Iginotus
Hosszú lesz
És nem tudom mi szükséges és mi nem szoval:X.Org X Server 1.6.0
Release Date: 2009-2-25
X Protocol Version 11, Revision 0
Build Operating System: Linux 2.6.24-23-server i686 Ubuntu
Current Operating System: Linux scaleo 2.6.28-13-generic #44-Ubuntu SMP Tue Jun 2 07:57:31 UTC 2009 i686
Build Date: 09 April 2009 02:10:02AM
xorg-server 2:1.6.0-0ubuntu14 (buildd@rothera.buildd)
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Sat Jun 20 22:47:30 2009
(==) Using config file: "/etc/X11/xorg.conf"
(==) No Layout section. Using the first Screen section.
(**) |-->Screen "Default Screen" (0)
(**) | |-->Monitor "Configured Monitor"
(==) No device specified for screen "Default Screen".
Using the first device section listed.
(**) | |-->Device "Configured Video Device"
(==) Automatically adding devices
(==) Automatically enabling devices
(WW) The directory "/usr/share/fonts/X11/cyrillic" does not exist.
Entry deleted from font path.
(==) FontPath set to:
/usr/share/fonts/X11/misc,
/usr/share/fonts/X11/100dpi/:unscaled,
/usr/share/fonts/X11/75dpi/:unscaled,
/usr/share/fonts/X11/Type1,
/usr/share/fonts/X11/100dpi,
/usr/share/fonts/X11/75dpi,
/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType,
built-ins
(==) ModulePath set to "/usr/lib/xorg/modules"
(II) Cannot locate a core pointer device.
(II) Cannot locate a core keyboard device.
(II) The server relies on HAL to provide the list of input devices.
If no devices become available, reconfigure HAL or disable AllowEmptyInput.
(II) Loader magic: 0x3bc0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.4
X.Org Video Driver: 5.0
X.Org XInput driver : 4.0
X.Org Server Extension : 2.0
(II) Loader running on linux
(++) using VT number 7
(--) PCI:*(0@0:2:0) Intel Corporation 82945G/GZ Integrated Graphics Controller rev 2, Mem @ 0xffa80000/524288, 0xe0000000/268435456, 0xffa40000/262144, I/$
(II) Open ACPI successful (/var/run/acpid.socket)
(II) System resource ranges:
[0] -1 0 0xffffffff - 0xffffffff (0x1) MX[B]
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
compiled for 1.6.0, module version = 1.0.0
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 2.0
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-DGA
(II) Loading extension DPMS
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
(==) AIGLX enabled
(II) Loading extension GLX
(II) LoadModule: "record"
(II) Loading /usr/lib/xorg/modules/extensions//librecord.so
(II) Module record: vendor="X.Org Foundation"
compiled for 1.6.0, module version = 1.13.0
(II) Loading extension RECORD
(II) LoadModule: "dri"
(II) Loading /usr/lib/xorg/modules/extensions//libdri.so
(II) Module dri: vendor="X.Org Foundation"
(II) Loading extension XFree86-DRI
(II) LoadModule: "dri2"
(II) Loading /usr/lib/xorg/modules/extensions//libdri2.so
(II) Module dri2: vendor="X.Org Foundation"
(II) Loading extension DRI2
(II) Scanning /usr/share/xserver-xorg/pci directory for additional PCI ID's supported by the drivers
(II) Matched intel from file name intel.ids
(==) Matched intel for the autoconfigured driver
(==) Assigned the driver to the xf86ConfigLayout
(II) LoadModule: "intel"
(II) Loading /usr/lib/xorg/modules/drivers//intel_drv.so
(II) Module intel: vendor="X.Org Foundation"
compiled for 1.6.0, module version = 2.6.3
Module class: X.Org Video Driver
ABI class: X.Org Video Driver, version 5.0
(II) intel: Driver for Intel Integrated Graphics Chipsets: i810,
i810-dc100, i810e, i815, i830M, 845G, 852GM/855GM, 865G, 915G,
E7221 (i915), 915GM, 945G, 945GM, 945GME, 965G, G35, 965Q, 946GZ,
965GM, 965GME/GLE, G33, Q35, Q33,
Mobile Intel® GM45 Express Chipset,
Intel Integrated Graphics Device, G45/G43, Q45/Q43, G41
(II) Primary Device is: PCI 00@00:02:0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[4] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[5] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[6] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[7] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[8] -1 0 0x00000000 - 0x00000000 (0x1) IX[B]
[9] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[10] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Loading sub module "vgahw"
(II) LoadModule: "vgahw"
(II) Loading /usr/lib/xorg/modules//libvgahw.so
(II) Module vgahw: vendor="X.Org Foundation"
compiled for 1.6.0, module version = 0.1.0
(II) intel(0): Creating default Display subsection in Screen section
"Default Screen" for depth/fbbpp 24/32
(==) intel(0): Depth 24, (--) framebuffer bpp 32
(==) intel(0): RGB weight 888
(==) intel(0): Default visual is TrueColor
(II) intel(0): Integrated Graphics Chipset: Intel(R) 945G
(--) intel(0): Chipset: "945G"
(--) intel(0): Linear framebuffer at 0xE0000000
(--) intel(0): IO registers at addr 0xFFA80000
(WW) intel(0): libpciaccess reported 0 rom size, guessing 64kB
(==) intel(0): Using EXA for acceleration
(II) intel(0): 2 display pipes available.
