- ASUS ROG Ally
- Megjöttek a be quiet! Pure Loop 3 sorozatú kompakt AIO-i
- RAM topik
- Notebook hibák
SwissAirplan
CPT.Pirk #61477 üzenetére
Ezt dobta arra a kettőre:
quattro@quattro-HP-TC ~ $ inxi -Gxxx
Graphics: Card: VIA VX900 Graphics [Chrome9 HD]
bus-ID: 00:01.0 chip-ID: 1106:7122
Display Server: X.Org 1.18.3 drivers: fbdev (unloaded: vesa)
Resolution: 640x480@73.00hz
GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.8, 128 bits)
GLX Version: 3.0 Mesa 11.2.0 Direct Rendering: Yes
quattro@quattro-HP-TC ~ $ inxi -Fxxx
System: Host: quattro-HP-TC Kernel: 4.4.0-21-generic i686 (32 bit gcc: 5.3.1)
Desktop: Cinnamon 3.0.6 (Gtk 3.18.9-1ubuntu3) dm: mdm
Distro: Linux Mint 18 Sarah
Machine: System: Hewlett-Packard product: HP t5570 Thin Client
Mobo: Hewlett-Packard model: 158Ch
Bios: American Megatrends v: 786R9 v1.03 date: 11/29/2010
Chassis: type: 3
CPU: Single core VIA Nano U3500 (-UP-) cache: 1024 KB
flags: (lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 1995 speed/min/max: 1000/800/1000 MHz
Audio: Card-1 VIA Device 9170
driver: snd_hda_intel bus-ID: 00:01.1 chip-ID: 1106:9170
Card-2 VIA VT8237A/VT8251 HDA Controller
driver: snd_hda_intel bus-ID: 00:14.0 chip-ID: 1106:3288
Sound: Advanced Linux Sound Architecture v: k4.4.0-21-generic
Network: Card: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
driver: tg3 v: 3.137 bus-ID: 05:00.0 chip-ID: 14e4:1692
IF: enp5s0 state: up speed: 1000 Mbps duplex: full
mac: 64:31:50:f3:35:ad
Drives: HDD Total Size: 250.1GB (2.5% used)
ID-1: /dev/sda model: Samsung_SSD_840 size: 250.1GB serial: S1DBNSBD905665H
Partition: ID-1: / size: 229G used: 5.0G (3%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 0.94GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
RAID: System: supported: N/A
No RAID devices: /proc/mdstat, md_mod kernel module present
Unused Devices: none
Sensors: System Temperatures: cpu: 51.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 159 Uptime: 3 min Memory: 365.6/872.0MB
Init: systemd v: 229 runlevel: 5 default: 2 Gcc sys: 5.3.1
Client: Shell (bash 4.3.421 running in gnome-terminal-) inxi: 2.2.35
quattro@quattro-HP-TC ~ $ -
CPT.Pirk #61410 üzenetére
Régi hát, szerintem az egész wiki haladóknak ér valamit. Én elvagyok a Debiannal, de első disztrónak kicsit hard, ha valami nem működik.
modeset-tel még én sem bírkóztam, de kernel paraméterekkel már kellett bíbelódnöm, ha egyszer már csinálta valaki, nem nagy valami. Legfeljebb akkor, ha fogalmam sincs, melyik paraméteren kéne változtani: például
processor.nocst=
Frawly
CPT.Pirk #61396 üzenetére
Tőle szeretném olvasni az okot. A Wiki-t érvnek nem tudom elfogadni, az Archnak és a Gentoo-nak is nagyon baró Wikije van, meg lehetne oldani azok alatt is, kezdőnek mégsem javaslom azokat sem. Vagy nincs valami jó Wikijük, de a LFS-szel és a Slackware-rel is, és azokat sem javasolnám neki. Ugyanakkor a distrowatch top10-e rogyásig van felhasználóbarát disztrókkal, ha valakinek nem tetszik az Ubuntu/Mint, még mindig tud sok másból választani, és azok teljesen felhasználóbarátak, nem kell hozzájuk külső tárolózni, meg nonfree vergődést levágni, hanem rendesen hivatalos tárolóból egy gombnyomásra cserélhető a GPU driver. De vannak speciális Kodi-disztrók is, amelyeken könnyű GPU drivert váltani.
