Computex 2024: az Acer Predator monitorok OLED lázban égnek
ph A cég harmadik negyedévben debütáló újdonságainál az 1440p és a 240 Hz jelenti az abszolút minimumot.
Ulefone Armor Pad 3 Pro - akkumulátor, lámpa, (tablet)
ma 33 280 mAh csak elég lesz bármire. És a régi hardver vagy szoftver?
OpenWrt topic
oatis
dhcp:
config dnsmasq
option domainneeded '1'
option boguspriv '1'
option filterwin2k '0'
option localise_queries '1'
option rebind_protection '1'
option rebind_localhost '1'
option local '/lan/'
option domain 'lan'
option expandhosts '1'
option nonegcache '0'
option authoritative '1'
option readethers '1'
option leasefile '/tmp/dhcp.leases'
option resolvfile '/tmp/resolv.conf.auto'
option localservice '1'
config dhcp 'lan'
option interface 'lan'
option dhcpv6 'server'
option ra 'server'
option ra_management '1'
option ignore '1'
config dhcp 'wan'
option interface 'wan'
option ignore '1'
config odhcpd 'odhcpd'
option maindhcp '0'
option leasefile '/tmp/hosts/odhcpd'
option leasetrigger '/usr/sbin/odhcpd-update'
config dhcp 'guest'
option interface 'guest'
option start '50'
option limit '200'
option leasetime '1h'firewall:
config defaults
option syn_flood 1
option input ACCEPT
option output ACCEPT
option forward REJECT
# Uncomment this line to disable ipv6 rules
# option disable_ipv6 1
config zone
option name lan
list network 'lan'
option input ACCEPT
option forward ACCEPT
config zone
option name wan
list network 'wan'
list network 'wan6'
option input REJECT
option masq 1
option mtu_fix 1
config forwarding
option src lan
option dest wan
# We need to accept udp packets on port 68,
# see https://dev.openwrt.org/ticket/4108
config rule
option name Allow-DHCP-Renew
option src wan
option proto udp
option dest_port 68
option target ACCEPT
option family ipv4
# Allow IPv4 ping
config rule
option name Allow-Ping
option src wan
option proto icmp
option icmp_type echo-request
option family ipv4
config rule
option name Allow-IGMP
option src wan
option proto igmp
option family ipv4
# Allow DHCPv6 replies
# see https://dev.openwrt.org/ticket/10381
config rule
option name Allow-DHCPv6
option src wan
option proto udp
option src_ip fe80::/10
option src_port 547
option dest_ip fe80::/10
option dest_port 546
option family ipv6
config rule
option name Allow-MLD
option src wan
option proto icmp
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
option family ipv6
# Allow essential incoming IPv6 ICMP traffic
config rule
option name Allow-ICMPv6-Input
option src wan
option proto icmp
list icmp_type echo-request
list icmp_type echo-reply
list icmp_type destination-unreachable
list icmp_type packet-too-big
list icmp_type time-exceeded
list icmp_type bad-header
list icmp_type unknown-header-type
list icmp_type router-solicitation
list icmp_type neighbour-solicitation
list icmp_type router-advertisement
list icmp_type neighbour-advertisement
option limit 1000/sec
option family ipv6
# Allow essential forwarded IPv6 ICMP traffic
config rule
option name Allow-ICMPv6-Forward
option src wan
option dest *
option proto icmp
option family ipv6
# include a file with users custom iptables rules
config include
option path /etc/firewall.user
### EXAMPLE CONFIG SECTIONS
# do not allow a specific ip to access wan
#config rule
