ECS K7S6A review
ECS K7S6A
PROCESSORS
  • 462 pin Socket A supports AMD® Athlon (K7) processors
  • Full series of Athlon XP/Athlon/Duron processors
  • Supports 100/133 MHz frontside bus (FSB)
  • CHIPSET
  • SiS® 745 System Chipset
  • Super I/O and LPC - ITE8705F
  • System Hardware Monitor: Built-in ITE8705F
  • AC97 Audio Codec
  • MEMORY
  • Three 184-pin DDR DIMM sockets to support
  • Three 2.5V DDR SDRAM (DDR266/DDR200) or
  • Two 2.5V DDR SDRAM (DDR333)
  • Maximum: 3GB
  • SYSTEM BIOS
  • Award 2Mb Flash EEPROM
  • Supports Plug and Play 1.0A, APM 1.2, Multi Boot, DMI
  • Full Support for ACPI revision 1.0 specification
  • I/O INTERFACE
  • Supports Plug and Play function
  • PS/2 keyboard and PS/2 mouse connectors
  • Two USB Ports
  • One - EPP/ECP mode parallel port
  • Two - 16550 high-speed serial I/O ports
  • Audio Ports (Line-in, Line-out, Mic-in, CD-in and game port)
  • Dual PCI IDE interfaces - support four IDE devices (PIO mode 4, DMA Mode 2, Ultra DMA 33/66/100)
  • Supports 360K~2.88M Byte, 3 Mode FDDs or LS120
  • ATX Power Supply Connector
  • ports, Headers and Others:
  • IrDA Cable header
  • Four additional USB ports (USB2/3 or LUSB1/2)
  • Two CD-In headers
  • Front Panel MIC/Line-Out header
  • HDD LED, ACPI MSG LED, Reset Switch, Power Switch headers
  • CPU and Case Fan headers
  • LAN Card Wake Up/Internal Modem Ring Wake Up headers
  • RTC & BATTERY
  • SiS® 745 included 256 bytes of CMOS SRAM
  • With CMOS SRAM hardware clear jumper
  • EXPANSION SLOTS
  • 5 PCI slots, 1 4X AGP slot, 1 CNR slot
  • FORM FACTOR
  • ATX (304mm*220mm), 4 Layers
  • ECS a jelek szerint megint megcsinálta. Egy olcsó alaplap kiváló teljesítménnyel és most a tuning opciókon is javítottak. Biztos kishazánkban is nagysikere lesz a lapnak.
    Már alig várjuk tesztlaborunkban...
