1983. szeptember 27.
A Massachusettsi Műszaki Egyetem (MIT) mesterséges intelligenciát kutató laboratóriumának programozója, Richard M. Stallman bejelenti a GNU Projektet, amely egy Unix-szerű, de kizárólag szabad szoftverekből álló operációs rendszer kifejlesztését célozza. A munka végül 1984 januárjában kezdődött el, a nyílt rendszer pedig 1992-ben a Linux-kernel beemelésével vált teljessé. A GNU egy rekurzív rövidítés, melynek feloldása: „a GNU nem Unix”.
Stallman a GNU-mozgalom születéséről
A bejelentés eredeti, angol nyelvű szövege:
From CSvax:pur-ee:inuxc!ixn5c!ihnp4!houxm!mhuxi!eagle!mit-vax!mit-eddie!RMS@MIT-OZ
Newsgroups: net.unix-wizards,net.usoft
Subject: new Unix implementation
Date: Tue, 27-Sep-83 12:35:59 EST
Organization: MIT AI Lab, Cambridge, MA
Free Unix!
Starting this Thanksgiving I am going to write a complete
Unix-compatible software system called GNU (for Gnu's Not Unix), and
give it away free to everyone who can use it.
Contributions of time, money, programs and equipment are greatly
needed.
To begin with, GNU will be a kernel plus all the utilities needed to
write and run C programs: editor, shell, C compiler, linker,
assembler, and a few other things. After this we will add a text
formatter, a YACC, an Empire game, a spreadsheet, and hundreds of
other things. We hope to supply, eventually, everything useful that
normally comes with a Unix system, and anything else useful, including
on-line and hardcopy documentation.
GNU will be able to run Unix programs, but will not be identical
to Unix. We will make all improvements that are convenient, based
on our experience with other operating systems. In particular,
we plan to have longer filenames, file version numbers, a crashproof
file system, filename completion perhaps, terminal-independent
display support, and eventually a Lisp-based window system through
which several Lisp programs and ordinary Unix programs can share a screen.
Both C and Lisp will be available as system programming languages.
We will have network software based on MIT's chaosnet protocol,
far superior to UUCP. We may also have something compatible
with UUCP.
Who Am I?
I am Richard Stallman, inventor of the original much-imitated EMACS
editor, now at the Artificial Intelligence Lab at MIT. I have worked
extensively on compilers, editors, debuggers, command interpreters, the
Incompatible Timesharing System and the Lisp Machine operating system.
I pioneered terminal-independent display support in ITS. In addition I
have implemented one crashproof file system and two window systems for
Lisp machines.
Why I Must Write GNU
I consider that the golden rule requires that if I like a program I
must share it with other people who like it. I cannot in good
conscience sign a nondisclosure agreement or a software license
agreement.
So that I can continue to use computers without violating my principles,
I have decided to put together a sufficient body of free software so that
I will be able to get along without any software that is not free.
How You Can Contribute
I am asking computer manufacturers for donations of machines and money.
I'm asking individuals for donations of programs and work.
One computer manufacturer has already offered to provide a machine. But
we could use more. One consequence you can expect if you donate
machines is that GNU will run on them at an early date. The machine had
better be able to operate in a residential area, and not require
sophisticated cooling or power.
Individual programmers can contribute by writing a compatible duplicate
of some Unix utility and giving it to me. For most projects, such
part-time distributed work would be very hard to coordinate; the
independently-written parts would not work together. But for the
particular task of replacing Unix, this problem is absent. Most
interface specifications are fixed by Unix compatibility. If each
contribution works with the rest of Unix, it will probably work
with the rest of GNU.
If I get donations of money, I may be able to hire a few people full or
part time. The salary won't be high, but I'm looking for people for
whom knowing they are helping humanity is as important as money. I view
this as a way of enabling dedicated people to devote their full energies to
working on GNU by sparing them the need to make a living in another way.