(II) Loading sub module "ddc"
(II) LoadModule: "ddc"
(II) Module "ddc" already built-in
(II) Loading sub module "i2c"
(II) LoadModule: "i2c"
(II) Module "i2c" already built-in
(II) intel(0): Output VGA using monitor section Configured Monitor
(II) intel(0): Resizable framebuffer: not available (1 3)
(II) intel(0): Output VGA disconnected
(WW) intel(0): No outputs definitely connected, trying again...
(WW) intel(0): Unable to find initial modes
(EE) intel(0): No valid modes.
(II) UnloadModule: "intel"
(II) UnloadModule: "vgahw"
(II) Unloading /usr/lib/xorg/modules//libvgahw.so
(EE) Screen(s) found, but none have a usable configuration.
Fatal server error:
no screens found
Please consult the The X.Org Foundation support
at http://wiki.x.org
for help.
Please also check the log file at "/var/log/Xorg.0.log" for additional information.
ddxSigGiveUp: Closing log -
Iginotus
Helyes-helyes. Átettem a szerverbe. Megnézem, hogy mik futnak rajta, egy db olyan csomag sem fut ami felhasználóhoz kötött, csak a root cuccai. És a gdm-en hal be tehát az xszervert nem tudja elindítani.
Tehát valami miatt nem indítja el a megjelenítésért felelős dolgokat, holott mindig kiírja hogy már fut egy. Illetve ez nem teljesen ugyanaz mert, startx re hibát dob hogy már fut, de gdm-et le tudom álltani simán, startx viszont utána is ugyanazt a hibád adja.
Hu mire ezt megoldom valamit talán már kapiskálni fogok a Ubuntuhoz
Iginotus
Hülye kérdés merült fel bennem reggel és megint furdal, mi van ha én azt a két vinyot teletömöm adatokkal és lekezdek vadul torrentezni
Szóval kérdés Ubuntuval bebotolok ráteszem azt a maradék 4 vinyot, és elkezdek bőszen ntfs-röl ext 3 ra másolni dolgokat sérülhet e az adat? És vissza ha esetleg gond van vele
Iginotus
És miben különbözik a 2-ö? Mármint a sima és a szerver verzió?
Már csak azért, hogy ha ilyen gondom van lehet-e rá megoldás a szerver verzió.Egyébként nem spec. hardver, csak egy normál 945 ös csipszet egy 1,6 ghz-s celeron és 512 ram ez tök normális csak spéci ház van benne amire nem jutott vga kimenet.
dbius
Közben synapticban ránéztem kézzel ezekre a frissítésekre. Úgy tűnik, mintha frissebb verzió lenne elérhető, újabb csomagokra hivatkozik, de frissítésre kijelölve azt a hibaüzenetet kapom, hogy a hivatkozott csomag nem érhető el...
Közben meg most nézem, hogy ha ALT+Print Screennel mentem el az aktuális ablakot, akkor az ablakkereteket nem menti el (Ha a teljes képernyőt mentem, akkor látszanak az ablakkeretek) - Ubuntu Jaunty, gnome alatt, compiz bekapcsolva.
ez is érdekes, mert mintha korábban jó lett volna... -
#51736960
köszi, hogy segiteni próbálsz, de nem ez a gond
tudok usb-ről bootolni, puppy linuxal sikerült, de ubuntut vagy xubuntut nem birok pendrive-ra rakni úgy, hogy müködjön.
elvileg feltelepül, de újrainditáskor nem bootol be róla.amúgy a boot sequence természetesen úgy van beállitva a biosban, hogy az usb az első.
