- Nyomtató topik
- Hisense LCD és LED TV-k
Computex 2024: okosmonitorok az Acer standján
ph A tajvani vállalat smart portfóliójában azért akad olyan modell is, ami játszani sem utolsó választás.
Bemutatkozott a Redmi 13 4G
csixy
válasz ubyegon2 #64273 üzenetére
Köszönöm az avanzsáltatást!
Anyyira huncutul lett a telepítés, hogy a benti winnyóz a kingstonon UEFI-s , az USB-re meg legacyban MBR-re lett teleptve az arch.
Kert, kütyük,munka,matek,morfondír...ennyi. Szóval ács nem vagyok, de nemrégiben sikerült faragnom egy mőködőképes fogpiszkálót.
csixy
[senki@fatengelyes-pc ~]$ sudo smartctl -a /dev/sdb
smartctl 6.6 2017-11-05 r4594 [x86_64-linux-4.19.8-arch1-1-ARCH] (local build)
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org=== START OF INFORMATION SECTION ===
Model Family: Indilinx Barefoot based SSDs
Device Model: Corsair CSSD-V32GB2
Serial Number: 10340061080009870002
Firmware Version: 2.1
User Capacity: 32.017.047.552 bytes [32,0 GB]
Sector Size: 512 bytes logical/physical
Rotation Rate: Solid State Device
Device is: In smartctl database [for details use: -P show]
ATA Version is: ATA8-ACS (minor revision not indicated)
Local Time is: Sun Dec 16 19:43:03 2018 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled=== START OF READ SMART DATA SECTION ===
SMART Status not supported: Incomplete response, ATA output registers missing
SMART overall-health self-assessment test result: PASSED
Warning: This result is based on an Attribute check.General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
Self-test execution status: ( 0) The previous self-test routine completed
without error or no self-test has ever
been run.
Total time to complete Offline
data collection: ( 0) seconds.
capabilities: (0x1d) SMART execute Offline immediate.
No Auto Offline data collection support.
Abort Offline collection upon new
command.
Offline surface scan supported.
Self-test supported.
No Conveyance Self-test supported.
No Selective Self-test supported.
SMART capabilities: (0x0003) Saves SMART data before entering
power-saving mode.
Supports SMART auto save timer.
Error logging capability: (0x00) Error logging NOT supported.
General Purpose Logging supported.
Short self-test routine
recommended polling time: ( 0) minutes.
Extended self-test routine
recommended polling time: ( 0) minutes.SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x0000 --- --- --- Old_age Offline - 6
9 Power_On_Hours 0x0000 --- --- --- Old_age Offline - 489
12 Power_Cycle_Count 0x0000 --- --- --- Old_age Offline - 807
184 Initial_Bad_Block_Count 0x0000 --- --- --- Old_age Offline - 11
195 Program_Failure_Blk_Ct 0x0000 --- --- --- Old_age Offline - 0
196 Erase_Failure_Blk_Ct 0x0000 --- --- --- Old_age Offline - 0
197 Read_Failure_Blk_Ct 0x0000 --- --- --- Old_age Offline - 0
198 Read_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 4239304818
199 Write_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 2197665990
200 Read_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 90343929
201 Write_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 38610438
202 Error_Bits_Flash_Tot_Ct 0x0000 --- --- --- Old_age Offline - 11514836
203 Corr_Read_Errors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 10661622
204 Bad_Block_Full_Flag 0x0000 --- --- --- Old_age Offline - 0
205 Max_PE_Count_Spec 0x0000 --- --- --- Old_age Offline - 5000
206 Min_Erase_Count 0x0000 --- --- --- Old_age Offline - 533
207 Max_Erase_Count 0x0000 --- --- --- Old_age Offline - 1156
208 Average_Erase_Count 0x0000 --- --- --- Old_age Offline - 898
209 Remaining_Lifetime_Perc 0x0000 --- --- --- Old_age Offline - 83
211 SATA_Error_Ct_CRC 0x0000 --- --- --- Old_age Offline - 0
212 SATA_Error_Ct_Handshake 0x0000 --- --- --- Old_age Offline - 0
213 Indilinx_Internal 0x0000 --- --- --- Old_age Offline - 0Warning! SMART ATA Error Log Structure error: invalid SMART checksum.
