- Céleszköz: LG Smart Monitor Swing
- Raspberry Pi
S_x96x_S
S_x96x_S #5243 üzenetére
TSMC ..
June 8, 2021
An AnandTech Interview with TSMC: Dr. Kevin Zhang and Dr. Maria MarcedIC: As process nodes shrink, resistance on metal layers is becoming more problematic. With regards innovative solutions, and exotic materials versus copper interconnects, is it just a case of more research down that front? Or do we need to put more effort into increasing and routing higher metal layers?
KZ: I think in the research session at our advanced technology introduction, we did cover a little bit about the back end work. For example, we are continuing to optimize the copper grain boundary to bring a lower resistance metal line to our overall chip technology and new technology. Also, with dielectrics we continue to find innovative materials to improve the dielectric in parasitic capacitance. So, those things are being actively researched.
The 3D integration can also bring an alternative solution to this whole performance requirement in the back-end. You can instead route from A to B in a 2 dimensional space, or you can route A to B vertically in 3 dimensions. In some cases, by going vertical, you can reduce the overall length of the RC wire, and reduce pass delay significantly. So all those things have to be looked at going forward. -
S_x96x_S
Petykemano #5242 üzenetére
> Tényleg mi lenne, ha skálázható lenne egy chiplet.
> És ebben a skálázhatóságban a L3$ csak az első lépés.valami lesz
habár szerintem az ARM-es design-oknak lesz egy kis előnyük a 12-es szendvich formációnál..
( kisebb fogyasztás .. kisebb hő .. kisebb gond )
És szerintem a következő Apple silicon is kaphat V-cache szerűséget."A single slide at the Technology Symposium shows it all off. TMSC is currently probing 12-Hi configurations of SoIC. Each of the dies within the 12-Hi stack has a series of through silicon vias (TSVs) in order for each layer to communicate with the rest of the layers, and the idea is that each layer could be a different element of logic, of IO, of SRAM, or could be passive to act as a thermal insulation layer between other active layers."
S_x96x_S
Petykemano #5227 üzenetére
> Gondolhatnánk, hogy tök jogos az áremelés,
> meg hogy csak a drágább modellek kapják meg,
> mert hát drága technológia.- még nem biztos, hogy lesz áremelkedés.
- ráadásul az Inteltől is függ, hogy milyen árat lő be.
( amit az AMD bizonyára figyelembe vesz )nekem a Gen5 a sötét ló , vajon mi az AMD stratégiája?
mert ha ZEN3XT - hez nem lesz Gen5-ös lehetőség, akkor
az sokaknak fájhat..A prémium gamer / mini workstation-t keresők körében szerintem tarolni fog a Gen5.
- főleg a Gen5-ös GPU-k sokkal alacsonyabb latency-je miatt
- valamint a több GPU-s CXL összekötés, ami annó "Coherent Multi-GPU" néven futott, habár nem tudom, hogy melyik CXL verzió mire képes .. ( Ez valami általános SLI szerűség utódja )vagyis 2 középkategóriás Gen5-ös Intel GPU .. _akár_ le is verheti,
a csúcs nVidia / Radeon (Gen4)-es kártyákat .. ( ~ elméletben )"If CXL can seamlessly scale GPUs, then the economics of the market would also change completely. People would be able to buy a cheaper GPU first and then simply add another one if they want more power. It would add much more flexibility in buying decisions and even alleviate buyers remorse to some extent for the gaming class. If CXL mode trickles down to the consumer level anytime soon, then we might even see motherboard designs change drastically as multiple sockets and multiple GPUs become a feasible option. Needless to say, it looks like things are going to get pretty exciting in a few years."
( a coherent multi-gpu-s linkről másolva ) -
S_x96x_S
látom - lassabb vótam ... ( de ezért itthagyom )
Jajj .. 2022-Q4 ! - akkor az egyik variáció:
2022Q1: ZEN3 XT
2022Q4: ZEN4AMD ZEN4 and RDNA3 architectures both rumored to launch in Q4 2022
https://videocardz.com/newz/amd-zen4-and-rdna3-architectures-both-rumored-to-launch-in-q4-2022 -
S_x96x_S
LINUX ..
fixálnak egy ryzen boot problémát ..
Linuxosok - óvatosan !CPU: Ryzen 7 3700x
MB: Asrock X470 Taichi bios P4.70
Have been unable to boot 5.13 rc kernels but bisected the issue to this commit:
"Linux x86/x86_64 Will Now Always Reserve The First 1MB Of RAM"
"The motivation now for Linux 5.13 in getting that 1MB unconditional reservation in place for Linux x86/x86_64 stems from a bug report around an AMD Ryzen system being unbootable on Linux 5.13 since the change to consolidate their early memory reservations handling. Just unconditionally doing the first 1MB makes things much simpler to handle."
https://www.phoronix.com/scan.php?page=news_item&px=Linux-Always-Reserve-1MB
S_x96x_S
Simply NUC Ruby R8 (CBM1r8RB) AMD NUC Review
https://www.storagereview.com/review/simply-nuc-ruby-r8-cbm1r8rb-amd-nuc-reviewvan több config ... R3/R5/R7
https://simplynuc.eu/ruby/
Ruby R3
AMD® Ryzen™ R3-4300U CPU (4c/4t) passmark: ~7667
AMD® Radeon™ Vega 5 Graphics
4GB DDR4 Memory
128GB SSD
1x 2.5GbE NIC + 1x 1GbE NIC + Intel Wi-Fi 6 AX200
Free OS installation
FULLY CONFIGURED
From €439 Ex.VAT -
S_x96x_S
CPU trend: VCPU specializálódás ..
Az általános x86 CPU feladatot - egyre inkább specializált chipek veszik át."Google New Custom Silicon Replaces 10 Million Intel CPUs | Google Argos VPU"
https://semianalysis.substack.com/p/google-new-custom-silicon-replaces
"if we assume that Google’s servers are utilized at 100% (they aren’t), all YouTube/Google Photos/Google Drive footage video is 1080p 30FPS, and the target is H264, the workload would require ~904,000 Intel Skylake server CPUs to encode. Google switching to VP9 with the same set of assumptions would require ~4,193,000 Intel Skylake server CPUs. If the ingest footage is 4k 60FPS, then the number of CPUs required for H264 is ~7,205,000, and VP9 requires ~33,407,000." -
S_x96x_S
AMD Rembrandt will not get Infinity Cache
AMD has recently updated the Linux kernel with information on the upcoming Yellow Carp APU.
https://videocardz.com/newz/amd-ryzen-6000-rembrandt-yellow-carp-apu-will-reportedly-not-feature-infinity-cache
The APU will require a new FP7 socket, which will force laptop makers to adopt existing designs for new motherboards and possibly power and thermal characteristics of the “Yellow Carp” APU series. This is understandable, as Rembrandt brings major changes not only to the CPU and GPU core but also I/O. Rembrandt will be the first AMD APU to support DDR5 and LPDDR5 memory standards. It will also enable PCIe Gen4 support, which is something that Cezanne currently does not.
According to some new information, Rembrandt will not have Level3 (L3) cache, at least there is no such entry in the recent Linux kernel update (only L1 and L2 cache).
Furthermore, instead of 8 Compute Units per ShaderArray, Rembrandt will have 6. The code does not confirm the full number of CUs in the APU though. The Zen3+ and 6nm fabrication processes have not yet been confirmed either, but they have been repeated in rumors for quite a while, so it would be surprising if they turn out to be false.
Source: @Broly_X1
S_x96x_S
paprobert #5214 üzenetére
> CPU-ból már túltermelés van,
ezt hogy érted?
- vagy erre milyen adatokból/jelekből következtettél?
- vagy ezt csak az OEM és a Cloud-ra érted?mert a Consumer hazai piacon:
- én "G"-s és "Athlon" procit nem is nagyon látok.
- és AthlonG-s pedig még ritkább. ( Athlon 3000G, 200GE, 240GE )ha csak a 7nm-resekre .. azért ott is lenne igény ..
és várják az új olcsó 5600G-t. ( meg ha lenne Ryzen3 -as ZEN3-as ) -
S_x96x_S
Petykemano #5211 üzenetére
> Lisa Su azt mondta a kísérleti zen3V-re, hogy év végén kerül gyártásba.
én már azzal a gondolattal is eljátszottam,
hogy a következő Threadripper (zen3-as) _TALÁN_ már ilyen lesz ..
De szeptemberre még semmi esély .. -
S_x96x_S
V-Cache - Anandtech részletes frissítés:
Update June 1st:
In a call with AMD, we have confirmed the following:- This technology will be productized with 7nm Zen 3-based Ryzen processors. Nothing was said about EPYC.
- Those processors will start production at the end of the year. No comment on availability, although Q1 2022 would fit into AMD's regular cadence.
- This V-Cache chiplet is 64 MB of additional L3, with no stepped penalty on latency. The V-Cache is address striped with the normal L3 and can be powered down when not in use. The V-Cache sits on the same power plane as the regular L3.
- The processor with V-Cache is the same z-height as current Zen 3 products - both the core chiplet and the V-Cache are thinned to have an equal z-height as the IOD die for seamless integration
- As the V-Cache is built over the L3 cache on the main CCX, it doesn't sit over any of the hotspots created by the cores and so thermal considerations are less of an issue. The support silicon above the cores is designed to be thermally efficient.
- The V-Cache is a single 64 MB die, and is relatively denser than the normal L3 because it uses SRAM-optimized libraries of TSMC's 7nm process, AMD knows that TSMC can do multiple stacked dies, however AMD is only talking about a 1-High stack at this time which it will bring to market.
S_x96x_S
S_x96x_S #5192 üzenetére
> - "Feb 2022 launch" -re jósolja a következő AMD cpu generációt.
> (feltételezem, hogy valami belsős infó alapján, Ian Cutress a kevésbé
> blöffölös fajta elemzők közé tartozik)rákérdezett:
"Confirmed with AMD that V-Cache will be coming to Ryzen Zen 3 products, with production at end of year."
https://twitter.com/IanCutress/status/1399766139769602058Az Intel ellen valamit ki kell állítani ..
Közben az interneten már találgatják a termékelnevezést:
"Ryzen 5950XT Pro Hyper V-Cache RX edition" -
S_x96x_S
ISA architektúrák .. X86 vs. ARM
RISC vs. CISC Is the Wrong Lens for Comparing Modern x86, ARM CPUs
https://www.extremetech.com/computing/323245-risc-vs-cisc-why-its-the-wrong-lens-to-compare-modern-x86-arm-cpusAGner Fog
ISA is not irrelevant. The x86 ISA is very complicated due to a long history of small incremental changes and patches to add more features to an ISA that really had no room for such new features…
The complicated x86 ISA makes decoding a bottleneck. An x86 instruction can have any length from 1 to 15 bytes, and it is quite complicated to calculate the length. And you need to know the length of one instruction before you can begin to decode the next one. This is certainly a problem if you want to decode 4 or 6 instructions per clock cycle! Both Intel and AMD now keep adding bigger micro-op caches to overcome this bottleneck. ARM has fixed-size instructions so this bottleneck doesn’t exist and there is no need for a micro-op cache.
Another problem with x86 is that it needs a long pipeline to deal with the complexity. The branch misprediction penalty is equal to the length of the pipeline. So they are adding ever-more complicated branch prediction mechanisms with large branch history tables and branch target buffers. All this, of course, requires more silicon space and more power consumption.
The x86 ISA is quite successful despite of these burdens. This is because it can do more work per instruction. For example, A RISC ISA with 32-bit instructions cannot load a memory operand in one instruction if it needs 32 bits just for the memory address."----------------------------------------
és mégegy Kapcsolódó cikk az elmúlt hetekből -
Emulációnál viszont az ARM(AArch64) - 2x annyi regiszterének és a 3 operandusos utasításkészletének van valami előnye.
