(használd a CYBSEC25PH kuponkódot további 20 ezer ft kedvezményért!)
Ablakos
A hhd-re vonatkozó sorok:
sda 8:0 0 1.8T 0 disk
└─md0 9:0 0 1.8T 0 raid1
├─vg--media-photo 252:13 0 150G 0 lvm
└─vg--media-macriumBackup 252:14 0 200G 0 lvm
sdb 8:16 0 1.8T 0 disk
Ablakos
Jajj, el nem igazodom itt
ls -l /dev/disk/by-uuid/
total 0
lrwxrwxrwx 1 root root 15 Oct 7 06:23 0060-3374 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 15 Oct 7 06:23 0074-B231 -> ../../nvme1n1p1
lrwxrwxrwx 1 root root 10 Oct 7 06:23 135cc457-7d52-4dc4-afaf-227d1b20137c -> ../../dm-1
lrwxrwxrwx 1 root root 10 Oct 7 06:23 491e4cef-0236-4f73-bfbc-498e10bc739e -> ../../dm-7
lrwxrwxrwx 1 root root 11 Oct 7 06:23 4c3d9d5d-2b93-48de-b5ff-68d58b603716 -> ../../dm-10
lrwxrwxrwx 1 root root 10 Oct 7 06:23 5b8b366b-70b2-44ca-9457-332b0a73b268 -> ../../dm-4
lrwxrwxrwx 1 root root 11 Oct 7 06:23 61020f79-aff3-456c-b518-c52b1fdb2b46 -> ../../dm-13
lrwxrwxrwx 1 root root 10 Oct 7 06:23 693aa4c9-686e-400f-8c7b-a2552dbf1c7d -> ../../dm-6
lrwxrwxrwx 1 root root 10 Oct 7 06:23 6c20e95e-cf9e-421b-92a7-29e033fb5f16 -> ../../dm-5
lrwxrwxrwx 1 root root 11 Oct 7 06:23 82f0b2da-d70d-4cc7-a1d8-bc67726f6d4b -> ../../dm-11
lrwxrwxrwx 1 root root 10 Oct 7 06:23 85a44c08-3db2-4b2d-bc95-c3d17f26ac34 -> ../../dm-2
lrwxrwxrwx 1 root root 10 Oct 7 06:23 98cb11cd-569e-4a34-a313-f093a293755d -> ../../dm-9
lrwxrwxrwx 1 root root 10 Oct 7 06:23 b19c2b32-917b-494c-bd7c-cfb57e5cda8c -> ../../dm-0
lrwxrwxrwx 1 root root 10 Oct 7 06:23 b493ad2e-96af-495f-a78c-84448f00c716 -> ../../dm-3
lrwxrwxrwx 1 root root 11 Oct 7 06:23 cdfd8a16-a8d8-4640-8d03-05216653d731 -> ../../dm-12
lrwxrwxrwx 1 root root 10 Oct 7 06:23 d90caaa3-ee59-467e-9242-a1ec005bb55d -> ../../dm-8
lrwxrwxrwx 1 root root 11 Oct 7 06:23 dc88258c-17c5-4440-96ee-b8808cb46a41 -> ../../dm-14
Siriusb
Valóban így működik nálam is, a kulcsszó, hogy ki van jelölve a könyvtár. Hogy régebben is így volt-e, azt nem tudom visszaidézni.
Szerk.:
Kipróbáltam double commander-ben, hiába van kijelölve a könyvtár, akkor is az aktális szinten hozza létre az újat, ahogy Te várod.
