- Akciókamerák
- AMD vs. INTEL vs. NVIDIA
Samsung LCD és LED TV-k
aag
tarkatehen #28866 üzenetére
Bocsika!
aag
Ezt a WVA 430TDE-1A2-est hol érdemes megvenni szerintetek? Hol a legolcsóbb?
aag
blakey #28778 üzenetére
Végre valaki aki szakmai választ akarna adni. Nos akkor elmondom, hogy a Mediainfo ezt adta ki rá:
General
Unique ID : 251371132750568348244450881682926078785 (0xBD1C51B53FAB900EA5ED295A875A0B41)
Complete name : /sample-Paul.2011.1080p.RETAiL.BluRay.x264.DTS.HUN-BiTZoNe.mkv
Format : Matroska
Format version : Version 2
File size : 90.7 MiB
Duration : 45s 464ms
Overall bit rate : 16.7 Mbps
Encoded date : UTC 2011-09-21 06:19:42
Writing application : mkvmerge v4.9.1 ('Ich will') built on Jul 11 2011 23:53:15
Writing library : libebml v1.2.1 + libmatroska v1.1.1Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High@L4.1
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Muxing mode : Header stripping
Codec ID : V_MPEG4/ISO/AVC
Duration : 45s 462ms
Bit rate : 14.1 Mbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.376
Stream size : 76.6 MiB (84%)
Language : EnglishAudio #1
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Bit rate mode : Constant
Bit rate : 754 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 24 bits
Compression mode : Lossy
Delay relative to video : 3ms
Stream size : 4.09 MiB (5%)
Title : hundub
Language : HungarianAudio #2
Format : DTS
Codec ID : A_DTS
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 8.18 MiB (9%)
Title : engdub
Language : EnglishText #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : hunsub.forced
Language : HungarianText #2
Format : UTF-8
Title : engsub
Language : EnglishText #3
Format : UTF-8
Title : hunsub
Language : Hungarian -
aag
Mi a félrevezetés? Hát az, hogy nem arra válaszoltok amit kérdeztem. Másra akartok rávenni. Ezt kérdeztem a #28727-ban:
"Mit javasoltok, milyen formátumba, milyen paraméterekkel végezzem az 1920-as felbontású mkv fájlok konvertálását, hogy a tévém is lejátssza, a képméret és a minőség pedig ne sokat romoljon?"
De erre a kérdésre nem kaptam választ, csak félrevezetést és szemétkedést. Most pedig magyarázod a bizonyítványod, de úgy, hogy személyeskedsz. Miért kell ez?
aag
LE40C530F1-es tévém van. Nem eszi meg az internetes 1980-as MKV-t. Mit javasoltok?
aag
szaszapi #14478 üzenetére
Igen, ez nálam is nagy gond. Megmondom én mit csináltam. Olcsó linuxos gép, olcsó USB-DVB-T dongle, Kaffeine szoftver és három kattintás az egérrel. Akár több csatornát is felvesz egyszerre minden gond nélkül. Nem terheli a gépet, lehet mellette bármit csinálni. A fene se kínlódik ezek után más megoldással.
aag
Anonymus23 #13880 üzenetére
aag
Szóval akkor jó a 100? Elhiszem nektek. Köszi!
aag
Ezt a 100 hercet én nem értem. Katódsugárcsöves monitoroknál még értettem, de lcd-nél nem tudom van-e még valódi haszna. Egyszer kíváncsi lennék két ugyanolyan tévére, amiben be, illetve ki van kapcsolva és ugyanaz az adás megy. Jó lenne látni a saját szememmel, hogy vajon látom-e a különbséget. (na ezt jólmegszondtam, de értitek remélem)
aag
Az természetes, hogy néha amikor gyengébb az antennajel, állomásváltáskor magas-éles kis csippantást ad a tévé?
aag
univerzita #13346 üzenetére
Azt megköszönöm ha körülnézel!
aag
univerzita #13335 üzenetére
Köszi, de ezt én nem merem megcsinálni. Csak akkor merném, ha valakinek ugyanolyan tévével mint az enyém, van már tapasztalata. Úgyhogy, köszi, de a te C650-esed szerintem más belsőrészű mint az enyém. Ami azon megy, nem biztos, hogy az enyémen is menne.