Mondom, nem akarok konkrét disztrót reklámozni, csak a mögöttes motiváció érdekel, ami a Debiant kizárólagossá teheti. Valahogy sok emberben az él máig, hogy a Debian „A” Disztró, „A” Szent, kultikusan tisztelik, szerintük a többi disztró amatőr és instabil. Közben meg rohadtul nem, nagyon sok disztró, disztrócsalád kinőtte magát mára elég stabilra, felhasználóbarátra, jól támogatottra.
jackal79
CPT.Pirk #61288 üzenetére
Sikerült! Köszi!
Még egy dolog lenne, régebben már sikerült megoldást találnom rá, de most egyszerűen nem jut eszembe semmi.
Van az SSD-n egy 1 gb-os titkosított (Veracrypt) lemezterület és ezt szeretném parancsikonként az asztalra helyezni.
Linux Mint 18.3-at használok.
Köszi! -
Flowtation
CPT.Pirk #61073 üzenetére
Ezt nem tudom megmondani, mert a grub után már fekete a képernyő. Régebben volt ilyen problémám, hogy kiterjesztett képernyőnek érzékelte a dsub-ot, de itt most ez sincs. E mellett pedig az advanced optionsban sincs semmi más lehetőségem, mármint másik kernel vagy ilyesmi.
cigam
CPT.Pirk #61012 üzenetére
Fura módon nálam tényleg az ablakkezelőtől függ hogy mennyire dadog a videó lejátszás. Gnome alatt folyamatosan akad, ami azért fura, mert látszólag még lehetne terhelni a procit(látszólag van még 10-20% tartalék), vagyis nem a CPU korlátozza. De akkor mi? A rengeteg háttérben elinduló vicik vacak(pl. evolution)? XFCE, LXQT alatt szinte akadásmentes, folyamatos a videó (W8 alatt sem jobb).
Ami angol bill. kiosztásban a SHIFT+6 (kalap?) azt hol érem el a magyar kiosztásban?
Linux alatt hogyan tudok a "scan" kóddal beírni 1-1 karaktert (Windows-ról rémlik, hogy alt+ numerikus kóddal lehetett begépelni) -
-Ben-
Chakrával se ment ennél jobban. Igazából itt a KDE a kulcs. KDE és Xfce rendben van, a böngészés meg mindenhogyan sz@r, ezt már elfogadtam.
Szerk.: a másik probléma, hogy tesztelnék 1-2 dolgot, de az OpenArena nem hajlandó elindulni. Konzolból indítva ezzel ér véget a folyamat:
/usr/lib/openarena/baseoa
/usr/lib/openarena/baseoa/z_oacmp-volume1-v3.pk3 (370 files)
/usr/lib/openarena/baseoa/pak6-patch088.pk3 (711 files)
/usr/lib/openarena/baseoa/pak6-patch085.pk3 (559 files)
/usr/lib/openarena/baseoa/pak6-misc.pk3 (229 files)
/usr/lib/openarena/baseoa/pak5-TA.pk3 (139 files)
/usr/lib/openarena/baseoa/pak4-textures.pk3 (1753 files)
/usr/lib/openarena/baseoa/pak2-players.pk3 (669 files)
/usr/lib/openarena/baseoa/pak2-players-mature.pk3 (231 files)
/usr/lib/openarena/baseoa/pak1-maps.pk3 (100 files)
/usr/lib/openarena/baseoa/pak0.pk3 (1042 files)
5803 files in pk3 files
Wrote challenges.cfg
RE_Shutdown( 1 )
------- FBO_Shutdown -------
------- R_ShutdownVaos -------
------- GLSL_ShutdownGPUShaders -------
tty]Szegmentálási hiba (core készült) -
cigam
CPT.Pirk #60999 üzenetére
vainfo
libva info: VA-API version 1.1.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib64/dri/i965_drv_video.so
libva info: va_openDriver() returns -1
vaInitialize failed with error code -1 (unknown libva error),exitvdpauinfo
display: :0 screen: 0
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
Error creating VDPAU device: 1Nem is értem milyen nvidia.so-t keres
ALFA
CPT.Pirk #60949 üzenetére
Biztosan nem, az elso oldalon az osszes pipa ki volt szedve.
Ahogy anno irtam, egy jo honapig nem hasznaltam a gepet, amikor elovettem, akkor egy teljes napig frissitette magat, es ketszer volt hiba miatti rendszerujrainditas is, vagy otszor kuldott hibauzenetet, hogy a fejlesztok javitsanak valami hibat, es azota bolond a bongeszo es azota nem tudom hasznalni az ubuntu centre-t se.Mindegy, par het mulva lesz egy tartalek hdd, akkor majd csinalok egy teljes ujratelepitest, mert egy ideig a 14-re kell visszallnom, talan utana megoldodik a gond.
