Arch Linux topik
linux-firmware >= 20250613.12fe085f-5 upgrade requires manual intervention
2025-06-21 - Jan Alexander SteffensWith 20250613.12fe085f-5, we split our firmware into several vendor-focused packages. linux-firmware is now an empty package depending on our default set of firmware.
Unfortunately, this coincided with upstream reorganizing the symlink layout of the NVIDIA firmware, resulting in a situation that Pacman cannot handle. When attempting to upgrade from 20250508.788aadc8-2 or earlier, you will see the following errors:
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad103 exists in filesystem
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad104 exists in filesystem
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad106 exists in filesystem
linux-firmware-nvidia: /usr/lib/firmware/nvidia/ad107 exists in filesystemTo progress with the system upgrade, first remove linux-firmware, then reinstall it as part of the upgrade:
# pacman -Rdd linux-firmware
# pacman -Syu linux-firmware -
Transition to the new WoW64 wine and wine-staging
2025-06-16 - Peter JungWe are transitioning the wine and wine-staging package to a pure wow64 build. This change removes the dependency on the multilib repository for wine and wine-staging.
The main reason for this is to align with upstream Wine development, which simplifies packaging and the dependency chain.
Potential Issues:
OpenGL Performance: A known limitation of the new WoW64 mode is reduced performance for 32-bit applications that use OpenGL directly
Breaking Changes: Existing 32-bit prefixes needs to be recreated
If you are facing issues with 32 bit prefixes, please recreate these and reinstall the application. -
IstvánLászló #9003 üzenetére
erre nem a bootolható iso a megoldás, hanem az image.
clonezillával, vagy bármi más rendszerklónozó szoftverrel készítesz egy másolatot a rendszerről, probléma esetén meg visszaállítod.
ehhez nem kell, hogy bootolható legyen -
wwenigma #8992 üzenetére
off, de ha már említetted azt az alaplapot: pont a múlt héten raktam össze egy gépet egy ilyen lappal, és nálam azt csinálja, hogy rebootkor percekig áll egy darab kurzorral a képernyőn az OS betöltése előtt, aztán elindul. ha kikapcsolom és bekapcsolom, akkor meg normálisan, azonnal bootol.
felraktam a 2.01-es béta BIOS-t, de nem változott semmi.te tapasztaltál hasonlót?
Siriusb #8844 üzenetére
ezen felbuzdulva kisakkoztam, hogy miért nem tudok belépni Waylanddal, egy mode setting hiányzott csak.
cserébe az első loginnél rá kellett jöjjek, hogy a kedvenc KVM szoftverem nem támogatja a Waylandet, ahogy a forkja sem, és az a szoftver sem, amiből ezt forkoltákszóval: ismer-e valaki ezekhez hasonló, aktívan fejlesztett programot, ami támogatja a Waylandet?
nekem lett is egy problémám
ugye Wayland lett a default, de azzal egész egyszerűen nem tudok bejelentkezni, login után újraindul a DE és visszadob a login képernyőre.
X11-re visszatéve minden hibátlan -
úgy látom átállunk 6-os KDE-re
ennek vajh' mi baja lehet?
[root@vavatch lenry]# pacman -Syu
:: A csomagadatbázisok szinkronizálása...
core.db failed to download
extra.db failed to download
multilib.db failed to download
linuxkernels.db failed to download
hiba: nem sikerült a(z) 'core.db' fájlt letölteni a geo.mirror.pkgbuild.com helyről : OpenSSL/3.2.0: error:0A000438:SSL routines::tlsv1 alert internal error
hiba: nem sikerült a(z) 'extra.db' fájlt letölteni a geo.mirror.pkgbuild.com helyről : OpenSSL/3.2.0: error:0A000438:SSL routines::tlsv1 alert internal error
hiba: nem sikerült a(z) 'multilib.db' fájlt letölteni a geo.mirror.pkgbuild.com helyről : OpenSSL/3.2.0: error:0A000438:SSL routines::tlsv1 alert internal error
figyelmeztetés: too many errors from geo.mirror.pkgbuild.com, skipping for the remainder of this transaction
hiba: nem sikerült a(z) 'linuxkernels.db' fájlt letölteni a nhameh.ovh helyről : OpenSSL/3.2.0: error:0A000438:SSL routines::tlsv1 alert internal error
hiba: failed to synchronize all databases (letöltőfüggvénytár hiba)de nem a pacman kehes, mert egy curl vagy wget sem működik
[root@vavatch tmp]# wget https://cdimage.https://cdimage.debian.org/debian-cd/current/amd64/iso-cd/debian-12.4.0-amd64-netinst.iso
--2024-01-07 10:15:35-- https://cdimage.debian.org/debian-cd/current/amd64/iso-cd/debian-12.4.0-amd64-netinst.iso
A hitelesítésszolgáltatói tanúsítvány („/etc/ssl/certs/ca-certificates.crt”) betöltve
cdimage.debian.org (cdimage.debian.org) feloldása… 194.71.11.173, 194.71.11.165, 194.71.11.163, ...