Jobban belegondolva a te álláspontoddal értek egyet, ennek így kellene működnie. -
Ablakos
Nem hiszem el. hogy ennyire bénázom ezzel:
Reboot után:
cat /proc/mdstat
Personalities : [raid0] [raid1] [raid6] [raid5] [raid4] [raid10]
md127 : inactive sda[0](S)
1953382488 blocks super 1.2
lsblk
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
└─md127 9:127 0 0B 0 md
nvme0n1 259:0 0 465.8G 0 disk
├─nvme0n1p1 259:1 0 1G 0 part /boot/efi
├─nvme0n1p2 259:2 0 1G 0 part /boot -
Ablakos
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a
# device; this may be used with UUID= as a more robust way to name devices
# that works even if disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
# / was on /dev/vgubuntu-system/lv-root during curtin installation
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOH5PipY0Ip61g3OcMbseeMc8aFyFK2fPDa / xfs defaults 0 1
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOHxRZTNBTsZMW0WUxa0pdq319sDVeMwWui none swap sw 0 0
# /var was on /dev/vgubuntu-system/lv-var during curtin installation
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOHZOdSmKYpfmuPZah3xKeZTbxF5xPgnJos /var xfs defaults,nosuid,nodev 0 1
# /var/cache was on /dev/vgubuntu-system/lv-varcache during curtin installation
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOHUX4YHM806NjbMPloBDjumecz82zEybaJ /var/cache xfs defaults,nosuid,nodev 0 1
# /usr was on /dev/vgubuntu-system/lv-usr during curtin installation
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOH52VZXdL7cIIR2Uy82cuhr999H3ioDs3w /usr xfs defaults,nodev 0 1
# /tmp was on /dev/vgubuntu-system/lv-tmp during curtin installation
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOH9cGKukmY2uED3V3Jn1gEp9EVZ0mpMtNh /tmp xfs defaults,nosuid,nodev,noexec 0 1
# /var/lib was on /dev/vgubuntu-system/lv-varlib during curtin installation
/dev/disk/by-id/dm-uuid-LVM-Xs4ndbGBzI8HTN65QdCM50slJohuUwOHht5CSBGcfoeiGbFKuTf04PCZ4YsvhS7H /var/lib xfs defaults 0 1
# /home was on /dev/vgubuntu-data/lv-home during curtin installation
/dev/disk/by-id/dm-uuid-LVM-lysHE8fQhIUXJXsreqAsbzYcmIpQOa8HvHAzxh3B1lYvLkfCeDasrvhTPDtrFCFN /home xfs defaults,nosuid,nodev,noexec 0 1
# /var/log was on /dev/vgubuntu-data/lv-varlog during curtin installation
/dev/disk/by-id/dm-uuid-LVM-lysHE8fQhIUXJXsreqAsbzYcmIpQOa8Hm4nRvGIHHFQDTm4m6cE1muXzRem67WVV /var/log xfs defaults,nosuid,nodev,noexec 0 1
# /opt was on /dev/vgubuntu-data/lv-opt during curtin installation
/dev/disk/by-id/dm-uuid-LVM-lysHE8fQhIUXJXsreqAsbzYcmIpQOa8HKS0O8m6vPlOxHHWfcO57fgnSMEni7VLN /opt xfs defaults,nodev 0 1
# /boot was on /dev/sda2 during curtin installation
/dev/disk/by-uuid/517b77b4-4937-4832-b7dd-262dcf16c0c7 /boot ext4 defaults 0 1
# /boot/efi was on /dev/sda1 during curtin installation
/dev/disk/by-uuid/E8E1-4FC1 /boot/efi vfat defaults 0 1
# /var/www was on /dev/vgubuntu-data/lv-www after installation
/dev/disk/by-id/dm-uuid-LVM-lysHE8fQhIUXJXsreqAsbzYcmIpQOa8Hc9yLpe4pY2C6oDePOjewwNMPCFpVdN3T /var/www xfs defaults,nodev,noexec 0 1
# Synology shares
//192.168.200.3/documents /media/documents/ cifs rw,vers=3.1.1,credentials=/root/.horvathCredentials,gid=1000,dir_mode=0775,file_mode=0664,nofail,_netdev,x-systemd.mount-timeout=30,iocharset=utf8
#//192.168.200.3/backup /media/backup/ cifs rw,vers=3.0,credentials=/root/.horvathCredentials,gid=1000,dir_mode=0775,file_mode=0664,nofail,_netdev,x-systemd.mount-timeout=30,iocharset=utf8
//192.168.200.3/java /media/java cifs rw,vers=3.0,credentials=/root/.horvathCredentials,gid=1000,dir_mode=0775,file_mode=0664,nofail,_netdev,x-systemd.mount-timeout=30,iocharset=utf8
Ez csak az Internet-re vonatkozik vagy erről a gépről minden átmegy a tunnelen?