(bocs, ezen a gépen nincs hosszú "i")
floatr
Ha ez így van akkor elég az XP alatti címet kideríteni, és ezt használni az upc net indításához ubi alatt:
sudo /etc/init.d/networking stop
sudo ifconfig eth0 hw ether XX:XX:XX:XX:XX:XX
sudo /etc/init.d/networking restartahol értelemszerűen az X-ek helyére az XP alatt olvasott MAC address-t kell beírni
#51736960
nem, egyszerűen átugorja a bootolási folyamatban, és a vinyóról bootol.
amúgy elvileg a pendrive és az alaplap is usb boot képes, mivel puppy linuxal meg tudtam oldani a dolgot.
(amúgy elég lenne nekem a puppy is, de sajnos haragban van az 1950pro karimmal, és csak alacsony felbontásban megy) -
terfy
Úgy néz ki, hogy ezek a dolgok rendben vannak. Sajnos nem ezek okozzák a problémát.
Egyre inkább vmilyen hw összeférhetetlensége gyanakszom, mert ha rá vannak dugva a kártyára az új HDD-k, akkor a biosban sem tudok megmozdulni, belép és onnan, mintha lefagyott volna a gép ... Csak akkor meg az a kérdés, hogy ha később dugom rá a wincsiket, akkor miért javul meg? -
dbius
Látom már, ez úgy tűnik feature lenne, de sokaknak nem tetszik, hozzám hasonlóan.
Egy megoldás, ha valaki hozzám hasonlóan nem szeretné, ha automatikusan elindulna a frissítéskezelő, ha van frissítés, csupán az értesítési területen szertné látni a kis ikont:
gconftool -s --type bool /apps/update-notifier/auto_launch false
#16820480
mi nem tetszik a kde-ben? mi változott?
mindig kacérkodtam vele, hogy feltegyem, eddig háromszor fel is tettem, de mindháromszor repült is... elsőre rondának találtam, másodszorra nem működtek benne dolgok rendesen, harmadszorra nem tudtam beállítani dolgokat. lehet, hogy még egy ráadás kékne, és megszoknám, de már úgy belaktam a gnome-ot.viszont ape fájlokat amúgy lejátszik egy csomó más dolog. én most gnome-mplayerben nyitom őket meg, az viszi gond nélkül.
még egy kérdés eszembe jutott közben: a deluge miért csinálja azt, hogy ahányszor kikapcsolom, elfelejti az összes torrentet, amit meg volt nyitva? repoból van feltéve. lehet, hogy az a baja, hogy felhazsnáló- meg home könyvtár nevet cseréltem? de azóta újra is lett telepítve, meg be vannak állíŧva elvileg a könyvtárai.
#16820480
Major Major
Az Exaile (mivel Amarok klón) szintén megjeleníti könyvtárszerkezetben is a zenéket. Sajna ebben sem fa strikturájú, és indításkor mindig a /-ből kell indulni, de végülsi nem vészes. Van még a Quod Libet, abban is van filerendszer megjelenítés, de nekem nem jön be a felépítése.
dbius
letelt a mod idő:
most ahogy nézem a külön letöltött wubi saját magának tölti le a telepítéshez szükséges iso-t nem lehet neki megadni kézzel. (viszont így gondolom a 8.10-et szedi le automatikusan
)zolikaDB: na, megvan a jauntyhoz való wubi telepítő: [link]
Innen töltsd le a legújabbat, jelenleg r105-ös: [link]
Ezzel sztem már működni fog a 9.04-es is. Soxerencsét.
mzx
köszi!
nem tudom, kinek higgyek, de remelem igazad van, és zártak a portok alapbol livecd-skor ubuntun.
Azert paráztam itt a topicban, mert pár napja nekem valaki azt irta, hogy NYITOTTAK a portok live-cd-zés alatt... Remelem, neked van igazad, de akkor most bocsássam szavazásra a dolgot? ;) ....