For more information, contact me.
Arpanet mail:
RMS@MIT-MC.ARPA
Usenet:
...!mit-eddie!RMS@OZ
...!mit-vax!RMS@OZ
US Snail:
Richard Stallman
166 Prospect St
Cambridge, MA 02139
  • 1985. október 14.
    Bjarne Stroustrup, a programnyelv kidolgozója kiadja a C++ első kereskedelmi célú implementációját, ezzel egy időben megjelenik a nyelvhez általa írott első kézikönyv (The C++ Programming Language). Stroustrup az AT&T Bell Laboratories megbízásából 1979-ben kezdett hozzá a C nyelv utódjaként meghatározott C++ fejlesztéséhez.
  • 1969. október 29.
    Este fél tizenegykor egy 50 kb/s-os telefonvonalon egy IMP-t (Interface Message Processor – üzenetfeldolgozó processzor) használva összekapcsolódik az UCLA SDS Sigma 7-es és az SRI SDS 940-es számítógépe, és ezzel gyakorlatilag megszületik az ARPANET, az első nagy távolságokat összekötő csomagkapcsolásos hálózat, az internet legfontosabb elődje. Magát az IMP-t már szeptember elején üzembe helyezték, sokan ezért azt a dátumot tartják az internet születésnapjának.
  • 1996. október 30.
    Megjelenik a Linuxra, illetve Unixra a Raster (Carsten Haitzler) által írott Enlightenment (E) ingyenes, nyílt forrású ablakkezelő első verziója.
  • 2000. október 30.
    Lekapcsolják az utolsó Multicsot (Multiplexed Information and Computing Service) használó számítógépet. Az 1964-től az USA-ban kialakított korai időmegosztó, többfelhasználós, többfeladatos operációs rendszer fejlesztését az akkori tulajdonos, a Honeywell az 1980-as évektől leállította. A munkából 1969-ben kiszálló Ken Thompson és Dennis Ritchie az itt szerzett tapasztalatokat is felhasználta a Unix létrehozásánál.
  • 2005. szeptember 2.
    A Sun úgy dönt, hogy megszünteti az SISSL licencét (Sun Industry Standards Source License), s ennek következtében az OpenOffice.org Közösségi Tanács bejelenti, hogy az addig kettős licencű nyílt forrású irodai programcsomagra a jövőben csak az LGPL (GNU Library General Public License) vonatkozik.
  • 1991. augusztus 25.
    A 21 éves finn egyetemista, Linus Torvalds egy hírcsoportban elhelyezi legendássá vált bejegyzését, mely így kezdődik: „Üdv minden Minix-felhasználónak odaát! Egy (ingyenes) operációs rendszert csinálok (csak hobbiból, nem lesz olyan nagy és profi, mint a gnu) a 386-os (486-os) AT-klónokhoz.” E bejelentés nyomán ezt a napot tartják a Linux hivatalos születésnapjának.
  • 1927. augusztus 9.
    Egy New York-i zsidó család gyermekeként megszületett Marvin Minsky, az MIT mesterségesintelligencia-kutatással foglalkozó AI-laborjának egyik alapítója. Az 1969-ben Turing-díjat kapott, kivételesen széles látókörű, kiemelkedő tudományos munkásságot felmutató kutató az 1950-es évektől kezdve roppant sok muníciót adott a számítástechnika AI-fejlesztéseinek.
  • 1953. március 16.
    New Yorkban megszületett Richard Matthew Stallman szabadszoftver-aktivista, hacker, szoftverfejlesztő. 1983 szeptemberében ő indította el a GNU projektet, azóta is ő a projekt vezető mérnöke és szervezője. Ugyanekkor kezdeményezte a szabad szoftver mozgalmat is, és 1985 októberében megalapította a Free Software Foundationt. Stallman volt a copyleft fogalmának egyik propagátora, alkalmazásának úttörője is.