SMART Error Log Version: 1
No Errors LoggedWarning! SMART Self-Test Log Structure error: invalid SMART checksum.
SMART Self-test log structure revision number 1
No self-tests have been logged. [To run self-tests, use: smartctl -t]Selective Self-tests/Logging not supported
csixy
válasz Frawly #64286 üzenetére
[senki@fatengelyes-pc ~]$ sudo smartctl -t short /dev/sdb
[sudo] senki jelszava:
Copyright (C) 2002-17, Bruce Allen, Christian Franke, www.smartmontools.org=== START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION ===
Sending command: "Execute SMART Short self-test routine immediately in off-line mode".
Drive command "Execute SMART Short self-test routine immediately in off-line mode" successful.
Testing has begun.
[senki@fatengelyes-pc ~]$ sudo smartctl -t short -a /dev/sdb
Local Time is: Sun Dec 16 20:51:54 2018 CET
was never started.
Self-test execution status: ( 249) Self-test routine in progress...
90% of test remaining.
command.
power-saving mode.
9 Power_On_Hours 0x0000 --- --- --- Old_age Offline - 490
198 Read_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 4239321810
199 Write_Sectors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 2198158606
200 Read_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 90344251
201 Write_Commands_Tot_Ct 0x0000 --- --- --- Old_age Offline - 38618593
202 Error_Bits_Flash_Tot_Ct 0x0000 --- --- --- Old_age Offline - 11514890
203 Corr_Read_Errors_Tot_Ct 0x0000 --- --- --- Old_age Offline - 10661672
208 Average_Erase_Count 0x0000 --- --- --- Old_age Offline - 899
Can't start self-test without aborting current test (90% remaining),
add '-t force' option to override, or run 'smartctl -X' to abort test.
[senki@fatengelyes-pc ~]$Kert, kütyük,munka,matek,morfondír...ennyi. Szóval ács nem vagyok, de nemrégiben sikerült faragnom egy mőködőképes fogpiszkálót.
csixy
válasz ubyegon2 #64425 üzenetére
Az egyszerű X541NA "neylon" Asuson is kitűnően érzi magát a linux. Egyetlen hibája, hogy ez már csak UEFI-ül tud (meg működés közben száradó c@ton szag jön a belsejéből a belenyomott "gyári" gumiragasztó miatt).
csixy
Mint a vilám , úgy bootol! Klón .... igaz scriptből van, de jó !
csixy
válasz Frawly #64479 üzenetére
Betoltam caddy-n a corsair32-est, ránéztem a distrowatch-ra és ez volt a legfrissebb, hát feltettem. ... Naggyon jó csak még csúnyácskák a betűk meg miegymás, de majd megjavítom.
csixy
Arch linux. Már mindenféle téma cserét mekkptróbáltam. De !!! Ettől a brontos feketeségtől hogy lehetne mekkxszabadulni?
Meg ezek a betűk és stílus is bornyasztók ! Ezt is hogy kell megoldani?[ Szerkesztve ]
csixy
Arch kde .... eltüntek a mappa ikonok . Hogy kell őket elővarázsolni?
csixy
válasz Frawly #64553 üzenetére
Na jó , de az Archlabs telepítő már megrágott pempőként felkínálta ezt a lehetőséget. A többiek miért nem ilyen okoskák?
Egyenlőre feltolom a Tessa kisasszonyt, aztán majd lehet, hogy nekiveselkedek , na nem Tessának, hanem a gummibootnak. ... hátha sikerül .[ Szerkesztve ]
csixy
válasz Frawly #64574 üzenetére
Az EFI partíció rendesen ott is van, az a második. Az első négy partíciót simán megcsinálta egy UEFI win10 telepítés , a hatodikat létrehozhatta a 1709-es windows frissítés (830 mega szokott lenni) , de mi célból került oda az ötödik?
csixy
válasz Frawly #64577 üzenetére
Ezt fordítsátok le RaPiDsHaRe kollégának !
https://ubuntuforums.org/showthread.php?t=2393686[ Szerkesztve ]
csixy
Felraktam megint egy archlabs linuxot megint systemd boottal egy usb -s vinyóra , csak hogy gyakoroljak, meg leellenőrizzem a vinyót , mert az előtte porteussal be-be döglött ( de az valószinüleg a porteus hibája lehetett). Saját UEFI partíciót csináltam neki. Most LTS kernelt dugtam bele, de így se nincsenek mappaikonok.
csixy
válasz ubyegon2 #64686 üzenetére
Össze -vissza csereberélgettem már mindenfélét , de a mappáknak nincsnek ikonjai, csak a helyük van ott.