Mindenesetre most már egy kicsit van bizalmam a live-cd-zős ubival NETRE IS lépni, de jo volna mihamarább minél tobb forrásbol utána néznem ennek a port zárt/nyitott dolognak...(A másik probl. szerencsére a kisebbik proléma, legfeljebb
mindent ujra állitok, reset utan; tul kicsi a vinyóm, a pendrive-m meg tul lassu, így marad a live cd megoldas; kár, h nem lehet livecd-zés alatt pendrive-ra menteni aktualis beallitasokat, mert az elfogadhato sebességgel zajlana konfigomon.) -
mzx
nah, ez is megnyugtato válasz, szoval ennyivel elobbre vagyok, koszi,
ugyanakkor szeretném megismételni: TOTÁL KEZDŐ linux user vagyok
Tehát nem tudom, HOGYAN tegyem fel leendő 1GB pendrive -mra az
ubuntu 8.10 -et live usb-t persistent módban?
Azt látom, h a napokban adtál erről valakinek linket,
és bár alapfokon birom az angolt, de amikor valamihez teljesen kezdő vagyok,
akkor csak magyar leirással boldogulok.
1)
Tehát esetleg egy magyar leirásról, hogy hogyan lehet ubuntu 8.10 -et live usb persistentként feltenni 1GB pendrive -ra
linket
tudsz adni?
2)
Valamint megismétlem másvalakire reagált hsz-emből:
tud valaki -szintén magyar- leirásról
linket
adni az ubi konzoljának (parancs sor) használatához?
(lexikonszerűen is oké, parancsokról, vagy ha csak az alapparancsokrol leiras, az is megteszi
)köszi előre is
#16820480
köszi! tényleg ott volt vagy 2 giga .deb fájl. viszont sikerült elrontani
, mert rootként megnyitott nautilusban simán "del"-t nyomtam, amitől ugyan eltűntek a fájlok, de a hely nem szabadult fel. ilyenkor elvileg ugye a szemetebe teszi a dolgokat, de rootként nincs szemetes, nem tudom most végül is hova tette azt a közel 2 gigát. -
mzx
Vladi megelőzött a köv. kérdésemmel, igy eggyel beljebb vagyok. ;)
Csak kissé elszomorodtam: totál kezdő linuxos vagyok, ezert elbizonytalanodtam, h a jövő héten megvásárlásra kerulo 1GB pendrive -omra leszek -e majd képes liv-USB persistent -et feltenni...Egyáltalán: 1GB -os pendrive -n képes mukodni a live-USB persistent?
Tehát NEM installálni akarok, hanem számomra is a live+beállitások elmentése lehetőség kell, egyelőre.
Vagy lehet, h számomra mint kezdő: esetleg kisebb gond lenne vinyót particionálnom a meglevő XP-m mellé, mint pendrive -t ?... Bár az xp-met nagyon féltem,
kezdőként nem akarom esetlegesen tonkre tenni... -
Major Major
Én totemet használok minden video lejátszásra, HDk közül eddig 720p-vel találkoztam, azzal nem volt gond, pedig nem egy mai gyerek a gépem. Ati kártyám van, a xorg driver van fent, compiz bekapcsolva. Emlékeim szerint a zárt driverrel rosszabban ment a filmlejátszás.
hcl: miért nem írod be az /etc/netwotk/interfaces fájlba a statikus IP-t?
Mikor én routernek használtam a gépet, webminnel állítottam be a szükséges dolgokat, az egy elég hasznos progi. -
zodo
Köszi a tényfeltáró összegzést.
Nem szoktam hd filmeket nézni,de sose lehet tudni. Windows alatt egy hd kamerás (1080p) koncert felvételt néztem össz-vissz. Hát meggyűlt vele a bajom, wmp meg se nyitotta vlc már igen,de 2mp útán feladta ,hibával elszállt. Végül Power Dvd 8 ultrával sikerült megnézznem,miútán bekapcsoltam a hardveres gyorsítást max.10% cpu terheltség melett. Ezekszerint a hd filmek kivételével el leszek a Vlc-el.
Sajnálattal olvasom,hogy egyenlőre nincs megoldás ubuntu alá, hd lejátszásra.
Délután,majd keresgélek, több szem többet lát alapon.