# option src lan
# option src_ip 192.168.45.2
# option dest wan
# option proto tcp
# option target REJECT
# block a specific mac on wan
#config rule
# option dest wan
# option src_mac 00:11:22:33:44:66
# block incoming ICMP traffic on a zone
#config rule
# option src lan
# option proto ICMP
# option target DROP
# port redirect port coming in on wan to lan
#config redirect
# option src wan
# option src_dport 80
# option dest lan
# option dest_ip 192.168.16.235
# option dest_port 80
# option proto tcp
# port redirect of remapped ssh port (22001) on wan
#config redirect
# option src wan
# option src_dport 22001
# option dest lan
# option dest_port 22
# option proto tcp
# allow IPsec/ESP and ISAKMP passthrough
config rule
option src wan
option dest lan
option proto esp
config rule
option src wan
option dest lan
option dest_port 500
option proto udp
### FULL CONFIG SECTIONS
#config rule
# option src lan
# option src_mac 00:11:22:33:44:55
# option src_port 80
# option dest wan
# option dest_ip 194.25.2.129
# option dest_port 120
# option proto tcp
#config redirect
# option src lan
# option src_port 1024
# option proto tcp
config zone
option name 'guest'
option network 'guest'
option input 'REJECT'
option forward 'REJECT'
option output 'ACCEPT'
# Allow Guest -> Internet
config forwarding
option src 'guest'
option dest 'wan'
# Allow DNS Guest -> Router
# Client DNS queries ordinate from dynamic UDP ports (>1023)
config rule
option name 'Allow DNS Queries'
option src 'guest'
option dest_port '53'
option proto 'tcp udp'
option target 'ACCEPT'
# Allow DHCP Guest -> Router
# DHCP communication uses UDP ports 67-68
config rule
option name 'Allow DHCP request'
option src 'guest'
option src_port '67-68'
option dest_port '67-68'
option proto 'udp'
option target 'ACCEPT'network:
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd0c:9583:f25f::/48'
config interface 'lan'
option ifname 'eth1'
option force_link '1'
option type 'bridge'
option netmask '255.255.255.0'
option ip6assign '60'
option ipaddr '192.168.64.2'
config interface 'wan'
option ifname 'eth0'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '0 1 2 3 4'
config interface 'guest'
option ipaddr '10.0.0.1'
option dns '8.8.8.8 8.8.4.4 84.206.109.1'
option gateway '192.168.64.254'wireless
config wifi-device 'radio0'
option type 'mac80211'
option channel '11'
option hwmode '11g'
option path 'platform/ar934x_wmac'
option htmode 'HT20'
option txpower '18'
option country 'HU'
option distance '30'
config wifi-iface
option device 'radio0'
option network 'lan'
option mode 'ap'
option ssid 'XXXXXXX'
option encryption 'psk2'
option key '123456'
config wifi-iface
option mode 'ap'
option ssid 'guest'
option encryption 'none'Időközben megpróbáltam újra. Ezzel a beállítással dhcp működik, de a net továbbra sem. Még a fő routereme tse tudom pingelni a vendég hálózatról.
oatis
Töröltem, de sajnos nem működik a vendégen a net így sem. A lanhoz bridgelt wifin pedig minden ok.
Lehet ez nem is megoldható ilyen formában.
"If you want the OpenWRT to just be a simple Access Point, the upstream router will have to create the VLAN, and route to it in order to have internet access."[ Szerkesztve ]
oatis
Teljesen ki reseteltem a routert és a wan portokat töröltem.