Csatlakozás a következőhöz: cdimage.debian.org (cdimage.debian.org)[194.71.11.173]:443… kapcsolódva.
GnuTLS: A TLS fatal alert has been received.
GnuTLS: received alert [80]: Internal error
Nem lehet létrehozni SSL-kapcsolatot. -
egy ideje a linux-amd kernelt használom, és most tűnt fel, hogy emellé nem töltődik be a frissített mikrokódokat tartalmazóamd-ucode.img
.ez hiba vagy a fenti kernel egyébként is tartalmazza ezt?
vak vagyok, betöltődik -
Git migration announcement
This Friday morning (2023-05-19) the Git packaging migration will start until Sunday (2023-05-21). The Arch Linux packaging team will not be able to update packages in any of the repositories during this period. -
bekerült a mainlineba a 6.3-as kernel, de aki ZFS-t használ, az ne frissítsen, mert nem kompatibilisak
growler #8532 üzenetére
lenry@vavatch:~$ grub-install -V
grub-install (GRUB) 2:2.06.r322.gd9b4638c5-3
lenry@vavatch:~$ sudo pacman -Syu
core naprakész
extra naprakész
community naprakész
multilib naprakész
:: Teljes rendszerfrissítés indítása...
nincs teendőhmmm
mod: újraindítottam, gond nélkül bootolt
Shyciii #8473 üzenetére
a service-re persze, hogy azt írja, hogy dead, mert nem önmagától fut, hanem a timer indítja.
én nem is erre utaltam.
ha megnézed, a saját logomat, amit odamásoltam, nekem is azt írja, hogy dead, alatta viszont ott van a journalctl vonatkozó logja, amiben látszik, hogy 6-án hajnal fél2-kor lefutott.
ha kiadod asystemctl status fstrim.service
parancsot, neked is látszódni fog ugyanaz, amit a journalctl-ban is látsz.
growlernek viszont nem volt ilyen alatta. -
growler #8457 üzenetére
ez azt jelenti, hogy nálad ez egyszer se futott le, mert különben írná a legutóbbi futás eredményét, ami úgy néz ki, hogy
lenry@zetetic-elench:~$ systemctl status fstrim.service
● fstrim.service - Discard unused blocks on filesystems from /etc/fstab
Loaded: loaded (/lib/systemd/system/fstrim.service; static)
Active: inactive (dead) since Mon 2022-06-06 01:33:16 CEST; 2 days ago
TriggeredBy: ● fstrim.timer
Docs: man:fstrim(8)
Process: 3023761 ExecStart=/sbin/fstrim --listed-in /etc/fstab:/proc/self/mountinfo --verbose --quiet-unsupported (code=exited, status=0/SUCCESS)
Main PID: 3023761 (code=exited, status=0/SUCCESS)
CPU: 831ms
Jun 06 01:33:02 zetetic-elench systemd[1]: Starting Discard unused blocks on filesystems from /etc/fstab...
Jun 06 01:33:16 zetetic-elench fstrim[3023761]: /: 25.1 GiB (26995699712 bytes) trimmed on /dev/md0
Jun 06 01:33:16 zetetic-elench systemd[1]: fstrim.service: Succeeded.
Jun 06 01:33:16 zetetic-elench systemd[1]: Finished Discard unused blocks on filesystems from /etc/fstab. -
growler #8453 üzenetére
trim támogatású USB3-as házban
azért én megpróbálnám rendesen, SATA-ra kötve is ugyanezt a műveletet, mert a hibaüzenet alapján mégsem annyira trim támogatású az a ház
nálam ugyanez lefuttatva:
lenry@so-much-for-subtlety:~$ sudo fstrim -v /
/: 117.1 GiB (125736411136 bytes) trimmed
(igen, nemrég töröltem egy tonnányi szemetet) -
growler #8441 üzenetére
nem.
olvasd el még egyszer BoB hozzászólását:
"az fstrim parancs az eszköznek megfelelő parancsot fogja küldeni amivel trimmelni fog a meghajtó. Ez a felhasználó számára transzparens."