Valamint energiahatékonyabb is az M1. ( de ez az 5nm miatt is )
"Temptation of the Apple: Dolphin on macOS M1""AArch64 does have its advantages, though. Namely, the processors have 31 registers, compared to the 16 available in x86-64 processors. The PowerPC processor we are emulating has 32 registers, and while it is rare for all of them to be used within a single code block, more registers is always nice to have. Another difference is that AArch64 and PowerPC have 3 operand instructions while x86-64 only has two.
PPC: A = B + C AArch64: A = B + C x86-64: A = B, A = A + C
As you can see, it makes emulating some instructions much cleaner and easier than on our x86-64 JIT. Alright, enough with the boring details. How does the M1 hardware perform when put up against some of the beasts of the GameCube and Wii library? ..."
S_x96x_S
hokuszpk #5199 üzenetére
>>"Az AMD általában kevesebbet igér"
persze relative ...
Charlie Demerjian(semiaccurate)
újabban nagyon ki van akadva az Intelre ..
nem tudom, hogy mi volt nála az utolsó csepp ..
de már nem finomkodik a véleményével ..
( vagy nála ez a finomkodás .. )
---------------AMD’s 3D V-Cache takes the advanced packaging lead
https://semiaccurate.com/2021/06/01/amds-3d-v-cache-takes-the-advanced-packaging-lead/
"Intel’s EMIB and Foveros have a lot of PR behind them and there are real products on the market too. All are low volume proof of concept more than mass market products though, none of them come close the the lowest volume AMD advanced packaging products. That said they all are lower power or use spread out dies in the case of EMIB. To date no one has released a high power product that doesn’t use spread out chips no matter what the tech. Most will talk and intone it is not an issue, especially to the less technical listener, but the tech isn’t there to make real products yet.
So that brings us back to AMD and their Computex 2021 keynote speech. In short AMD just kicked all other comers to the curb with their technology even if they didn’t call it out explicitly. What they did is a game changer but not the holy grail of advanced packaging technology. Think of it as a big step that will pay significant dividends in the market. Once again no one else has shown anything close and AMD is planning on starting consumer volume production this year.
Lets take a look at what AMD announced, why it is so impressive, and why no one else is close.
""Intel’s honesty shows through at Computex 2021"
https://semiaccurate.com/2021/05/30/intels-honesty-shows-through-at-computex-2021/
"SemiAccurate won’t rehash the last six months of performance messaging from Intel but suffice it to say they claim victory over AMD with their 4C and 8C Tiger Lake CPUs. Their graphs and comparisons are a tad skewed and don’t hold up to independent testing by non-tame sites, but Intel continues to make the same curious claims at Computex. Don’t believe the spin, AMD beats Intel like a drum in everything but proper disclosure."" ... Qualcomm has a 5G world certified M.2 module and so Intel now has one too. Qualcomm makes their silicon, Intel uses, wait for it, Mediatek silicon. You remember Mediatek, the ones shouting about how they were way ahead of Qualcomm a few years ago but suddenly went radio silent about the time silicon was supposed to launch. It is here now with an Intel name tag on the module.
Qualcomm has a 5G sub-6 and MMWave on their modem, Intel has sub-6. And if history is any guide, the head to head comparisons between the Qualcomm and Mediatek silicon is going to be a laugh riot. Intel for some reason doesn’t mention MMWave in their presentations, no clue why.
The module itself is made by Fibocom, the silicon is by Mediatek as we previously mentioned, so what does Intel do? Some software. How much? They won’t say but it is unlikely to be the bits they want you to think they make. Remember what we said about not wanting critical minds to view their present
S_x96x_S
Az AT értékelése ( találgatása )...
- az új cache jó dolog, és 7nm-en .. ( nem 5nm! )
(feltételezem, hogy valami belsős infó alapján, Ian Cutress a kevésbé blöffölös fajta elemzők közé tartozik)- a megnövelt L4es cache "önmagában" nem mindenhol okoz sebességnövekedést.
- mindenféle új kombinációs lehetőségek vannak, ( 7nm + 5nm kombinálása) - ami újabb értelmet add az eddigi hibrid pletykáknak.
- "prémium" ..
ha folytatódik az eddigi trend, akkor nem lesz olcsó.. és várhatóan a TOP 6 magos - nem $250 lesz .."AMD Demonstrates Stacked 3D V-Cache Technology: 192 MB at 2 TB/sec"
https://www.anandtech.com/show/16725/amd-demonstrates-stacked-vcache-technology-2-tbsec-for-15-gaming"
On the performance, we’ve seen L3 cache depth improve gaming performance, both for discrete and integrated gaming. However, increased L3 cache depth doesn’t do much else for performance. This was best exemplified in our review of Intel’s Broadwell processors, with 128 MB of L4 cache (~77 mm2 on Intel 22nm), wherein the extra cache only improved gaming and compression/decompression tests. It will be interesting to see how AMD markets the technology beyond gaming.Finally, interception into the mainstream - AMD says that it is ready to start integrating the technology into its high-end portfolio with production at the end of the year. AMD has said that Zen 4 on 5nm launch is in 2022. Based on previous timescales, we have predicted that AMD’s next processor family is roughly a Feb 2022 launch. Whether that would be Zen 4 it’s unclear at this point, but also Zen 4 is on 5nm and AMD is showcasing this 3D V-Cache on 7nm. Whether AMD has plans to monetize this feature on 7nm, or whether it might combine a 5nm Zen 4 chiplet with a 7nm 64 MB cache chiplet is unclear. It wouldn’t be too difficult to combine the two, however I suspect that AMD might want to push its caching technology into more premium products than Ryzen desktop. We might see special one-off editions as the technology ramps through the stack."
S_x96x_S
Armagedown #5187 üzenetére
> egy ideig nem várhatóak PCI Express 5.0át támogató cuccai.
(PCIe5.0 mániásként is)
ez inkább úgy fogalmaznám át, hogy:egészen más az Intel és az AMD kommunikációs stílusa.
pl. az 3D V-Cache váratlan volt.
bár nagy is volt a nyomás az AMD-n, hogy mondjanak már végre valamitAz AMD általában kevesebbet igér és "őszintébb" (mint az eddigi Intel)
én reménykedek, hogy 2022 Februárban lesz PCIe5.0 -ás meglepetés is.
és csak 2-3 hónapos lemaradás lesz az Intel mögött.Persze ettől még néha sírok ...
és ha az Inteles Gen5 "kivételesen" tényleg jól sikerül és 3hónapon belül nem látható AMD-s alternativa, akkor lehet, hogy lesz egy új Inteles gépem _is_. -
S_x96x_S
Petykemano #5176 üzenetére
> A $259-os 5600G szerintem is kifejezetten jó.
egy bajom van vele, .. sajnos nem PCIe4.0 -ás
> És elegendő az Alder Lake ellen is.
hátha az AMD
a PCIe5.0 -val is meglep bennünket a 3D V-Cache - mellett.
de jó lenne .. -
S_x96x_S
Petykemano #5159 üzenetére
> hogy akkor a top 6 magos $249 volt, most meg $299.
nem top .. de GPU-val - és közel a te lélektani áraidhoz:
2021 - Augusztus 5!
- Ryzen 5700G $359
- Ryzen 5600G $259
https://www.anandtech.com/show/16722/computex-2021-amds-keynote-a-live-blog-10pm-et -
S_x96x_S
S_x96x_S
Cathulhu #5171 üzenetére
ennek az APU-nak elméleti maximuma ~ 2.048 TFLOPs
vagyis elég gyenge a DDR4-es GPU teljesítménye.> Mennyi is az, 1? 1.2? Valahogy úgy.
"With the base model PlayStation 4 being capable of 1.84 TFLOPS and the PS4 Pro being capable of 4.2 TFLOPS, the PS5 is dramatically ahead of both with its recently-revealed capacity for 10.28 TFLOPS " [link]
S_x96x_S
Q3 -ban NUC szerűség ..
Gigabyte Unveils 2021 BRIX Mini-PC With AMD Ryzen 5000U ‘Cezanne’ APUs, More TFLOPs Than The Original PS4
https://wccftech.com/gigabyte-unveils-2021-brix-mini-pc-with-amd-ryzen-5000u-cezanne-apus/
S_x96x_S
paprobert #5166 üzenetére
> Értem én, hogy keresletnövekedés, na de miért csak késő ősszel,
> azaz 8-10 hónappal a lezárások után tűntek el a hardverek a polcokról,
> miért nem rögtön februárban?A virus hullámokban jött és sokan halogatták a beruházást.
1.) Az első hullám
- kiszipkázta a tartalékokat a raktárakból.
- és az emberek nagy része, reménykedett, hogy nem lesz folytatás ..
pl. nem kell az otthoni 3 gyereknek - külön számítógép ..
és a cégek is reménykedtek, hogy nem kell tartós home officra berendezkedni ..vagyis sokan halogatták a beruházást.
2.) Második hullám ősszel - viszont mindenkit egyszerre "ébresztett" fel.
nézz meg egy covid grafikont ..
Az Északi félteken - Európában/Amerikában szinte egyszerre durrant be a virus.közben a gyárak kapacitásait nem lehetett annyira rugalmasan átállítani mint egy WC papír termelést - ami ráadásul fix kereslet ..
csak a hivatalos/iskolai/éttermi/office wc-papir helyett - otthoni/lakossági wc papirt kellett gyártani
Amúgy is ..
Az emberiség ugyanakkora mennyiségű wc papirt használ el ..
Ez nem egy hasmenéses vírus ..De a számítógép komplexebb terméklánc
A Just In Time gyártás miatt nincs tartalék a rendszerben ..
Közben a szállítási költségek is az egekben .. mert nincs elég konténer, vagy mert kitört a járvány a hajókon ... vagy mert eldugaszolták a szuezi csatornát.
Közben 2020 öszel a Bitcoin ára is bedurrant; és újjabb embereket szippantott be ... ami újabb hardver keresletet inditott el.
ott van még a Chia coin .. meg még sok más ..Ez olyan káoszelméletes dolog ..
csak itt nem pillangó - hanem egy annál is kisebb "virus" a lánc elinditója ..
és még nincs vége.. biztonsági öveket bekapcsolni .. mert a változások tovább gyűrűznek .. -
S_x96x_S
> de azért az nem változtat azon a tényen, hogy
> akkor a top 6 magos $249 volt, most meg $299.lehet, hogy rosszul emlékszem,
de azért az 1600 -as nem volt még TOP (pl. az Intel-hez képest)
Az 5000-res sorozat már más - az már King !AT: "Zen 3 and the new Ryzen 5000 processors, for the desktop market, are the realization of those goals: not only performance per watt and performance per dollar leaders, but absolute performance leadership in every segment. We’ve gone into the new microarchitecture and tested the new processors. AMD is the new king, and we have the data to show it."
Az 5000-res sorozatnál a sweet spot .. nem a 6 vagy a 8 magos..
hanem a 12 magos.de amúgy:
- Ryzen 5 1600X - nincs hütő
- Ryzen 5 5600X - hütővelpersze a fentiek nagy része - marketinges trükk ..
hasonlóan mint a mobilprocis átnevezések ..Igazából nem tudom, hogy mit tehetett volna mást Abu vagy LisaSu
Mivel - az 5000-res sorozat az új "Király" vagy top ..
nagyobb a kereslet iránta.
és mivel a gyártókapacitás korlátos -
csak az árakkal tud játszani az AMD.
Ha magasabb az ár - kisebb a kereslet ..
és aki el tudja halasztani a vásárlást .. az elhalasztja ..
A másik stratégia az nVidia stratégiája ..
Kihozta a 3000-res sorozatot jóval olcsóbban ...
