- Autóhifi
- Steam Deck
iPhone felhasználók szakmai topikja
Kérek mindenkit, hogy a topikban kulturáltan kommunikáljunk: [link]
Archívum #1
Archívum #2
Ck.
Tiszteletem az egybegyűlteknek,
Felteszem inkább itt a kérdést, hátha itt többen fordulnak meg AirPods Pro-val.
Amikor 1 hete kibontottam, kipróbáltam mindhárom méretű gumi haranggal, lefuttattam a szigetelés tesztet is, hibátlan volt minddel.
Néhány napra rá azonban akármit csinálok, ha fejen állok se sikerül átmenni a szigetelés tesztjén. Próbáltam a korábban tökéletesen működő másik 2 méretet, egyik sem megy át a teszten.
Ahogy jobban elkezdtem beleásni magam a témába, nem egyedi eset...Valami nem kerek ezzel az AirPods Pro-val, tele van a net kísértetiesen hasonló sztorikkal:
”Agree. Mine passed the fit test on the first try but, not since. The large tips also work well for me. I only wish there was an XL tip to try. I have large ear canals.”
“I also think there’s a problem with the fit test, not the earphones.
I have two pairs of AirPod Pros (don’t ask). The first pair passed the fit test immediately, and consistently (with the large tips) on the day I bought them. Then, after about two days’ of use, the first pair stopped passing the fit test (and no amount of twisting or pushing helped). I then opened the second pair of AirPods and ran the fit test — and the second pair passed consistently (even though I was using the same size tips on both pairs, and the first pair failed consistently). So I exchanged the first pair, thinking the first pair was somehow faulty.
Now, several days later, the second pair are consistently failing the fit test — but the third pair (the pair I received when I exchanged the first pair) pass the fit test consistently. My guess is that after a bit of use, something borks the fit test. My suggestion would be to use the fit test, when the AirPods are new to help identify the best tips for your ears — and then forget about the fit test because it won’t be reliable for long.
I have a (large) number of earphones, and I’m pretty sure I know what a decent seal feels like — and I’m getting a decent seal with the AirPod Pros and the large tips. They sound terrific and the noise cancelling works really well. I’m assuming at this point that the inconsistent results I’m getting when I run the fit test represent a problem with the fit test, not the earphones. I suppose Apple may be able to fix that with a firmware update — but until they do, I wouldn’t drive myself crazy running the fit test.”Bárki tapasztalt már hasonlót? Akinek hosszabb ideje megvan, megtenné hogy most is lefuttat egy tesztet?
Ck.
válasz MasterMark #211928 üzenetére
Nem érv a PS-sel szemben. Akinek fontos a pótolhatatlan játék élmény és a fantasztikus exluzívok, azt nem fogja az MS az “ingyen” címeivel megvásárolni.
Ck.
iCloud-ban tudok tárolni a telefonra másolt saját zenéket is? Elsősorban FLAC miatt.
Ck.
válasz herdsman12 #212005 üzenetére
Maga a tárhely méret nem probléma, úgyis akkor nagyra váltanék, ha megoldható.
Eddig az sem tűnt fel, hogy az iCloud egyáltalán képes a saját zenéidet eltárolni a felhőben....
Függetlenül a VOX-tól, iCloud-on belül hol van lehetőség a zenék eltárolására? Végignéztem a menthető tartalmakat, fotók, videók, dokumentumok, alkalmazásadatok, üzenetek, emailek, stb. de zenét sehol sem találok. -
Ck.
A Viber változott meg vagy az új iOS az oka, hogy már nem lehet szabadon képeket küldeni a galériából? Nincs közvetlen hozzáférése a vibernek, magukat a képeket kell egyenként engedélyezni. Elmebaj.
Ck.
válasz tesz-vesz123 #231950 üzenetére
Az, hogy eddig nem kellett kijelölni hogy mit lásson, elég volt egy általános engedélyt adni neki a galéria tartalmához. Közben megtaláltam a beállításokban a régi módszert, de nem értem az iOS 14 frissítés miért állította ezt át magától.
Ck.
Üdv,
lassan több mint 1 évnyi rendszeres maszk használat után nagy hirtelenséggel tegnap óta nem kér jelkódot a telefon a feloldáshoz, a face id működik maszkon keresztül is. Nem állítottam el semmit, a figyelem érzékelés ugyanúgy be van kapcsolva. Ez bug fagy feature? Kellene aggódni? iPhone 11 Pro Max
Előre is köszi.[ Szerkesztve ]
Ck.
Ha Sirinek diktálok egy sms-t és nem érti, mindig azt írja be, hogy ‘maa’. Minden nem értett szóra vagy mondatra ‘maa’, ‘maa’, ‘maa’. Évek óta csak tűrök, de mostmár kezd baromi idegesítő lenni...
Ck.
Üdv,
Lehetőleg minél kevesebbet akarom az új jövevénynél a lightning-portot használni, mert már a 11 Pro Max-nál be sem tudom teljesen dugni, valami megmihálylott benne (napi 3x szoktam általában leejteni sajna, az ideivel jobban vigyázok majd), viszont egyelőre még nincs MagSafe töltőm, csak egy egyszerű 4 ezer Ft-os, benzinkúton vásárolt lassú vezetéknélküli korong. Karácsonyra majd kérek szépen egy MagSafe-t, de addig is szerintetek megteszi egy ilyen olcsó, vezetéknélküli lassú töltő? Tönkre tudja tenni az aksit idővel vagy a QI az mindenhol QI, nem kell úgy tartani tőle mint az utángyártott vezetékes töltők esetén? -
Ck.
Üdv,
iPhone 13 (Pro Max) széria. Akik gyári bőrtokot használnak, senki nem tapasztalt olyat, hogy pl. a hangerő gombok nehezebben járnak, ragadósabbak, nehezebb lenyomni őket, nem kattannak? Én már a második tokot rendeltem meg emiatt, de ez is ugyanolyan. Ennyire szerencsétlen lennék?
A 11 Pro Max gyári bőrtokjának gombjai a mai napig hibátlanok, határozottan kattannak, tökéletes nyomásponttal. -
Ck.
válasz MasterMark #251270 üzenetére
Apple Storeban vettem mindkettőt. De attól még nem biztos.
Ck.
Úgy tűnik nem egyedi eset, ettől függetlenül nem vigasztal a dolog. Legszívesebben ezt is visszaküldeném, de már attól tartok, hogy egy idő után feltűnik nekik, hogy ugyanarról a címről, ugyanazzal a névvel rendelnek, majd küldözgetnek vissza tokokat hetente több alkalommal és egy idő után meg fogják kérdezni, hogy mi a f@sz van... [link]
Ck.
Le szabad törölni alkohollal a telefon kijelzőjét vagy akkor annyi a gyári NASA-rétegnek és jönnek a mindennapos zsírpacák, valamint a sima, az ujjat könnyen végigcsúsztatható, sima
felületnek is annyi?
- Okosóra és okoskiegészítő topik
- Konzolokról KULTURÁLT módon
- Konteó topic
- Samsung Galaxy S22 és S22+ - a kis vagány meg a bátyja
- Középpontba kerültek a hibrid autók, alig fogyaszt a BYD újdonsága