Gondolom az nem az oka, hogy telepítéskor cyptrootot választottam.
csixy
Most egy usb-s tokba rakott vinyóra telepítettem fel UEFI, GPT, systemd-boot, saját EFI partíció (boot, esp) és cryptroot . Így:
Az lenne a kérdésem, hogy ezt a gumi-asus notin be tudom bootolni, viszont a HP250G1-es notin csak addig jut el, hogy a / partíció UUID-jét beadja, de a cryptroot jelszó bekéréséig már nem jut el . Miért?
Na egyszerűsítek . Újratelepítem ezúttal a HP notit használva cryptroot nélkül , de azon kívül ugyanígy . Meglátjuk, hogy mi lesz a mappa ikonokkal.
csixy
válasz Frawly #64700 üzenetére
Köszönöm ! Ezt az ikon téma témát mégyszer megpróbálom úgy ahogy írtad most ( mert nekem csak most esett le a tantusz az újra indítással kapcsolatban).
"Az UUID-t beadja kitételen nem tudom mit értesz. Mit ír ki pontosan?" hát ez nem működik gondolom printscreennel. De ugyanúgy indul mint a működőn, azután , hogy kiírja hogy
... UUID: blablabla ezután a sor után nem bír továbblépni jó irányba.
csixy
Feltettem az arch ikon témát , újraindítás után elfelejti, pedig a rendszerbeállításoknál látszik kékkel bekeretezve, hogy az az ikontéma az aktív.
csixy
válasz Frawly #64708 üzenetére
Már belefáradtam.
Ezt még lelőttem, de a dmesg elszalad , nem tallózható.Megpróbálom titkosítás nélkül.
Az nem kavarhat be hogy az egyik gépen sdc , a másikon sdb a külső vinyó, meg az hogy úgy volt eredetileg sorban a három partíció hogy:
/dev/sdc1 az efi
/dev/sdc3 a /
/dev/sdc2 a swap?????????
csixy
válasz Frawly #64710 üzenetére
Na azt már elb@xtam , mert újratelepítettem titkosítás nélkül most a HP250G1-en. Műkszik , de a plasmában nincs mappaikon továbbra sem . Valószinüleg a qt5ct nem kellett volna nekem ? Vagy még azt kellene b@szkurálni?
Dugom át az asusra , hogy azon is megy-e.
csixy
válasz Frawly #64712 üzenetére
oksa
most a hp250g1-en megy és az asus541na-n nem megy és a wise keskeny kliens USB3-as portjáról nem indul el ,de az USB2-esről elindul csak a make user accoutnts után elakad a boot folyamat.# vim:set ft=sh