De nem lehet kapni ...
King? .. igen ...
Tisztességeseb és jobb az nVidia mint az AMD?Mindenesetre az Intel - összel bedurrantja a rakétákat ..
és ha lesz elég kapacitása, akkor csinál egy kis árversenyt ..
ha nem lesz kapacitása .. akkor pedig felárazza a procikat - éppen annyira, hogy a kereslet és a kinálat egyensúlyban legyen. -
S_x96x_S
Petykemano #5154 üzenetére
> Szóval értem. Csak hát akkor is bosszantó, hogy abu magdömpiget
> "ígér", aztán eltelik pár negyedév és elmarad.igazából
- Lisa Su igérte a magdömpinget.Abu csak a hírhozó ..
- határidő nélkül - csak általánosságban
Persze az újságiróknak is van felelőssége, hogy hogyan szinezik ki..
LisaSu: "There will be more core counts in the future."Amúgy engem is bosszant a helyzet,
de én inkább a külső dolgokat ( covid ) okolom.
AMD CEO Lisa Su Talks: Chip Shortages, Tariffs, GPUs,
and More Cores
( Plotting the course for 2021)
https://www.tomshardware.com/news/lisa-su-ces-2021-interviewThis raises questions about whether it’s feasible to infuse more cores within the electrical and thermal confines of today’s systems, or if software even requires a jump to higher core counts. Su says that AMD will continue to expand core counts in the future:
LisaSU: “If you look at what we've done between Zen 2 and Zen three, as well as between the second- and third-generation EPYC and Ryzen 4000 and 5000, we really focused on increasing single-threaded performance, as well as Improving some of the latencies and overall systems, such that we've gotten tremendous gen-on-gen performance within the same process technology,” she said.
LisaSu: “So, all of that is in 7nm products, and we’ve probably been able to increase performance by 20%+, depending on which metric you're looking at. There will be more core counts in the future.I would not say that somehow 64 cores is the limit, but I think they will come as we scale other parts of the system, as well.”
S_x96x_S
Petykemano #5150 üzenetére
> De a 6 magos procik az 1600/X megjelenése
> óta nem lettek olcsóbbak, sőt, drágultak is.azért ez így pontosításra szorul:
mikor kijött a ZEN1, akkor
a legjobb "disruptive" stratégia az volt, hogy a Consumer piacot becélozni.
- CMOS: 14 nm ; GloFo -n gyártva.
- akkor 250$ -ral jelent meg.
ma a newegg-en - OEM Ryzen1600X -et 145$ - 199$ között látok.most a Covid okozta túlkereslet és a gyártási kapacitások miatt is -
Cloud és OEM first a stratégia ..
a Consumer piacra ebből már alig csorog le valami.
Egyáltalán - nincs APU a piacon ..
és még tudnék panaszkodni én is ..A covid hiány miatt nincs verseny .. mindent el lehet adni ..
és az árak az egekben.
még az AT - is megemliti, hogy most 2x annyiba kerül a ryzen 1600, mint 1 évvel ezelőtt.
"surprisingly the Ryzen 5 1600 is also a top seller at #7, despite the $168 price tag, which is well above the $85 we saw this time last year."
https://www.anandtech.com/show/9793/best-cpusHa lesz "igazi" verseny, akkor lesznek jó árak - nekünk - consumereknek is.
És ennél még lehet rosszabb is ..
tegnapi hír:
Coronavirus: Taiwan chip maker TSMC confirms second coronavirus infection but says operations not affected
The Covid-19 outbreak in Taiwan comes amid an ongoing global semiconductor shortage which has caused widespread disruption to tech-dependent products
27 May, 2021
https://www.scmp.com/tech/big-tech/article/3135032/coronavirus-taiwan-chip-maker-tsmc-confirms-second-coronavirus -
S_x96x_S
> A 16 magra gondolsz?
arra is ..
meg amit a "Moore's Law is Dead" - összerakott. ( fekete - piros betüs )
8 core chipset
vagyis AM5 -re itt már 3x8 = 24core -t ír max-nak.
ZEN4 - 2022Q3 ( de akár Q2 .. Q4 )
X690 - PCIe 5.0 ??? ( talán )
USB4 talán ...
50% performance/watt növekedés ( laptopoknál jól jön, de a szervereknél is )
AVX-512 ...de igazából már én is keverem a dolgokat ...
S_x96x_S
még egy variáció ..
"AMD Zen 4 Powered Ryzen ‘Raphael’ Desktop CPU Rumors: Over 20% IPC Gain, 16 Core Flagship at Launch, DDR5-5200 on AM5 LGA1718 Socket, 2022 Launch"
Wccftech
( jobb egérklick + új ablakban megnyit és akkor olvasható ) -
S_x96x_S
Jim Keller intervjú .. hosszú ..
érintve a ZEN, Raja Koduri, Riscv, ...An Interview with Tenstorrent: CEO Ljubisa Bajic and CTO Jim Keller
https://www.anandtech.com/show/16709/an-interview-with-tenstorrent-ceo-ljubisa-bajic-and-cto-jim-kellerIC: Correct me if I’m wrong, but for the time inside AMD, it kind of sounded like Jim’s way or the highway?
JK: I wouldn't say that! The funny thing was, we knew we were kind of at the end of the road - our customers weren’t buying our products, and the stuff on the roadmap wasn’t any good. I didn’t have to convince people very much about that. There were a few people who said ‘you don’t understand Jim, we have an opportunity to make 5%’. But we were off by 2X, and we couldn’t catch up [going down that route]. So I made this chart that summarised that our plan was to ‘fall a little further behind Intel every year until we died’.
With Zen, we were going to catch up in one generation. There were three groups of people - a small group believed it (that Zen would catch Intel in one generation); a medium-sized group of people that thought if it happens, it would be cool; then another group that definitely believed it was impossible. A lot of those people laughed, and some of them kind of soldiered on, despite this belief. There was a lot of cognitive dissonance, but I found all kinds of people that were really enthusiastic.
Mike Clark was the architect of Zen, and I made this list of things we wanted to do [for Zen]. I said to Mike that if we did this it would be great, so why don’t we do it? He said that AMD could do it. My response was to ask why aren't we doing it - he said that everybody else says it would be impossible. I took care of that part. It wasn’t just me, there were lots of people involved in Zen, but it was also about getting people out of the way that were blocking it. It was fun – as I’ve said before, computer design needs to be fun. I try to get people jazzed up about what we’re doing. I did all kinds of crazy stuff to get people out of that kind of desultory hopelessness that they were falling into. -
S_x96x_S
S_x96x_S #5146 üzenetére
> PCIe5
egy kicsit megnyugodtam ..
az AMD szerepel a "Launch Partners - Ecosystem" slide-on
az Intel és a Renesas mellett.
Van még remény
amúgy az STH -s cikk jobb mint az AT-s .. sok sok slide ...
https://www.servethehome.com/marvell-bravera-sc5-offers-2m-iops-and-14gbps-in-a-pcie-gen5-ssd/A Latency- csökkenés jó lesz .. meglássátok!
A Gen5 és a CXL - miatt a Szerverek gyors elavulását jósolja az STH. -
S_x96x_S
> lehetőleg CXL-es PCIe5-el.
ajajj .... tényleg kelleni fog az a PCIe 5.0 ...
Marvell Announces First PCIe 5.0 NVMe SSD Controllers: Up To 14 GB/s
"These new SSD controllers roughly double the performance available from PCIe 4.0 SSDs, meaning sequential read throughput hits 14 GB/s and random read performance of around 2M IOPS. To reach this level of performance while staying within the power and thermal limits of common enterprise SSD form factors, Marvell has had to improve power efficiency by 40% over their previous generation SSD controllers." -
S_x96x_S
Petykemano #5138 üzenetére
még emésztem ...
de APU-nál és Desktop-nál normális a heterogén architektrúra.
"Zen 5 CPU codename Granite Ridge.
Zen5 APU? codename Strix Point (Big Core Zen5+Zen4D Small Core)"
https://twitter.com/9550pro/status/1397812947049533445 -
S_x96x_S
Petykemano #5137 üzenetére
>> de Cloud-ban szerintem nem sok értelmét látom..
> De hát ezt csinálja az Arm.lehet, hogy nem jól fogalmaztam ..
a Cloud-ban - én
a homogén magoknak látom értelmét.
vagy másképpen a homogén CCD-knek - egy CPU-n belül.de tisztán csak praktikusság miatt.
> Azt mondod, hogy ez valójában nem így van, ez csupántisztán csak a homogenitás praktikusságára céloztam.
az AM5 - amúgy is Desktop ... és itt már előny lehet ( marketingben is ) az erős egy szálas teljesítménynek. ( ~ erősebb CCD-nek )
A félig Desktop-nak számító: Threadrippernél is lehet értelme..
Az céges EPYC-nél kevesebb ..
Cloud-os EPYC-nél meg még kevesebb.
HPC-s EPYC -nél meg közelít a nullához> ...ARM .. V1 vs. N2
Ahogy látom:
az X86 -os magok differenciálása a piac számára
jelenleg gyártóspecifikus.
a Cloud-okban találálható
- többfajta Intel
- többfajta AMD ( ZEN2, ZEN3 )
persze ez csak részben fedi le a piaci igényeket.Stratégiailag többféle lehetősége is lehet az AMD-nek,
ha netalán
egy generáción belül többféle CCD chipletre is lenne erőforrása1.) hasonlón mint a V1/N2 ..
X86-A64-ből: gyenge sok mag vs. kevesebb erősebb mag.2.) vagy a merészebb:
erős X86-A64 és erős ARMv9
(mert stratégiailag - jobban megérheti a mérnöki erőforrásokat egy ARMv9-be ölni , .. már a Xilinx miatt is. )3.) És ott van még az önmagát (bootoláskor) automatikusan átkonfigurálható architektúra ötlete..
amikor a gyenge magok - össze tudnak állni erős magokká.
vagyis
a jelenlegi 8x( 1c/2t ) -ból lehetne még
->> 4x(1c/4t) vagyis 4 erős mag.
->> 2x(1c/8t) vagyis 2 szuper erős mag.
->> vagy 16x(1c/1t) 16 gyenge mag.de ez csak találgatás és álmodozás részemről ..
S_x96x_S
https://oxide.computer/ Servers as they should be
CPU: 2,048 X86 CORES (AMD MILAN)
MEMORY: UP TO 32TB DRAM
STORAGE: 1024TB OF RAW STORAGE IN NVME
NETWORK SWITCH: INTEL TOFINO
NETWORK SPEED: 100 GBPS
https://oxide.computer/product
https://news.ycombinator.com/item?id=27294471
S_x96x_S
Petykemano #5134 üzenetére
>Mennyire lenne bonyi csinálni
> egy zen4 heavy magot + és egy zen4 light magot,technikailag kivitelezhető ..
legalábbis, szerver szinten egy 16 magos CPU -t .
4 x 4 core -ra szét lehet bontani egyszerűen ..
de a power CCD -nél nem tudom hogyan lenne célszerű ..
Az eddigi árazási elveket felboritja .. újra ki kellene találni ..akkor már inkább egy CCD-n belül kellene.
- 8 core / CCD - amiből 2core extra (duplás) és 6 egyszerű.
persze ez se ideális ..
de legalább 1 chiplet-ből megoldható ..
míg a tied 2 különböző CCDA probléma a szoftveres lekövetése .. átverni a Microsoftton ..
és belerakni a Linux kernel ütemezőjébe.
Ráadásul azt vissza is kell portolni ..
És hogy egy Linux 20.04 LTS megkapja -e a frissítést .. hát kérdéses ..
persze a bencsmarkoknál .. erre lehet mutogatni ..
szóval nem egyszerű ..Összefoglalva:
- csak Desktop / játék szinten lehetne értelme ..