Minden esetben a konfig fájlok végére másoltam az általad írtakat. a dhcp nem megy + az interfészeknél a guest zónára az írja: unsupported protocol type
dhcp:config dnsmasq
option domain 'lan'
config dhcp 'lan'
option ra 'server'
option ignore '1'
config dhcp 'wan'
option ignore '1'
option maindhcp '0'
config dhcp 'GUEST'
option interface 'GUEST'
option start '100'
option limit '15'firewall:
config defaults
option syn_flood 1
option input ACCEPT
config zone
option name lan
list network 'lan'
option input ACCEPT
config zone
option name wan
list network 'wan'
list network 'wan6'
option input REJECT
option masq 1
option mtu_fix 1
config forwarding
option src lan
option dest wan
config rule
option src wan
option proto udp
option dest_port 68
option family ipv4
# Allow IPv4 ping
config rule
option src wan
option proto icmp
option family ipv4
config rule
option src wan
option proto igmp
option family ipv4
config rule
option src wan
option proto udp
option src_port 547
option family ipv6
config rule
option src wan
option proto icmp
option family ipv6
config rule
option src wan
option proto icmp
option family ipv6
config rule
option src wan
option dest *
option proto icmp
option family ipv6
config include
#config rule
# option src lan
# option dest wan
# option proto tcp
#config rule
# option dest wan
#config rule
# option src lan
# option proto ICMP
#config redirect
# option src wan
# option dest lan
# option proto tcp
#config redirect
# option src wan
# option dest lan
# option proto tcp
config rule
option src wan
option dest lan
option proto esp
config rule
option src wan
option dest lan
option proto udp
#config rule
# option src lan
# option dest wan
# option proto tcp
#config redirect
# option src lan
# option proto tcp
config zone
option name 'lan'
option input 'ACCEPT'
option forward 'ACCEPT'
option masq '1'
option mtu_fix '1'
config zone
option name 'GUEST'
option network 'GUEST'
config forwarding
option dest 'lan'
option src 'GUEST'
config rule
option name 'GUEST-DNS'
option family 'ipv4'
option src 'GUEST'
config rule
option name 'GUEST-DHCP'
option proto 'udp'
option src 'GUEST'
option src_port '67-68'network
option ifname 'lo'
option ula_prefix 'fd9a:af65:6f91::/48'
option dns '8.8.8.8 8.8.4.4'
config switch
option reset '1'
config switch_vlan
option vlan '1'
config interface 'GUEST'
option ipaddr '192.168.101.1'
option dns '8.8.8.8 8.8.4.4'wireless
option channel '11'
option hwmode '11g'
option txpower '18'
option country 'HU'
config wifi-iface
option mode 'ap'
option key 'xxxxxx'
config wifi-iface
option mode 'ap'
option ssid 'guest'
option encryption 'none' -
Egy percig sem gondoltam, hogy nem hiszed, sokkal inkább magamban nem voltam biztos
Valoszínű mindent ki fogok próbálni amit javasoltatok és tudok.Még egy kérdésem lenne. Arra van valami lehetőség hogy online lássam a rácsatlakozott eszközöket egy logfile-ba, vagy valahogy úgy ahogy a luci-n is látszik? Gyakorlatilag ugyan azt szeretném megvalosítani csak egy külső eszközön.
Meglátszik az 1 óra alvás eredménye. Egész nap szorakoztam vele táveléréssel, majd miután leirtad is, es csak most, nemrég esett le, hogy azert "nem működik" mert nincs otthon senki aki rácsatlakozott volna. Asszem mentem haza aludni. (Közben kiderült, hogy mindkét megoldas jó) köszönöm
Zirowe
Ez gyakorlatilag kb majdnem minden, amit felraknék, köszi szépen.
Most már egyre jobban várom.
Mik a tapasztalatok emag kiszállítási idejével?
Nekem holnapot írt, de tudom, hogy az irreális.Igen, próbáltam már trunkot, első alkalommal volt is meglepetés, azóta már nem.
We've jumped way beyond the Red Line. Limited supplies. Limited fuel, and now no hope! But I promise you one thing. On the memory of those lying here before you, we shall find it. And Earth will become our new home. So say we all!
sutszi
Ahogy látom alakul a wifi stabilitás... Ha ez a probléma megoldódik akkor megfontolom.
Mondja, Mr. Babbage, ha rossz adatokat ad meg a gépnek, akkor is jó válasz fog kijönni belőle?" Képtelen vagyok felfogni azt az értelmi zavart, ami valakit egy ilyen kérdés feltevésére késztethet. - by Charles Babbage
syler123
Akkor én még várok, mert a legtöbb eszközöm csak 2,4ghz-es wifit tud.
Nem úgy volt hogy 2 mag van csak és 4 szál? Mert ha így van akkor ez így ebben a formában nem igaz "A 4 mag miatt a 4-es load felel meg 1-nek!". Openwrt oldala 2 magról árulkodik.
