- Végre 120 Hz-es lesz az Apple következő monitora
- Lenovo Legion és IdeaPad Y széria
- Bambu Lab 3D nyomtatók
Announcing Windows 10 Insider Preview Build 16281 for PC
We fixed an issue resulting in Train Simulator 2017 failing to launch on recent flights.
We fixed an issue resulting in not being able to tab into an open PDF in Microsoft Edge after interacting with the any of the Microsoft Edge window elements using mouse.
We fixed an issue where the Windows Defender Security Center app icon was missing in taskbar when the app was open, as well in Start’s all apps list. You will also notice that the icon is now un-plated in the taskbar.
We’ve made some adjustments to address an issue resulting in sudden and brief CPU spikes where you couldn’t move your mouse. If you’ve encountered this, please try it in this new build and let us know if your experience has improved.
We fixed an issue where minimized app windows on mixed-DPI monitor setups might end up drawing offscreen after your PC resumed from sleep.
We fixed an issue where if you changed your display language preference to something other than the machine’s default then any app which did not take an update while also getting the updated language resource package from the Store would end up continuing to display its tile in Start in that default language rather than the new language displayed within the app and other system UI. -
Este hétig még van majdnem 1 óra, hátha.
Bobo_07
#1317
Ha magyar nyelvű W10-ed van, akkor az utolsó nagy frissítés (Creators Update) óta jönnek arra is az Insider buildek, előtte nem igazán volt elérhető ehhez a nyelvhez, csak külön telepítve az angol Insider verziót és úgy a magyar nyelvi csomagot (ha épp volt hozzá). Most már együtt kezeli a Microsoft.
Akinek nvidia kártyája van: nektek is újra kell rakni minden insider update után a rendes drivert? Eleve visszakapcsolja a Windows a saját driver telepítést és bár a verziószám megmarad az nvidiaé, olyan mintha nem lenne rendesen telepítve, a telepítő írja is, hogy nem talál telepített verziót, mikor elérek a választható részhez. Nem zavar, mert úgyis újraraknám egy éles upgrade után is, csak nem értem akkor miért nem telepíti az utolsó WHQL drivert, ha már hozzányúl.
Nálam sincs lassulás, próbáld meg esetleg újrarakni a VGA drivert.
Más: jól értelmezem, hogy ez a "Skip ahead..." opció a Windows Insider beállításoknál kihagyja a végleges fall update-ig a javításokat már és lehet tesztelni a jövőbeli buildeket és amint megjelenik az őszi frissítés, visszaáll sima fast ringre? Mert elég b*lf*szul sikerül megfogalmazniuk minden ilyen frissítéssel kapcsolatos választási opciót (lásd még múltkori normál buildre való visszatérés 4 lehetősége)
Windows 10 Insider Preview build 16232 (aktuális slow ring) ISOk is tölthetők
Közben slow ringre is kitolják az előző buildet és ISO is várható. Én tegnap újraraktam desktopon az előző build UUP-ből gyártott isoval, az most felfrissült gond nélkül fast ringen. Csak a firewall beállítás van elcsesződve WFC miatt, meg a Virtualbox nem megy, szóval semmi komoly
Nálam az angol nyelvű Pro-n is megállt a telepítés 33%-nál a Virtualboxban. Kezdek gyanakodni, hogy olyan hardver miatt lehet, amit a virtuális gép is átvesz és mivel elég standard cuccaim vannak, gyanítom másoknál is hasonló probléma lehet, csak kérdés, hogy driver szintű a gond az updaterben vagy mást csesztek el Redmondban.
Most még megpróbálom a gyártott magyar isoból frissíteni/felrakni a Virtualboxban lévőt, igaz az töröl minden alkalmazást és beállítást, de legalább kiderül, felmegy-e egyáltalán.