Szerver szinten nem igazán. -
S_x96x_S
Petykemano #5131 üzenetére
A 6 core / CCD - re talán
az AVX512 / AVX512-VNNI / AMX lehetne az egyik magyarázat.
( vagy másképpen AVX3-512 )
És az 5nm -mellett még 2 core -t be kellett áldozni, hogy elférjenek
a rengeteg tranzisztorral.Ráadásul, hogyha túl sürün pakolják - akkor beleütköznek
az AVX-512 Downlocking-ba .. ( ~ throttling )Ha mindegyik mag mellé
2x futószalagot tennének AVX-512 -ből.
akkor már a magok száma is számít ..> Az energiahatékony az nem low power.
remélem neked lesz igazad ..
és a power - csak annyit jelent, hogy 5.5Ghz felett túrbozik.
a másik két energiahatékony meg csak 4.5Ghz-ig> 3 CCD-nél
lehet, hogy a Xilinx FPGA-t is betervezték
- 1 CPU ( Zen4 )
- 1 GPU ( Radeon )
- 1 FPGA ( Xilinx )
És három a magyar igazság
persze 6 CPU maggal nem sok értelme van ennek,
de ne ma ébressz fel .. -
S_x96x_S
Petykemano #5123 üzenetére
> "AM5 can get 3 CCDs. But each CCDs will lose 2 cores.
3*6 = 18 ..
a mostani 2*8=16 power core - hoz képest
nem valami nagy előrelépés.meg, ha én tervezném, akkor csak 1 energiahatékony CCD-t
raknék bele .. nem kettőt ..Lehet, hogy 3 chiplet van benne - de nekem
+1 power +1 energiahatékony +1 GPU
lenne értelmes.
vagy
+2 Power +1Energiahatékony. -
S_x96x_S
Petykemano #5120 üzenetére
> Azt gondolnám, hogy ennek neked otthon,
> aki esetleg nem engedhetsz meg magadnak két számítógépet, még lenne értelme.
> De egy nagy cloud szolgáltató miért járna jobban?mindkettő tisztán gazdasági ok - költséghatékonyság , TCO, business agility
a piac nem statikus; egy beruházás viszont több évre szól ..
és a meglévő gépparknak le kell követni az igényekben bekövetkező változást.
És bár most a COVID miatt jelentős túlkereslet van, eljöhet az az idő, amikor
kapacitás felesleg lesz.Persze ilyen esetben próbálják legalább az önköltségi árat ( pl. áram, hardver amortizáció )
kitermelni - pl. Spot/ preemptible VM pricing-al ...
https://www.datacenterdynamics.com/en/opinions/complete-guide-spot-instances-aws-azure-and-gcp/
"Most cloud providers divide their pricing models into three categories:
- On demand instances—let you pay for computing power per hour or per second, without long-term commitments or upfront payments. You can increase or decrease resources available to your applications at will.
- Reserved instances—for workloads that run on the cloud in the long term, you can commit to compute instances for a period of betweenone to three years, with the option of paying some of the amount upfront. Reserved instances grant discounts of between 40-75 percent, depending on the cloud provider and the level of commitment.
- Spot instances—spot instances let you bid on unused capacity in the cloud provider's data center. They provide the highest level of discount, up to 90 percent compared to on demand costs."persze most még ~90% -10% lehet az X86 - ARM megoszlás,
de 4-8 év múlva az ARM feljöhet 30 - 40% -ra is .de ez az én logikám .. sokszor tévedek .. szóval ne vegyétek készpénznek.
Az is kérdés, hogy az Intel és az AMD közötti licensz-ben jogilag lehet-e valami ezzel kapcsolatos korlátozás ..
De amúgy ..
a piac eldönti!
ps:
Ez az én fejemben ez hasonló mint egy ingatlanberuházás ..
pl. Ha a belső tér könnyen átalakítható ; akkor most a covid idején az üres irodákat át lehet alakítani lakássá .. vagy viszont .. Ez az üzleti agilitás - számomra. -
S_x96x_S
Petykemano #5107 üzenetére
> Raphael
> - 28 PCIe 4.0 lanes (+4 compared to Zen 3)én azért egy kicsit sajnálom, hogy nem lesz rögtön PCIe 5.0 -a a consumer piacon.
Bár eléggé ellenmondó hirek vannak arról, hogy az AlderLake desktop-on most támogatja-e a CXL-t vagy sem ..azért nekem folyik érte a nyálam. Persze én nem játékra használom, fontos az I/O , latency ..
és hogy mindenféle enterprise-os kütyüket is rá tudjak kötni ..Az egyetlen reményem - hogy lesz olcsó -mini- Threadripper PCIe5.0 -val - ZEN4-en
főleg most, hogy olvasom, hogy az év végén itt a PCI Express 6.0 -is..
PCI Express 6.0 Status Update: Draft 0.71 Coming Soon, Final Release by End of Year
- 800G Ethernet suppoort ... jajj .. de folyik a nyálam...
S_x96x_S
18.ról - 11. pozicióra ugrás - 1 év alatt.
A kombinált XILINX-es egyesülés utánni pozició - még előrébb leszAMD: +93%
INTEL: -4%
MEDIATEK: +90%
nVIDIA: +51%
Qualcomm: +55% ( ők vették meg a nuviát, erős ARM-es rivális lesz! )
AMD was No. 11 semiconductor company in Q1 2021.
https://www.tomshardware.com/news/ic-insights-top-15-makers-of-semiconductors
"AMD and MediaTek were two new entrants to the top 15 list of semiconductor companies. AMD significantly increased shipments of its CPUs for servers and high-performance desktops, so its revenue in the first quarter totalled $3.445 billion, up 93% year-over-year. In Q1 2021 AMD was ranked 11th largest semiconductor company in the world. The company was ranked 18 in the first quarter 2020. MediaTek's sales reached $3.849 billion, an increase of 90% year-over-year. AMD and MediaTek replaced Huawei's HiSilicon and Sony's chip division in Top 15. "
S_x96x_S
a következő 1-2 hónapban nálunk is megjelenhetnek az "olcsó
Benchmarking AMD Ryzen 5 5500U Linux Performance With A $450 Lenovo Laptop
( Lenovo Ideapad 3 15 with Ryzen 5 5500U )
https://www.phoronix.com/scan.php?page=article&item=lenovo-ryzen5-5500u&num=1és egy játékteszt ( sakk )
"If taking the geometric mean of all 139 benchmarks, the Ryzen 5 5500U was the fastest of the tested processors by a slim lead. From the Ryzen 5 4500U to 5500U was about 11% higher performance and over the Core i7 1165G7 was about 10% higher performance in these CPU benchmarks. With the graphics tests is where the Intel Tiger Lake came out stronger overall against the Vega-based Radeon graphics found within the 5500U."
S_x96x_S
> Valamiért nekem a SkyBridge koncepció
Az extremetech-es cikk csak egy újságírói továbbgondolása
a SkyBridge-nek.egy logikus spekuláció.
az eredeti cikkben
"... the puzzle that AMD didn’t mention — an SoC architecture that we ultimately believe could combine ARM and x86 hardware on the same die."
"This article is speculative — AMD has not acknowledged such a strategy at this point — but if you read between the lines a bit, the pattern fits."
S_x96x_S
hokuszpk #5113 üzenetére
Megelőztek, ... nincs új a nap alatt
"an ambidextrous heterogeneous compute strategy"
2014:
"To discuss why AMD might build a single chip with both ARM and x86 cores, we first need to cover the industry’s previous attempts at multi-ISA products. (Yes, chip makers have tried this before.)""For AMD, neither of these approaches is ideal, and while the company could theoretically implement an x86 cluster and an ARM cluster on the same die (switching between them at boot), that’s another mediocre solution that sacrifices die space for compatibility but risks two mediocre CPU clusters ending up side by side rather than one amazing product. In its discussions, AMD is clear that it’s targeting something unique, something that would leverage its IP and particular strengths — so let’s take a look at two options for what that might be."
"A dual x86/ARM SoC could accomplish that if AMD can build a sufficiently elegant architecture. It’s not as crazy an idea as it sounds at first glance — much of the research going on in computing today is focused on improving performance by spinning workloads off to the right core at the right time. Ideally, an initiative like this would establish AMD as the go-to community with comprehensive ISA support that could unify the fractured computing ecosystem.We won’t know if a chip like this is in the cards for quite some time, but given the direction AMD is headed and its previous public comments, we’d be stunned if it wasn’t. The company has poured too much effort into redefining itself as the heterogeneous compute leader of the future to balk at the idea of a truly heterogeneous ARM-x86 SoC."
forrás:
AMD’s next big gamble: ARM and x86 cores working side by side on the same chip ( 2014 ! ) -
S_x96x_S
Petykemano #5111 üzenetére
> Viszont ha úgy alakulnak az ügyféligények, akkor kiszolgálják.
szerintem:
1.)
Cloud -ban már most is valós ügyféligény lehet a heterogén - át-konfigurálható - architektúra.
Vagyis bootoláskor eldönti a gép, hogy most X86 vagy ARM ISA legyen.
az új X3D technológiával - tudnak egy réteg X86 és egy réteg ARM -ot csinálni, de mindig csak az egyik lenne aktív.
Lehet, hogy 20%-al többe kerül a proci, de jobb lesz a gépek kihasználása ( Memoria, ház, disk, .. )
és jobban le tudják követni az igényeket.2.)
Ott van az nVidia ARM-es Cloud -os terve .. hogy az ARM Szerver piacra betör - a saját gyorsítóival.
És az AMD-nek el kell happolnia az nVidia elől a piacot!
és erre szerintem a dual-X86-ARM proci lehet az ideális - csodafegyver.
3.)
De az is lehet, hogy az Intel lépi meg elősször.. ( az nVidai miatt .. )
és az AMD kénytelen lesz követni ..Vagyis szerintem a piaci nyomás miatt - lesz duál-X86-ARM proci!
racionális, kivitelezhető .. és szerintem már dolgoznak rajta. -
S_x96x_S
Petykemano #5108 üzenetére
> /konkurencia/ ... ARM ...
ki tudja ...
soha ne mond, hogy soha ...
Szerintem kezdi felkészíteni a piacot .. az AMD-s ARM-es procikra.
Főleg, hogy a Xilinx miatt - az ARM úgyis aktuális lesz."AMD Interested In Entering Telecommunications Sector As CEO Doesn't Rule Out Arm-based Products For Enterprise Use"
https://wccftech.com/amd-ceo-optimistic-for-arm-based-products-tight-supply-chains-5g-market/LisaSu:
". . .So I actually think it's less about ARM versus x86 and more about do you have the right compute at the right performance point, the right price point, with the right features and functions. And so that's how we see this market evolving. So there's definitely a place for ARM in the data center. I think we have deep relationships with all of the data center customers, and we're talking to them about what do they need over the next 5 years. You'll see AMD add more points to our compute road map as well to optimize for some of these different workloads. And I think the value is really in how you put things together.
And so from an AMD standpoint, we consider ourselves sort of the high-performance computing solution working with our customers. And that is certainly the way we look at this. And if it means ARM for certain customers, we would certainly consider something in that realm as well. But we look at it as really, let's talk about what problem you're trying to solve. And then we'll work with you with the best components to address the customers' needs. So that's how we think about our differentiation, and it is an exciting place in compute. So there's a lot of people who are active in the space because there's just so much need for different optimization points." -
S_x96x_S
Lehet, hogy mégis lesz Warhol ( ZEN3+ )
https://twitter.com/KittyYYuko/status/1396241079913959426GTranslátorral fordítva:
"AMD seems to have resumed the Warhol project, but it's still 7nm on the roadmap. It will be a 6nm process."@1usmus : " Confirm"
A nagy kérdés, hogy mikor jön a ZEN4 .. mert addig is kell valami.