A terv az lenne, hogy igazából a qbittorrent működjön ezen a gépen VPN mögött.
Ez az egyetlen szolgáltatás, ami az internet forgalmat használ.
Ennek beállítottam, hogy a "wg0" hálózati eszközt használja.Minden további dolog ami ezen a gépen fut (pl. samba) csak a helyi hálón működik.
Most például megy a Samba elérés, de akkor szerinted ez is átmegy a tunnel-en? -
"nem világos miért akarod szopatni magad a systemd-vel, gondolom az a konfig 1:1-ben betölthető a wg-quickbe"
Azért akarom "szopatni" magam, ahogy fogalmaztál, mert a wg-quick-hez felkell tennem egy wireguard-tools csomagot.
Ahhoz, hogy be tudjam importálni a konfigot és írni tudja a /etc/resolvconf-ot kell neki az openresolv csomag is.
Minek tegyem fel ezeket jó esetben egyetlen futtatáshoz, amikor annyit csinálnak most, hogy megírnak egy pár soros konfigot helyettem.
Ezért akarom magam megírni.Akkor, ha jól értem, így kéne kinézni esetemben a systemd konfignak, ha a fentebb említett szolgáltatói VPN adatokat használom?
/etc/systemd/network/99-wg0.netdev
[NetDev]
Name=wg0
Kind=wireguard
Description=WireGuard tunnel wg0
[WireGuard]
ListenPort=51871
PrivateKey = key1_blah_blah...xyz
[WireGuardPeer]
PublicKey = key2_blah_blah...xyz
AllowedIPs = 0.0.0.0/0
Endpoint = 123.456.789.1:51820
/etc/systemd/network/99-wg0.network
[Match]
Name=wg0
[Network]
Address=10.2.0.2/32
DNS = 10.2.0.1
daninet
a qemu-ovmf-x86_64 csomag verzióját nézed? Mert én úgy látom ezt dátummal és verzióval számozzák.
Tumbleweed egyébként és ha jól olvastam RPM-es disztrókat érintiInformation for package qemu-ovmf-x86_64:
Repository : openSUSE:Tumbleweed
Version : 202502-1.1
Arch : noarch
Vendor : openSUSE
Installed Size : 64.9 MiB
Installed : Yes
Status : out-of-date (version 202411-1.2 installed)
Source package : ovmf-202502-1.1.src
Upstream URL : https://github.com/tianocore/edk2
Summary : Open Virtual Machine Firmware - QEMU rom images (x86_64)
Description :
The Open Virtual Machine Firmware (OVMF) project aims to support
firmware for Virtual Machines using the edk2 code base.
This package contains UEFI rom images for exercising UEFI secure
boot in a qemu environment (x86_64) -
#36299904
Az én problémám? Honnan veszed ezt? Tedd fel és próbáld ki. Egyből tiéd (is) lesz a probléma.
Nézd, az én gépem nem kisérleti gép. Plusz nem is értek a linuxhoz mélységében. Miért az én gépe(im)en kellene megoldani a problémát?
Én azt hittem, hogy ismeritek ezt a problémát ti is és vagy azt mondjátok, hogy ezt és ezt kell csinálni, vagy azt, hogy majd a disztribúció megoldja egyszer.
Egyébként a Perplexity mi-t kérdeztem. Azzal kezdte, hogy "ismert probléma" de amit megoldásokat adott rá, egyik sem működött (vagy én csináltam rosszul). Azt hittem ti majd adtok rá jó megoldást. Tévedtem. -
vargalex
Igaz, még Windows 7-el kapcsolatban, de itt kliens oldali cache-elésről írnak.