Privatban majd ird meg, merrefele vagy, hogy nehogy elhibazzalak par honap mulva, amikor lesz egy kis nyugi.
Mar csak azt nem ertem, hogy miert irta allandoan, hogy a sw teljesen uptodate, amikor alapdolgok hianyoztak?
ALFA
CPT.Pirk #60940 üzenetére
Igen, update volt, mindenre azt mondja, hogy napra kesz, nincs se torott csomag, se egyeb gond.
Lekertem a vlc fuggosegeit, ezeket irta:
Itt a lekerdezesed eredmenye az smplayer valasszal egyutt: (csupa kisbetuvel irva ugyan ezt irja, ha apt-get install -t irok, akkor eloszor kiirja, hogy dependency tree-t epit, majd utana kozli, hogy nem talal ilyet.)
ALFA
CPT.Pirk #60936 üzenetére
Eddig se kellett, mindig ki volt kapcsolva.
Nem ertem, minek akarja egyaltalan hasznalni, amikor nincs hardveres gyorsitas.
Smplayer ubuntuban nincs benne, az ubuntu sw centre pedig nem mukodik, ahogy par hete irtam.
Kellene a csomag pontos neve, hatha terminalbol meg tudom talalni.Illetve webes keresessel azt talaltam, hogy valami PPA-t kell telepiteni eloszor, csak utana mukodik a smplayer.
-Ben-
CPT.Pirk #60905 üzenetére
OpenGL bekapcsolása után sokkalta jobban szaggat/lassul, a processzort is jobban tekeri, mint előtte. Ez is érdekes.... Szerintem ebben nemigen lesz megoldás. Talán még az is lehet, hogy hardveres a probléma, talán táp vagy alaplap, de inkább az OpenGL -el lehet összefüggésben.
-Ben-
CPT.Pirk #60896 üzenetére
Kubuntut is próbáltam, de az nem sokkal volt jobb, mint a gnome -os uborka.
Persze azért jobb volt, de amiben igazán rossz, abban nem. Sajnos a weblapokon a görgetés nagyon silány, főleg ha youtube -ról van szó. Lehet, hogy beszerzek egy Radeont (bár nem sok „kedvem” van hozzá, mivel 1 hete vettem a GT 710-et...)
Kérdés, hogy egy olcsóbb Radeonnal is sima lenne -e, mint a palacsinta....? Mert, ha ugyanezt kapnám, akkor nyilván nincs sok értelme. -
Frawly
CPT.Pirk #60876 üzenetére
Igazad van, eddig nálam is Basic volt, most, hogy ránéztem. De nem értem, mert mégis van hardveres gyorsítás, nem akadnak a videók, normális a görgetés, nem laggol, nem szaggat, nem magas a prociterhelés. Most bekapcsoltam az about:configban a layers.acceleration.force-enabled értékét true-ra, így már Basic helyett OpenGL-t ír, de érdemben nem volt változás, semmi nem lett se gyorsabb, se gördülékenyebb, se a prociterhelés nem csökkent, ugyanolyan jól működik az egész, ahogy előtte.
Szerintem ennek az a magyarázata, hogy bár a FF nem használt hardveres gyorsítást, de a grafikus felület és/vagy a kompozitor viszont igen, így továbbra is hardveresen gyorsítva mentek a dolgok.
Ha nem ment volna, azt azonnal észreveszem, érzékeny vagyok arra a szaggatásra, lagolásra, amit a hardveres gyorsítás hiánya okoz. Ami előfordul, de akkor nincs fent a megfelelő GPU driver, és a FF is Basic helyett valami 0-át ír az about:support lapon. Akkor érezni is, hogy szaggat.
Frawly
CPT.Pirk #60874 üzenetére
4 éve használtam Mintet utoljára, akkor ott alapból ment. Aztán Kubuntun is ment alapból. Aztán Arch-on is ment, és megy a mai napig minden újratelepítés után. Csak akkor tiltódik le, ha nincs fent a megfelelő DRI-képes driver, így nem tud a FF gyorsítást használni. Szerintem Chackrán is kéne menjen alapból.
Frawly
CPT.Pirk #60865 üzenetére
Igen, az is lehet, hogy nincs fent neki az adott csomag. Azért kértem inxi kimenetet, mert azon látni fogjuk milyen disztró, hányas kernel, milyen GPU, milyen GPU driver, hányos Xorg és Mesa. Azért nem inxi -Gxxx kimenetet kértem, mert az -Fxxx teljes reportot csinál, CPU, memória, minden hóbelebanc, ami fontos lehet szaggatás szempontjából.
