- MWC 2026: Megérkezett a Xiaomi Pad 8 sorozat
- Mikor lesz már jó a Bluetooth? — Bluetooth 6.0 technológia
- Ilyen olcsó sem volt még egy Apple notebook
- Autós kamerák
- DUNE médialejátszók topicja
- Pedzegeti az új Xbox irányát a Microsoft
Vagyok
enzo_ferrari
#1
Végkifejlet?
Danecay
Hi All! Nos nekem most olyan problémám lenne, hogy a Easy Recovery Professional 6.01 szerint a 40-es Maxtorom partíciói (4db) hibásak.
A következőket írja:
''Recommendations:
Partition test for drive F failed, critical system structure errors have been found. Run the Full Diagnostic Test, from the DriveTests tool, on the drive containing the partition to verify if your drive has any physical problems. If you ARE experiencing a data loss situation, you should run the applicable tools in the Data Recovery category to recover lost data. Also, professional services are available by contacting Technical Support or Data Recovery Services. If you ARE NOT experiencing a data loss situation, use the Windows Check Disk tool or other file system repair utility like Ontrack Fix-It Utilities (TM) to fix the file structure errors. In the case of severely corrupted partitions, you may need to reformat you drive and restore data from a previous backup. NOTE: Reformatting your drive will destroy all data on your drive.''
Miután megcsináltam a javasolt Full Diagnostic Test-et, az eredmény a következő:
''Full Diagnostic Test for drive MAXTOR 6L040J2 passed, no physical drive problems have been found. Run the PartitionTests tool, from the Disk Diagnostics category, on any partitions with data loss, to verify on-disk structures. If you ARE experiencing a data loss situation, you should run the applicable tools in the Data Recovery category to recover lost data. Also, professional services are available by contacting Technical Support or Data Recovery Services.''
No akkor most mi az igazság? Sem a CHKDSK, sem a Norton Utility (igaz a 2002-es), sem a PQ Magic 8 paertícoó ellenőrzője nem találtahibát. A bizonság kedvéért megszüntettem a winyón lévő partíciókat, újraformatáltam az egészet, szektorellenőrzéssel meg minden, utánna újrapartícionáltam, Hogy nehogy úgy járjak mint nemrég, közel 200GB adatvesztés. Miután készen lettem vele, feltelepítettem újból az Easy Recovery-t és úrateszteletem. Az eredmény ugyan az. Beszereztem a javasolt progit az Ontrack Fix-It Utilities-t. Ez, végigmegy a kijelölt partycion, de vizsgáló, és javító procedúrák után, hibát nem jelez, ha viszont ismét leellenőrzöm az Easy Recovery-vel a hiba jelen van.
Mi lehet itt a gond? -
Vagyok
enzo_ferrari
#11
Így kiderül, hogy nem gyengusz é a tápod (bár szerintem ennyit még éppen bírhatna is). Azt is kiprószálhatod, hogy másik tápcsatira dugod a vinyót hátha a csati rosssssz.
enzo_ferrari
#11
Még azt elfelejtettem megkérdezni hogy milyen chipset van az alaplapodon..
Mert nálam pl: [I845PE], ha használom, a SATA-t akkor nem tud kezelni 4 ide eszközt, csak 3 at.. nem lehet hogy neked is ilyen problémád lehet???
Szerintem érdemes lenne megnézni, mint már előttem is mondták hogy lehúzod a cd-t és a dvd-t...hátha...:DD -
bcs
enzo_ferrari
#9
próbáld ki, hogy lehúzod a dvd-t, meg a cd írót
enzo_ferrari
halloooooo
enzo_ferrari
senki? :((
enzo_ferrari
#5
milyen és hány más ide eszköz van még a gépedben?? Cd?? Dvd??
enzo_ferrari
egy 300-as tápom van, gondolom nem valami márkás (nem tom) a kékhalnál a házzal együtt adták még egy éve mikor vettem...
Úgy néz ki, hogy amin az oprendszer van az egy SATA vinyó, és a maxtor van a rack-ben. A múltkor még le tudtam szedni az adatokat róla, igaz akkor sem elsőre, de sikerült. Most rögtön lefagy a másolás indításakor. Itt a benti gépben műxik, itt is slave-ként funkcionál. A haverom a múltkor elvitte, mert az adatokat DVD-re kiírta róla, nála sem volt gond...
röviden ennyi... -
enzo_ferrari
szasztok,
a problem a köv.: 80gb-s vinyóra a munkahelyemen simán tok másolni, de mikor otthon át szeretném pakolni a másik vinyómra az adatot akkor kattan egy kicsit és lefagy a rendszer.
Ez mi a szösztől lehet?! Megőrülök már, mert innen bentről vagy 40 GB adatot másoltam fel és otthon nem tok vele mit kezdeni...
- Gumi és felni topik
- Andras-G: Az internet veszélyei [2. rész] - Facebook Marketpalce
- Synology NAS
- Hálózati / IP kamera
- 1 TB Samsung, HGST, Western Digital 2,5" SATA-s winchesterek eladóak! 100/100
- 500 GB 2,5" SATA-s winchesterek eladóak (Samsung, Toshiba, Seagate) 100/100
- 500 GB 3,5" SATA-s winchesterek eladóak (Western Digital, Toshiba, Seagate) 100/100
- Hitachi 500GB 2,5"-os laptop hdd-k (ár és állapot a leírásban)
- BESZÁMÍTÁS! 2TB Kingston KC3000 NVMe SSD meghajtó garanciával hibátlan működéssel
- BESZÁMÍTÁS! ASUS H110M i5 6500 8GB DDR4 240GB SSD GTX 1050 Ti 4GB Zalman T3 Plus DeepCool 400W
- ÁRGARANCIA!Épített KomPhone Ryzen 5 4500 16/32/64GB RAM RTX 3050 6GB GAMER PC termékbeszámítással
- Újszerű Dell XPS 13 9310 - 13.4" FHD+ i7-1185G7 - 16GB - 1TB - Win11 PRO
- Telefon felvásárlás!! Samsung Galaxy A70/Samsung Galaxy A71/Samsung Galaxy A72
- Apple iPhone 11 Pro Max 64GB, Kártyafüggetlen, 1 Év Garanciával