Vasti74
Eléggé kicsi a valószínűsége... Az előző gépem (Fujitsu D738, i5 8400) évekig tökéletesen működött Mint Cinnamon-al, a 4k monitor megvétele után is, csak ott vacak a skálázás - váltottam Fedora Plasma-ra - jöttek a hibák. Pár hete megvettem ezt a Lenovo M75-öt Ryzen 5 4650G procival - pont ugyanazokat a hibákat produkálja.
vargalex
Biztos, hogy nincs semmi külső hivatkozása? Esetleg nézd meg ilyenkor böngészőben a network fület, hátha igaza van bambanonek és valamit nem tud letölteni, ami kellene ehhez a lejátszáshoz is.
Nálam Arch Linux, Wayland, Gnome, nincs probléma...Szerk.: Örülök, hogy közben megoldódott. (Nálam fenn van a
pipewire-pulse
csomag,pulseaudio
már régen nincs..) -
Vasti74
Tudom, hogy ez rajtad nem segít, de nálam a Fedora 41 Plasma is ezt csinálja (Firefox és Chrome is) , de szerencsére nem mindig. Úgy kb. 50 "beletekerésből" 1x. Már kétféle vasam volt (az i5-8400 + IGP gépet azért cseréltem Ryzen 5 4650G + IGP masinára, hátha a sokkal jobb integrált grafika elvileg jobb támogatottsággal megoldja a problémáimat, de sajnos nem...
Én már nem is keresem az okát, mert a keresgéléseim alapján ez ilyen.
Már elavult, vagy még nem kész technológiák vacak hardvertámogatással, ezt kínálja jelenleg a linux desktop, lehet választani ;-)
De sajnos még mindig ez a legjobb alternatíva (számomra) , úgyhogy egyszerűen nem rántom fel magam, amikor nem megy a videó, vagy csíkok vannak a képernyőn, vagy vastag villogó kerete van az ablakoknak, stb. (tuti nem hardveres hiba, mert a két totál különböző gépem is pontosan ugyanúgy, ugyanazokat a hülyeségeket produkálta)
A Plasma szerintem elmebeteg és alig használható alapértelmezett alkalmazásai (Mint MATE és Cinnamon után) szintén nem tudnak már felbosszantani ;-)
Pontosan, ELK, vagy hasonlo stack. Ezeket celszeruen strukturalt logot etetsz. Persze megcsinalhatod a parszolast sajat szabalyokkal, viszont ha journalbol jon, akkor a melo jo reszet mar megcsinalta helyetted a rendszer. Tehat valami miatt itt csomoan azt szeretnek, ha pl. a severity level beallitasara nekik kene megirni a regexet egyenkent minden processzre, de nem tudom, h ez miert elvezetes.
Longeye
Köszönöm! Ok, értem.
A 2 és 20 GB-okat szerverre írtam. Ott nem egy tábla csokiba kerülnek a háttértárak. Nem az otthoni rendszereimre gondoltam, hanem a munkahelyi szerverekre.
Nem kifejezetten a helytakarékosság miatt osztom fel, hanem első sorban biztonsági okokból.Ezért is kérdezek, mert a saját desktop környezetemnél nem érzem szükségességét ennek. Ez nem lesz kiakasztva publikus fix IP címmel az Internetre és főleg nem 24 órában. A szerverek egy része viszont igen.
Longeye
Köszönöm a válaszod!
Ha a /home-ot külön teszem, mennyit hagyjak a root-nak (/)?
Szerveren a /home-nak 2GB-ot szoktam max adni és ott a /srv-hez, vagy az oda felcsatolt mappákhoz rendelek sokat.
A root-nak 20GB-ot szoktam adni, de az is bőven túlzás, mert a /tmp, /var/tmp, /var/log, /var/spool, var/cache is mennek külön partíciókra és így még a harmada sem szokott elfogyni.
Nem tudom, hogy mire kell figyelni desktop környezetben.2017, az nem semmi! Én kb. azóta kezdtem el Linux szervereket üzemeltetni.
