- Bluetooth hangszórók
- Amazon Kindle
- OLED monitor topik
Breki
LCD Density Changer és root kell hozzá
Breki
nagy1970 #20575 üzenetére
próbáld meg innen bár nem egészen értem miért akarod a számítógépet kihagyni
Google Earth v6.1
Requirements: Android version 2.1 and higher
Overview: Use Google Earth to fly around the planet with the swipe of a finger. Explore distant lands or reacquaint yourself with your childhood home. Search by voice for cities, places, and businesses. Browse layers including roads, borders, places, photos and more.Image Image
For tablet users on Android 3.0 (Honeycomb), you can now enjoy a new Google Earth experience optimized for the large screen. With a new action bar, you can get easy access to search, reset-to-north, my location, and layers. Also, on tablets and select phones, you can now explore the same photo-realistic 3D buildings that have previously only been accessible with the desktop version of Google Earth. Visit the Statue of Liberty in New York, the Taj Mahal in India, or the Sydney Opera House in Australia, all in their full 3D glory! To view 3D buildings, just select ‘3D Buildings’ from the layer menu.
You can easily navigate with your fingers, using:
* a one finger swipe to move the globe
* a two-finger pinch and rotate to zoom in and out and rotate your viewpoint
* two-fingers swiped together to tilt your view
* a one single finger double-tap to zoom in and
* a two-finger double-tap to zoom outRecent changes:
6.1
* Changed version number to match desktop releases
* Performance and compatibility improvements
* New balloon open animation -
Breki
hodostamas #20572 üzenetére
Énis így kezdtem
Breki
Storms #20551 üzenetére
először is le kell szedni ezt
mClock Widget v2.2.6
INSTRUCTIONS:
1. Install the newest mClock
2. Create a folder in the root of your SD card called 'mClock'. (sdcard/mClock)
3. Download and Extract the .zip/rar files (folders)into this folder
Be sure to use the exact location as shown above, or the clock background will NOT work.
4. Add mClock widget on your homescreen.
4. Load the downloaded xml file in the settings menu of mClock (Hit "Xml Template" in the mClock settings)
5. Select the desired .xml file.
6. If necessary resize the widget
7. Enjoy! -
Breki
Ma raktam fel egy 64 órát tartalmazó packot jobbnál jobb órákkal
Breki
Mai ajánlat
BobClockD3 Clock Widget Alternate XDA Version (exclusive) BobClockD3Configure.apk [link]
Breki
gaben92maste #18859 üzenetére
hát szerintem meg kéne próbálnod visszarakni az alapsoftot PC Companion-al vagy Zeus-al
Egyébként van a telónak saját fóruma
Breki
Korábban volt kérdés a Notification Bar színének változtatása erre egy példa
MetaMorph – Notification Bar – Sky Blue
Metamorph leírás
[link]Installation:
1. Download file below, note this file requires the MetaMorph Application
2. Move to “Android Themes” folder created by MetaMorph on SD card
3. After checks, choose “Unzip/Extract New”
4. Follow instructions from there
5. Phone may reboot, if not, manually rebootPlease remember always to make a Nandroid backup as well as an Application backup. Some MetaMorphs will not be compatibile with your device or ROM please make sure that you always have a way to “unbrick your device”.
Breki
ADW EX-nél a probléma van a widget betöltésével felirattal találkozott már valaki
?Megcsinálom a widgeteket és újraindításkor vagy launcher váltása után ez fogad.
VAn erre valami egyszerű megoldás? -
Breki
TazLeacher #17735 üzenetére
Nem az enyém, de szerintem így megtalálod
SGS2 Windmills wallpaper
Breki
Spirit FM Radio
It works on a few stock phones with Broadcom or TI FM chips, but usually requires SuperUser/root access. It is mostly likely to work well on CyanogenMod ROMs.
Experimental support added for Samsung Galaxy S on CM7 and Darky ROMs.
Google does not support FM, and Broadcom and TI specs are secret, so this app uses painstakingly reverse-engineered low level methods. PLEASE do not rate it down if it doesn't work on your device.
Work is underway to support as many devices as is feasible.
For further information, please see the thread at: http://forum.xda-developers.com/showthr ... p=13385163
What's in this version:
- Samsung Galaxy S support re-enabled. Speaker issues appear dubious or very isolated.
- Improve detection of TI and Broadcom FM chips for Archos etc.
- Fix reversion to North American RDS values on orientation change or return to app.
- Email Logs uses /data/local/tmp/sprt_debug.txt instead of /sdcard/sprt_debug.txt .