# MODULES
# The following modules are loaded before any boot hooks are
# run. Advanced users may wish to specify all system modules
# in this array. For instance:
# MODULES=(piix ide_disk reiserfs)
MODULES=()# BINARIES
# This setting includes any additional binaries a given user may
# wish into the CPIO image. This is run last, so it may be used to
# override the actual binaries included by a given hook
# BINARIES are dependency parsed, so you may safely ignore libraries
BINARIES=()# FILES
# This setting is similar to BINARIES above, however, files are added
# as-is and are not parsed in any way. This is useful for config files.
FILES=()# HOOKS
# This is the most important setting in this file. The HOOKS control the
# modules and scripts added to the image, and what happens at boot time.
# Order is important, and it is recommended that you do not change the
# order in which HOOKS are added. Run 'mkinitcpio -H <hook name>' for
# help on a given hook.
# 'base' is _required_ unless you know precisely what you are doing.
# 'udev' is _required_ in order to automatically load modules
# 'filesystems' is _required_ unless you specify your fs modules in MODULES
# Examples:
## This setup specifies all modules in the MODULES setting above.
## No raid, lvm2, or encrypted root is needed.
# HOOKS=(base)
## This setup will autodetect all modules for your system and should
## work as a sane default
# HOOKS=(base udev autodetect block filesystems shutdown)
## This setup will generate a 'full' image which supports most systems.
## No autodetection is done.
# HOOKS=(base udev block filesystems shutdown)
## This setup assembles a pata mdadm array with an encrypted root FS.
## Note: See 'mkinitcpio -H mdadm' for more information on raid devices.
# HOOKS=(base udev block mdadm encrypt filesystems)
## This setup loads an lvm2 volume group on a usb device.
# HOOKS=(base udev block lvm2 filesystems)
## NOTE: If you have /usr on a separate partition, you MUST include the
# usr, fsck and shutdown hooks.
HOOKS=(base udev autodetect modconf block filesystems shutdown keyboard fsck)# COMPRESSION
# Use this to compress the initramfs image. By default, gzip compression
# is used. Use 'cat' to create an uncompressed image.
#COMPRESSION="gzip"
#COMPRESSION="bzip2"
#COMPRESSION="lzma"
#COMPRESSION="xz"
#COMPRESSION="lzop"
#COMPRESSION="lz4"# COMPRESSION_OPTIONS
# Additional options for the compressor
#COMPRESSION_OPTIONS=()most a boot mappát nem látom, mert ez a linux a vinyó uefi partícióját nem csatolja fel (nyilván hivatalból kontra tarokkos nyelven szólva).
Holnap majd bebootolom a hp-ről és felteszem a conf fájlok tartalmát.
Addig is Köszönöm szépen!
csixy
válasz Frawly #64714 üzenetére
Ebben már nincs encrypt, mert már újra lett telepítve titkosítás nélkül.
hcl:
én is így látom, hogy ahány alapgép, annyiféle UUID azonosító ... lehet hogy az USB miatt?[ Szerkesztve ]
csixy
Amíg ilyen jól kivitatkoztátok magatokat, addig én ágyaspálinkát gyártottam aszalt gyümikkel , üvegekkel , dugókkal,címkékkel , zsugorfedőkkel, hőlégfúvóval, nameg pálesszel, de azóta sem értem, hogy ha frissen leformázok három partíciót egy USB-s vinyón és csatolom ahogy kell és telepítem rá a rendszert és már sehol sincs titkosítás, akkor miért nem viselkedik minden vason ugyanúgy ez a rendszer. Az UUID-ról én is rendelkezem némi fogalmakkal openwrtés korom óta. BUÉK !!!!
csixy
válasz Rimuru #64717 üzenetére
Köszi, igazad lehet!
Jó akkor nekiesek mégegyszer és a lemez piszkálát egy új partíciós tábla felrakásával fogom kezdeni és mög fogjuk látni, de a kde helyett a cinnamonnál fogok maradni.Kert, kütyük,munka,matek,morfondír...ennyi. Szóval ács nem vagyok, de nemrégiben sikerült faragnom egy mőködőképes fogpiszkálót.
csixy
Hát én most megcsinálom rajta az őszi mélyszántást , aztán a földmérővel újra kikarózzuk a határokat, aztán jöhet a házszámtáblázás , meg a boronázás , aztán újra bevetem.
csixy
válasz ubyegon2 #64763 üzenetére
ELLENPRÓBA
Egon, köszönöm,hogy írtál! Újra raktam az archlabs linuxot most csak cinnamonnal, de most sem jut el csak az első vassal az igazi bootig . Arra gondoltam, hogy most felteszek egy Tessa cinnamont ezúttal Grubbal, és ha most is csak az egyik vassal fog menni , akkor Neked kell nekeM segíteni majd, de nem baj , ha Más is segít és azt is fogom köszönni! Az egész előtt természetesen gyalulom az USB-s vinyót.[ Szerkesztve ]
csixy
válasz ubyegon2 #64767 üzenetére
Köszi, nem baj, majd küzdünk, de valószinüleg semmi dolgunk sem fog keletkezni! (ez a drCsI-féle sejtés! Mindjárt meg lesz az első kisérleti adat a teóriá(m)ra).
csixy
Jó elindult a Tessa. Már eltávolítottam synapticból a timeshiftet, mert ez nekem csak zavarna, de ezt a sárga csíkot milyen config fájlból kell kiradírozni (na nem oly nagy baj, mert egy rákattintás után mindig eltűnik.)?
