- ASUS ROG Ally
- iPad topik
Még a nyár előtt megérkeznek a G.Skill új Ripjaws memóriái
ph A külsejüket tekintve Trident Z sorozatból merítő modulpárok 32, 64 és 96 GB-os csomagokban vásárolhatók majd meg.
blizzrd
válasz tomy86 #13717 üzenetére
A Flashtool log-ja:19/009/2014 14:09:28 - INFO - Executing search strategies to find proxy selector
19/009/2014 14:09:28 - INFO - No proxy found for IE. Trying next one
19/009/2014 14:09:28 - ERROR - Error parsing settingsprefs.js (A rendszer nem találja a megadott fájlt)
19/009/2014 14:09:28 - INFO - Strategy firefox failed trying next one : java.io.FileNotFoundException: prefs.js (A rendszer nem találja a megadott fájlt)
19/009/2014 14:09:28 - INFO - No proxy found for java. Trying next one
19/009/2014 14:09:28 - INFO - Syncing devices from github
19/009/2014 14:09:28 - INFO - Pulling changes
19/009/2014 14:09:29 - INFO - Devices sync finished.
19/009/2014 14:09:33 - INFO - Device disconnected
19/011/2014 14:11:08 - INFO - Selected Bundle for ST18i. FW release : 4.1.B.0.587. Customization : CE_1252-3693_ForsakenNGL
19/011/2014 14:11:08 - INFO - Preparing files for flashing
19/011/2014 14:11:09 - INFO - Please connect your device into flashmode.
19/011/2014 14:11:18 - INFO - Device connected in flash mode
19/011/2014 14:11:19 - INFO - Opening device for R/W
19/011/2014 14:11:19 - INFO - Reading device information
19/011/2014 14:11:19 - INFO - Phone ready for flashmode operations.
19/011/2014 14:11:19 - INFO - Current device : ST18i - CB511V1B6V - 1252-5870_R2I - 1248-9545_4.1.B.0.587 - WORLD-i_4.1.B.0.587
19/011/2014 14:11:19 - INFO - Start Flashing
19/011/2014 14:11:19 - INFO - Processing loader.sin
19/011/2014 14:11:19 - INFO - Checking header
19/011/2014 14:11:19 - INFO - Flashing data
19/011/2014 14:11:19 - INFO - Processing of loader.sin finished.
19/011/2014 14:11:24 - INFO - Loader : S1_Loader_Root_773f - Version : R4A066 / Boot version : R9A028 / Bootloader status : NOT_ROOTABLE
19/011/2014 14:11:24 - INFO - No bootdelivery to send
19/011/2014 14:11:24 - INFO - Processing kernel.sin
19/011/2014 14:11:24 - INFO - Checking header
19/011/2014 14:11:24 - INFO - Flashing data
19/011/2014 14:11:26 - INFO - Processing of kernel.sin finished.
19/011/2014 14:11:26 - INFO - Processing fota1.sin
19/011/2014 14:11:26 - INFO - Checking header
19/011/2014 14:11:26 - INFO - Flashing data
19/011/2014 14:11:27 - INFO - Processing of fota1.sin finished.
19/011/2014 14:11:27 - INFO - Processing fota0.sin
19/011/2014 14:11:27 - INFO - Checking header
19/011/2014 14:11:27 - INFO - Flashing data
19/011/2014 14:11:28 - INFO - Processing of fota0.sin finished.
19/011/2014 14:11:28 - INFO - Processing adsp.sin
19/011/2014 14:11:28 - INFO - Checking header
19/011/2014 14:11:28 - INFO - Flashing data
19/011/2014 14:11:30 - INFO - Processing of adsp.sin finished.
19/011/2014 14:11:30 - INFO - Processing amss_fs_urushi.sin
19/011/2014 14:11:30 - INFO - Checking header
19/011/2014 14:11:31 - INFO - Flashing data
19/011/2014 14:11:31 - INFO - Processing of amss_fs_urushi.sin finished.
19/011/2014 14:11:31 - INFO - Processing amss.sin
19/011/2014 14:11:31 - INFO - Checking header
19/011/2014 14:11:38 - INFO - Processing of amss.sin finished.