- Fix NullPointerException on phone call mute/unmute.Egyébként Tune In
Breki
spiritex #17475 üzenetére
na amit most írok nem biztos, hogy jó nálad ez mini pro-ra van, de érdemes megnézni azért hátha segít
"root explorer:
system -> usr -> keyboard-config -> keyprint.xml utolsó sorában a "qwerty-en"-t át kell írni "qwertz"-re. Az "en" nem kell a végére. "ha van ilyen neked lehet pont fordítva kell először egyáltalán nézd meg van-e ilyen és mi van benne pontosan
Breki
spiritex #17471 üzenetére
mutasd már meg milyen ez a billentyűzet nálam pont úgy van ahogy te akarod
van alapból rendes ékezetes betűd?mert lehet ugyanúgy lehet átállítani qwerty qwertz-t de akkor ha most van nem lesz ékezet
flash-: pont most találkoztam egy ilyennel próbáld ki hátha megfelel widgetet nem találtam a leírásában !
[link] -
Breki
spiritex #17390 üzenetére
Szóval akkor neked jó helyen van a a betű azt írja ami a bill-en van, de te pont fordítva szeretnéd.
Viszont az írt módban pont fordítva volt és arról volt szó hogy kerüljön a helyére.
Na most szerintem amit te akarsz megvalósítható átrakva angolra viszont akkor szerintem az ékezetek nem lesznek jók. De ezt a telód fórumában kérdezd meg !
Nálam a T mellett van a Z és Y mellett az X
Breki
Breki
spiritex #17367 üzenetére
igen nálunk rom manager -el beállítom qvertz-sre és kiszedem a pipát az androidos bill elöl ahogy írtam és működik
de nem tudom nálatok milyen rom-ok vannak a módszer gondolom hasonló
úgy tudom manuálisan is át lehet írni qvertz-repollai szívesen szerintem is nagyon jó oldal rengeteg jó ötlet van amit le lehet lesni
Breki
spiritex #17360 üzenetére
nálam kihúzható igazi billentyűzet van tehát én arról beszélek, virtuálist ritkán használom
Mai ajánlat egy fantasztikus oldal
http://mycolorscreen.com/
tetszik például ez a kinézet, szeretnéd megtudni, hogy lehet létrehozni?
Itt csak elég rákattanni pl ide (másik példa) és már nézheted is virtuális hogy néz ki
[link]És ha tetszik képernyőre kattintva megnézheted mivel készítette és letöltheted a file-ket háttérképet szinte mindent a megfelelő programokhoz pedig linkek vezetnek.
Ezenkívül lehet kommentálni értékelni sőt ha valaki profi a sajátját is feltölteni.
Mindenkinek akit érdekel a mobilja kinézete ajánlom
Breki
vaoooooooooooooooo
MIUI Launcher 3.0 by ~Vipitus
This is my modded version of QQLauncher. It's fully translated to English (thanks xda) and Polish (me).
It's really pretty good clone of stock MIUI launcher.Changelog (from 2.1):
- Changed default colors to orange
- Fixed translations (English is default locale now)
- Bugfixes by QQ and by me
- App encryption function (by QQ) -
Breki
HollyBoni #17339 üzenetére
Mini Pro-n így lehet újra ékezetesen írni lehet nálad is működik.
Cyanogen rom esetén a mini rom managerből közvetlen lehet állítani qvertz-t, a mini rom manager meg ott van a programok közt+ Beállítások-Nyelv és billentyűzet-Itt az android billentyűzet ne legyen kipipálva
Breki
Ez jó
Breki
GO Launcher EX v2.55 Final
1. (New) 4 new home screen transitions
2. (Improve) Restore option of hiding notification bar
3. (Improve) Supports screen rotation of first installation
4. (Improve) User experience of dragging operation
5. (Fix) Wallpaper zoom issueDownload Instructions:
[link]Mirror:
[link] -
Breki
A Missed It-nél az Output format-nál mit kell pontosan átírni, hogy ilyen legyen?
Breki
petipetya #17134 üzenetére
Mivel nekem nincs eredeti ezt nem tudom megítélni
Ha tényleg ennyi van lehetetlenség is elvárni egy pár megás apk-tól, hogy az összes gyári benne legyen. Ugye ez nem rom, hanem egy sima Launcher
De egy mini pro-ra alap launchernek felrakva szerintem tökéletes.Mondjuk a méretezés kicsit fura a go Launcher EX után, de majd megszokom.