azaz: te kiadod az fstrim parancsot, az op.rendszer meg az SSD vezérlője meg majd lematekozzák, hogy ténylegesen mit is kell csinálni, neked ezzel már nem kell foglalkoznod.igen, külön fajta megoldása van a SATA-nak meg az NVME-nek a trimmelésre, de mindkét esetben ugyanazt az fstrimet kell elindítani, ugyanúgy
growler #8423 üzenetére
szia
egyrészt nem kell külön foglalkozni vele, a fájlrendszer folyamatosan csinálja (continous trim), emiatt nem feltétlenül ajánlott még külön a periodic trimet bekapcsolni (amit az általad írt parancs csinál) - de a lényeg, hogy csak az egyik legyen bekapcsolva.
másrészt ebből a szempontból a SATA és az NVME közt nincs különbség, egész pontosan nem itt van a különbség. a trim a flash cellák karbantartása miatt fontos. az, hogy aztán az SSD milyen kapcsolaton keresztül csatlakozik a gép többi részéhez (SATA v NVME) ebből a szempontból irreleváns.
lsblk --discard
paranccsal tudod ellenőrizni, hogy működik-e most is a trim. az SSD-k esetében a DISC-GRAN oszlopban nem nulla értéket kell hogy visszakapj.tldr: a mai rendszerek automatikusan kezelik az SSD-k sajátosságait, semmi külön teendő nincs már velük.
ezekkel a 10 évvel ezelőtti machinációkkal nem kell ma már foglalkozni (és a szerény véleményem az, hogy már akkor is túl volt misztifikálva a dolog) -
mod: már látom, ezt próbáltad
Nem lesz semmi baja, én pl átlagosan heti egyszer frissítek, de van olyan gépem, amit sok hónap után most vettem elot, gond nélkül frissített.
A KDE Discover pl szól ha van mit frissíteni
szerintem túl van misztifikálva ez az egész.
kb semmiben nem tér el az Arch akármelyik másik Linux disztrótól, ha egyszer belaktad.
annyi, hogy kezdetben elég fapados, és nem fogja a kezedet, de amint felkerültek a használt programjaid, onnantól úgyis azokat fogod használni, nem az OS-t, akkor meg édesmindegy, hogy Arch, Debian, Fedora, vagy bármi más.
semmiben nem kényelmetlenebb használni, mint bármelyik más disztrót.hogy most nem szoptad végig kézzel a telepítést, hanem használtál egy scriptet? ennek max akkor van jelentősége, ha érdekel, hogy mi történik pontosan a telepítés alatt, vagy nagyon egyedi igényed van.
jól jön, ha meg akarod tanulni mélyebben a dolgokat, mert azáltal, hogy te csinálod meg kézzel, meg is tanulod, ha érted is, hogy miért csinálod azt, amit, ez máskor is segíthet.
minden más esetben tökmindegy,az op.rendszer nem cél, hanem eszköz
hmmm
ezt nézted már? -
attilav2 #8003 üzenetére
évek óta kizárólag Arch fut a saját munkaállomásomon, bár nyilván ha valami nyűgöm volna, azt magamnak könnyen tudom orvosolni.
ennek ellenére nem nagyon volt bajom, sima irodai munkára bátran merném ajánlani.
termelésirányítónak, stb... ha az adott szoftver fut Linuxon, akkor nem érzem hogy bármivel nagyobb kockázat vagy probléma lenne, mint a Windows, sőt... -
a 777 csak egy példa volt. írhattam volna 666-ot vagy 400-at vagy 644-et is. faxmindegy
Ez a chmod 3+ számjegy akkor kell...
... amikor épp olyan kedved van hogy ezt akarod használni. mint írtam, oda-visszaváltható az oktális formátum a betűs változattal. egyik sem jobb mint a másik, mert pontosan ugyanarra valók és pontosan ugyanazt lehet megvalósítani velük. egyik sem tud olyat, amit a másik nem.Az apt-get már évek óta deprecated, helyette az apt ajánlott.
erről most hallok először. linkelj már pls erről valamit. kösz. -
Ez a három számjegyes gányolás még...
az égvilágon semmi gányolás nincs benne, csak ésszel kell használni. mint mindent.
egychmod 777
pont ugyanazt csinálja, mintha azt mondanám neki, hogychmod ugo+rwx
, csak rövidebb leírni. ne csináljunk úgy, mintha nem tökéletesen ugyanannak a funkciónak két külön szintaxisáról lenne szó, amik egy az egyben válthatók oda-vissza.Ugyanezen anyagok szokták írni az apt-get használatát
már mi bajod van még az apt-gettel is? -
Siriusb #7632 üzenetére
én ha úgy állok fel a céges gépemtől, hogy tudom, hogy ki fog kerülni a látóteremből, akkor zárolom. ekkor egy általam válaszott kép lesz a teljes képernyőn, középen egy jelszómezővel.
ha pár percig nem nyúl hozzá senki, akkor a monitorok elalszanak.
ettől az égvilágon semmi bajuk nem lesz, ez teljesen üzemszerű, tervezett működés, ettől teljesen fölösleges féltened a monitort. -
anorche1 #7539 üzenetére
a Windows alatt jobb nem piszkálni, ő akkor is használja, amikor te nem akarod, és hülyébbnél hülyébb hibákat képesek generálni a legkülönfélébb szoftverek, ha nincs swap.