19/011/2014 14:11:38 - INFO - Processing apps_log.sin
19/011/2014 14:11:38 - INFO - Checking header
19/011/2014 14:11:38 - INFO - Flashing data
19/011/2014 14:11:38 - INFO - Processing of apps_log.sin finished.
19/011/2014 14:11:38 - INFO - Processing cache.sin
19/011/2014 14:11:39 - INFO - Processing of cache.sin finished.
19/011/2014 14:11:39 - INFO - Processing system.sin
19/011/2014 14:11:39 - INFO - Checking header
19/011/2014 14:11:39 - INFO - Flashing data
19/013/2014 14:13:59 - INFO - Processing of system.sin finished.
19/013/2014 14:13:59 - INFO - Processing userdata.sin
19/013/2014 14:13:59 - INFO - Checking header
19/013/2014 14:13:59 - INFO - Flashing data
19/014/2014 14:14:04 - INFO - Processing of userdata.sin finished.
19/014/2014 14:14:04 - INFO - Ending flash session
19/014/2014 14:14:04 - INFO - Flashing finished.
19/014/2014 14:14:04 - INFO - Please unplug and start your phoneA Lasy féle javítás sem hozott eredményt :S
benfolds
válasz tomy86 #13730 üzenetére
Az enyem mostanaban (ket ev es ket honaposan) mintha mar csak egy napot birna szolid hasznalat mellett is, mig korabban, ha szukseg volt ra masfel nap nem jelentett neki gondot (alapbol amugy minden este toltore teszem). Nemreg a telekomtol uj modemet kaptunk, ami wifire is kepes. Kerdeztem az embert, aki hozta, h erdemes-e hasznalni a wifi-jet, azt mondta, h erdemes. Ehhez kepest annyira fos a wifije, h sokszor meg abban a szobaban is szenved a telefon a kapcsolodassal, ahol a modem van. Korabban egy 4000 ft-os tplinket hasznaltam, es vigan tudtam tuneint, spotifyt hasznalni az also szinten is. Arra gondolok, h esetleg a kapcsolodasi nehezsegek meritik jobban az akksit azota. Egy dlink dcm740es kabelmodemrol van szo egyebkent.
benfolds
válasz tomy86 #13741 üzenetére
igazából azért kérdeztem, mert nem tepsi, hanem "mini" (4,5"), és nem is szappantartó samsung, szóval azt gondoltam, hogy kb. bejöhet neked. de ez a 160 kb. egy 100-assal több a reális árnál, szóval nálam is kiesik, hiába lenne ideális a mérete és jön be a htc design. lehet az a stratégia, hogy pár hónap múlva lesz egy "hatalmas" vevőcsalogató akció, amikor majd 120-ért meg lehet venni.
oncsi
válasz tomy86 #13745 üzenetére
Igazábol semelyik árszegmensben nam gyártanak normális (értsd, olyat amiben nincs legalább 1 olyan hiba, amivel nem lehet együttélni ) telefont.
Most egy M-es Sonyt próbálgatok asszonynak. Ez a telefon, a Ray korában csúcskészülék lehetett volna, de legalábbis a felső sávban lett volna a helye.
Ma ez alsó-közép kategoriás telefon. Igazábol csak az ára miatt, mert mikor megjelent 75e ről indult.
4' pont tökéletes.
Formára sem vészes, de nem egy Ray.
Értem én, hogy el kell adni a teljes termék palettát, de olyan szinten butitott a készülék, hogy csak bosszankodni lehet rajta. A Ray-nek vannak hibái, de az a technikai korlátai miatt van. Érződik, hogy próbáltak összerakni egy jó készüléket.
Az M pedik ennek a forditottja. Csináltak egy csúcskészüléket, az lett az év zászlóshajója. Ebböl faragják le a gazdasági szakik (nem a mérnőkök) az alsóbb palettát. Visszafogják az anyaghasználatot mert 1 cent is pénz, meg mégsem lehet olyan mint a nagy. Tesznek bele rosszab kijelzőt, kevesebb RAM-ot És ha a hardwer-en már nem lehet sporolni, akkor jön a soft. És itt van a lényeg, mert amíg a RAY-en lelkes "amatőr " gárda csiszolgatja a szoftvereket, ennél mérnőkők hada dolgozik azon, hogy ezt ne lehessen megtenni.