HTC Sense Weather Flip Clock-ot meg egy Agile Lock-ot még fel lehet esetleg rakni melléAzért amit privátban küldtem cyanogenmod's theme chooser,-es videó elég meggyőző
[link] -
Breki
Istwan #17111 üzenetére
Pont ez a lényeg komplakt HTC Sense mod Androidba egyben tökéletes gyors működéssel
és remek widgetekkelpl naptár, gmail , contact, ugyan lehet ezek egy része a pro plus-ban is benne van és van külön sense kinézet is, de így egyben az egész mindenféle egyéb telepítése nélkül most komplett és szinte tökéletes számomra.
Ha valakinek ez hype sajnálom....
Breki
találtam egy még jobb videót róla
LauncherPro Sense UI
Z0C! igen olvasgattam a hozzászólásokat nálam simán megy, bár lehet ha másképp rakom fel még több funkció és widget lenne, de pont az tetszett benne, hogy egy apk és máris minden működik nem kell semmit állítani telepítgetni.
A Facebook-os dologra a fórumokon vmi olyasmit olvastam, hogy ez alól kell újratelepíteni és azután teljesen jól működik.
Breki
akkor miért nem szóltál előbb
kereső pedig nem dobott rá semmités így egészében szerintem fantasztikus jó
nem úgy raktam fel hogy Launcher Pro-t és rá a widget pack-os skint hanem egyben egy apk-t felraktam aztán néztem, hogy mi ez amiben minden ilyen frankón működik.
Launcher Pro fent sem volt előtte nem is kellett hozzá felrakni.Számomra jelenleg elég nagy dolog így egyben.
Breki
Heti ajánlat !
Nagyon csodálkoztam hogy a következő Launcher még nem szerepelt itt, legalábbis a kereső szerint.
LP Sense UI Launcher
egy jelentősen turbósított Launcher Pro
HTC Sense UI kinézet remek widgetek pl a naptárnál a névnapos váltás nagyon bejött, gyors az egész és alapból is nagyon jól néz k szerintemi.Mióta felraktam csak lesek jelenleg ez a kedvenc, alap Launcher Pro nem a kedvencem de így felturbózva remek lett ! Hamarosan jön az új verzió is.
Nem is szaporítom a szót működéséről két videó
[link] -
Breki
dokee78 #16907 üzenetére
természetesen Go Launcher EX
A magyarosító ki fog akadni
GO Launcher EX v2.55 beta1
Requirements: Android OS 2.0+
Overview: GO Launcher EX is the extended version of GO Launcher, one of the most popular home apps in Android Market. It’s a highly customizable home replacement application, which will run when you press your android phone’s HOME key. GO Launcher EX supports hundreds of themes, fast flip speed and tons of useful functions.Image
Features:
- Hundreds of themes
- Fancy home screen transition
- Smooth scrolling experience
- Icon popup menu
- Folder and task manager in app drawer
- Gesture supported
- Scrollable & resizable widgets supportedNew features:
4. (Fix) Wallpaper zoom issue -
Breki
Szép lett ez a new iPhone iOS Extreme
Agile Lock 1.6 by CyberAndroid
Overview: Are you still envy of the brilliant lock screen of Sense 3.0? Now, as long as your phone is Android system, you will be able to experience the beauty of the lock screen. Only
use one button, you can choose to use this agile lock screen or system default screen.Drag the bottom circle to the top can unlock screen.Requirements: Android 2.1+
This program has a lot of setting options: font, font color, font size, background settings, shortcuts settings, etc., must be well meet your needs.
Version 1.6
1.During add widget to lockscreen, can move music control layout position.
2.Fixed FC problem.
3.Add horizontal screen support.Add "Screen orientation" setting item. -
Breki
másoddiplomát munka mellett szereztem, de ne offoljunk
GO Launcher EX v2.53 Final (2.53) Android Apk App
Features:
- Icon popup menu
- Gesture supported
- Scrollable & resizable widgets supportedTips:
1. Pinch fingers to enter preview screen and edit home screen pages
2. Search “go launcher theme” to get themes and select them in “Themes preferences”
3. Set screen transition and flip speed in “Display settings”
4. Long press icons on home screen to active popup menu
5. Long press icons in app drawer to edit location, uninstall apps and create folders
6. If you can't set GO Launcher as your default home, download "Home manager"Important:
1. This is a totally free application and we need directly call phone numbers permission to enable the direct dial shortcut on home screen.