Linuxon tényleg fölöslegessé tud válni, ha kellően sok RAMod van. cserébe nyilván neked kell figyelni, meg homlokon csapni magad, amikor az OOM killer elkezdi kilőni a programjaidat.
jah meg swap nélkül nincs Hibernálás -
Archttila #7534 üzenetére
pacman.conf-ba atirtam az architekturat) tovabbra is hibauzenetet dob hiaba vana helyen a szoban forgo libre2.so.8 fajl, wrong ELF class ... boffent vissza.
persze, hogy ezt írja, ARM architektúrán próbálsz futtatni x86-ra fordított binárist. ez így semmiképp nem működhet. -
anorche1 #7506 üzenetére
ha nagyon zavar, akkor AUR-ból mindháromhoz van firmware
aic94xx-firmware
wd719x-firmware
upd72020x-fw -
Meg Debian- és Ubuntu-vonal alatt azért sem gond, mert ott külső tárolóként hozzá lehet adni a Google-nek a Chrome-tárolóját, vagy kézzel, a Google oldaláról letöltve a .deb csomagot, dpkg -i segítségével telepíteni.
ne felejtsd el, hogy raspberryről van szó.
a Google nem compile-ol ARM-re asztali Chrome-ot, meg én Chromiumból se láttam kész friss deb-et, akinek van rá ingerenciája az fordíthat magának, de az huszonsok gigabyte meg egy Pi-n gondolom el is tart kb addig, amíg kijön a következő verzió -
Ha egy mai fiatal nézi, vagy valaki nyugati emberke, aki ebben sose élt, szerintem annak csak szimplán fura és unalmas lesz.
jah gondolom azért magasztalta az egekig Tűzföldtől Tokióig mindenki, mert furának és unalmasnak találta.
maradjunk annyiban, hogy neked személy szerint nem jött át, és pont. -
Shyciii #7466 üzenetére
az mindenképp gond a te esetedben, hogy az AUR-ban nincsenek csomagok, tehát nincs egy központi hely ahonnan be lehetne szerezni az adott szoftver korábbi változatát, hanem ezt minden egyes package-re külön kellene megoldani, amivel nagyjából senki sem foglalkozik, így hacsak nincs meg neked valahol a korábbi változat (én a pikaurt használom, az pl a
~/.cache/pikaur
mappában tartja az általa elkészített csomagokat), akkor tényleg csak a kézzel telepítgetés marad, vagy az, hogy megvárod, amíg kijön a javított, frissebb változat. -
anorche1 #7445 üzenetére
"bash color prompt"
erre keress rá, de ez külön művészeti ágegyébként a
~/.bashrc
PS1
kezdetű sorát kell izgatni
én pl a legtöbb gépen más színt igyekszem beállítani, hogy ezzel is elkülönüljenek, ha több gépre vagyok belépve, illetve nálam a root promptjában aroot
(usernév) általában piros. -
Shyciii #7434 üzenetére
most hogy így mondtad, lecsekkoltam, hogy amúgy nálam is aktív-e vagy csak én hittem azt eddig, de úgy látom rendben van
[root@vavatch lenry]# systemctl status fstrim.service
Loaded: loaded (/usr/lib/systemd/system/fstrim.service; static)
Docs: man:fstrim(8)
[root@vavatch lenry]# systemctl status fstrim.timer
● fstrim.timer - Discard unused blocks once a week
Loaded: loaded (/usr/lib/systemd/system/fstrim.timer; enabled; vendor preset: disabled)
Active: active (waiting) since Fri 2020-11-27 15:58:25 CET; 2 days ago
Trigger: Mon 2020-11-30 01:35:57 CET; 7h left
Triggers: ● fstrim.service
Docs: man:fstrim
nov 27 15:58:25 vavatch systemd[1]: Started Discard unused blocks once a week. -
anorche1 #7426 üzenetére
nem kell a discard az fstabba
Arch-on a systemd hetente intézi a discardot (periodic trim), így nincs szükség a folyamatos trimet kapcsoló fstabos megoldásra.