Nálam is kb. úgy akadnak a HD dolgok mint nálad. Én is végigprószáltam kb. azokat a dolgokat mint Te. Eredmény hasonló
A konzolos mplayert megnézem, lehet úgy jó lesz.Én még azt vettem észre, h minden grafikusan megjelenített dolog (film, ablakok, böngésző, bármi...) lassabb Ubin. A legalapabb .avi filmet is észrevehetően "töri" a win-hez képest. Nemrég telepítettem 1 gyengusz gépre Xubit ott még nagyobb különbség volt köztük. A winxp teljesen nézhetően stream-elte a filmet, Xubin nézhetetlen volt, ez van... (de az okára nagyon kiváncsi lennék)
Vladi
Na ennyit tudtam megnézni:
Nevezett gépen, Fedora 10 x32
mplayer-1.0-0.104.20090204svn
ffmpeg-0.4.9-0.54.20080908Film:
Complete name 1984.720p.HDTV.x264.HUN-P0NR.mkv
Format : Matroska
File size : 4.09 GiB
Duration : 1h 46mn
Overall bit rate : 5 529 Kbps
Encoded date : UTC 2008-01-05 07:56:31
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L5.1
Format settings, CABAC : Yes
Format settings, ReFrames : 11 frames
Muxing mode : Container profile=Unknown@5.1
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 46mn
Bit rate : 5 198 Kbps
Nominal bit rate : 5 200 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16/9
Frame rate : 25.000 fps
Original frame rate : 23.976 fps
Resolution : 24 bitsAkadás nélkül ment. Lazán tekergetve oda-vissza. Cpu: 70-80%-on használva.
Vladi
Azon a gépen tényleg mennie kéne. Win alatt milyen lejátszót és codecet használsz? Az is sokat jelenthet!
Hardveres gyorsítást nézegesd.Valamint esetleg próbáld ki terminálban indítani az mplayert.
mplayer film.valamiEddig csak rövidebb 720-as filemeket próbáltam, de azzal viszonylag ment a gépemen.
Nincs se ilyen filemem, se ubuntum.
rollins
Csak egy tipp, hogy hátha ezért van nálad is.
Ez milyen modem? Router vagy olyan modem ami dhcp-vel tud ipcímet osztani? Mert lehet hogy időközönként újraosztja a címet és lehet az interfész címe már nem az lesz, amit a szolgáltatótól kapott az első kapcsolódáskor. Gondolom akinek belső hálóza van, az már kialakította, péld nat vagy proxy, stb kell -e neki a belsőre a dhcpd.
Nekem péld egy D-Link modem csinálta ezt, nem tudtam elkélpzelni miért nem megy a net egy idő után, aztán kiderült csak a modem dhcp-t kellett kikapcsolni az adminfelületén.
Nem igazán értek a hálózati dolgokhoz, csak gondoltam neked is ez problém. -
dbius
viszont valami még mindig van... torrentek leállnak, azaz kliens indítása után van bejövő kapcsolat, ami fokozatosan eltűnik (úgy fél perc alatt), pedig a porttal minden rendben...
Látom, hogy próbálnak kapcsolódni, de semmi...
kipróbáltam transmission-t, deluge-t, valamint wine alatt utorentet is. Mind ugyanezt csinálja.
Vladi
Hasonló gond. Hátha ott van ötlet.
Ügyfélszolgálat?
harry
Valószínűleg nem, mint ahogy azt a bemásolt részlet is mutatja, ezért kérdezem, hogy mit jelent a Basic, és miben tér el a Sane-től. Illetve, hogy azt miképp kell felrakni, mert amit letöltöttem, majd make, make installal telepítettem, az azt eredményezte, amit bemásoltam.
harry
Ezt töltöttem le, a 0.13.1-et, és amit bemásoltam üzenetet, az már a "make install" vége volt. Csak azokat nem igazán értettem, amiket írtam. Nem tudom mi a különbség a basic/sane driverek között, ha jól értem, az előbbi fent van, tehát mennie kéne, szóval akkor a jogokkal lehet valami (bent vagyok a "scanner" csoportban).
Siriusb
Nos, ez benne van.
Amikor elindul a gnome, csak 2 munkaasztal van. Normál esetben ekkor töltődik be a conky. Ezután jön a compiz, s lesz 4 munkaasztal, de conky csak az aktívon látható. Ha a compiz betöltése után indítom a conky-t, mindenhol látszik.Köszi a linkeket, megyek csemegézni.
dbius
Na, az előbb hirtelen nem találtam, de ezt a topicot akartam linkelni, itt van pár darab conky konfig fájl, amiből lehet csemegézni
[link]Szerk: Még egy fontos dolog kimaradt.