Ahol az egyik pont tízszer gyorsabb és tud párhuzamosan olvasni a másikkal ellentétben
Nem tudom, mire gondolsz, ami 10x gyorsabb, de még mindig azt mondom, hogy hardverkörnyezet és SSD tipus függő. Egy HMB-s Samsung 980 sok szempontból jobb a PCIe 4.0-nál, de egy belépő NVMe 3.0-nál még a Samsung PM883, de akár a kistesója, a 860 EVO is hamarabb másol egy adott méretű fájlt sustainedben a DRAM cache miatt... ezért nincs értelme így konkrétumok nélkül hasonlítgatni. Nem véletlen, hogy a Milyen SSD-t vegyek topikban az alapkérdés, hogy milyen a hardverkörnyezet. Szóval ez nem ilyen egyszerű téma, hogy leírjuk, valami 10x gyorsabb a másiknál.
De legyen nektek igazatok, én inkább maradnék e témában az SSD szaktopikjaiban. (amúgy sincs semmi dolgom a Haladó topikban)
láthatóan és érezhetően gyorsabban indul az OS és bármely program
Igen kevesen érzékelik ezt így, de hardverösszetevőktől is függ nyilván. Jó a marketing, nyilván sokan veszik értelmetlenül emiatt a PCIe 4.0 SSD-ket is. Mindegy, egy átlag gépnél vakteszten tuti nem venni észre, hogy Sata2 vagy Sata3 csatolón fut a rendszer. Most hagyjuk a régi desktopomat, ami Sata2 volt, de az alaplap miatt csak Sata1-ben látta az Intel 520-at, az access time miatt így is gyors volt HDD csere után. Meg persze azt megint elfelejtük, hogy milyen Sata SSD-t hasonlítunk milyen NVMe-hez. Jó példa erre a Samsung 980, ami PCIe 3.0, de minden review alapján gyorsabb, mint a belépő szintű NVMe 4.0 SSD-k.
SSD szaktopikban sok éve egerészek és ott is sokan meglepődnek a szakik véleményén, hogy nincs igazán érezhető különbség. Vagyis van, egy game betöltése egyiknél 59 sec, másiknál 56 sec(számtalan YT video van erről). De ez NVMe Sata3 különbség, nem Sata3 Sata2 különbség.
No de mindegy, megesszük, amit a markecingűek főztek nekünk!
Jelenlegi desktopomon a 860 EVO 1TB ugyanolyan pörgős, mint a 980 1TB.
(egyébként elég értelmetlen SSD-t SSD-vel összevetni anélkül, hogy a pontos tipust nem adjuk meg)
Lenry
a neten kutakodva találtam egy memwatch nevű programot, ami ezt mondta:
ő szerinte az X-ből folyik a RAM, úgyhogy próbaképp leállítottam a grafikus alrendszert (itthonról úgyis csak az SSH-t látom a gépből
). persze az elfolyt memória már nem szabadult fel, így most le is tiltottam azt, majd restart.
újraindulás után 1.68GB a foglalt RAM, holnap ránézek mi a helyzet. -
Lacc
Igen KDE-t is ahogy fentebb írtam, de az még rosszabb, a fájl és könyvtárak drag and drop feature nem igazán működik nekem Dolphinban. (Bár van egy youtube videó, jó látni nem csak én szenvedek vele), másik problémám, hogy a scaling nem mindig működik minden applikációnál, jó lenne egy 125% vagy 150%, mert akkor jobban lehetne ujjal vezérelni tablet móddal.
Többiről nem igazán írták hogy jó lenne, talán az Elementary OS 7.1 kaphatna esélyt (nem tudom mi a DE neve, valami Pantheon)
Elméletben a Gnome a legjobb, ahogy olvasom, de kinek működik, kinek nem, van egy-két jó gnome extension de sajnos nem mindegyik extension kompatibilis az újabb Gnome verziókkal.
bpx
Részemről 0. lépés ilyenkor egy /proc/meminfo
A top meg egyéb eszközök sem a PageTables-t, sem a HugePages_* részeket nem mutatják, ezek a területek nem tartoznak processhez. De ezek DB szerver hostokon tudnak jelentős mennyiségű memóriát foglalni (előbbi) vagy vannak általában konfigurálva (utóbbi, az előbbi pazarlásának enyhítésére), esetleg VM-eknek, lehet nálad nem ez lesz.Vagy tmpfs foglaltság, esetleg ipcs kimenet, szintén nem tartoznak processzhez mert ugye shared memory, de ezek a "share 10" miatt itt valószínűleg nem játszanak.