Milestone2
#1253
Notira gond nélkül felmegy/felment, az előző buildnél a helyi hálózati rész nem működött, de mint most kiderült, valószínűleg azért, mert elkezdték kiszedni az SMBv1-et. A mostani buildben már jó minden megint. Csak a desktopra nem megy fel valami olyan hiba miatt, ami nem csak nálam jön elő, de kicsit komolytalannak érzem a fejlesztés mostani fázisát, amikor már 2x is azt írják kijavították, közben ugyanúgy ott van. Az sem normális, hogy a telepítő elkezdi a mappájába hardlinkelni a jelenlegi rendszert, miközben ezt a notin nem csinálta. Valami megakasztja a felkészítési fázisban és hiába van ott minden a mappában, telepítéskor megáll vagy elszáll. Most nem néztem logokat, de igazából sok minden nem derül ki belőlük illetve normális memdumpot sem csinál akkor, amikor elakad... És igen, ez már a 3. build, ami zsákutca, 16193-on vagyok emiatt még mindig desktopon, ami nem igazán stabil verzió, volt már pár GSOD rajta.
Na mindegy, amint lesz egy slow ringes iso, újrarakom abból, ha az update akkor sem működik.
16215-ben nem működik a Safe Mode, ugyanúgy hibás a updater (legalább 10 post van rólam Insider fórumon), szóval ez a verzió is kimarad nálam (laptopon meg jó...). Lassan a vicc kategóriába megy a fejlesztés, pedig még csak most jön a nyári szünet.
The issue causing updating to the latest builds to get stuck at 12% should be fixed. If you still hit this, please send us feedback in Feedback Hub so the team can investigate.
kiskacz
#1207
Úgy az insiderek elég nagy hányada csak
Sajnos mindenki zúgolódik, héten nem lesz build, úgyhogy rakd slow ringre, amíg nem jön a következő.
Nálam laptopon 25 perc alatt frissült, desktopon ugyanez a 12%-os fail jelenség van, akármilyen woodoo módszert veszek elő, sajnos rossz a build telepítője és valaminél elakad...
Holnap lesz Windows Cloud event, akkor kiderül minden
Milestone2
#1185
Olyan mint a ChromeOS, csak UWP apokat futtat és nyilván ajánlott az online felhő alapú szolgáltatások használata vele. Mivel hivatalosan még be sem jelentették, sokat nem lehet tudni róla.
Biztosan lesz újdonság 1-2 hónapon belül, mert elvileg szeptemberben jön a következő nagy frissítés.
Én Virtualboxban futtatok Insidert angolul, a magyar éles rendszereken bár be van kapcsolva, de még egyszer nem töltött le insider buildet (naívan várom, mikor kerül be a magyar build a körforgásba). Éles, napi szinten használt rendszernél amúgy is felesleges, csak ha tesztelni akarsz, akkor jó (volt már, hogy nem működött a start menü vagy a hálózat, szóval csak kíváncsiságból nem éri meg felrakni)
- Okos Otthon / Smart Home
- Jogász topik
- Apple iPhone 13 mini - miért nem veszik elegen?
- VGA kibeszélő offtopik
- Allegro vélemények - tapasztalatok
- Pécs és környéke adok-veszek-beszélgetek
- Vicces képek
- Windows 10/11 Home/Pro , Office 2024 kulcsok
- MEGA AKCIÓ! - Jogtiszta Windows - Office & Vírusirtó licencek- Azonnal - Számlával - Garanciával
- Game Pass Ultimate előfizetések 1 - 36 hónapig azonnali kézbesítéssel a LEGOLCSÓBBAN! AKCIÓ!
- PC Game Pass előfizetés
- HIBÁTLAN iPhone 13 Pro Max 256GB Sierra Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3958
- GYÖNYÖRŰ iPhone 13 mini 128GB Blue -1 ÉV GARANCIA - Kártyafüggetlen, MS3293
- Dell Latitude 5400 14" FHD IPS, i7 8665U, 8-16GB RAM, SSD, jó akku, számla, 6 hó gar
- ÁRGARANCIA! Épített KomPhone Ultra 9 285K 64GB RAM RTX 5090 32GB GAMER PC termékbeszámítással
- Új, Aktiválatlan iPhone 17 Pro (256 GB) (rendelhető)
Viszont az AIDA64-ben a legtöbb szenzor nem elérhető az e heti Insider óta, szóval van még probléma rendesen.