aag
univerzita #13331 üzenetére
LE40C530F1
Tudsz hozzá valami okosságot hogy legyen VR?
aag
Hahó! Jól leszaladt a kérdésem. Már nem is találom. Azért megkérdezem, tudtok valamit a C530-asok VR-módjáról?
aag
Újra beírom, mert gyorsan átlépte a topik és nem kaptam még választ rá:
Nagyon morcos vagyok, amiért a legolcsóbb Technika, meg egyéb névtelen szarok is már felveszik a TV-adást USB-re (DVB-T adásoknál), de az én méregdrága samum nem tudja ezt. Persze tudná, ha nem lenne letiltva. Nemértem miért nem találok valami "feloldást" rá. Lehetséges, hogy még senki nem csinált?
aag
Észrevettem egy érdekes dolgot. Samu tévém és samu kamerám van. LE40C530F1 és Q10. Namost fullhd 50i felvételnél más képet ad ha a kameráról nyomom az anyagot, mintha kirakom pendrájvra és a tévé játssza le. Nevezetesen arról van szó, hogy a kamera oldalmozgásánál a tévé által lejátszott kép elmosódik. Vagyishogy sokkal jobban elmosódik, mint a kamera által beadott képnél. Van valami tipp, hogyan lehetne javítani a tévé lejátszás-minőségén? Ha például frissítenék, az megoldaná?
aag
Szerinted én nem tudom, mi a motion resolution?
Fogalmam sincs arról, hogy te mit tudsz és mit nem. Azt viszont tudom, hogy a sorfelbontás fogalma, műszaki tartalma micsoda és hogyan változott az idők során. Ha ennyire jól képben vagy, nem kellek én ide. Majd elmondod te nekik.
aag
Freestyle79 #12380 üzenetére
aag
gulyasa #12370 üzenetére
Minden egyes típusnak (nem sorozatnak) saját egyedi EDID-je van.
Dehogyis! ON vagy OFF értéket vehet fel. Az ON esetében további beállítások lesznek elérhetők. Ezek nem gyártóspecifikus adatok, hanem beállítható tulajdonságok. Engem az érdekelne, hogy egy C530-as esetében mi a default beállítás. Jó lenne ha valaki kiolvasná nekem a sajátját. Ezzel nem kockáztat semmit. Köszönöm.
aag
A szerviz menüben mit jelent az EDID opció és mi a default értéke? (C530)
aag
Xmodule #6070 üzenetére
Info-Menu-Mute-Power (on) ekkor belepunk a service menube
Valóban, ekkor belépünk. Állítgathatunk. De ha balfékek vagyunk és elcsesztük, hogyan lehet rendbehozni? Nem látok olyan opciót, hogy "Load default". Vagy valami hasonló, de kellene. Vagy egy szervízkönyv, amiből kiderülnek a gyári default beállítások. Tudtok ilyesmit?
(#12337) canniball: Szólni fogok. Egyenlőre még nem kezdtem hozzá. Keresem a visszavonulási utat.
Sőt, az is érdekelne, hogy a szervízmenüben való matatást rögzíti-e a rendszer. Nemám ez miatt elvesztem a gart. (Bár nem látok a gar-papírban olyan szövegrészt ami erre utalna.)
aag
Bevallom őszintén nagyon kellemes meglepetés ért a divixes filmeimmel kapcsolatban. A monitoron a 320X240-es gyufaskatulyányi kis nézhetetlen vacak, a TV-nem "felskálázva" egészen nézhetővé vált. Az 1280-as szélességű meg kifejezetten szép lett. Ezt nem gondoltam volna. Meg vagyok vele elégedve.
aag
műszakilag nem is képesek másra. Stúdióban, broadcast minőségű berendezéseken konvertálják a filmeket 1080-ra.