Nem tudom így teljesítményben mennyivel lenne jobb mint a xiaomi mini router, maga a gigabites port ami erre a dlink-re vinne engem, de ha nem jó a wifi, akkor nálam kilőve. Lehet soha nem lesz rá normális wifi driver (2013-as termék és még mindig nem jó a wifi).
Zirowe
Közben megoldódott, az automount kavart be.
lócitrom
fasza. akkor találgathatok életem végéig gondolom. most ismét hasonló gond akadt, de most ellenőriztem mindkét végről a kábelt. végtelenségig csinálná, ha jól sejtem:
Nov 3 07:50:14 TL-WR741ND kern.info kernel: [227331.720000] br-lan: port 1(eth0) entered disabled state
Nov 3 07:50:14 TL-WR741ND kern.info kernel: [227332.140000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:14 TL-WR741ND kern.info kernel: [227332.140000] br-lan: port 1(eth0) entered forwarding state
Nov 3 07:50:14 TL-WR741ND kern.info kernel: [227332.150000] br-lan: port 1(eth0) entered forwarding state
Nov 3 07:50:14 TL-WR741ND kern.info kernel: [227332.260000] eth0: link down
Nov 3 07:50:15 TL-WR741ND kern.info kernel: [227332.640000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:15 TL-WR741ND kern.info kernel: [227332.760000] eth0: link down
Nov 3 07:50:15 TL-WR741ND kern.info kernel: [227333.140000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:15 TL-WR741ND kern.info kernel: [227333.420000] eth0: link down
Nov 3 07:50:16 TL-WR741ND kern.info kernel: [227333.640000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:16 TL-WR741ND kern.info kernel: [227333.720000] eth0: link down
Nov 3 07:50:16 TL-WR741ND kern.info kernel: [227334.140000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:16 TL-WR741ND kern.info kernel: [227334.150000] br-lan: port 1(eth0) entered forwarding state
Nov 3 07:50:16 TL-WR741ND kern.info kernel: [227334.220000] eth0: link down
Nov 3 07:50:17 TL-WR741ND kern.info kernel: [227334.640000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:17 TL-WR741ND kern.info kernel: [227334.650000] eth0: link down
Nov 3 07:50:17 TL-WR741ND kern.info kernel: [227334.720000] br-lan: port 1(eth0) entered disabled state
Nov 3 07:50:17 TL-WR741ND kern.info kernel: [227335.140000] eth0: link up (1000Mbps/Full duplex)
Nov 3 07:50:17 TL-WR741ND kern.info kernel: [227335.140000] br-lan: port 1(eth0) entered forwarding state
Nov 3 07:50:17 TL-WR741ND kern.info kernel: [227335.150000] br-lan: port 1(eth0) entered forwarding state
Nov 3 07:50:18 TL-WR741ND kern.info kernel: [227335.700000] eth0: link downa rádugott eszköz egy laptop gigabites aljzattal. akármelyikbe csatlakoztatom ugyanez van. de újraindítgatni meg nem szeretném. nem lehet valami paranccsal újralőni az aljzatokat külön net bontása nélkül?
„the cake is a lie” - mi band 4 fordítás: https://bit.ly/miband4hu - mi band 5 fordítás: https://bit.ly/miband5hu - mi band 6 fordítás: https://bit.ly/miband6hu
Vargalex 1.1.7, egy 16 gigás pendrivet dugtam rá próba gyanánt, semmi nincs rajta. 2 partícióra formáztam, egy 128 megás SWAP partíciót, a többit tárhelynek. Elvben formatálás után magától fel kellene csatolnia a tárhelyet.
Lehet tolok az egészre egy alaphelyzetet, ezt csak a reset gombal lehet, vagy van a menüben opció rá?[ Szerkesztve ]
sutszi
Azzal kapcsolatban van valami előrelépés, vagy még mindig rossz a wifi?
Értem, de elvben akkor nem szabadna elfogyni a helynek rajta. Használtan vettem a routert, gyári fw, én raktam rá a rendszert. Most nyomtam rá egy alapbeállítást, azóta 5 perce csak pörög a karika, hogy:
A rendszer most törli a konfigurációs partíciót majd újraindul.
