- M.2 SSD: hova tedd, hogy a leggyorsabb legyen?
- Bambu Lab 3D nyomtatók
- Házimozi haladó szinten
"Sokan hiányolták, hogy a CIS topiknak nincs első hsz-e, ráadásul tényleg hasznos lenne egy összefoglaló a programhoz, ezért most megszületett, használjátok egészséggel, remélem, néhányotoknak könnyít az életén és a "Sárkány" használatán!
ƵøŁĭ
Comodo Internet Security 6.0.259057.2639 BETA released
FIXED! Killswitch consumes too much CPU
FIXED! Killswitch does not exit properly
FIXED! Virtual Kiosk hangs in some computers
FIXED! Submission status dialog is shown during cloud scanning
FIXED! Browser home pages are changed to Yahoo after opting out
FIXED! Kiosk does not fit to VMWare screen
FIXED! KillSwitch doesn't handle rating for processes which launched from network location
FIXED! Ping command doesnt work inside sandbox
FIXED! No 'Run in COMODO Sandbox' function in right-click menu before reboot
FIXED! Killswitcxh deosnt allow blocking files
FIXED! Various fixes in Russian language translation
FIXED! CLT.exe running as 'Sandboxed application' is not placed in the list 'Show only Sandboxed Processes'
Letöltés: [link]
ƵøŁĭ
Vélemények Beta-ról?
ƵøŁĭ
CIS 6.0.258294.2626 beta
What's New?
IMPROVED! The desktop widget now have common tasks pane and status pane which shows # of sandboxed apps, unrecognized files etc.
IMPROVED! Killswitch now shows the traffic per process by default(should run as admin)
IMPROVED! Maximize window support added to relevant dialogs such as advanced settings, Quarantined items windows etc.
IMPROVED! Right click menu has been added to grids in relevant dialogs such as advanced settings
IMPROVED! Sound effects are used in alert windows to grab users' attention
IMPROVED! Log viewer has been redesigned to fir CIS 6 theme
IMPROVED! Offline virus database update functionality - Import Virus Database feature has been introduced
IMPROVED! File submission and lookup operations have been introduced
IMPROVED! Reboot reminder alert has been introduced to various places
IMPROVED! Diagnostics download missing files from the Internet
IMPROVED! Error log in updater is now accessible for more information
IMPROVED! Web Browser Data Folders file group has been created so that it could be added to sandbox exceptions to preserve various browser data e.g. downloads, bookmarks, chrome apps etc.(Not added by default currently)
IMPROVED! Configuration editor and virus scanning operations can now be performed in safe mode
IMPROVED! Better keyboard support(Press and hold ALT key to see options)
IMPROVED! Non-blocking grids with progress(e.g. trusted files, submitted file etc.)
IMPROVED! Trust connect integration reintroduced
IMPROVED! Upgrade to paid products is now possible
IMPROVED! Browse processes dialog has been improved
IMPROVED! Verbose mode for HIPS alerts added to configuration list
IMPROVED! Added an option to disable cache builder for antivirus
IMPROVED! Help buttons added to all dialogs
FIXED! cmdagent constantly access disk
FIXED! Behavior Blocker does not intercept some COM related operations for auto-sandboxed apps such as PCFlank leak test
FIXED! Windows 8 black screen of death on some computers
FIXED! Computer freezes after resetting sandbox
FIXED! Sandboxed bittorent doesnt function properly
FIXED! Sandboxed IE cannnot browse certain web pages with flash support
FIXED! Sandboxed browsers leak memory on some flash based web sites
FIXED! Cannot sandbox Dragon/Chrome if an instance is already running
FIXED! Password protection doesnt work in UI and Kiosk
FIXED! Firewall creates popup alerts in Game mode
FIXED! It is not possible to set Chrome/Dragon as default browser when they run in sandbox
FIXED! CIS consumes too much CPU while applying actions in scan windows
FIXED! Smart screen window closes automatically in Kiosk on Windows 8
FIXED! HIPS does NOT stop screen capturing/key logging when unknown apps run outside the sandbox
FIXED! CIS cant be started if cmdagent is disabled
FIXED! Web Browser option is missing in firewall alerts
FIXED! CIS alerts for shell32.dll after hibernation
FIXED! CIS shows undefined popup alert
FIXED! BSOD while running backup with shadowprotect
FIXED! AV alert freezes while applying some actions or being shown
FIXED! BSOD in kiosk during Firefox update
FIXED! Firewall creates alerts with random process names for IGMP -
ƵøŁĭ
Üdv mindenkinek!