FF-ban lehet ellenőrizni még, hogy az about:support oldalon mit ír a GPU gyorsításra.
Pirostank
CPT.Pirk #60795 üzenetére
Szia,
sajna nincs valtozas,
terminalban ezt irja:
[00007fc5b40009c8] vdpau_avcodec generic error: decoder profile not supported: 7
libva info: VA-API version 0.39.0
libva info: va_getDriverName() returns -1
libva error: va_getDriverName() failed with unknown libva error,driver_name=(null)
[00007fc5b539a398] vdpau_avcodec generic error: decoder profile not supported: 7Köszönöm,
-Ben-
CPT.Pirk #60855 üzenetére
Kipróbáltam a kubuntut és a mint cinnamon verziót. Egyik se olyan botrányosan lassú, mint a gnome 3, de sajnos nem tökéletesek. Kubuntu 18.04 alatt már a KDE se olyan fürge. Nem rossz, de a gépelés pl. nagyon lassú, a prohardver oldala chromiumról szinte lefagy, annyira lassú......
Eközben rákérdeztem ismerősnél, hogy mi a helyzet nála... Állítólag minden vaj simán, gördülékenyen működik. Igaz, neki egy GT 1050 -je van..... Azért általános használatra nehogy már kevés legyen egy GT 710 ...
-Ben-
CPT.Pirk #60845 üzenetére
Igazából, most hogy nézegettem a KDE-t, sokkal szimpatikusabb - és szebb -, mint a gnome 3. Bár a solus féle gnome 3 azért szebb, mint az Ubuntué. Esetleg, szerinted van értelme kipróbálni az ubuntut KDE-vel? Hátha nem lassul... Mert, ha ez így marad, akkor sajnos kukázom az ubuntut..
Terminálból tudom úgy telepíteni, hogy minden szükséges csomagot feltegyen hozzá? Egyszer próbálkoztam másfajta kezelőfelülettel, be is borult egy kicsit......
-Ben-
CPT.Pirk #60825 üzenetére
Maga a chakra nemigazán jön be sajnos..
Nem érzem túlságosan felhasználóbarátnak, legalábbis Ubuntu után. Úgyhogy remélem lesz megoldás erre a problémára, de egyre inkább úgy tűnik, hogy nem lesz. Zárt 390-es szoftverrel se jó. Szinte ugyanolyan darabos, lassú.... Valamivel azért jobbnak érzem, de elenyésző a különbség.
-Ben-
CPT.Pirk #60815 üzenetére
A lev285 által említett „etcher” nagyon jó..
Sikerült telepítenem pendriveról a 18.04 -et (és még gyorsabb is volt, mint dvd -ről). Úgy döntöttem, hogy inkább újat telepítek, mert sok idő menne el ezzel a vacakolással.
Hogyan telepítsem a 390-es szoftvert konzolból, hogy maradéktalanul feltegyen minden szükséges csomagot? -
-Ben-
CPT.Pirk #60809 üzenetére
„sudo apt-get purge nvidia-opencl-icd-340” >>
Csomaglisták olvasása... Kész
Függőségi fa építése
Állapotinformációk olvasása... Kész
Próbálja futtatni az „apt --fix-broken install” parancsot ezek javításához.
Az alábbi csomagoknak teljesítetlen függőségei vannak:
libglx0:i386 : Függ ettől: libglx-mesa0:i386 de az nincs telepítésre megjelölve vagy
libglx-vendor:i386
libnvidia-ifr1-390 : Függ ettől: libnvidia-gl-390 de az nincs telepítésre megjelölve
libnvidia-ifr1-390:i386 : Függ ettől: libnvidia-gl-390:i386 de az nincs telepítésre megjelölve
nvidia-driver-390 : Függ ettől: libnvidia-gl-390 (= 390.48-0ubuntu3) de az nincs telepítésre megjelölve
Ajánlja: libnvidia-gl-390:i386 (= 390.48-0ubuntu3)
E: Teljesítetlen függőségek. Próbálja kiadni az „apt --fix-broken install” parancsot csomagok nélkül (vagy telepítse a függőségeket is!). <<Az apt --fix-broken installt próbáltam már, illetve a komplett nvidia állományt eltávolítani....
Pendrive téma: legközelebb megnézem, hogy milyen hibával áll le a telepítés.
lev258
lev258
CPT.Pirk #60803 üzenetére
A Catalyst már megszűnt, a nyílt drivert pedig az AMD rakta rendbe. A 3D teljesítményére ma már nem lehet panasz és még mindig ki tudnak sajtolni belőle egy kis javulást.
