- E-book olvasók
- A Windows 11 lett az úr az asztali PC-k piacán
- Milyen processzort vegyek?
Out
Q9: What colour modes are currently supported?
A9: 24-bit True Colour is currently the only native colour mode for the ATI Proprietary Linux Driver. 8-bit colour can be achieved using the pseudo-colour visuals feature, but may not work in all applications. 16-bit colour is not supported; if any of your critical applications require 16-bit colour, you should not install the ATI Proprietary Linux Driver
Magyarul megszivtam, koszonom ATI -
Out
Felmerult egy problema a 3dmark2001 telepitese kozben... azt keri a program hogy valtsak 16 bit-es szinmelysegbe... de a XFree nem hajlando csak 24 bit-be futtatni magat... ilyenkor mi a teendo??
Out
Nyah, ha mar az X-nel tartunk, a monitorom elvileg birna a 1024x768@100hz-es bigyulat, de hiaba irom ezt be modeline-ba az XFConfig-4 fileba nem vesz rola tudomast es 85hz-en megy a moncsi... van erre megoldasotok?
Out
Errol tudtok?
NVidia has released a new minor update of their Linux drivers from version 6106 to 6111 for both 32 and 64bit x86 CPUs.
A tip for people with selfcompiled kernels:
At ''STEP 2: Download the Driver File'' on the download page: Instead of downloading the NVIDIA-Linux-#arch#-#version#-pak1.run or pak2.run file which contains several precompiled kernelmodules for the most common distros of which none will fit your kernel - copy the link, replace the pakX.run part with pak0.run and download this file instead, it is amost half the size of the full package.
Changelog:
* Fixed problem that caused cursor misplacement/corruption in certain TwinView configurations.
* Fixed console restore problems on GeForce4 Ti.
* Supports all Intel EMT-64, AMD Opteron™, AMD Athlon™64 and AMD Athlon™FX 64 processors.
Bővebben: link
[Szerkesztve] -
Out
Nah, felmerult egy olyan dolog, hogy a mostani 9100LE-s videokartyamat lecserelnem egy masmilyenre, mert a tv-out csak fekete-feher kepet ad es mar annyit bajlodtam vele eredmenytelenul... tehat az lenne a kerdesem, hogy maradjak az ATI-nal, vagy esetleg nezzek Nvidia-t? Nem akarok nagy kartyat, ATI-bol lenne egy 8500-os elado, szal Nvidiabol is hasonlo kellene... de a lenyeg, az lenne hogy pl WineX-ben jobb lenne-e az Nvidia kartya vagy nem?
Out
Izelitonek:
ATI has just released their new drivers for the x86 arch. The new drivers adds support for the chipsets:
FireGL™ X3-256
RADEON™ X800 (AGP only)
Besides the following issues where fixed:
fglrx RPM files are now conflicting with older fglrx-glc22 as originally intended
fglrx kernel module is now compiling properly on 2.6.6 and later kernels
The Color Palette now remains intact when switching VT terminals
Running a 3D application after any DGA applications no longer hangs the system
Enabling Quad-Buffer stereo on FireGL X1/Z1 no longer results in desktop corruption
driver: Bővebben: link -
Out
gyanitom Cannon usb-s nyomtatoval nem lesz gond, Aiptek digivel megintcsak nem (nekem is Aiptek digikameram van), a dvd-iro csak attol fugg hogy az iroprogi felismeri-e majd..... es asszem siman lehet hasznalni a vodka gprs-t is...
bocs, hogy en valaszoltam a kollega helyett -
Out
A napokba tervezem egy dhcp server felrakast, de idom meg nem engedte, viszont talalhatsz hozza howto-kat a google-n... pl Bővebben: link
munkaidom lejart, megyek haza
[Szerkesztve] -
Out
a chat.hu a kommunikaciora egy meghatarozott portot hasznal, amit en megnem mondok neked hogy melyik es ezt kellene engedelyezni a tobbi gepek fele is....
de ahogy latom mar a linuxforumra is felraktad a temat, ott talan talalsz olyat aki mar csinalt ilyet, mert en csak a sotetben tapogatozom
Viszont en a helyedben azert megneznem azt az iptables -L parancsot, mert ezekszerint nem te allitottad be a tuzfalat hanem az van amit alapba a mandrake beallit...
[Szerkesztve] -
Out
Ezis_foglalt #859 üzenetére
Aki ennyire ert a windozhoz annak semmi szuksege linuxra...
Out
eddie303 #856 üzenetére
A cdrecord nem tudott mit mondani rola, valami ilyesmit irt ki hogy manufacturer id -1 meg hogy ismeretlen tipus, es kiirta hogy a cdrecord nem tud adni infot a DVD-R/DVD-RW-krol,de irni tokeletesen tudok ra, csak igy nem tudom hogy tenyleg olyan lemezt vettem-e amilyet akartam....
Out
Ezis_foglalt #823 üzenetére
Es nem tud? Nincs olyan benne hogy Export to PDF?
Egyebkent miert kell neked linux az OOo-hoz? Elerheto vindozon is
[Szerkesztve] -
Out
Nem a linux a szar hanem a disztribuciok olyanok amilyenek, illetve a juzer meg a gyenge lancszem.... senki nem fog kenyszeriteni teged a linuxra, hasznald a vindozt nyugodtan..
Out
Tud valaki olyan programot ami infot ad egy dvd lemezrol?
Out
steveetm #802 üzenetére
az furcsa hogy miutan connected lesz nem kezd el tarcsazni a modem, jol bevan az allitva?
Protocol botch, unexpected EOF. The client closed the connection prematurely.
Ezt talaltam errol...itt: Bővebben: link
[Szerkesztve] -
Out
steveetm #800 üzenetére
a how to-t mar probaltad? Bővebben: link
- Háztartási gépek
- Filmvilág
- Vivaldi (böngésző)
- Lakáshitel, lakásvásárlás
- E-book olvasók
- ricshard444: Fényképező ? Telefon helyett
- Vékonyabb lett, jobb kamerát kapott, de az akku maradt a régi: itt a Fold7
- Gyúrósok ide!
- Honor Magic 7 Lite 256GB Kártyafüggetlen 1Év Garanciával
- Beszámítás! Sony PlayStation 5 PRO 2TB Digital játékkonzol extrákkal garanciával hibátlan működéssel
- Bomba ár! Dell Latitude 5490 - i5-8GEN I 8GB I 256GB SSD I 14" HD I HDMI I Cam I W10 I Gari!
- BESZÁMÍTÁS! Asus B760M i7 12700KF 32GB DDR4 512GB SSD RX 6800 16GB Rampage SHIVA FSP 700W
- Beszámítás! Sony PlayStation 5 825GB SSD lemezes konzol extra játékokkal garanciával hibátlan
Cég: CAMERA-PRO Hungary Kft
