sg22
Most of the actions we tested have a fairly low parallel efficiency (below .7 or 70%). They still benefit from having more cores, but in most situations a CPU with a lower core count but higher operating frequency will give you the best performance. However, exporting images - which pretty much any Lightroom user is going to do - has a very high parallel efficiency which means a CPU with a high core count will allow you to export images faster. This means that the best CPU for you is going to depend on exactly what actions in Lightroom you regularly find yourself waiting on.
azt irjak h magasabb freki jobb mint a tobb mag ehhez a progihoz (lightroom). megoldas lett volna egy tobb magos xeon proci alacsonyabb frekivel ezaltal alacsonyabb tdp-vel. de mivel magas freki kell ezert a tdp is magas lesz
- Patriot Viper Elite 5 Ultra - 48GB (2x24) DDR5 6400MHz CL32 - 10 év garancia
- DDR5 G.SKILL Trident Z5 Neo RGB 6000MHz (AMD EXPO) 32GB - F5-6000J2836G16GX2-TZ5
- G.SKILL 32GB (2x16) DDR5 7200MHz CL34 - Trident Z5 RGB - 99 hónap garancia
- 16 GB DDR5 5600 Mhz Samsung RAM !
- Új, bontatlan ADATA XPG 48GB (2x24GB) KIT DDR5 6000MHz CL30 Lancer Blade RGB Black XMP/EXPO - 10 év
- HIBÁTLAN iPhone 13 Pro 128GB Alphine Green -1 ÉV GARANCIA - Kártyafüggetlen, MS3024, 100% Akksi
- Macbook Air M3 15" 16GB 256GB 100%
- Apple iPad 9th Gen 256GB, Wi-Fi+Cellular, Kártyafüggetlen, 1 Év Garanciával
- Apple iPad 9. Generáció . 10.2 (2021) / 64GB / Bluetooth / Wi-fi / Újszerű állapot / 12 Hó Garancia
- HIBÁTLAN iPhone 14 Plus 128GB Purple -1 ÉV GARANCIA - Kártyafüggetlen, MS3659, 100% Akksi
Cég: BroadBit Hungary Kft.
Város: Budakeszi
Cég: ATW Internet Kft.