Betöltés Waiting for changes to be applied...
Egyre jobban tetszik a dolog, meglesz az elfoglaltságom mostanában, mire mindent beállítok.
Mert a gyerekszobában a szekrény alatt vigyorog, mert a mi szobánk olyan mint egy űrhajó már, az asszony meg ugat így is mint a sakál (nem, nem vagyok bunkó, imádom a feleségem, de nem hallottátok még emelt hangerőn reklamálni az éjszakai díszkivilágítás miatt )
De nem baj, most átosonok és áthozom ide -
vargalex
Újra tesztelgettem kicsit a DIR-860L-t sebesség szempontjából. A NAT képességet iperf3-al mértem, az sokkal jobban közelít a valósághoz:
gavarga@gavarga-e5540 ~ % iperf3 -c 192.168.22.200 -i 1
Connecting to host 192.168.22.200, port 5201
[ 4] local 192.168.10.175 port 44966 connected to 192.168.22.200 port 5201
[ ID] Interval Transfer Bandwidth Retr Cwnd
[ 4] 0.00-1.00 sec 113 MBytes 950 Mbits/sec 0 527 KBytes
[ 4] 1.00-2.00 sec 111 MBytes 935 Mbits/sec 0 553 KBytes
[ 4] 2.00-3.00 sec 112 MBytes 936 Mbits/sec 0 1.03 MBytes
[ 4] 3.00-4.00 sec 111 MBytes 928 Mbits/sec 0 1.31 MBytes
[ 4] 4.00-5.00 sec 111 MBytes 933 Mbits/sec 0 1.31 MBytes
[ 4] 5.00-6.00 sec 112 MBytes 938 Mbits/sec 0 1.38 MBytes
[ 4] 6.00-7.00 sec 111 MBytes 935 Mbits/sec 0 1.38 MBytes
[ 4] 7.00-8.00 sec 110 MBytes 927 Mbits/sec 0 1.79 MBytes
[ 4] 8.00-9.00 sec 108 MBytes 909 Mbits/sec 6 1.71 MBytes
[ 4] 9.00-10.00 sec 111 MBytes 935 Mbits/sec 0 1.71 MBytes
[ 4] 0.00-10.00 sec 1.09 GBytes 933 Mbits/sec 6 sender
[ 4] 0.00-10.00 sec 1.08 GBytes 930 Mbits/sec receiver
iperf Done.Szóval, úgy tűnik, hogy teljesen jó OpenWrt-vel akár gigabites Digi/Telekom nethez is.
A transmission letöltés folyamatosan 6 MB/s (kicsivel néha fölötte) volt teljesen alap configgal. A transmission csak 1 magot használ, így a load 1 körül alakult. A 6 MB/s-es letöltés közben újra futtattam egy iperf3-at:gavarga@gavarga-e5540 ~ % iperf3 -c 192.168.22.200 -i 1
[ 4] local 192.168.10.175 port 44820 connected to 192.168.22.200 port 5201
[ 4] 0.00-1.00 sec 92.9 MBytes 779 Mbits/sec 0 3.08 MBytes
[ 4] 1.00-2.00 sec 94.6 MBytes 794 Mbits/sec 0 3.08 MBytes
[ 4] 2.00-3.00 sec 97.1 MBytes 815 Mbits/sec 0 3.08 MBytes
[ 4] 3.00-4.00 sec 91.1 MBytes 764 Mbits/sec 0 3.08 MBytes
[ 4] 4.00-5.00 sec 88.7 MBytes 744 Mbits/sec 0 3.08 MBytes
[ 4] 5.00-6.00 sec 96.6 MBytes 811 Mbits/sec 0 3.08 MBytes
[ 4] 6.00-7.00 sec 81.5 MBytes 684 Mbits/sec 0 3.08 MBytes
[ 4] 7.00-8.00 sec 90.8 MBytes 761 Mbits/sec 0 3.08 MBytes
[ 4] 8.00-9.00 sec 98.1 MBytes 822 Mbits/sec 0 3.08 MBytes
[ 4] 9.00-10.00 sec 97.5 MBytes 818 Mbits/sec 0 3.08 MBytes
[ 4] 0.00-10.00 sec 929 MBytes 779 Mbits/sec 0 sender
[ 4] 0.00-10.00 sec 926 MBytes 777 Mbits/sec receiver
iperf Done.Alex
sutszi
Ez remek hír. Köszi.