7etape: Nézd meg, melyik Nvidia driver támogatja a kártyád. Nem mindegyik változat (branch) jó bármely kártyához. Azért javasoltam már az elején másik grafikus felületet, mert abból kiderülne, hogy adott Ubuntuval van gondod vagy Nvidia driverrel. Nem hiszem, hogy nálad ilyenről lenne szó, de volt már példa olyanra is, hogy valaki kínlódott a videókártyával meg a driverekkel, aztán kiderült, hogy a kártya-alaplap haldoklott, nem kapta meg a feszültséget rendesen. -
-Ben-
CPT.Pirk #60801 üzenetére
Igen, pont ezért „erőltetem” a mai napig az nVidiát, de úgy tűnik már erre se lehet alapozni.
Sajnos nem oldotta meg. Nem engedi telepíteni a legfrissebb NV szoftvert synapticból.
„E: /tmp/apt-dpkg-install-KUB8HS/09-libnvidia-gl-390_390.48-0ubuntu3_i386.deb: new libnvidia-gl-390:i386 package pre-installation script subprocess returned error exit status 2
E: /tmp/apt-dpkg-install-KUB8HS/13-libnvidia-gl-390_390.48-0ubuntu3_amd64.deb: new libnvidia-gl-390:amd64 package pre-installation script subprocess returned error exit status 2”Próbálgatnám én, de nincs cd/dvd olvasóm, pendrive -ról meg az Istenért se akar bootolni egyik se..
-Ben-
CPT.Pirk #60799 üzenetére
Az az érdekes, hogy már 16.04 alatt se volt minden rendben. Akkor is darabos volt, pl. görgetéskor, több videó egyidejű megnyitásakor. Iszonyatosan lassult, de a 18.04 még sokkal rosszabb. Eddig egy 9400 GT -t használtam, most próbálgatom a 710 -zel, de egyikkel se akar normálisan működni....
-Ben-
CPT.Pirk #60797 üzenetére
Megpróbáltam leszedni minden drivert, nagyjából sikerült is. Visszatenni egy újat, na az már nem sikerült a törött csomagok miatt. Próbáltam „javítani” a törött csomagokat, de hiába....
A nyílt driverrel se jó, pont emiatt kezdtem el az nV driverekkel babrálni....
Miért lenne jobb döntés egy "Mint" jelen pillanatban?Egyébként egy „GT 710” kártya dolgozik a gépben.
csurgoi
CPT.Pirk #60761 üzenetére
Bocsánat a duplázásért, de nagyon be voltam vagyok szarva az adatvesztés miatt.
Az általad javasoltakat megprobáltam a superblockra ezt a választ kaptam:
A grarted meg egy 8 kb-os particiót dobott fel a meglévő s mellé(927Db meg a swap4 gb) egy nagy kérdőjellel.
Most probálom az Easeust remélem azzal sikerül valamit visszanyerni. -
ALFA
CPT.Pirk #60766 üzenetére
Kiprobaltam, de nincs semmi lehetoseg, csak vagy belepek, vagy guest-kent "demo" modban hasznalhatom a gepet. Kiprobaltam, ekkor a xorg nem indul el a htop szerint.
A bejelentkezesi kepernyonel a jobb felso sarokban egy kek korben levo feher emberke ikon jelenik meg, kepernyo betumeretet es kontrasztot lehet allitani, mas lehetoseg nincs.
ALFA
CPT.Pirk #60755 üzenetére
Most ismet van egy kis idom, a kovetkezo a helyzet.
Amikor gond volt, akkor cpu teljes terhelessel ment, kiderult, valami xorg okozta.
A kernelben sikerult visszallni egy elozo verziora, de ott csak kis valtozas volt (talan 043 volt es most 037, vagy hasonlo.) es most a ff-t is visszaallitottam 45.02-re, nana, hogy ezuttal torolte az osszes konyvjelzot, mig frisiteseknel nem bantotta oket.:-(Az indulo programok mindegyike be volt pipalva, azok nagy reszet kivettem, most probalgatom, hogy mire van szukseg a gep indulasakor, eleg keves info van, igy csak talalgatok. Az udvozlesre nincs, abban biztos vagyok, a tobbi tucatnyinal most jatszogatok.
Most xorg tartosan 15-20%-on van, a ff 15-rol indul, es egyebekkel egyutt cpu terheles 50% kornyeken van, idonkent hullamosan ff felugrik 75%-ra, majd visszaesik, tehat ff fogja a cpu-t.