Comodo termékek esetében a web védelem milyen formában érhető el , illetve hogy működik ?
(DNS,Siteinspector) -
ƵøŁĭ
PumpkinSeed #7064 üzenetére
Sajnos ez bármelyik AV mellet megtörténhet. Pontosan mit talál MBAM? Ne cseréld le a CIS-t , mivel a legjobb ingyenes IS . De ha mégis váltani akarsz , tűzfalukat használd
,más av mellett.
ƵøŁĭ
Hatos verzió újításainak felsorolása megtalálható valahol vagy csak beta testkor olvasható?
ƵøŁĭ
Comodo Virtual Kiosk for CIS 6
1 – Fully virtualized browsing and computing experience
2 – Isolated from keylogging, ideal for online banking
3 – Will turn the computer into an iPAD like UI
4 – The sandbox is significantly improved to support a lot more applications than previous edtions -
ƵøŁĭ
COMODO Cleaning Essentials 2.4.225190.192 Released!
What's new in CCE 2.4.225190.192?NEW!Add more system/process information to KillSwitch, including disk IO, network IO, GPU, .Net Assembly, etc.
NEW!Scan for abnormal system settings in CCE
IMPROVED!Detect and clean tdss boot partitions
IMPROVED!Enhanced Windows system file repair
IMPROVED!Clean remnants of viruses and rootkits from certain registry locations as well
IMPROVED!Added detection for files signed with weak Authenticode signatures.
IMPROVED! Defense CCE applications against global hook.
FIXED!Autorun Analyzer crashes under certain circumstance.
32bit:[link]
64 bit :[link] -
ƵøŁĭ
Misi 007 Fandango Köszi fiúk.
ƵøŁĭ
6.0 verzió mikorra várható?Lehet leírta már valaki ,de nem találom
,tartogat valami újdonságot ?
ƵøŁĭ
Tetszik ez a COMODO Dragon ,felturbóztam pár bővítménnyel nagyon bejön.
ƵøŁĭ
Üdv
Az utóbbi időben mennyit fejlődött a COMODO AV-része?Gondolok itt arra ,Avast,AVG termékekkel felveszi a versenyt vagy egy kategóriával lentebb sorolható.
ƵøŁĭ
Comodo agrees to pay AV-Comparatives.org $50,000 for 3rd party auditors to validate AV-Comparatives.org tests.
None of the AV-Comparatives.org tests are validated by a credible, independent 3rd party. It is in the end user interest to have the tests validated. There are many respectable independent and qualified organisations who can audit and validate AV-Comparatives testing methodologies and financial transactions.
This offer of payment is a goodwill gesture to AV-Comparatives.org so that they can prove to end users their testing methodologies and their financial relationships with Anti virus vendors. Its a win-win for everyone!
We are hopeful that AV-Comparatives will accept this offer and allow an independent third party audit and validate their claims in the interest of end users.
thank you
Melih
ƵøŁĭ
wilburwalsh #6283 üzenetére
Hát lehet de szerintem lesz itt olyan mega frissítés
, be kell hozni a lemaradásokat...
ƵøŁĭ
Latest Database Version:
10778
Release Date (all times GMT):
13-Nov-2011 19:21:22Khhm ellustultak a fiúk vagy mi történik ?
ƵøŁĭ
ƵøŁĭ
Üdv
Azzal a kérdéssel fordulok hozzátok,életemben nem használtam még Comodo IS-t ,hogy miben különbözik Avastól(IS),hiszen hamarosan lejár a kulcsom és láttam 1 évre van most promó
ƵøŁĭ
For the month of August 2011 here are the stats. Test done on October 18, 2011.
Number of Unique Files: 3137
Detected Without Heuristics: 3110
Additionally Detected With Heuristics on Low: 1
Additionally Detected With Heuristics on Medium: 0
Additionally Detected With Heuristics on High: 0
Not Detected: 26Total Detection Ratio: 99.2%
ƵøŁĭ
Ez létezik,hogy egy vírus kikapcsolja a vírusírtót?
- Battlefield 6 - Digitális játékkulcs
- Honor Magic5 Lite 128GB, Kártyafüggetlen, 1 Év Garanciával
- Lenovo Tab P12 / Wi-fi / 8/128GB / 12Hó Garancia
- HIBÁTLAN iPhone 14 128GB Midnight -1 ÉV GARANCIA - Kártyafüggetlen, MS3240
- iKing.Hu -Xiaomi 14T Pro Titan Gray Használt, karcmentes állapotban 12 GB RAM / 512 GB tárhely
Cég: CAMERA-PRO Hungary Kft.