ez ilyen vagy-vagy dolog, nem érdemes mindkettőt bekapcsolnia relatime-ot is hagyhatod, mára az az alapértelmezett beállítás, lényegesen kevesebb terheléssel jár, mint a régi atime, de megmarad a funkcionalitás, amit a noatime-al elvesztenél
anorche1 #7418 üzenetére
ebbe én is belefutok mindig, amikor új gépre rakom fel az Archot.
első körben fusd át a Wiki idevonatkozó részeit
Font configuration
Firefox#Font troubleshooting
Rondák a betűk a Feuerfuchsban -
"Mondjuk az igaz, hogy én i3-at nem vennék"
ma már én sem.
én döntök a cégben az informatikai beszerzésekről és töredelmesen bevallom, hogy a saját hülyeségem, hogy eddig Intelt vettünk. egyszerűen nem foglalkoztatott az AMD, ha kellett egy gép, akkor kinéztem, hogy melyik Intel CPU felel meg a felmerülő igénynek és azzal rendeltem a gépet.
aztán most nyáron vettünk egy Ryzen 5 4500U-s laptopot és a hajam letettem attól, amit a GPU-ja 4K-ban tud, meg nem sokkal később kellett egy fejlesztői gép és körbenéztem az AMD-s oldalon: 6 mag 12 szál 60k-ért?Inteléknél ugyanez 100 fölött van.
azóta most csak AMD-s gépeket veszek, de idő, amíg átbillen a mérleg...mindig megtartom a CPU dobozokat, az Inteles piramisban olyan 40 doboz van, az AMD-s most jól láthatóan kilencnél tart
bocsi a hosszú OFF-ért
"Harmada-negyede boot és lag a progik betöltésénél, háromszor-négyszer olyan gyors leállás"
heti egyszer indítom újra a gépet, akkor is nagyjából 5-7 másodperc alatt jutok el a Grubtól az asztalig, a maradék 167,999 órában meg folyamatosan be van kapcsolva.
programok indítása szintén 1-2 másodperc.
és ez nem egy überhyper gép, hanem egy négymagos i3, annyi, hogy NVME-s SSD-n van a rendszer meg a /home is, de nem hiszem, hogy ez akkora truváj.
tehát ennek fényében kérdem, hogy valójában mi jelentősége lecsupaszítani mindent*, meg a huszadik DE-t felrakni, mikor egy aktuális modern gép röhögve elvisz egy KDE-t"hogy van indítómenü, meg asztali ikonok, mindent egérrel csinálok, stb.. Ez annyira mélyen be tud ivódni az emberben"
egyetlen ikon sincs az asztalomon vagy a tálcámon, a leggyakrabban használt programokat Win+1, Win+2, stb kombókkal indítom, minden másra ott a
MasterCardAlt+F2ne érts félre, senkit nem akarok semerre orientálni, csináljátok nyugodtan, csak pár hsz-t visszaolvasva úgy éreztem magam, mint amikor 128MB RAM-om volt a 466-os Cerka mellett, aztán a fentebb felsoroltak valóban számítottak, és azt hittem itt is valami ilyesmiről van szó.
* mármint nyilván azon túl, hogy van, aki szeret ezzel pöcsörészni
akár káros is lehet, mert belefuthatsz két frissítés közötti felemás állapotba, meg nagyon friss bugokba, amiket néhány óra alatt javíthatnak. Biztonságosabb néhány naponta frissíteni.
ez nem véd meg semmitől. több naponta frissítés esetén is kifoghatok két frissítés közti felemás állapotot -
- Házimozi haladó szinten
- Óvodások homokozója
- Milyen processzort vegyek?
- ldave: New Game Blitz - 2025
- Assassin's Creed Shadows Collector's Edition PC
- Kaspersky, McAfee, Norton, Avast és egyéb vírusírtó licencek a legolcsóbban, egyenesen a gyártóktól!
- AKCIÓ! Apple Macbook Pro 16" 2019 i9 9980HK 64GB DDR4 1TB SSD Radeon Pro 5500M garanciával
- DELL PowerEdge R730xd 12LFF+2SFF rack szerver - 2xE5-2680v3,64GB RAM,4x1GbE,H730 RAID v ZFS
- Csere-Beszámítás! Prémium felsőkategóriás Gamer PC! X870 / R9 9950X / 9070XT / 64GB DDR5
- ÁRGARANCIA!Épített KomPhone Ryzen 5 4500 16/32/64GB RAM RTX 3050 6GB GAMER PC termékbeszámítással
Cég: CAMERA-PRO Hungary Kft