A
.conkyrc
fájl rejtett fájl, (ezért kezdődik ponttal - linux így jelzi, hogy rejtett a fájl), erre figyelj, ha pl. nautiluson keresztül akarod megnyitni.
Siriusb
Siriusb
Én azzal kínlódom , hogy a conky csak a compiz után induljon el. Intrepid előtt a session-ben volt egy fül, ahol ezzel lehetett játszani, sajnos ez megszűnt.
Mindenestre beírtam a sleep 20 && conky-t a parancshoz, de nem csak a conky nem índult el, hanem a cpu fire applet sem.
Van még valami ötleted? Eleddig itt a fórumon sem tudott senki segíteni, és interneten sem találtam megoldást. Kösz. -
pc-user
[11323.422517] bttv0: unloading
[11350.011407] bttv: driver version 0.9.17 loaded
[11350.011420] bttv: using 8 buffers with 2080k (520 pages) each for capture
[11350.012276] bttv: Bt8xx card found (0).
[11350.012304] bttv0: Bt878 (rev 17) at 0000:01:00.0, irq: 11, latency: 132, mmio: 0xf4100000
[11350.012863] bttv0: detected: Leadtek TV 2000 XP [card=34], PCI subsystem ID is 107d:6609
[11350.012872] bttv0: using: Leadtek WinFast 2000/ WinFast 2000 XP [card=34,insmod option]
[11350.012915] bttv0: gpio: en=00000000, out=00000000 in=003ff502 [init]
[11350.014753] bttv0: tuner type=38
[11350.015101] bttv0: i2c: checking for MSP34xx @ 0x80... not found
[11350.015842] bttv0: i2c: checking for TDA9875 @ 0xb0... not found
[11350.016731] bttv0: i2c: checking for TDA7432 @ 0x8a... not found
[11350.084290] bttv0: registered device video0
[11350.084338] bttv0: registered device vbi0
[11350.084377] bttv0: registered device radio0
[11350.084419] bttv0: PLL: 28636363 => 35468950 . ok
[11350.101092] input: bttv IR (card=34) as /devices/pci0000:00/0000:00:1e.0/0000:01:00.0/input/input7Most látom, hogy elírtam fentebb a tunerkártya típusokat...
úgyhogy bocs!TvTime üzenete: nincs jel
pc-user
Az első parancsra nincs válasz.
A másodikra ez:bt878 11832 0
bttv 175860 1 bt878
ir_common 36100 1 bttv
compat_ioctl32 2304 1 bttv
i2c_algo_bit 7300 1 bttv
videobuf_dma_sg 14980 1 bttv
videobuf_core 18820 2 bttv,videobuf_dma_sg
btcx_risc 5896 1 bttv
tveeprom 16656 1 bttv
videodev 29440 1 bttv
v4l2_common 18304 3 tuner,bttv,videodev
v4l1_compat 15492 2 bttv,videodev
i2c_core 24832 9 tuner,tea5767,tda8290,tuner_simple,mt20xx,tea5761,bttv,i2c_algo_bit,tveeprom -
pc-user
00:00.0 Host bridge: Intel Corporation 82815 815 Chipset Host Bridge and Memory Controller Hub (rev 02)
Subsystem: Intel Corporation 82815 815 Chipset Host Bridge and Memory Controller Hub
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR+ FastB2B-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort+ >SERR- <PERR-
Latency: 0
Region 0: Memory at ec000000 (32-bit, prefetchable) [size=64M]
Capabilities: <access denied>
00:01.0 PCI bridge: Intel Corporation 82815 815 Chipset AGP Bridge (rev 02) (prog-if 00 [Normal decode])
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap- 66MHz+ UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 96
Bus: primary=00, secondary=02, subordinate=02, sec-latency=64
Memory behind bridge: e8000000-e8ffffff
Prefetchable memory behind bridge: f0000000-f40fffff
Secondary status: 66MHz+ FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort+ <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA+ MAbort- >Reset- FastB2B-
00:1e.0 PCI bridge: Intel Corporation 82801AA PCI Bridge (rev 02) (prog-if 00 [Normal decode])
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 0
Bus: primary=00, secondary=01, subordinate=01, sec-latency=32
I/O behind bridge: 00002000-00002fff
Memory behind bridge: e9000000-e90fffff
Prefetchable memory behind bridge: f4100000-f41fffff
Secondary status: 66MHz- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- <SERR- <PERR-