Most nem azt mondom, hogy használhatatlan ez a készülék, csak már nincs benne egy csepp mínőségérzet sem.
(Ha fizikai gombjai lennének, talán én is elhasználnám, de sosem szeretném)Kinek csak kalapácsa van, mindent szögnek vél
zhata
válasz tomy86 #13767 üzenetére
Szia.
Csak az a bajom, hogy ha szétszedem, a bénaságom miatt, esetleg annyi lesz neki.
Csak egy szösz szállt valahogy bele.
Sejtem is, hogy a nem túl régi tok áldása. Ahogy levettem, szinte penészesedést is láttam a tok hajlataiban.
Igazad van, messze nem garis. De van egy (volt) topiktársunk, aki azt mondaná, hogy két év után minden nap nyeremény.Azt hiszem, elgondolkodom a javaslatodon.
Köszönöm.Ui.
Kb 2.5 évig nem volt semmi baja sem tok nélkül... . -
zhata
válasz tomy86 #13770 üzenetére
Köszönöm a linket és a tanácsot.
Szervizbe eszem ágában sincs vinni, mert még a végén megállapítanák, hogy "szoftverfrissítésre" van szükség.
(Ha hiszed ha nem, már egyszer jártam így -*- nem dőltem be.)Mivel csak egy szöszdarab, holnap lecsavarozom, és megpróbálom kifújni.
Mégegyszer köszi.
diane
válasz tomy86 #13774 üzenetére
Végül nem alaplapot cseréltek, hanem kijelzőt, mondván, hogy az alaplapomnak semmi baja. Most frissíteni akartam újra a fenti probléma (nem talál hálózatot) miatt, erre kiírja a SEUS, hogy a frissítés nem sikerült, azóta pedig sony felirat utána meg egy nagy háromszögben felkiáltójel, mellette egy telefonnal kép jelenik meg.
Egyébként ha cserélik az alaplapot, az imei-szám marad? vagy honnan tudom, hogy kicserélték vagy nem. -
zhata
válasz tomy86 #13785 üzenetére
Köszi a kérdésed, de sem otthon, sem a munkahelyemen sem találtam olyan spéci
csavarnyúzót, amivel komolyabb rendbontás nélkül neki mertem volna állni.
Így hát maradt a némileg rosszabb kamerakép.
Viszont a tokot, ami feltételezésem szerint okoz(hat)ta ezt, kidobtam.
Tény, nagyon vigyázni kell egy telefonra.
Szerviz - ilyen esetben - kizárva. -
tomy86
válasz tomy86 #13796 üzenetére
"Szerintem ez a funkció legfeljebb a kínai telókban működik gond nélkül"
Ezt úgy értettem, hogy azoknál szinte bármelyiket veheted és jó eséllyel működni fog a hívásrögzítés. Míg más telefonoknál meg kell keresni a megfelelő telefon-rom és kernel verzió-hívásrögzítő program triót. -
oncsi
válasz tomy86 #13797 üzenetére
Értem én a jogi oldalát, csak kissé ferde ez szabályzás. Mig nekem az esetek nagyrészében nem kérik ki a véleményem a rögzithetőségröl, legalábbis jelezvén, hogy ennek techniki akadálya nincs.
Másik oldalon meg egyenesen tiltják. 1-2 hetente jól jönne a bizonyiték egy rendelésröl, amit eképpen én nem tudok bizonyitani.Kinek csak kalapácsa van, mindent szögnek vél
zhata
válasz tomy86 #13806 üzenetére
Köszi,
beefjeez-nek is:Ugyanazok a háttérfolyamatok mennek, amik eddig is.
-whatsapp
-google play szolg. 1-2
hi screen lock
call recorder pro
mobile security & antivirus
hivasnaplo bovitmeny
kapcsolatok
google play szolg.
update center
swype+dragon+ timeriffic
A régi akkuval is ezek mentek
Pompi
MODERÁTOR
válasz tomy86 #13819 üzenetére
"Azt hiszem, ha a "beállítások - teljesítmény - magas minőségű grafika" opciót választod, akkor működik, de nem nagyon javasolják emlékeim szerint."
Valóban, itt belehetett, itt nem is néztem, mert még rejve volt az opció, a fejlesztői lehetőségekkel együtt jött meg, rég volt, már, hogy azt elő kellett szednem, azért nem is futottam még itt rayen bele
Gyanús volt, mert a rom screenshotjaiban transzparens a státusz sor.
