- PlayStation 4
- Product code CUH-1000A series
- Recommended retail price $399/€ 399/£349
- Main processor:
– Single-chip custom processor
– CPU : x86-64 AMD “Jaguar”, eight cores
– GPU : 1.84 TFLOPS, AMD next-generation Radeon based graphics engine - Memory GDDR5 8GB
- Storage size 500GB Hard disk drive
- External dimensions Approx. 275×53×305 mm (width × height × length)
- Mass Approx. 2.8 kg
- BD/ DVD drive (read only): BD × 6 CAV, DVD × 8 CAV
- Input/ Output:
– Super-Speed USBx (USB 3.0) port × 2
– AUX port × 1 - Networking:
– Ethernet (10BASE-T, 100BASE-TX, 1000BASE-T) ×1
– IEEE 802.11 b/g/n
– Bluetooth® 2.1 (EDR) - AV output:
– HDMI out port
– DIGITAL OUT (OPTICAL) port - Included:
– PlayStation 4 system × 1
– Wireless Controller (DUALSHOCK 4) × 1
– Mono headset × 1
– AC power cord × 1
– HDMI cable × 1
– USB cable × 1 - Wireless Controller for PlayStation 4 (DUALSHOCK 4)
- Product code CUH-ZCT1
- Recommended retail price $59/$59/€59/£54
- External dimensions Approx. 162mm × 52mm × 98mm (width × height × depth)
- Weight Approx. 210g
- Keys / switches:
- PS button, SHARE button, OPTIONS button
- Directional buttons (Up/Down/Left/Right)
- Action buttons (Triangle, Circle, Cross, Square)
- R1/L1/R2/L2 button, Left stick / L3 button, Right stick / R3
button, Pad Button
- Touch pad 2 Point Touch Pad, Click Mechanism, Capacitive Type
- Motion sensor Six-axis motion sensing system (three-axis gyroscope,
three-axis accelerometer) - Other features Light Bar, Vibration, Built-in Mono Speaker
- Ports: USB (Micro B), Extention Port, Stereo Headset Jack
- Wireless communication Bluetooth® Ver2.1+EDR
- Battery Type Built-in Lithium-ion Rechargeable Battery
- Voltage DC3.7V (tentative)
- Capacity 1000mAh (tentative)
- PlayStation Camera
- Product code CUH-ZEY1
- Recommended retail price $59/€49/£44
- External dimension Approx. 186mm × 27mm × 27mm (width × height × depth)
- Weight Approx. 183g (tentative)
- Video pixel (Maximum) 1280 × 800 pixel × 2
- Video frame rate 1280×800 pixel @ 60fps
- 640×400 pixel @ 120fps
- 320×192 pixel @ 240fps
- Video format RAW, YUV (uncompressed)
- Lens Dual Lenses, F value/F2.0 fixed focus
- Capture range 30cm~∞
- Field-of-view 85°
- Microphone 4 Channel Microphone Array
- Connection type PS4 dedicated connector (AUX connector)
- Cable length Approx. 2m (tentative)