S_x96x_S
mintha az első AM5-ös chipset - nem PCIeGen5 -ös lenne ..
vagy ez még ZEN3+ -os mag ..Lehet, hogy hasonló lesz az átmenet mint az AM4 megjelenésekor, az "A"-s procikkal.
AM5 😏
- LGA-1718
- Dual-channel DDR5
- PCI-e 4.0
- 600 series chipset
https://twitter.com/ExecuFix/status/1396185408904564738----------------------------------------------------------------------------------------------------
-- videocardz-os link:
https://videocardz.com/newz/amd-next-gen-am5-platform-to-feature-lga1718-socket
"PCI Express Gen5 support is to be exclusive to Zen4 Genoa (EPYC) processors. This means that the next-gen AMD consumer processors will retain PCIe Gen4 support. AMD AM5 processors are to compete with Intel Alder Lake-S, which is now confirmed to support PCIe Gen5 interface as well as DDR5." -
S_x96x_S
CXL - AMD analógiával ..
"There can be PCIe Gen5 devices, but many PCIe Gen5 (or PCIe 5.0) devices will also support the ability to run lanes in either PCIe or CXL modes. In some ways, this is analogous to how AMD EPYC CPUs can run their I/O lanes as either PCIe or as Infinity Fabric. Instead of being a vendor-specific implementation, this is going to be a broad industry standard. The key advantage of CXL is it allows load/ stores to happen to memory that is directly attached to different endpoints which is what we are going to get into next."
STH 2021May21: Compute Express Link or CXL What it is and Examples
S_x96x_S
> 1 év szerintem nagyon optimista...
lehetséges
ezen nem veszünk össze ..Az AMD nincs könnyű helyzetben ezen a téren. és a pici R&D költségből se túl sok jut erre.
Az Intel is megfontoltabb már .. pl. a ClearLinux támogatását visszavették.
És a ClearLinux Desktop vonalat beszüntették .ettől még tény, hogy a leggyorsabb linux AMD ZEN3-ra is
az Intel támogatott ClearLinux
Phoronix 2020Dec: The Fastest Linux OS For AMD Ryzen Zen 3? It's Still Intel Clear Linux
"If taking the geometric mean of all 107 tests, Clear Linux was about 15% faster than the other Linux distributions tested in their out-of-the-box / stock configuration for this comparison atop the AMD Ryzen 9 5900X. This doesn't come at all surprising to us given the past successes we have seen with AMD CPUs on Clear Linux, but just fun to see it still being in good shape for Zen 3 and after Clear Linux has been divesting their desktop interests. Fedora Workstation 33 meanwhile was in last place for the geometric mean average."Ez az X86 kompatibilitás paradoxona - előnye ..
ZEN3 cpu-n használhatod az Intel által fejlesztett ClearLinux -ot -
S_x96x_S
> Amd-nek nincs valami saját fordítója azzal nem lennének jobb értékek ?
ki kell próbálni: https://developer.amd.com/amd-aocc/
és akinek fontos a teljesítmény, biztos ki is fogja próbálni.szubjektív vélemény: valamiben biztos jobb lehet, de mindenben nem ..
Ráadásul az AOCC "Based on LLVM 12.0 trunk (llvm.org, 22-October-2020)"
mig a "hivatalos" LLVM 12 - 15 April 2021 jelent meg..
vagyis kb. fél év javításait/optimalizációját nem tartalmazza az AOCCA legnagyobb probléma, hogy a Linux csomagok ( Ubuntu,Debian,RHEL,CentOS,SLES,...)
általános fordítót használnak. nemigen fordítják újra native ZEN3-as AMD-re.
Míg egy nagy cég megengedheti, hogy 2-3 embert alkalmazzon - ezek karbantartására és tunningolására, de a legtöbb felhasználó ezt nem engedheti meg magának.amúgy
Az "x86-64 Microarchitecture Feature Level" lehet az egyik praktikus megoldás,
amikor utasításkészlet alapján 4 csoportba osztják az X86-os procikat.
https://www.phoronix.com/scan.php?page=news_item&px=GCC-11-x86-64-Feature-Levelsx86-64 : CMOV, CMPXCHG8B, FPU, FXSR, MMX, FXSR, SCE, SSE, SSE2
x86-64-v2: (close to Nehalem) CMPXCHG16B, LAHF-SAHF, POPCNT, SSE3, SSE4.1, SSE4.2, SSSE3
x86-64-v3: (close to Haswell) AVX, AVX2, BMI1, BMI2, F16C, FMA, LZCNT, MOVBE, XSAVE
x86-64-v4: AVX512F, AVX512BW, AVX512CD, AVX512DQ, AVX512VL
A ZEN3-as a x86-64-v3
A ZEN4-es meg várhatóan x86-64-v4 lesz ..ezen felül még - AMD és Intel-re is osztani - nem sok praktikus értékkel bír
( az átlag felhasználónak )
S_x96x_S
kb. 1 évnek el kell telnie,
mig a szoftveres ökoszisztéma kezdi utolérni a ZEN3-at.
de ez sajnos lassú folyamat ..
mindenesetre a szerver szinten a szoftveres tunning szintén érdekes elfoglaltság - hogy milyen opciókkal lehet maximalizálni a teljesítményt.LLVM Clang 12 Compiler Is Performing Very Well For AMD Ryzen 9 5950X / Zen 3
https://www.phoronix.com/scan.php?page=article&item=5950x-clang12-gcc11&num=1
S_x96x_S
"AMD Ryzen 6000 notebook roadmap leaks, 6nm Rembrandt with Zen3+ and Navi2 in 2022"
https://videocardz.com/newz/amd-ryzen-6000-notebook-roadmap-leaks-6nm-rembrandt-with-zen3-and-navi2-in-2022"AMD Rembrandt-H will launch in 2022 on the new FP7 socket. The roadmap confirms it would utilize a 6nm fabrication process as well as the new Zen3+ core architecture. These 45W TDP processors are to support PCIe Gen4, LPDDR5, and DDR5 memory as well as USB4. A low power (15W) Rembrandt-U variant is also to be expected featuring identical specifications."
S_x96x_S
Petykemano #5075 üzenetére
> Ez úgy hangzik, mintha cserélnék az IO lapkát TSMC-nél gyártottra,
> de az nem feltétlenül jelent előrelépést semmiben.Ez szerintem még GloFo lehet ..
a meglévő generációt nem sok értelme lenne átvinni TSMC -re ..
másrészt most kapacitáshiány van minden szinten ..A következő generációnál viszont szóba jöhet ...
A stratégiai döntés : az AMD a GloFO vagy a TSMC Interposerjét választja a HBM kapcsán. -
S_x96x_S
AMD hivatalos válasz a B2 stepping kapcsán
igyekszenek alacsonyan tartani a várakozásokat ..."As part of our continued effort to expand our manufacturing and logistics capabilities, AMD will gradually move AMD Ryzen 5000 Series Desktop Processors to B2 Revision over the next 6 months. The revision does not bring improvements in terms of functionality or performance, furthermore, no BIOS update will be required.
— AMD spokesperson to Benchmark.pl"AMD Ryzen 5000 “Vermeer” on B2 stepping is only to improve production and availability
https://videocardz.com/newz/amd-confirms-b2-stepping-for-ryzen-5000-series-brings-no-functionality-or-performance-improvements -
S_x96x_S
Petykemano #5066 üzenetére
"There is no further information, but it is likely to remain the best gaming cpu until zen4 comes out."
az I/O feltunningolása elméletben elképzelhető ..
és akkor a ZEN3(+) chiplet-ek is maradhatnak.De ami a lényeges:
a PCIe GEN5 és a DDR5 -höz nem árt egy új alaplap is.
és akkor már új foglalat is kell.
és erről még semmi hír.Én Gen5 - nélkül nem tartanám versenyképesnek ..
( Az Intel idén novemberben kijön az Alder Lake-el + új Xe GPU -val ?)legalábbis remélem,
hogy a " the best gaming cpu until zen4 comes out.""
nem a " the best AMD gaming cpu until zen4 comes out." - akar lenni -
S_x96x_S
egy kicsit régi roadmap ..
AMD EPYC 7004 with 64+ cores
We received a slide showing a (very) old roadmap featuring Zen4 embedded products.
https://videocardz.com/newz/amd-embedded-roadmap-for-2020-2023-lists-zen4-epyc-with-64-coresés ez is régi ..
S_x96x_S
Az Intel új CEO -ja gratulál Lisa Su-nak.
És Lisa Su kétértelműen válaszol ..
azta paszta .."Congratulations @LisaSu
on the 2021 Robert N. Noyce medal. Your continuing accomplishments truly demonstrate the critical role semiconductors play in our digitized global world. #IEEEAwards2021"
https://twitter.com/PGelsinger/status/1393211312335818754Lisa Su válasza:
"Thanks Pat for the kind wishes. Completely agree on the critical role of semiconductors !" -
S_x96x_S
ahogy várható volt .. GloFo -val szabadabb szerződések várhatóak.
a régi chipek és az i/o die - jelenleg még 12nm-en a GloFo -nál van."AMD and GlobalFoundries Update Wafer Supply Agreement: Orders Through 2024, Now Non-Exclusive"
https://www.anandtech.com/show/16677/amd-and-globalfoundries-update-wafer-share-agreement-through-2024"Still, it’s somewhat difficult to imagine AMD needing over a billion dollars in last-gen logic and I/O dies going into the next three years. In 2019 we remarked that “AMD's needs for such a large node (or GlobalFoundries' other specialized nodes) in the 2022-2024 timeframe are not nearly as obvious” and that remains true to this day. So it will be interesting to see if AMD places enough orders to use all of that capacity, or whether they'll end up leaving some of it on the table."
S_x96x_S
S_x96x_S #5055 üzenetére
A Samsung az AMD-t is megemliti a sajtóközleményben.
úgyhogy van még remény .."Dan McNamara, senior vice president and general manager, Server Business Unit, AMD, added, “AMD is committed to driving the next generation of performance in cloud and enterprise computing. Memory research is a critical piece to unlocking this performance, and we are excited to work with Samsung to deliver advanced interconnect technology to our data center customers.”"
S_x96x_S
Ez a CXL ütős lesz ..
( A PCIe Gen5 -nek sokkal -de sokkal alacsonyabb a latency-je . ugyhogy
készülhetünk a memória bővítőkre )Samsung CXL Memory Expander with DDR5 Launched
( SCM = Storage Class Memory )
https://www.servethehome.com/samsung-cxl-memory-expander-with-ddr5-launched/ -
S_x96x_S
csak lesz valami új proci ... feltételezve az új chipset alapján
( avagy ahol lószar van - ott kell lennie egy póninak is .. )MSI X570S Motherboard Lineup For AMD Ryzen AM4 Desktop CPUs Leaks Out, First Fanless X570 Board Pictured Too
https://wccftech.com/msi-x570s-motherboard-lineup-amd-ryzen-am4-desktop-cpus-leaks-out/És az AMD EPYC szerver részesedése 8.9%
Idén szerintem meglesz a 11%.( főleg, hogy az év elején 3 hónap alatt 1.8% -al nött )
Persze ehhez az Intelnek is lesz 1-2 szava - az év végi Gen5/PCIe5 -ös felhozatallal.Az év végén lezárul a XILINX -es akvizició, és annak szintén lesz egy pici pozitiv szinergetikus hatása - a jövő évre ..
S_x96x_S
a nemzetközi helyzet fokozódik ..