Bekapcsoltam, meglátjuk mi lesz, köszi még 1xFeel Good Inc.
szabozsolt87
válasz tomy86 #13826 üzenetére
Eroot-al elvileg már rootoltam a telefont rajta is a Superuser progi. Én azt hittem CWM nem is lehet rátenni, ha a bootloader nem nyitható.Galaxy S és HTC Desire X rootoltam és custom romot is tettem fel, de mindegyik egy kicsit más mint a többi. Ezért néha kicsit össze vagyok zavarodva, hogy mit hol honnan és milyen sorrendben kell megtenni.
furmint
válasz tomy86 #13841 üzenetére
2.3.4
ext2
Officesuit nálam nem volt áthelyezhető, ha rábökök a link2sd listában, akkor a következő gombok jönnek fel:
mozgatás sd-re; műveletek; link létrehozása(?); link eltávolítása(?)
Ha átmozgatnám, dolgozok egy darabig, majd az előbb írt hibaüzenetet dobja fel.A telefon telenoros, zárt bootloaderes, ez lehet gond?
adabra
válasz tomy86 #13846 üzenetére
Úgy látom, Te tartod a lelket ebben a topikban...
A feleségem használ egy Ray-t; jelenleg egy CM7.2 -es ROM van rajta (már vagy egy éve).
A telefont néhányszor csak a (remek) mérete mentette meg attól, hogy falhoz vágja(m)
Bármilyen ROM-mal időnként újraindul, leginkább hívás előtt (csengéskor), közben vagy közvetlenül a beszélgetés után. Néha máskor is (pl. táskában). Jó ideje kikapcsoltam a PIN-t, hogy legalább elérhető legyen utána is.Az utóbbi hónapokban az akku merülés aggasztó méreteket öltött; de nem általában gyengébb az akku teljesítméne, hanem a wifi, BT, cella készenlét szívja le erősen. A képernyő sokadik a sorban, pedig "normál" esetben az szokott a legnagyobb fogyasztó lenni. Egyébként rendeltem ebay-ről egy eredinek és újnak mondott akkut, de most éppen e két tulajdonság valódiságán megy a disputa az eladóval
Az lenne a kérdésem, hogy az általad használt ROM-nak vannak-e a napi használatot megakadályozó/megkeserítő hibái? Az XDA-s fórum utolsó oldalán pl ezt olvastam:
Is there a fix for the low microphone's volume?
Unfortunately no, we're trying to find a solution for that but it's difficult to fix.Ezzel mi a helyzet? Illetve még fontos lenne, hogy rendesen használható-e a bluetooth headset -tel?
Köszönöm
adabra
válasz tomy86 #13848 üzenetére
Köszi az infókat.
Nekem is az a gyanúm, hogy bizony ennek a típusnak (pontosabban minden példánynak) vannak hardveres hibái, csak a Sony(Ericsson) ezt sohasem ismerte el...
Ismerőseim körében van még 3 Ray, mindegyik szarakszik időnként valamivel.
A "spontán" újraindulás gyakori, és a wifi is problémás: időnként úgy tesz, mintha csatlakozva lenne, de valójában nincs kapcsolat. Olyat is láttam, hogy csatlakozott wifi mellett ment a mobilinternet is.Próbálkozok még valamelyik ROM-mal, de ebből rövidesen telefon csere lesz, mert: [link]
Csak nem tudom, mi lenne megfelelő, ami viszonylag kisebb méretű = keskeny
Xiaomi MI2S
S4 Mini
Motorola Razr i
Jiayu G2FMoto G
Moto X
Ez utóbbiak már "nagyok". Bár egy Moto X-re szívesen elcserélném a saját Nexus 4-emet is...[ Szerkesztve ]
-HajTömeg-
válasz tomy86 #13860 üzenetére
Hát így van ez,mam már az hamisítvány,ami nem kínai..
A vicc egyébként,hogy Ázsia center tele van mindenféle tokokkal, fóliákkal stb. kínai telefonokhoz semmi
MOndtam is az egyik árusnak,hogy akkor kénytelen leszek valami magyar hamisítványt venni hozzáAlias: Júzer error
