02S3F
CPT.Pirk
#106365
Köszi! Azt vettem észre, ahogy az idő telt, hogy nekem jó, ha nagy méretűek a betűk, mert könnnyebben olvasom őket. Természetesen rendelkezem megfelelő dioptriájú szemüveggel, de jó 1-2 szinttel mindig lejjebb veszem a felbontást. Vagy a skálázást veszem fel 25-50%-al.
Milyen program ami... [link]
- Teszt [Linux] A Flatpak
- AliExpress tapasztalatok
- Tőzsde és gazdaság
- World of Tanks - OFF topic
- Epic Store Ünnepi Ajándékozás - 6. nap: Bloodstained: Ritual of the Night
- Xbox Series X|S
- Áramszünet küldte betegszabadságra a robotaxik hadseregét
- Adobe Előfizetések - Adobe Creative Cloud All Apps - 12 Hónap - 15% AKCIÓ
- MS SQL Server 2016, 2017, 2019
- Keresem a Barkács Balázs Játékokat
- iPhone 14 Pro Max 256GB Space Black -1 ÉV GARANCIA -Kártyafüggetlen
- Dell Latitude Precision Üzleti gépek, 2-in-1 gépek, 3-11. gen.
- BESZÁMÍTÁS! MSI B550M R5 5600X 16GB DDR4 512GB SSD ROG RTX 3070 Ti 8GB Asus A31 PLUS TG ARGB 750W
- Xiaomi 11 Lite 5G NE 256GB, Kártyafüggetlen, 1 Év Garanciával
- iKing.Hu-Nothing Phone 3a Pro Grey Glyph stílus, 3 optikai zoom 12/256 GB -3 hónap garancia
Cég: BroadBit Hungary Kft.
Város: Budakeszi
De majd holnap szórakoztatom magam a többi AUR-os megfejtéssel ma már hagyom pihenni.