AMD Rembrandt with Zen3+ and RDNA2
AMD Ryzen 6000 mobile series beginning to leak.
https://videocardz.com/newz/amd-ryzen-9-6900h-rembrandt-rumored-to-feature-zen3-cores-and-12-rdna2-compute-units
"The only Zen3+ that I've seen is the 6nm one in Rembrandt" -
S_x96x_S
Petykemano #5037 üzenetére
> Raphael: 2022Q4
> Hát ez eléggé lelombozó.Az új ( AM5 / nextEpyc ) alaplapok fejlesztése / tesztelése ..
sokáig tart .. kb fél-1 év ..
főleg a szerver vonalon hosszú a validálás.
Ráadásul az új technológiák: Gen5/DDR5/CXL is bekavarnak.
Nem tudom, hogy az Intel - hogy lesz képes 2022Q1 -re kijönni vele.sajnálom ... valami lehet a háttérben - amiről nincs infónk ..
Remélem nem valami extrém technikai nehézség.de akkor a legvalószínűbb
a 7nm Ryzen 5000 XT Refresh,
amit a marketingesek -
lehet, hogy átneveznek az utolsó pillanatban 6000-re_ALternative teória_ - minden alap nélkül:
Az AMD át-prioritizálta a termékfejlesztési sorrendet -
és szerverrel ( ZEN4 Genoa ) -el jön ki 2022Q2?-ben.
Lehet, hogy nem lesz elég N5(P) kapacítás ..
mert már tulrendelték az OEM és Cloud -os Enterprise ügyfelek,
emiatt a Consumer Desktop vonalon fél évvel később jönnek ki.
Az is lehet, hogy N5 - nem megy 4.0Ghz felé ..
és az N5P kapacitás később lesz.
Viszont szervernek lehet, hogy megfelel a 3-3.5Ghz is.A Stratégia váltást a 2021Q1 -es eredmény is alátámaszthatja ..
amikor az OEM és a CLOUD ügyfelek kaptak teljes prioritást
és a Consumer piac alig kapott valamit."AMD Reports Q1 2021 Earnings: Firing on All Cylinders and Setting Records"
https://www.anandtech.com/show/16645/amd-reports-q1-2021-earnings-firing-on-all-cylinders
"Meanwhile AMD’s Enterprise, Embedded, and Semi-Custom segment has seen an explosion of growth of its own over the past year, thanks to the launch of AMD’s third-gen EPYC (Milan) processors, as well as the 9th generation consoles. "vagyis lehet, hogy váltás történik
és a desktop first -ből a desktop last - lesz ..de ki tudja..
S_x96x_S
Mindfactory 2021Apr statisztika.
https://imgur.com/a/o5V8gjzahhoz képest .. elég sok Ryzen 5900X, 5950X -et eladtak.
S_x96x_S
annó ..
ITANIUM ...an EPIC Architecture ami befuccsolt ..
ráadásul az AMD 64 bites újjításának hatására is ..
https://hu.wikipedia.org/wiki/Intel_Itaniumde az AMD "EPYC" elnevezése nagyon hasonló.
Lehet, hogy az Intel "EPIC Architectura" -ra
egy újabb marketinges fricska?
S_x96x_S
hokuszpk #5032 üzenetére
> aszondod a Xilinxxel megvan a 10% ?
szerintem megvan .. ( és lehet, hogy a 11-12% -is.)
és mivel a GlobalFoundries+AMD szerződése 2021-ig tart, lehet, hogy a TSMC emiatt is körbeudvarolja az AMD-t.
Ha a GloFo 12nm+ nem lesz hosszabítva 2022-23 -ra, akkor
új I/O die lesz .. TSMC alapon.
és a régi /olcsó csipeknek /Chipset-eknek is kell valami alternativa.
vagy valami erőltetett áttérés lesz.-------------------------
A xilinx 3nm-en is elég agressziv, hogy nevesítsék.
TAIPEI (Taiwan News) — Taiwan Semiconductor Manufacturing Co.’s (TSMC) upcoming 3 nm process is reportedly already fully booked until 2024.TSMC is planning to release its 3 nm chips in four waves, the first of which will be allocated to its largest client — Apple — according to TechNews. The following three waves of production will be split between AMD, NVIDIA, Xilinx, Qualcomm, and others.
The Taiwanese foundry is investing around NTD$2 trillion (US$71.6 billion) into its 3 nm process technology, which is slated to enter risk-production sometime this year, with an eye on commercial production during the second half of 2022. Initially, monthly 3 nm production capacity will begin at around 55,000 wafers, and by 2023 that should increase to 105,000 wafers."
https://www.taiwannews.com.tw/en/news/4119659 -
S_x96x_S
Mumukuki #5028 üzenetére
> Pont ez a baj hogy van miből locsolni bele a pénzt ,
> így simán egy jó darabig ki tudják fúrni a többi megrendelőt a gyártótólakinek van pénze, az diktál
a mellékhatása:
- egyben elő-finanszirozza a következő technológiai fejlesztést is.
- meg besegít a TSMC-nek a tesztelésben. ( nem kevés meló az se )
https://www.extremetech.com/computing/321012-amd-may-soon-become-tsmcs-second-largest-customer-by-revenue
viszont az AMD egyre inkább prioritizált ügyféllé lép elő a TSMC-nél.
- a Xilinx -el egyesülve elég nagy volument jelentenek majd.
- egyenlőre Hűséges - nem ugrál mint az nVidia - aki a Samsung-al is flörtöl.
- és mivel az Intel erőss riválisa szeretne lenni a TSMC-nek, ( a FAB-ben) emiatt egyben természetes stratégia szövetségese lett az AMD az Intellel szemben. -
S_x96x_S
TSMC EPYC szervereket használ .. hogy ..
TSMC Uses AMD's EPYC Chips to Make Chips
https://www.tomshardware.com/news/tsmc-uses-epyc-for-mission-critical-fab-tools -
S_x96x_S
Mumukuki #5022 üzenetére
> Ha a köcsög apple nagyon elhúz , az mindenkinek rossz jövőt jelent.
Szerintem a verseny - úgy általában .. jó .. függetlenül, hogy most az AMD - hogy szerepel benne.
Valamint az ARM ISA is elég jó .. nem véletlenül, hogy az nVidia meg akarja szerezni.
az X86-A64 -nek a legnagyobb előnye a bináris szoftver kompatibilitás
de ez egyben a béklyólya is .. mert visszamenőleg mindent támogatnia kell ( 8bit / 16 / 32 --> 64 bit )és bár sok mindenért lehet kritizálni az Apple-t .. -
az a tény, hogy elhúz az Apple ..
sokkal inkább a versenytársakat minősíti ..
( Intel-t és persze az AMD-t )az AMD-nek
az Apple / Intel és a többi ARM chip gyártóval is versenyezni kell
és ez remélhetőleg kihozza a legjobbakat az AMD-ből.
A prés alatt születik a gyémánt is.Lisa Su diplomatikusan megválaszolta ( de mivel az Apple az egyik ügyfelük. ( GPU vonalon ) .. az udvariasság elvárt tőle is .. )
Lisa Su: ‘The M1 is more about how much processing and innovation there is in the market. This is an opportunity to innovate more, both in hardware and software, and it goes beyond the ISA. From our standpoint, there is still innovation in the PC space – we have lots of choices and people can use the same processors in a lot of different environments. We expect to see more specialization as we go forward over the next couple of years, and it enables more differentiation. But Apple continues to work with us as their graphics partner, and we work with them.’
ez az én pragmatikus nézőpontom.
Azért reménykedem, hogy az AMD valamit villant majd a ZEN4-el is ! -
S_x96x_S
még ha idén csak a refresh várható 5000 XT ..
azér remélem, hogy az év végén - legkésőbb - a következő év kora tavasszal beüt az új ZEN4 .. a már fejlettebb N5P-n.
------------------AMD Ryzen 6000 ‘Warhol Zen 3+’ CPUs Reportedly Cancelled, Red Team To Focus on 7nm Ryzen 5000 XT Refresh & 5nm Raphael Zen 4 Chips Instead
https://wccftech.com/amd-ryzen-6000-warhol-zen-3-desktop-cpus-reportedly-cancelled/ -
S_x96x_S
Mumukuki #5018 üzenetére
> apple M1 fogyasztás / teljesítmény
azért remélem, hogy az AMD is hamarosan megcélozza az N5P-t
és pariban lesz az új Apple cpu-val.It does, however, highlight how its standard N5 and N5P will differ when comparing the last-gen 7nm FinFET node.
- N5 - 15 percent performance improvement, 30 percent reduction in power consumption
- N5P - 20 percent performance improvement, 40 percent reduction in power consumption
https://wccftech.com/apple-m1x-m2-specs-features-release-date-more/ -
S_x96x_S
- ebből nem következik, hogy csak 1 évet töltene 5nm-en.
- nincsenek dátumok a spekulációs roadmap-hez.
- folyton változik minden. ( külső és belső dolgok )A cégek manapság - párhuzamosan több projektet is futtatnak ..
egy biztonságosat és egy kockázatosat
és az utolsó pillanatban elkaszálják a kevésbé jót.
vagyis e mellett lesz egy másik belsős projekt is.
( egy vagy több B-terv. )Ha a TSMC -nél jól megy az átállás .. és lesz elég kapacitás a 3nm-re,
akkor a mobil szegmensben ( a big.Little alapján következtetve)
lehet, hogy kijönnek a 3nm-rel a fogyasztás miatt.
de emelett a desktop és a server oldalon a big.Little -nek kevesebb értelme van - ott a fogyasztás kevésbé fókusz - vagyis az a rész elég homályos még, hogy merész kijelentéseket tegyünk.De mi van, hogyha a TSMC szerencséje megszakad ..
kicsi az esélye, de erre is kell stratégia. -
S_x96x_S
> 5nm en csak 1 évet töltene és ugrana 3nm-re ?
- még azt se tudjuk pontosan mikor jön ki 5nm-en ..
- meg amúgy is 3 év múlva lesz 2024.
- hogy jött ki neked az 1 év? 2023-ban jön az 5nm? Ajajj .."According to the report, AMD Zen5 “Strix Point” is set to launch in 2024, but as mentioned in the article, it is too early to talk about
a platform 3 years from now," [link] -
S_x96x_S
Busterftw #5006 üzenetére
> Itt az Intel 10nm Superfin vagy az elso verziok?
az első ..
a Superfin-ről nem találtam adatot .. vagy csak felületes voltam ..de következtetni nem nagyon lehet a superfin-re.
pl. az is lehet, hogy a tunningolás során
csökkentették a sűrűséget a superfin-nél.mert 14nm++ -en pl. ez volt.
44.67 MTr/mm -ről levitték - 37.22 MTr/mm² -re.""
Intel's 22 nm process (2012) had 16.5 MTr/mm²,
14 nm process (2014) had 44.67 MTr/mm², and
14++ nm process had 37.22 MTr/mm².
https://en.wikichip.org/wiki/mtr-mm%C2%B2#Example -
S_x96x_S
sok ez mára - AMD big.LITTLE
és még ma várható az AMD negyedéves is.AMD “Strix Point”: Zen5, 3nm, big.LITTLE
An interesting (and unverified) rumor about AMD Ryzen 8000 CPUs based on Zen5 architecture has been just shared Moepc."Zen 5 APU “Strix Point” belongs to Ryzen 8000 series (at the time of writing), and it will adopt big.LITTLE like Intel’s Alder Lake and Raptor Lake, with 8 big Zen 5 cores and 4 little cores. It’s scheduled to be launched in 2024.
— Moepc (translation)" -
S_x96x_S
Petykemano #5008 üzenetére
> Szóval az AMD felkötheti a gatyát.
ajajj
papiron - szinte minden újdonságot beleraktak.