2. We will bring out some charged apps like themes and widgets, but most of our apps are free!
3. The weather and clock widget in screenshots belongs to GO Weather, one of the applications developed by our team!
4. The other widgets in screenshots are our GOwidgets, try to search and download them in Android Market!
5. Download our “Classic Theme GO Launcher EX” to get the wallpaper!
6. GO Dev team has released GO Launcher EX, GO SMS, GO Weather and GO Contacts. More and more applications are coming soon!Think of an extreme makeover to your phone? Try this out!
1. (New) Dock icon supports to open folder
2. (New) Add an icon to open theme preview in app drawer
3. (New) Add restart icon in Menu
4. (New) New transition for vertical app drawer (3D)
5. (Fix) Translation for Polish and Portugal -
Breki
speciel nekem van karórám méghozzá mutatós és például versenybiciklin is van külön óra
és nem a menőség miatt van a telefonon is óra, viszont a lockscreen-en nincs ott csak
a hívások emailek stb vannak.
Azt órát direkt szinkronizálom is, hogy teljesen pontos legyen.,Neked vmi időjárásfóbiád van :-)
Nekem speciel be szokott jönni az előrejelzés és általában nyaraláskor is jó idő van
szval számomra hasznos is persze egy időjárás-előrejelzése sosem lehet 100%-ig pontos de ennek nincs köze az androidhoz általánosságban is igaz.Ezenkívül igen egy ilyen számomra grafikusi szemmel szép is
Breki
Istwan #16635 üzenetére
akkor a választ megkaptad
mi speciel a munkahelyen nem nézünk tv-t és nem hallgatunk rádiót az időjárás meg ugyanannyira pontos mint a neten lévő, mint kiderült ez esetben pont pontos
és nem csak a jelenlegi és nemcsak a helyben lévő időjárás érdekes nekem pl görög-ben
semmi felháborodott nem volt egyébként a válaszban csak az illető úriember szeret mindig ilyeneket kérdezni ahelyett, hogy megmutatná az övét
Breki
Breki
Breki
Igen pontosan az elsőben linkelt témáról van szó
és abban vannak olyan ikonok amivel pl a középsőt megcsináltam, de a szélsőnél csúszik
illetve ugye fel kéne cserélnem mert most az alkalmazások van középen nem a phonea leírásban most ennyit találtam, de nekem most magyar és először csinálom ezért kéne egy kis segítség hozzá
Theme setup:
1. You must have Go Launcher installed
2. Select theme and press “apply”
3. You will see have the new SENSE dock, along with your app icons.
4. You will need to remove icons 2 and 4 off the dock, by press-holding on the icon and selecting “change shortcut” > “blank”.
5. On remaining icons, press-hold and select “choose icon” > “themes” and select icons for the dock that is currently selected (classic or carbon).
6. For central button/icon, select a transparent icon, through same method, but it will be second on the list!Notice, for classic dock, left and right icons are not interchangeable, but for carbon dock you can mix left and right icons. Also notice, carbon dock uses its own icons from the same menu icons.
Breki
Érdekelne, hogy a mostani képernyőmnél alul a dock-ot ami jelenleg ilyen
Hogy lehet megcsinálni pontosan ilyenre
Breki
Hogyan tartsuk kordában telefonszámlánkat? - Call Meter 3G
Egy kis segítség, a pontos beállításhoz
[link] -
Breki
kripo666 #16531 üzenetére
A dock-on kell lennie egy hasonló üzenetek ikonnak
Egyébként
Alkalmazások
Keresés + B: Böngésző megnyitása
Keresés + C: Telefonkönyv megnyitása
Keresés + E: E-mail megnyitása
Keresés + G: G-Mail megnyitása
Keresés + I: Naptár megnyitása
Keresés + M: Google Maps megnyitása
Keresés + P: Zene megnyitása
Keresés + S: Szöveges üzenetek megnyitása
Keresés + Y: YouTube megnyitása -
Breki
Mai ajánlat
MX Home - 3D Launcher
[link] -
Breki
Simulates a reboot by closing/restarting all core and user processes (configurable) and thus frees up memory.
Your phone should be much snappier after using Fast Reboot Pro.- Select processes that should be excluded from being restarted/closed!
- Schedule automatic fast reboots (e.g. every day at 4am)
- Option to automatically fast reboot when you unlock your device (from standby)
- Comes with a widget to instantly start a rebootWhat's in this version:
-Some small bugfixes -
Breki
Ilyen van
Unlock With WiFi provides convenience, security, and battery saving, all in one package!
Unlock With WiFi unlocks your phone when you're connected to your home WiFi network. What does "unlock" mean? It means you don't have to enter your password/pattern/PIN when you turn on your phone. When you're at home, or work, you don't need to worry about losing your phone, so why should you have to enter your password?