BridgeCtl: Parity- SERR- NoISA+ VGA- MAbort- >Reset- FastB2B-
00:1f.0 ISA bridge: Intel Corporation 82801AA ISA Bridge (LPC) (rev 02)
Control: I/O+ Mem+ BusMaster+ SpecCycle+ MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap- 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 0
00:1f.1 IDE interface: Intel Corporation 82801AA IDE Controller (rev 02) (prog-if 80 [Master])
Subsystem: Intel Corporation 82801AA IDE Controller
Control: I/O+ Mem- BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Latency: 0
Region 0: [virtual] Memory at 000001f0 (32-bit, non-prefetchable) [disabled] [size=8]
Region 1: [virtual] Memory at 000003f0 (type 3, non-prefetchable) [disabled] [size=1]
Region 2: [virtual] Memory at 00000170 (32-bit, non-prefetchable) [disabled] [size=8]
Region 3: [virtual] Memory at 00000370 (type 3, non-prefetchable) [disabled] [size=1]
Region 4: I/O ports at 1800 [size=16]
00:1f.2 USB Controller: Intel Corporation 82801AA USB Controller (rev 02) (prog-if 00 [UHCI])
Subsystem: Intel Corporation 82801AA USB Controller
Latency: 0
Interrupt: pin D routed to IRQ 11
Region 4: I/O ports at 1820 [size=32]
00:1f.3 SMBus: Intel Corporation 82801AA SMBus Controller (rev 02)
Subsystem: Intel Corporation 82801AA SMBus Controller
Control: I/O+ Mem- BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Interrupt: pin B routed to IRQ 9
Region 4: I/O ports at 1810 [size=16]
00:1f.5 Multimedia audio controller: Intel Corporation 82801AA AC'97 Audio Controller (rev 02)
Subsystem: Hewlett-Packard Company Unknown device 1249
Latency: 0
Region 0: I/O ports at 1200 [size=256]
Region 1: I/O ports at 1300 [size=64]
01:00.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Subsystem: LeadTek Research Inc. Unknown device 6609
Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap+ 66MHz- UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 132 (4000ns min, 10000ns max)
Interrupt: pin A routed to IRQ 11
Region 0: Memory at f4100000 (32-bit, prefetchable) [size=4K]
01:00.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Control: I/O- Mem+ BusMaster- SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B-
Region 0: Memory at f4101000 (32-bit, prefetchable) [size=4K]
01:04.0 Ethernet controller: 3Com Corporation 3c905C-TX/TX-M [Tornado] (rev 78)
Subsystem: Hewlett-Packard Company Unknown device 1246
Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV+ VGASnoop- ParErr- Stepping- SERR- FastB2B-
Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 80 (2500ns min, 2500ns max), Cache Line Size: 32 bytes
Interrupt: pin A routed to IRQ 5
Region 0: I/O ports at 2000 [size=128]
Region 1: Memory at e9000000 (32-bit, non-prefetchable) [size=128]
[virtual] Expansion ROM at f4120000 [disabled] [size=128K]
02:00.0 VGA compatible controller: nVidia Corporation NV17 [GeForce4 MX 440] (rev a3) (prog-if 00 [VGA controller])
Status: Cap+ 66MHz+ UDF- FastB2B+ ParErr- DEVSEL=medium >TAbort- <TAbort- <MAbort- >SERR- <PERR-
Latency: 64 (1250ns min, 250ns max)
Interrupt: pin A routed to IRQ 10
Region 0: Memory at e8000000 (32-bit, non-prefetchable) [size=16M]
Region 1: Memory at f0000000 (32-bit, prefetchable) [size=64M]
Region 2: Memory at f4000000 (32-bit, prefetchable) [size=512K]
[virtual] Expansion ROM at f4080000 [disabled] [size=128K]
- ÁRGARANCIA!Épített KomPhone Ryzen 7 9800X3D 64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- HIBÁTLAN iPhone 13 128GB Red -1 ÉV GARANCIA - Kártyafüggetlen, MS3760
- Pixel 7 pro 128/8
- Samsung Galaxy S25 FE 5G 256GB, Kártyafüggetlen, 1 Év Garanciával
- 157 - Lenovo LOQ (15ARP9) - AMD Ryzen 7 7435HS, RTX 4060 (ELKELT)
Cég: BroadBit Hungary Kft.
Város: Budakeszi