N5, CCIX 2.0, CXL compatibility, Gen5, DDR5, HBM3, up 256 core / die
https://www.anandtech.com/print/16640/arm-announces-neoverse-v1-n2-platforms-cpus-cmn700-meshannyira túl jó számok .. hogy az AT -ből előjött a szkeptikusság
"Usually, I’m more open to Arm’s performance projections, however this time around the V1 and N2’s performance projections are extremely optimistic, especially since they’re completely dependent on the vendors achieving good implementations on N5 and actually reaching the projected 40% perf/W process node and implementation power efficiency gains. Based on what I’ve seen in the mobile space, I remain quite sceptical, and will be adopting a wait & see approach this time around."...
The star of the show today was I think the CMN-700, and the vast new flexibility it allows vendors to achieve. The new architectural improvements and the move towards CCIX 2.0 and CXL are definitive big advances that will allow licensees to create more exotic designs. At the very least, it allows for effective usage of chiplet architecture designs, which is a much-needed feature that vendors need to adopt to be able to ensure affordability and manufacturability of products on leading edge nodes.
I’ll be looking forward to new V1 and N2 designs in 2022, and hope we’ll hear more details from licensees through the course of the year." -
S_x96x_S
TSMC Update: 2nm in Development, 3nm and 4nm on Track for 2022
https://www.anandtech.com/show/16639/tsmc-update-2nm-in-development-3nm-4nm-on-track-for-2022
"It is not particularly surprising that TSMC's N5 is gaining market share among adopters of leading-edge technologies. Analysts from China Renaissance estimate that
TSMC's N5 features a transistor density of around 170 million transistors per square millimeter (MTr/mm2),
which if accurate, makes it the densest technology available today.
By contrast,Samsung's Foundry's
5LPE can boast with about 125 MTr/mm2 ~130 MTr/mm2,
whereas
Intel's 10 nm features an approximately 100 MTr/mm2 density."
-------------gyorsan csináltam egy gyüjtést - nagyjából így nézhet ki a rangsor:
Samsung’s 8nm 61.2 (MTr/mm²)
TSMC 7nm (HPC) 66.7 (MTr/mm²)
Samsung’s 7nm EUV 95.3 (MTr/mm²)
TSMC’s 7nm (Mobile) 96.5 (MTr/mm²)
INTEL 10nm 100.0 (MTr/mm²)
TSMC’s 7nm+ EUV 115.8 (MTr/mm²) ~N6 is e-körül
Samsung 5LPE 125.0 (MTr/mm²)
TSMC’s 5nm EUV 171.3 (MTr/mm²)
INTEL 7nm 237.0 (MTr/mm²)
TSMC's 3nm 291.2 (MTr/mm²)
vagyis relative az Intel 10nm -e elég versenyképes az új N7 / N6-hoz képest is .. -
S_x96x_S
8 magos EPYC-ek összehasonlítása -. ( phoronix )
Az átlag +17% .. de az átlag mindig csalóka
.. valamikor több ( akár +85%! )
.. valamikor kevesebb ( csak +2.9% )"Or if taking the geometric mean of every single benchmark carried out, the AMD EPYC 72F3 came out to being about 17% faster than the EPYC 7F32, which is still good considering the same core and base clock speeds."
S_x96x_S
Az 5Gzh - hihető a ZEN3+ -ra
Az emlitett ZEN2 -> ZEN4 IPC +45% , annyira nem sok ;
A ZEN3+ -> ZEN4 -re kb ~10% növekedés jön ki ..
Valamint nagy kérdőjel. hogy az 5nm -en elérhető -e már az 5Ghz."Rumor | AMD Ryzen 6000 Warhol could hit 5 GHz with 9-12% gains over Zen 3 to take on Alder Lake; Ryzen 7000 Raphael may offer up to 45% higher IPC than Zen 2 to maintain leads over Raptor Lake"
( RedGamingTech forrás )
"Coming to Zen 4 Raphael Ryzen 7000, Paul feels that the core count for mainstream will continue to top-out at 16 cores and 32 threads. However, we might see a 40-45% performance increase from Zen 2 to Zen 4 owing to DDR5 memory, the 5 nm process, and possibly improvements to the cache, branch prediction, etc."
https://www.notebookcheck.net/AMD-Ryzen-6000-Warhol-could-hit-5-GHz-with-9-12-gains-over-Zen-3-to-take-on-Alder-Lake-Ryzen-7000-Raphael-may-offer-up-to-45-higher-IPC-than-Zen-2-to-maintain-leads-over-Raptor-Lake.533613.0.html -
S_x96x_S
mélyvíz: ZEN optimalizáció - szoftverfejlesztőknek.
video "AMD Ryzen™ Processor Software Optimization (Presented by AMD)" 25 perc; 2021 apr 21 ( ZEN2,ZEN3, .. )
https://www.youtube.com/watch?v=2p-UpVc1qZQ
website: Ryzen performance guide
https://gpuopen.com/ryzen-performance/
vannak benne a teszteléssel kapcsolatos tippek is.
"Determine if CPU-bound
Typically, the application is CPU-bound if GPU Idle > 5%
- Look for bubbles of idle work on the GPU in tools such as RGP, GPUView, and the Visual Studio Concurrency Visualizer.
S_x96x_S
kezd érződni az AMD hatás is ( persze gyártási problémák mindenütt ..)
INTEL .. data center .. -20% ??
" also reported a sudden slump in data center sales that found revenue dropping 20%, a record for the segment, as the number of units shipped and average selling prices both declined dramatically. Intel also posted its lowest profitability for its server segment in recent history, which surely is exacerbated by AMD's continuing share gains and Intel's resultant price cuts."
https://www.tomshardware.com/news/intel-q1-2021-earnings-pcs-up-data-center-revenue-plummets -
S_x96x_S
AMD EPYC 7003 Series Performance In The Cloud With Microsoft Azure HBv3 HPC VMs
https://www.phoronix.com/scan.php?page=article&item=epyc-azure-hbv3&num=1""
Out of 63 tests ran across all five Azure HPC virtual machine generations tested, the EPYC 7V13 powered HBv3 virtual machine was the obvious winner overall. When taking the geometric mean of all the raw benchmark results, the Azure HBv3 was 32% faster compared to the prior generation Azure HBv2 that offered similar performance to the Xeon Scalable powered Azure HC. The uplift isn't as dramatic as going from HBv1 to HBv2 where there was also the doubling of the vCPU/core count, but with HBv3 maintaining the same CPU count it's quite the generational lift. Also fun to note is the Azure HBv3 offering nearly 3x higher performance compared to the Azure H instance that ushered in their HPC VMs a half-decade ago
Quite exciting with the Azure HBv3 is that the on-demand pricing and other select tiers ends up being priced the same as HBv2, thus significant value to enjoy. Meanwhile the Intel-based HC VM with 44 cores is costing 17% more for the on-demand price compared to the Azure HBv3 120 core intance. (Again though depending upon the region and if going for a multi-year reserved instance, etc, pricing may come out differently. For simplicity sake, just looking at the on-demand pricing for benchmarks.) The main area where the Azure HC virtual machine was competitive to Azure HBv3 was for a subset of the AI / deep learning workloads that are optimized well for Intel Xeon Scalable / AVX-512 platforms.
S_x96x_S
AMD Ryzen 9 5950X ( Alza )
Beszállítás alatt > 5 db
Várható 2021. 04. 20. -
S_x96x_S
sötét trükkök ...
"Alienware Really Doesn’t Want You to Buy an AMD Ryzen PC"
https://www.extremetech.com/gaming/321919-alienware-really-doesnt-want-you-to-buy-an-amd-ryzen-pc
Alienware a Dell -hez tartozik - lehet, hogy csak "muszályból" árulnak,
de az is lehet, hogy AMD CPU hiányuk van."To summarize: Intel products get updated descriptions, AMD products don’t. Intel products get model number increases, AMD products don’t. Intel systems are directly described as “gaming desktops,” while AMD systems are not. Intel Aurora systems are correctly identified as offering PCIe 4.0, while the AMD Aurora R10 has never been advertised as offering PCIe 4.0 in the landing page’s spec sheet. I checked every single WayBack Machine instance saved since September 2019 as noted above. PCI-Express 4.0 support wasn’t important enough to list as a reason to buy an AMD PC, yet somehow became a reason to buy an Intel PC."
S_x96x_S
már a Dell ( az egyik legjobban - az Intel felé elkötelezett cég )
is elkezdett AMD-s laptopokat árulni ...és milyen akció Németben ..
AMD Ryzen 5 5500U - Vostro ; win10pro ; 8 GB RAM ;256GB SSD; 14 col
~ 589 EUR- akciós ( eredeti 906,15 € )
https://www.dell.com/de-de/work/shop/dell-notebooks/sr/laptops/vostro-laptops/amd-prozessor?appliedRefinements=6077 -
S_x96x_S
>> [MSRP alatt elérhető az 5800X]
> Szállításnál csak amcsi' cím választható.Az EU-ban ~422 Eur -tól ( de pár hete volt az 399 EUR -ért is )
https://geizhals.de/amd-ryzen-7-5800x-100-100000063wof-a2392525.html#offerlistpersze nálunk még nem ment br 150e alá ..
S_x96x_S
"Specifications of AMD Ryzen PRO 5000G series have been leaked"
https://videocardz.com/newz/specifications-of-amd-ryzen-pro-5000g-series-have-been-leaked
Most már tudjuk, hogy mi ..
De bajon mikor ???? -
S_x96x_S
Cathulhu #4960 üzenetére
> Az az 1TB/s brutalisan soknak tunik.
és akkor az 1.6TB/s ?
Ez a cél a 72x Arm Neoverse Zeus - magos SiPearl-nél
ami már a TSMC N6-ján készül és 2022Q4-re tervezik kihozni.
https://sipearl.com/index_en.php
" a Rhea SoC could feature up to 96 GB of HBM2E at 1.6TB/s as well as up to 6TB (using 8-Hi 16Gb-based DDR5 stacks) or 12TB (using 16-Hi 16Gb or 8-Hi 32Gb-based stacks) of DDR5 memory using two modules per channel."SiPearl's 72-Core Rhea HPC SoC to Be Made Using TSMC's N6 Node"
https://www.tomshardware.com/news/sipearl-rhea-n6-open-silicon-research ( 2021Feb)
https://www.anandtech.com/show/16072/sipearl-lets-rhea-design-leak-72x-zeus-cores-4x-hbm2e-46-ddr5 ( 2020September8)Igazából az Intel 1TB/s - lehet, hogy kevés is lesz
Főleg ha az AMD az Epyc Zen4- el is hasonlót tervez ( ~ 1.6TB/s ) -
S_x96x_S
Petykemano #4965 üzenetére
> A 6nm eléggé kis haszonnal jár.
A mostani hivatalos N6 infó szerint 2 féle mód lehet ..
- "N6 NTO" ( "new tapeout"? )
- "N6 RTO" ( “re-tapeout” ) ( minimális befektetéssel ez jár )"Our customers can adopt N6 while sustaining N7 investments. In RTO mode, die size remains the same as N7, but the yield is improved with reduced masking layers and simplified process. In NTO mode, yield improvement comes from both die size reduction with denser standard cells and masking layer reduction with EUV."
https://www.tsmc.com/english/dedicatedFoundry/technology/platform_HPC_tech_advancedTech#tbc_N6
S_x96x_S
S_x96x_S #4958 üzenetére
Ha abból indulok ki, hogy
a.) Augusztus ( után valamikor ) ---> új Threadripper
b. ) valamint nézegetve a legújabb Videocardz-os összefoglalót az AMD roadmap-ról. benne egy ilyen megjegyzéssel"The Zen3+ (unofficial name) based processors should launch later this year. We have heard some rumors that both next-gen Threadripper and Ryzen 5000 Refresh (or Ryzen 6000) might use this new node. It may explain the delay of the new Threadripper"
lassú felfogású vagyok ..