Ez így nemigaz. Például arra is képesek, hogy a félkép sorrendet hibásan adják meg. Ilyenkor aztán rángatózó, lényegében élvezhetetlen film-szakaszt látunk a híradókban. Főleg a kereskedelmi tévéknél dolgoznak ilyen gagyigó szakemberek. Vagyis nem arról van szó, hogy azokon a gépeken ne lehetne perfekt munkát végezni, hanem arról, hogy az utcáról felvett, szaktudás nélküli olcsójánosokra bizzák a szakértelmet követelő munkát. Ennek szerves következménye az-az anomália-csoport amiről itt szó van.
aag
Imifej #12136 üzenetére
Szerintem ugyanaz volt a gondom mint neked. Én kizárólag DVB-T adásokat fogok. Tehát mindegyik digitális adás. Mióta beállítottam a globális 4:3-at és mellé az automata szélességet, minden helyesen jelenik meg a tévém képernyőjén. Nekem ennyi volt a megoldás és ez engem tökéletesen kielégít. Ha te valami mást szeretnél, ahhoz nem tudok hozzászólni. Akkor bocs.
aag
aag
Szeretnék valahonnan egy profi-kamerás 1080 50p-s filmrészletet letölteni. Tudtok valahol?
aag
ORCA58 #12049 üzenetére
Az adás vagy tartalmazza vagy nem a képméret infót. Ha nem , akkor a TV nem tudja beazonosítani azt.
Nem! Én a MINDIGTV DVB-T csatornáit fogom. Semmi mást! És nem úgy működik ahogy írjátok!
Most nemértem, már negyedszer írom, hogy egy csatornát beállítok és más csatornákra is rögtön az érvényes. Megint másokra pedig nem. Mi ennek a logikája?
aag
Imifej #12034 üzenetére
Az MTV1 és 2 is ad 16:9-ben és 4:3-ban is. Dőt a DunaHD is ad 4:3-ban is. Most akkor te úgy nézed ahogy adják és kész? Mert itt jön a bibi. Mondjuk az MTV2-nél automatába teszem, (mert éppen 16:9-es az adás), és rögtön az MTV1 és a retekklub is is 16:9-be kerül. Miért? Ez így marhaság! Már nagyon bosszant a dolog. Állandóan állítgatom a távirányító "P.size" gombjával.
Mi, -mivel van "összedrótozva" és miért? Valaki legyen olyan jó és homályosítson fel már engem erről az összevisszaságról!
Előre is: Please!
aag
Imifej #12031 üzenetére
Dehát ez pontosan a default állás. És ehhez képest kell nyomkodnom a távirányító méretarány gombját. És akkor van az, hogy átállítom, és ez a változás nem csak arra az egyetlen csatornára lesz hatással, hanem még egy jópár másikra is. De nem mindre. Ez-az amiben a logikát nem lelem. Mi-az ami alapján csoportosítva vannak ezek a csatornák?
aag
Mindig azt a képarányt választod, ami neked legjobban tetszik, illetve ami az adáshoz illik.
Azthiszem nemérted. Mondjuk az RTLKLUB mindig 4:3-as. De ha átállítok valami mást (mittudomén MTV2-őt) 16:9-re, akkor az RTLKLUB is arra vált, pedig annak 4:3-on kellene maradnia. Nemértem mi-mivel van összedrótozva és miért.
aag
Olyan gondom van a tévémmel (LE40C530F1WXXH), hogy ha egy digit-adást beállítok 4:3-ra, egy csomó más is azzá válik. Aztán vissza 16:9-re és visszaáll a többi is. Most mi ez? Hiba, vagy én vagyok tudatlan?
aag
Anonymus23 #11921 üzenetére
Én ultrahangos víztelenítésről beszéltem...
Húha, az milyen?
aag
DVB-T szobaantennával kapcsolatban tudtok topikot?
aag
...és honnan a fenéből tudta, hogy van új? Az én TV-m tipusa a kövekező: LE40C530F1WXXH. Jó lenne tudni, hogy egyáltalán hol vannak a frissítések és hogyan kell felrakni. Az is érdekelne, hogy a mostanit hogyan lehet elmenteni? Hátha vissza akarnám csinálni a dolgot? Egyébként az enyém nem akart még magától frissíteni. Lehethogy az én tipusom nem is tud ilyet? Egyáltalán, mi a frissítés felrakásának a módja?
aag
nightshadow #11780 üzenetére
Afenébedecsúnya! Akkor jobban jártam a fénycsöves megoldással?