Már nagyon kíváncsi vagyok, mi sül ki a wifis témából... Ha menni fog, egyből veszek egyet és cserélem a wdr3600-at.
bigrock
Akkor, ha jól értem, az
/Openwrt_Chaos_Calmer/D-LINK-DIR-860L-B1/
mappából először felrakom aopenwrt-15.05.1-ramips-mt7621-dir-860l-b1-squashfs-factory.bin
-t
majd újraindulás után a biztonsági mentés címszóval feltöltöm asuste-headless-0.8.2-backup-Dlink860l-2016-11-05.tar.gz
állományt? -
woodworm
Mivel ott volt kéznél, az oldaladról töltöttem le a gyári fw-re való bin-t. Az md5 rendben lefutott, de valami nem százas az fw-vel, már a luci is nehezen röffent be, viszont egyszerűen nem fogad jelszót. Hiába írom be, folyamatosan ott a figyelmeztető szöveg és nem tudok mozogni a felületen.
sutszi
Tehát a 2,4Ghz teljesen off-on van, és csak 5Gghz AC-s hálózat van? Tapasztaltál más anomáliát a 2.4-es Wifi-n kívül?
Zirowe
Mondjuk ha a xiaomi minibol indulok ki, ami azert mar egy ideje kaphato, de a wifije nem okes se cc, se dd alatt, akkor a lelkesedes egy kicsit alabb adodik..
Zirowe
+vargalex
Nagyjabol most elegedett vagyok a xiaomi minivel, egyedul a procijat erzem neha lassunak.
Ki fogom most probalni vargalex altal emlitett LEDEt, eddig meg nem volt szerencsem hozza.
Amugy meg turelemmel varom a fejlemenyeket, csak csodalkozva latom, hogy openwrt forumon egyaltalan nem foglalkoznak a temaval, asszem osszesen 1 topicban ha volt rola szo par hszmerejeig tavasszal.Masik kerdes: erdemes a hd-idlet hasznalni?
Nyaron vettem egy 500gb-s 2.5" hddt.
Ment nalam osszesen 76napot, ezalatt kb 2000 leallas/indulast csinalt az en felhasznaloi szokasaimmal es 10percre beallitott hd-idlevel, amit igy hirtelen soknak tartok, de lehet megsem olyan nagy szam.
Most lecsereltem egy 1tbs wd10jpvx vinyora, amit szeretnem hogy sokaig szolgaljon.
A torrentezes nem olyan intenziv, napkozben nulla, max este filmnezes kozben, neha ejjel.We've jumped way beyond the Red Line. Limited supplies. Limited fuel, and now no hope! But I promise you one thing. On the memory of those lying here before you, we shall find it. And Earth will become our new home. So say we all!
A 3.5-es vinyót nem ette meg, Revoltec ház, külső táp, No Drive found, 64 gigás pendrive-t megint csak nem, 16 gigásat nem csatolja, szóval marad a "nem veszek tudomást a hibáról állapot", és várok, hogy a drága kicsi távol keleti barátaink küldjék a HUB-ot. (külső tápos, nem vacak, de kínai )
woodworm
Valami nem kóser nálam. Hiába viszem végig a procedúrát, a legvégén újraindítva a routert nem működik a 9092-es felület. Tanulva a múltkori esetből, lehúztam az elöl lévő routert és csak a d-link csatlakozott a gépre. A fájlokat még lementettem az előző héten, de a friss sem működik.
- Steam kulcsok - UTALÁS/REVOLUT
- Megmaradt - Eredeti Humble, Choice - Steam kulcsok