és most kezdek rádöbbeni, hogy az agusztusi Threadripper - akár már ZEN3+ ; 6nm -as is lehet ..
és talán akkor szeptemberben jön a hasonló Ryzen 6000-el és az új X570S-es alaplapokkal.( Párhuzamosan az Intel új procijaival. )
vagyis akkor a Zen3+ és 6nm a következő lépés.Persze a 6nm - valószínüleg csak a 7nm picit csiszolt verziója
( amolyan 7nm+ )
mindenesetre talán meglehet a bűvös 5GHz-es határ is.És remélem, hogy a ZEN4 procik első köre a következő év első felében (2022H1) piacra kerülnek ..
S_x96x_S
megint csepegtettek valami infót a rivális "Sapphire Rapids" -ról.
Az Intel - szinte mindent betol a következő generációba.
és ez az integrált HBM2-vel - papiron - elég ütős lesz;
nem lesz könnyű helyzetben a ZEN4 - alapú EPYC ..."Sapphire Rapids will introduce on-package 64GB HBM2 memory with bandwidth up to 1 TB/s per socket."
https://videocardz.com/newz/intel-sapphire-rapids-to-feature-up-to-56-cores-350w-tdp-and-64gb-of-hbm2-memory -
S_x96x_S
Petykemano #4956 üzenetére
> A remrandtól ki van húzva az AM rész.
> Ezért lehet DDR5, de DIY nem lehet majd kapni.jó hogy felhívtad a figyelmemet ..
jobban megnézve a másik chiphell-es ábrát .. ( kivágva alul )
tényleg nincs a Rembrandt*-ból AM4-es.
- AM5(desktop)/FP7(integrált,laptop) van feltüntetve.ha feltételezem,
hogy az oszlopok az időrendi sorrendet is meghatározzák,
akkor az első körben (idén?) a Gen4/DDR5 -ös AM5 -ök jönnek ki.
S_x96x_S
>> AMD X570S chipset
> Újabb rókabőr?a birkákat évente nyírják,
de ez már elég régi design ( 2 éves ? ) és sok frissítés ráférne.
- 2.5G LAN - alapból ..
- modernebb kivitel, alacsonyabb fogyasztás ..
- USB 4
- és lesz-e DDR5-ös változat? ( a 6000G -hez ) -> kicsi az esélye.Ha a AMD Zen3+ -al jön ki,
akkor
- a.) 6000X - i/O die -ából fabrikálják.
- b.) vagy már ASMedia 600-as ; aminek az előző év végén kellett volna megjelennie."ASMedia Technology has reportedly secured orders for AMD's 500- and 600-series chipsets, which will buoy the Taiwan-based chipmaker's sales performance in 2020 and 2021, according to industry sources.
AMD's 600-series chipsets are scheduled to be released at the end of 2020. Although ASMedia has not obtained orders for AMD's X570 chipsets that supports PCIe Gen 4, the chipmaker continues to be the maker of AMD's B550 and A520 chipsets, the sources said.
In addition to its partnership with AMD, ASMedia's USB 3.2 Gen 2x2 controller chip that supports transmission speeds up to 20Gbps is also expected to see rising demand as the chip integrated in Intel's existing CPUs can only support USB 3.2 Gen 2 that features a maximum transmission speed of 10Gbps, the sources said.
ASMedia has also begun development of a USB 4 controller chip, which is set to be released in 2020, and is expected to obtain orders from PC and motherboard brands. The US-China trade war has also sent some clients shifting orders to ASMedia for packet conversion ICs and USB 3.2 host controller chips for server CPUs, and these orders' contribution to ASMedia's revenues is also expected to gradually pick up over the next three years."
https://www.guru3d.com/news-story/asmedia-600-chipset-family-for-zen-3-available-in-late-2020.html -
S_x96x_S
pletyka .. 6000, 7000
"Ryzen 6000 would be based on 6000 Rembrandt architecture (Zen 3+) and Barcelo (Zen 3). New is the (apparent) addition of Navi graphics to Raphael, the Zen 4-based Ryzen 7000 desktop chips. According to users on ChipHell, AMD will switch to an I/O die fabricated at 6 nm with this generation. There would be n IGP in every AMD processor. Phoenix, the Ryzen mobile Ryzen 7000 chip, coming to the desktop as well, would contain a stronger, newer graphic piece based on RDNA 3. It is reported that AMD has internally set the target to achieve 50 percent better performance per watt with RDNA 3 compared to RDNA 2. The step to DDR5 memory may mean that this computing power can also be performed well in an APU."
https://www.guru3d.com/news-story/rumor-ryzen-7000-processors-all-get-integrated-graphics.htmlAmi érdekes a táblázatban - és nem tudom, hogy elírás-e.
Ryzen 6000 Warhol Zen 3+ 6 nm ddr4 PCIe4
Ryzen 6000G Rembrandt Zen 3+ 6 nm RDNA2 ddr5 PCIe4vagyis
a 6000G-s már DDR5-öt kap, a 6000X-es meg csak DDR4-et?
Ezt csak úgy tudom elképzelni,
- hogy 3-4 hónappal később jön ki a 6000G-s ;
- vagy az AM4-es DDR5-ös alaplapok hiányával.
vagy ...És az is lehet, hogy a DDR5-re már új chipset is kell ..
elméletileg a memóriavezérlő az i/o die-ban van ..
de kérdéses, hogy a gyakorlatban ez működik-e ..mindenesetre ez felemás válasz az Inteles Gen5/DDR5 -re ..
de majd meglátjuk a valóságban.
nekem igazából a Gen5/CXL -re csorog a nyálam ..
S_x96x_S
egyenlőre - menetrend szerint megy az egyesülés.
AMD and Xilinx Stockholders Overwhelmingly Approve AMD’s Acquisition of Xilinx
SILICON VALLEY, Calif. 04/07/2021
https://www.amd.com/en/press-releases/2021-04-07-amd-and-xilinx-stockholders-overwhelmingly-approve-amd-s-acquisitionÉs kikerült a friss - befektetőknek szóló reklámanyag is.
AMD+Investor+Presentation+Apr2021+Final.pdf
( created: Mon 05 Apr 2021 07:51:40 PM CEST )
( vagy ha nem jó a link itt elérhető: https://ir.amd.com/ )és a szokásos benne
* 150+ commercial and consumer notebooks expected in 2021
* epyc 3
* ryzen 5000H .. -
S_x96x_S
AMD X570S chipset
Gigabyte preparing X570S motherboards, could be for AMD Zen3+ “Warhol” CPUs
AMD could launch a new version of its X570 chipset.
"Update: Moore’s Law is Dead claims that the S stands for ‘Silent’, which implies that those boards will rely on passive cooling:"
https://videocardz.com/newz/gigabyte-preparing-x570s-motherboards-could-be-for-amd-zen3-warhol-cpus -
S_x96x_S
Petykemano #4934 üzenetére
> Vigyázó szemedet a 8 magos tiger lake -re vesd.
STH elemzés a szerver trendekről .. nem unatkozunk ...
https://www.servethehome.com/intel-xeon-ice-lake-edition-marks-the-start-and-end-of-an-era/6/
Let us pretend that we are covering the Sapphire Rapids launch in 2022, here is what we expect to be saying to be the benefits of Sapphire Rapids over Ice Lake Xeons:
- PCIe Gen5 support
- DDR5 support
- First-gen CXL support for memory pooling
- Greatly expanded core counts due to the multi-die approach
- More customization options due to the multi-die approach
- New acceleration options
- Higher TDP to go along with the additional cores
- Additional focus on local caching and memory hierarchy will be required to enable the aboveGiven just the above, one can see why Sapphire Rapids is going to be a big deal for the industry, and AMD EPYC 7004 “Genoa” is being designed to compete with Intel at Sapphire Rapids in 2022.
To be sure, AMD still has a product that is good and AMD did not take dominant share when it was clearly the better option. The fact that Intel still had ~90% market share when its competitor had more cores, lower power consumption per core, PCIe speed and lane advantages, memory bandwidth advantages, and a two-year head start on the new generation should not be lost on folks. Intel dropped prices by 60% about a year ago and is now aggressively pushing prices down as AMD has sought to raise prices to capture the extra value created by its new chips. Intel did not need to take the performance crown, it just needed to show up with something competitive again as it had in the EPYC 7001 generation.For STH readers, this is great. AMD platforms will have been in the market longer, and will therefore be a bit more mature, but Intel will quickly follow. By July 2021 we should have an extremely competitive market where pricing can make a true difference throughout large areas of the market. We mentioned that AMD’s strategy of raising prices may also have been in anticipation of needing to discount more with Ice Lake, and that will likely be true.
Overall, 2021 is the most exciting year in the server space in a decade, and this is happening just on the cusp of server architectures completely changing in 2022.
S_x96x_S
> Hát tudod azért hogy az Intel még idén 30%-ot verjen a Zen 3-ra
a Gen5/CXL a sötét ló ... a sokkal alacsonyabb latency-vel.
mert hiába gyorsabb ZEN3 core ..
ha a memória sebessége (DDR5/HBM ) és a GPU latency által nyújtott előnyök miatt a tesztek 2/3 -ban leveri a ZEN3 -as megoldásokat.Ez olyan mint az Optane memory a szervereknél.
Hiába gyengébb a XEON CPU mint az EPYC ..
ha az Optane miatt mégis gyorsabb a teljes rendszer - bizonyos fontos üzleti benchmarkokban.vagyis a lokális (CPU) és a globális ( teljes rendszer) optimumot ne tévesszük össze.
mindenesetre én óvatos lennék az AMD helyében. Az új Intel vezér tapasztalt róka .. jól fogja kijátszani a kártyáit ..
majd meglátjuk.
mindenesetre nehezebb dolga lesz az AMD-nek. -
S_x96x_S
> Ősszel jön? Nincs az papírba vésve lehet
> abból még 2022 első negyedév is.ősszel jelentik be, de bármi lehet,
de amúgy - stratégiai tervezéskor
a rivális legjobb lépésére kell felkészülni.
Nem lehet, abban bizni, hogy az Intel örökké bénázni fog.> Szóval ameddig nem jutott mindenkinek Zen 3 fölösleges a Zen 4-et
> piacra dobni.ez szerintem nem így működik és sokkal komplexebb.
Ha az Intel kihoz egy DDR5/HMB/Gen5/CXL -es új platformot, ami +30%-ot ráver a ZEN3-ra; ( nem a mag, hanem az architektúra miatt )Akkor az AMD-nek az új presztízse (~ élen haladnak a fejlesztésben) miatt is valamit válaszolnia kell - ha tud.
Az Intelnek az a célja, hogy visszaszerezze a bizalmat és nagyot durrantson a Gen5/DDR5/CXL -el
Az AMD-nek meg bele kell ronditani abbe a "képbe"... hogy mégse így van.
Akkor már senkinek se kell a ZEN3 .. mindenki a ZEN4-re vár .. vagy visszamegy Intelre.
Nem építhetsz a márkahűségre. Ha az Intel jó üzletet kínál - sokan hajlamosak elcsábulni.
- Bomba ár! Dell Latitude 7390 - i7-8GEN I 16GB I 256GB SSD I 13,3" FHD I HDMI I Cam I W11 I Gari!
- Legjobb kijelzős! ThinkPad T14s Gen 2 i5-1135G7 16GB 1000GB FHD 1 év garancia
- Samsung Galaxy S22 Plus / 8/128GB / Kártyafüggetlen / 12Hó Garancia
- AKCIÓ! EZÜST! RITKASÁG! Surface Pro 11 Qualcomm Snapdragon X Elite 16GB 512GB OLED 120Hz Gar!
Cég: CAMERA-PRO Hungary Kft.
