Intel Celeron 1.10GHz és egy kis tuning infó!
Egy kis adalék a lelkes tuningolóknak :). Mint tudjuk, a steppinget érdemes figyelni, azon belül is az új, cD0-ás verziót. A cD0-ás stepping teszi lehetővé a Coppermine-256 (P3) és Coppermine-128 (Celeron) prociknak az 1.13GHz-es órajelet, tehát pl egy cD0-ás 800MHz-es (100MHz-es FSB) Celeron egész biztosan elmegy majd 1066MHz-en (133MHz FSB). Ilyen FSB mellett pedig már nem marad el sokkal a P3-tól...
Node, jöjjenek a száraz adatok, egyenesen az Intel oldaláról:
Speed (MHz) Boxed (S-spec) OEM (S-spec) Stepping CPUID L2 Cache Size Thermal Spec (°C) Thermal Design Power (W) Notes
733 SL4P3 SL4P7 cC0 0686 128K 80 19.1 3,4,5,6,8,12
N/A SL52Y cD0 068A 128K 80 22.8 3,4,5,6,11,12
766 SL4QF SL4P6 cC0 0686 128K 80 20.0 3,4,5,6,8,12
N/A LS52X cD0 068A 128K 80 23.6 3,4,5,6,11,12
800 SL55R/SL4TF SL4TF cC0 0686 128K 80 20.8 3,4,5,6,8,13
N/A SL54P cD0 068A 128K 80 24.5 3,4,5,6,8,13
850 SL5GB SL5GA cC0 0686 128K 80 22.5 3,4,5,6,8,13
N/A SL54Q cD0 068A 128K 80 25.7 3,4,5,6,8,13
900 SL5MQ SL5LX cD0 068A 128K 77 26.7 3,4,5,6,11,13
950 SL5V2 SL5UZ cD0 068A 128K 77 26.7 3,4,5,6,11,13
1.0 GHz SL5XQ SL5XT cD0 068A 128K 77 26.7 3,4,5,6,11,13
1.1 GHz SL5XR SL5XU cD0 068A 128K 77 26.7 3,4,5,6,11,13
1. This processor is in S.E.P.P. form factor
2. This processor is in PPGA form factor
3. This processor is in FC-PGA form factor
4. This processor is a die shrink to 0.18 micron process technology.
5. This processor's L2 cache has a 4GB address range and supports ECC, which cannot be disabled.
6. These processors implement independent Vtt and Vcccore power planes.
7. Vcc for processor core = 2.00 V.
8. Vcc for processor core = 1.70 V.
9. Vcc for processor core = 1.65 V.
10. Vcc for processor core = 1.50 V.
11. Vcc for processors core=1.75 V.
12. This processor's system bus operates at 66 MHz only
13. This processor's system bus operates at 100 MHz only
  • Intel