csixy
válasz ubyegon2 #64770 üzenetére
Köszi , ez sikerült, de a lényeg az, hogy egyszerre nem enged egynél több EFI partíciót felcsatolva lenni ,épp ezért mindig csak egy EFI tud működni és ez lehet az ok a systemd-boot esetén is a külső USB-s vinyó használatakor. Tehát, ha az egyik EFI-ről vagyok bootolva, akkor a rendszer nem engedi okosítani a másik EFI partíciót. ... Ez így nagyon okoska , de mégsem elég egzakt , a frász essen bele.
csixy
Úgy működik gyakorlatilag, mint a közlekedő edények törvénye. Csak az az opció íródhat be az n.-nedik EFI-be, ami ezzel egyidejűleg ill azt megelőzően egy másik EFI-ből kitörlődött valami módon.
csixy
válasz ubyegon2 #64782 üzenetére
Nem. Most is arról műkszik a / partíció. Csak a Tessa telepítő nem volt hajlandó a neki szánt EFI partícióval foglalkozni, mert már talált a gépben egy másikat. Node majd mindjárt elrontom még jobban szoftveresen a gépet. Vagy megszokik, vagy megszököm.
csixy
Na egy kicsit durva voltam. Linux telepítőből töröltem a gép EFI partícióját (marad a gyerek, ha játszik ) és így már lett EFI az USB-s vinyón , viszont az update grub így már nem tudja felderíteni a WinX-et , de pár óra alatt egy újratelepítéssel azt is meg tudom majd oldani, ha másképp nem.
Mindjárt megnézem, hogy a kőkori HP250G1-en be tudom-e brűgetni a vinyóra tett linuxot.[ Szerkesztve ]
csixy
válasz ubyegon2 #64796 üzenetére
A manjaro tényleg tök jó és kényelmes. Valóban az arch vonal mintje, csak nem szabad dualbootba tenni másik linux dystroval (és ez igaz a kapitány kedvenc dystrojára is, egyébként az is nagyon jó), mert a másik linux grub frissítéskor elb@xxa a bootját. Ennyi.
No az USB-s mint Tessa viszont elindult a HP250G1-esen is . Most abból írok. Az nem tetszett neki amikor kijelentkeztem belőle (fsck-zni kellett miatta, de rendbe jött) - lehet, hogy a hibernálást tiltani kellene?
Az exfat mountolás után simán megy mint alatt is , de most nem tudom megnézni, mert most fogom bcdboottal gyógyítani winx efi partícióját és még utána kell meggyógyítani a linuxot is.
csixy
válasz ubyegon2 #64801 üzenetére
Nem sajnos a chakra bootját nem tudtam így megcsinálni, egyenlőre pusztán csak ezért tettem félre azt a projectet.
Sikerült megcsinálni a winx és a dualbootos mint bootját is.
Frawly: Köszi , nekem az alanti módszer lett sikeres, hosszas próbálkozások után, mert sajnos meg kellett volna hagyni neki üresen az EFI partíció helyét, de a végére rájöttem! A védett partíciót csak gparteddel sikerült kigyalulni , aztán az üres 100mega helyet már be tudta kapálni a diskpart. Közben volt egy olyan észtvesztő beugratás, hogy egy elválasztó 1 megás helyecskéből csinált a diskpart EFI partíciót, na mire arra rájöttem kishíján földhöz vágtam a pálinkás kanalat. Szóval így csináltam:
Method 2. Create lost/deleted EFI partition by using CMD
Boot PC with Windows 10/8/7 installation media > press SHIFT + F10 on the first screen to bring up Command Prompt.
Type the following commands and click Enter each time:diskpart
list disk
select disk # Note: Select the disk where you deleted the EFI System partition.
list partition
create partition efi
format quick fs=fat32
list partition
list volume Note: Note the volume letter where the Windows OS is installed.exit
bcdboot X:\windows Note: Replace "X" with the volume letter of the Windows OS partition.
BCDBoot copies the boot files from the Windows partition to the EFI System partition and creates the BCD store in the same partition.
Now you can remove the Windows installation media and restart the computer.
Igy sikerült helyretenni a winnyózt , aztán chrottal megyógyítottam a linux efi-bootját és kis megőrülés után rájöttem, hogy nem az optibayba tett 30 gigás SSD-m rossz, hanem az fstabban javítanom kell az EFI partíció UUID-jét és lett boldogság
Milyen program ami... [link]
- Vélemény Ubuntu 20.04 LTS
- Tudástár MX-Linux 19