A letoltesek hektikusak, ures weboldalnal is csinalja idonkent, alig par weboldalt nezegetek, egyszerre csak egyet, tehat nem a weboldalak tartalmat tolti le elore. ahogy a korabbi kepen lathato, mindig hirtelen, tuskeszeruen van valami letoltes, mig a cpu terheles lassabban ingadozik.
Az ubuntu sw centre-t elinditva cpu terheles azonal es tartosan 100%-ra szogezodik, ff nem fut olyankor, tehat a xorg es egyebek feletti reszt mind elhasznalja az a progi, gyakran 68%-ot is fog a cpu-bol, gondolom, az a szabad maximum.
ALFA
CPT.Pirk #60753 üzenetére
Ez a gondom, ff tartosan 50-90% cpu terhelest okoz es idonkent hirtelen letolt valamiket, amik osszessegeben napi 100 MB-osak es nem tudom, hova mennek, mert nincs nyoma:
ubuntu sw centre-t megnyitva tovabbra is tartos 100% cpu terheles van.
Valami nagyon nem jo itt es most nem tudok ujratelepiteni, mert hataridos munkam van es nincs semmi tartalekom, amire akarcsak atmeneti mentest tudnek vegezni.
#68216320
CPT.Pirk #60747 üzenetére
Cirka 2-3 év után kiderült, hogy miért nem tudok egymásra nyitott ablakokban kattintani semelyik gépemen, egyik distro-val sem.
Tessék kapaszkodni: a Logitech M705 egerem miatt.
Ma reggel mikor kiderült, azt hittem lefordulok a székről
Ezt az egeret használom évek óta. ha egyik gépről megyek át a másikra, akkor viszem magammal. Ugyebár az os ezt usb egérnek és billentyűzetnek ismeri fel, mert a külön gombjai valami billentyűzet kombinációkat jelentenek. Namost ha be van dugva a vevője az usb-be és az egér be van kapcsolva, akkor bármi mást is használok (touchpad, második egér) akkor sem lesz jó. Olyan érzésem van, mintha a fókusz valahogy a megnyitott ablak alatti területre kerülne. Ha kattintok a felső ablakban valamire és az alsó ablakban ugyanott van valami gomb, akkor az alsó ablakban történik a klikk esemény.Kezdett lemerülni az elem, ezért kikapcsoltam az egeret és touchpad-al próbálkoztam és láss csodát, hirtelen minden működött
#68216320
CPT.Pirk #60738 üzenetére
A helyzet az, hogy más gépeken is Ubuntu van, nem szeretnék több féle OS-el dolgozni.
Majd valamikor nekifutok újra, most megint kifeküdt a gép, éppen a fájlrendszer lett oda egy fagyás/power off miatt.
Nincs Bp-en valahol valami Linux-os klub, ahol házi feladatnak feladhatnám ezt? -
#68216320
CPT.Pirk #60731 üzenetére
A probléma túlmutat ezen a gépen. Jó ideje (>1éve) képtelen vagyok a vga driverekkel megbírkózni.
Eddig két laptopom volt, amire nem tudtam Ubuntut tenni és használni, mert egyszerűen nem érzékeli a kattintásokat. Mintha nem a képernyőn megjelenő elemre kattintanék. Néha működik a kattintás ablakon belül (pl:settings), de ha ilyenkor megnyit egy újabb ablakot (pl: settings/language) akkor abban már biztosan nem működik. Próbáltam Ubuntu 16.04, 18.06, Lubuntu, Kubuntu, stb verziókat.
Mindkét laptop igp+nvidia párossal van.
HD3000+540M és HD Graphics 530+960M párosítás. Nem tudok másra gondolni, mint valami vga driver gondra. Természetesen 1000 megoldást próbáltam már végig, rendszerint előbb-utóbb odáig jutva, hogy már be sem bootol csal low graphics mode ablakot látok a képernyőn vagy még azt sem. Aztán kezdem az egész installt elölről.De most ugyanez a jelenség van az öreg 945GM esetében is. Lubuntu-val is próbáltam ezen az öreg vason, az sem lett jobb. Tök lényegtelen, hogy lassú-e vagy nem, nem működik jól.
Asztali gépen viszont tökéletesen működnek.