(#11779) sandró60: kicsit levettem a gyári beállítás-fényerőből, mert majdkisütötte a szememet, de a kép egyébként nagyon rendben van. Szerintem.
Amin még problémázom az a firmware-frissítés. Most akkor kell, vagy nemkell? És mi a módja?
aag
nightshadow #11776 üzenetére
aag
magic_screen #11759 üzenetére
Szerintem is nyomdahiba.
aag
ORCA58 #11739 üzenetére
Ha annyira fontos a felvétel akkor marad a Box. de nem olcsó.
Egy péda: Ez 2 tuneres DVB-C és DVB-T [link]
9060-as változat ugyan ez csak a 1 tuner van benne. Nekem ez vanKérdeznék azért: A digi-adásokat milyen formátumban rögzíti? PC-n vágható marad a kártyás kódolt adásból felvett anyag?
aag
attamero81 #11714 üzenetére
Hümmm... jól hangzik, de engem most a record izgat nagyon.
aag
attamero81 #11712 üzenetére
C650-et? Hogyan és miért jó az nekem? Esetleg pont azt fogja tudni pluszban amit szeretnék? Felvenni USB-s pendrájvra?
aag
attamero81 #11708 üzenetére
Gondolom programozással akarod becsapni a tv-t?
Becsapniii? Nem. Egyszrűen arról van szó, hogy a központi csipp (és néhol a teljes hardver-környezet is) azonos, de a firmwer változik. Manapság (kb 15-20 éve) skálázzák a termékeket, hogy a nagytestvérek is eladhatók legyenek jó drágán. Így megy ez a PC-s processzoroknál, a videókameráknál, a TV-knél és még ki tudja miknél.
aag
attamero81 #11706 üzenetére
Nem a gyárira gondoltam, hanem egy "átalakítottra". Miért, mert bizonyos típusok tudják, az enyémben meg ez a funkció le van tiltva. Csináltam már ilyen "feloldást" anno DV-kameránál. Egyetlen bitet kellett átírni, máris tudott felvenni is. Gondolom ezt itt is meg lehet csinálni. Ez után érdeklődtem kedvesen és udvariasan.
aag
attamero81 #11702 üzenetére
Firmware-csere?
aag
Egy LE40C530E-jelű tévém van. Kérdésem: Hogyan tudnám azt elérni, hogy a beledugott pendrájvra felvegyen?
- Lexus, Toyota topik
- Nintendo Switch 2
- Honor 200 Pro - mobilportré
- Filmgyűjtés
- Mégsem érkezik előbb a Pixel 10 a vártnál
- LG (77C47LA) 195CM 120HZ 4K OLED PRÉMIUM ! AKCIÓ! UJ MODELL
- LG (OLED65B42LA) 165CM 4K 120HZ OLED ! UJ PRÉMIUM ! AKCIÓ!
- Samsung The Freestyle Gen. 2 Hordozható Smart Projektor + Samsung Battery Base akksi!
- Jabra Evolve2 85 Vezeték Nélküli Fejhallgató!
- LG 65" OLED65B49LA 165cm UHD 4K HDR Smart OLED Tv
- Maximális teljesítmény és biztonság, csak az ARCTIC mx-4-el! Adj új erőt a gépednek!
- PS5 konzolod megvásároljuk: Budapest, Kecskemét, Szeged, Debrecen vagy akár GLS futárt küldünk!
- ÁRGARANCIA!Épített KomPhone Ryzen 7 7700X 32/64GB RAM RTX 5070 12GB GAMER PC termékbeszámítással
- Azonnali készpénzes Intel i3 i5 i7 i9 12/13/14 gen processzor felvásárlás személyesen / csomagküldés
- LG 27GR95UM - 27" MiniLED - UHD 4K - 160Hz 1ms - NVIDIA G-Sync - FreeSync Premium PRO - HDR 1000