How does it work?
When you get home and connect to your WiFi network, your device will unlock. Then when you leave, and the WiFi disconnects, the device will lock again. You have to enter your password the first time after you connect to your WiFi network. This is so that if someone steals or finds your phone, they can't just bring it to your house to unlock it. After you enter your password once while connected to your WiFi network, you won't have to enter it again until you leave/disconnect. This is great for SMS texting!
What else does it do?
You can also set a lock delay, for when you're not at home. The default delay is set to 5 seconds (you can adjust it), so when you turn the screen off, the device won't lock until 5 seconds have passed. That way, if you remember something you forgot to do, you can turn it back on without entering your password. This feature is considered experimental at this time. It works on most devices, but isn't guaranteed to work on all devices.
There are also battery saving options to:
Turn off WiFi when you leave home
Turn on GPS when you leave home*
Turn off GPS when you get home*
Turn on Bluetooth when you leave home
Turn off Bluetooth when you get home
Turn off Auto Sync when you leave home
Turn on Auto Sync when you get home* This feature is experimental, and not guaranteed to work on all devices.
Works on tablets too!
Breki
Agile Lock v1.5
If you have a double lock-screen problems,or home button problem, or the volume keys light up the screen, try using the "fix double lock issue" setting item.
Version 1.5
1.New feature: Users can choose their own font file.
2.New feature: During add widget, add zoom in and zoom out function.
3.Add "Display time", "Display date", "Display status message" setting item.
4.Fixed select shortcut icon problem.
5.Fixed FC problem.Narxis köszi
Breki
Narxis #16287 üzenetére
PowerMax-ról írhatnál kicsit bővebben azt még csak kipróbáltam
Más:
Make Your Clock Pro Beta v15 Android
Make Your Own Clock Widget. Add clock weather and battery status.
Make your very own clock widget design. Ultimate solution for all home screen modders.
You can create either minimalistic text-based or full features text based clock by yourself.
If you have a Taskmanager/Task Killer running please exclude/uninstall. They make your phone unstable.Main features:
- highly customizable clock widget
- weather widget
- battery widgetSupported sizes:
- 1x1, 1x2, 2x1, 2x2, 3x1,3x2, 4x1, 4x2, 4x4, 4x3, 5x3, 5x4Editor features:
- Textsize
- Textcolor
- Adjustable color
- Adjustable transparency
- Background color
- Font sizeWidget features:
- Single Tap to start App
- Disable TapWeb Gallery
- download designs from the webIMPORTANT: If clock NOT UPDATING please UNINSTALL TASK KILLER
-Web Gallery Remodeling
-Minor bug fixes and improvements -
Breki
Azért az órás működési elve érdekelne mert gondolom az is hasonló
TRob1 : Szerintem pedig nagyon pofás ahogy a három kör mozog és jól is néz ki ezért is használom
Keresném ezt a skint Weather & Toggle Widget-hez
After Hour Toggle a neve és elvileg ingyenes, de sehol sem találok linket hozzá
Breki
El tudná valaki magyarázni, hogy a következő képen látható Honeycomb-os 3 körös aksikijelző tulajdonképpen hogy működik?
A kiírás alapján oké, de a körök alapján ez, hogy olvasható le a pontos érték?
Breki
Visszatérve a nagy ikonokra találtam még kettőt ami egész jó
Sizone Theme GO Launcher EX
Icon App 1 Go Launcher EX
Breki
Breki
Breki
És miért is?
2001 óta járok ide megszoktam, hogy mindenkinek külön a hozzászólására válaszolok
hisz akkor még nem is volt szerkesztés gomb.
- AMD CPU-k jövője - amit tudni vélünk
- Amazfit Active 2 NFC - jó kör
- Telekom mobilszolgáltatások
- Amazon Kindle
- ÁRGARANCIA! Épített KomPhone i5 14400F 32/64GB DDR5 RTX 5060Ti 8GB GAMER PC termékbeszámítással
- NEC MultiSync V421 monitor (42") 1920 x1080px
- AKCIÓ! Apple MacBook PRO 15" 2018 i9 32GB 500GB 560X 4GB notebook garanciával hibátlan működéssel
- Bomba ár! Dell Latitude 5500 - i5-8GEN I 8GB I 256SSD I HDMI I 15,6" FHD I Cam I W11 I Garancia!
- BenQ PD-3200-U Monitor - Designer 4K 32"
Cég: CAMERA-PRO Hungary Kft