Egyszerűen az őrületbe kerget már, hogy ennyire vacak az egész. Az utolsó a 14.04 volt, amit tudtam használni a HD3000+540M párossal, akkor bumblebee is ment még rá. -
Slownz
CPT.Pirk #60717 üzenetére
Persze:
Disk /dev/sda: 111,8 GiB, 120034123776 bytes, 234441648 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x7843e261Device Boot Start End Sectors Size Id Type
/dev/sda1 2049 215981605 215979557 103G 83 Linux
/dev/sda2 215981606 234436544 18454939 8,8G 82 Linux swap / SolarisDisk /dev/sdb: 465,8 GiB, 500107862016 bytes, 976773168 sectors
Disklabel type: dos
Disk identifier: 0xdb0ddb0dDevice Boot Start End Sectors Size Id Type
/dev/sdb1 2048 976773119 976771072 465,8G 83 LinuxDisk /dev/sdc: 931,5 GiB, 1000204886016 bytes, 1953525168 sectors
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0xb36cefe4Device Boot Start End Sectors Size Id Type
/dev/sdc1 2048 1953523711 1953521664 931,5G 83 LinuxDisk /dev/sdd: 28,7 GiB, 30752000000 bytes, 60062500 sectors
Disklabel type: dos
Disk identifier: 0x00000000Device Boot Start End Sectors Size Id Type
/dev/sdd1 32 60062499 60062468 28,7G c W95 FAT32 (LBA)---------------------------------------------------------------------------------------------------------------
# /etc/fstab: static file system information.
# Use 'blkid' to print the universally unique identifier for a device; this may
# be used with UUID= as a more robust way to name devices that works even if
# disks are added and removed. See fstab(5).
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=82f34ceb-8aa2-42f6-94ba-ae20ae9441b7 / ext4 defaults,noatime,discard 0 1
UUID=62554d73-b6c7-40b7-acf2-319a31bee463 swap swap defaults,noatime,discard 0 2
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=af5757a3-7657-4a36-9212-9c102f8f5e3d /media/tarkomatas/af5757a3-7657-4a36-9212-9c102f8f5e3d ext4 defaults,noatime 0 0
UUID=93b1fe90-bb8c-44ad-99b0-8685dc4fc9bb /media/tarkomatas/93b1fe90-bb8c-44ad-99b0-8685dc4fc9bb ext4 defaults,noatime 0 0---------------------------------------------------------------------------------------------------------------
Ha már bemásoltam, lenne még egy kérdésem. A mostani beállítás szerint bár működik frankón az összes HDD, ami benne van és el is érem őket, de macarás, hogy a legtöbb program, amiben meg akarok nyitni egy fájlt a HDD-ről nem rakja ki nekem a bal oldalra, a root mellé, hanem mindig ki kell tallóznom a path-ot, ami elég macerás. Van erre megoldás? Ugyanezt szeretném megoldani akkor is, ha pendrive-ról szeretném fájlokat betallózni.
CPT.Pirk #60661 üzenetére
Kössz!
Ezt dobta:
# cpupower frequency-info
analyzing CPU 0:
driver: acpi-cpufreq
CPUs which run at the same hardware frequency: 0
CPUs which need to have their frequency coordinated by software: 0
maximum transition latency: 4.0 us
hardware limits: 1.10 GHz - 1.70 GHz
available frequency steps: 1.70 GHz, 1.50 GHz, 1.30 GHz, 1.10 GHz
available cpufreq governors: conservative userspace powersave ondemand performance schedutil
current policy: frequency should be within 1.10 GHz and 1.70 GHz.
The governor "ondemand" may decide which speed to use
within this range.
current CPU frequency: 1.10 GHz (asserted by call to hardware)
boost state support:
Supported: yes
Active: no
Boost States: 3
Total States: 8
Pstate-Pb0: 2700MHz (boost state)
Pstate-Pb1: 2400MHz (boost state)
Pstate-Pb2: 2000MHz (boost state)
Pstate-P0: 1700MHz
Pstate-P1: 1500MHz
Pstate-P2: 1300MHz
Pstate-P3: 1100MHz
Pstate-P4: 900MHzTehát van, de nem aktív.
0xmilan
CPT.Pirk #60404 üzenetére
Koszi a cikket, btw! Valamiert en is azt hittem, hogy az OpenGL a default. Bekapcsoltam es kb. felere ugrott a CPU kihasznaltsag.
(a cimben van egy typo: kompozitálás)@Frawly Par hete (honapja?) beszeltunk az xfce kompozitorjabol adodo tearing hibakrol. Ugy nez ki, hogy ez most azon is segitett. A borderlands-es videon akkor se lattam hibat, de most a fekete-feher oszlopos video is jobban nez ki.