Vagy ha ez egy VM, és ilyen csodák be vannak kapcsolva, mint a VMware Memory Balloon vagy Hyper-V Dynamic Memory, az is megjelenhet így.
sonar
Réges rég nekem az smem segített a valós foglalást kideríteni, nem tudom, hogy manapság mi a helyzet, de talán segít. [link]
Másik meg, hogy eddig is ilyen volt csak nem tünt fel?
Amíg nem swappel addig szerintem nem kell parázni.
Elinditanék egy két alkalmazást, hogy lássam mi a helyzet.
Illetve ha magas a swappiness érték akkorlehet, hogy sokmindent tart a memóriában. (db servereknél ez előny is szokott lenni) -
bambano
első körben firmware-t frissítenék a mikrotiken, második körben megnézném az sfp+ hőmérsékletét másolás közben.
ha rezen kötötted össze, akkor vagy át kellene szokni üvegre, esetleg dac-ra, vagy legalább nem egymás melletti portokba dugni az sfp-t, vagy megnézni, hogy v1 vagy v2 az sfp+ rezed.az tény, hogy ettől a közvetlen kapcsolatos másolásnak nem kellene megdöglenie... esetleg megnézném azt is, hogy gigára lassítva is megdöglend-e.
a crs az switch. cloud router switch.
szerk: a linuxokkal azt lehet kezdeni, hogy nagyobbra veszed az interfészen a queue-t, a kernelben a tcp méreteket (küldés, fogadás buffer) és lecserélheted a tcp ütemezőt is. a google féle ütemező jobb, mint a default linux.
Köszi!
Havonta automatikusan - na itt ezzel lesz gond, ugyanis nem megy 0-24 a NAS
Ez ugye a NAS-om, és általában off van.
De gondolom scrub futtatható cron-ból is, azaz ilyesmit olvastam.
Az a bajom, hogy 5 SATA-s a lap, tehát nem tudom, bele tudok-e dobálni még egy 500-as winyót; akkor lehetne Raid-Z2, vagy mezei RAID6 is.
Még annak utánanézek, hogy mennyire macera pl. kicserélni alatta a diszketet, meg méretezni. (Alapvetően 250GB-os winyókkal kezdte ez a tömb, és 2x lett alatta mind cserélve.)Illetve; sebességben milyen a viszonya ennek egy mezei md RAID5-höz?
growler
Elotte a forras eszkozt at kell meretezni (Live rendszer -> GParted
-> Resize/Remove opciojaval - hogy kisebb legyen mint a celeszkoz)
Ezutan, pl. a "Rescuezilla"-val (Clonezilla GUI) folytatni. [link]
Vagy a hasonlo "Foxclone"-al.
Vagy vegsosoron, a GParted Copy, Paste opcioival.
(Elore letrehozott szamu/meretu/ fajlrendszeru particiokra - igy
lehetoseg van pl. nagyobb meretu / particio letrehozasara is.
A rendszerbetoltot meg chroot-al a boot, esp jelolesu
"/boot/efi "particiora.) -
bambano
értem, de azt se írtad le, hogy fixen akarod, véglegesen, vagy most van valami, és ahhoz kell.
buguntuban például a network managerben manualra állítod a kártyát, oszt jónapot.
debianban is, vagy a /etc/network/interfaces-ben beállítod manualra. szóval kaptál még teret a kérdés pontosítására
- Update 10.10. - Bomba árak 2025-ben is! Üzleti - Consumer laptopok DELL FUJITSU HP LENOVO
- Fotó állvány eladó
- HIBÁTLAN iPhone 15 Pro Max 256GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3493, 93% Akkumulátor
- Macbook Pro 2019 // i9 // 32GB / 2TB // Számla+Garancia //
- Apple iPhone 13 Mini / 128GB / Gyárifüggetlen / 12Hó Garancia / 84% akku