Piciszoftver - az Picipuha -
Skullwipe
CPT.Pirk #60320 üzenetére
Már most ez a helyzet, már az elején így csináltam. Csak most másodjára, hogy javasoltátok, a Mint totál nem csinált grubot (ha jól értem) nekem meg nem sikerült, aztán töröltem is, erre meg a win se csinál semmit az MBR-jével hogy elinduljon automatikusan, hiába látja pedig az msconfig32-ben.
Akkor ezek szerint ez a grub mindenhol ott van, nem csak a rootban. Akkor tényleg nem úszom meg újra telepítés nélkül, pedig mondtam hogy én azt nem akarom.
Skullwipe
CPT.Pirk #60313 üzenetére
[link], nem tudom mi ez, hogy töröljem és álljon helyre csak hogy a win menjen. Viszont akkor ez kavart össze minden, és nem csinálta meg. Lehet visszakapcsoltam valamikor és most meg emiatt nem ment... Pedig rémlik hogy ezzel kapcsolatban mindig szólt eleinte a Mint hogy kapcsoljam ki, aztán nem foglalkoztam vele és nem is szólt utána.
Skullwipe
CPT.Pirk #60311 üzenetére
"*a csillag alatt viszont nem tudom mit értesz"
[Grub Rescue - Complete Re-install of GRUB 2 from Live USB ]
Egyáltalán nem működöt ez se nekem. Még mindig amúgy ez a grub fogad és az MBR nem áll helyre, és nekem ötletem sincs mit kéne csinálnom vagy mi a gondja baja, egyáltalán nem megy. De legalább bejön még ha ilyen kis plusz munkával, ennek is örülök. -
Skullwipe
CPT.Pirk #60308 üzenetére
Nem emlékszem már mi volt, de egyértelműen hibára futott a dolog. Még tudok rá rakni rendszert, de már az elveszett ahogy volt. Ezt is azért próbáltam, hogy hátha végre legalább betud bootolni mbr-ről. Ja de most hogy írom azt tudom, hogy elvileg egy csillagnak kellett volna lennie valaminél, de nálam nem volt semmi, ugye ez a leírásban nem volt amit mutattál, és számomra nagyon homályos is volt alapból az a leírás hiába lényegre törő.
De így utólag már eltudom mondani, hogy át raktam végre ma délelőtt "Other OS"-re a bootot, eddig ment a secure boot, az biztos, és nem is értem hogy tudod eddig bármi is működni, elvileg ennek nem kéne bekapcsolva lennie.
[60309] Majd akkor linkelek egyet, hátha segít, de kétlem hogy ez fura lenne, de az nekem fura és egyáltalán nem értem, hogy tud még mindig a grub bejönni, pedig töröltem a particiókat, és loli-val bekértem hogy csinálja meg nekem (ezt követtem), meg próbáltam a "boot-repair-disk-64bit"-et is de csak hibára futot, hiába kérte a parancs beadást, nem csinált semmi, hiába teljesítettem a bios boot átállítással vagy UEFI módban.
Skullwipe
CPT.Pirk #60284 üzenetére
Semmi se történik, használhatattlan. A w bejön f8-ra a linux semmire se jött be csak a kis grub, ami nem az emergency ahogy láttam. Próbáltam sok féle megközelítésben a grubot vagy mbr-t helyre rakni de sehogy se sikerült a win indításon kívül. Mérgemben letöröltem a particiókat is, így már nincs fent semmi. Feladtam, még az se fogom tudni megúszni hogy wint rakjak újra, de annyira utálok újra konfigurázgatni, sokszor csináltam már, én már az ilyesmit unom. Most viszont már elvagyok szomorodva hogy ezt tettem és nagyon bánom, most már inkább csendben maradok. De azért máshol maradnak a rendszerek fent, majd a Kodi-t még mondom, de most terminálból indítva már nem akart kilépni.
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Tudástár MX-Linux 19
- Dell és HP szerver HDD caddy keretek, adapterek. Több száz darab készleten, szállítás akár másnapra
- Lenovo ThinkPad T14 G1 Ryzen 5 PRO 4650U 24GB 1000GB 1 év garancia
- Bomba ár! Dell Latitude 5510 - i5-10G I 8GB I 256SSD I HDMI I 15,6" FHD I Cam I W11 I Gari!
- KIÁRUSÍTÁS - HP Elite / ZBook Thunderbolt 3 docking station (akár 2x4K felbontás)
- Eladó arany színű Apple iphone 7 128GB / 12 hó jótállással
