- Amazon Kindle
- ASUS Vivobook Snapdragonnal: talán egy új korszak kezdete!
- Philips LCD és LED TV-k
Olcsó USB WiFi AC adapter
Switch-re is befut a Darkest Dungeon 2
gp A PlayStation kiadások mellett a Nintendo konzoljára is elérhető lesz jövő hónapban az új kiadás.
ASUS WL-500G Premium
Intruder2k5
MODERÁTOR
mgrincs #9396 üzenetére
Nekem nem egészen ugyanaz mint neked...
root@INT-ROUTER:/tmp/home/root# find - /
find: unrecognized: -
BusyBox v1.14.3 (2009-08-17 20:49:23 EDT) multi-call binary
Usage: find [PATH...] [EXPRESSION]
root@INT-ROUTER:/tmp/home/root# type find
find is a tracked alias for /usr/bin/find
root@INT-ROUTER:/tmp/home/root# l /opt/bin/find
lrwxrwxrwx 1 root root 16 Aug 21 21:22 /opt/bin/find -> /opt/bin/busybox*
root@INT-ROUTER:/tmp/home/root# l /usr/bin/find
lrwxrwxrwx 1 root root 17 Aug 18 03:07 /usr/bin/find -> ../../bin/busybox*
root@INT-ROUTER:/tmp/home/root# ipkg files findutils
Package findutils (4.2.32-1) is installed on /opt/ and has the following files:
/opt/man/man1/xargs.1
/opt/bin/findutils-xargs
/opt/man/man1/find.1
/opt/bin/findutils-find
Successfully terminated.
root@INT-ROUTER:/tmp/home/root#...és fent van a findutils is. (már régebben, nem most tettem fel)
root@INT-ROUTER:/tmp/home/root# ipkg list_installed
apr - 1.3.8-1 - Apache Portable Runtime library
apr-util - 1.3.9-1 - Apache Portable Runtime utilities library
busybox - 1.10.3-1 - A userland replacement for embedded systems.
busybox-base - 1.10.3-1 - A userland replacement for embedded systems.
busybox-links - 1.10.3-1 - A userland replacement for embedded systems.
bzip2 - 1.0.5-1 - Very high-quality data compression program
coreutils - 7.5-1 - Bunch of heavyweight *nix core utilities
cyrus-sasl-libs - 2.1.22-2 - Provides client or server side authentication (see RFC 2222).
e2fslibs - 1.41.9-1 - Ext2 Filesystem Libraries
expat - 2.0.1-1 - XML Parser library
findutils - 4.2.32-1 - File finding utilities
fontconfig - 2.5.0-0 - Font configuration library
freetype - 2.3.6-1 - Free truetype library
gawk - 3.1.7-1 - Gnu AWK interpreter
gconv-modules - 2.2.5-7 - Provides gconv modules missing from the firmware. These are used by glibc iconv() implementation.
gdbm - 1.8.3-2 - GNU dbm is a set of database routines that use extensible hashing. It works similar to the standard UNIX dbm routines.
glib - 2.20.4-1 - The GLib library of C routines.
grep - 2.5.3-1 - Global regular expression parser
ipkg-opt - 0.99.163-10 - The Itsy Package Manager
libcurl - 7.19.6-1 - Curl is a command line tool for transferring files with URL syntax, supporting FTP, FTPS, HTTP, HTTPS, GOPHER, TELNET, DICT, FI
libdb - 4.2.52-3 - Berkeley DB Libraries
libgd - 2.0.35-3 - An ANSI C library for the dynamic creation of images
libjpeg - 6b-3 - collection of jpeg tools
libpng - 1.2.39-1 - Portable Network Graphics Libraries
libsigc++ - 2.2.3-1 - libsigc++ implements a typesafe callback system for standard C++.
libtorrent - 0.12.5-2 - libtorrent is a BitTorrent library with a focus on high performance and good code.
libuclibc++ - 0.2.2-8 - C++ standard library designed for use in embedded systems
libxml2 - 2.7.3-1 - Libxml2 is the XML C parser and toolkit developed for the Gnome project.
libxslt - 1.1.24-1 - An XML Stylesheet processor based on libxml2
lighttpd - 1.4.23-1 - A fast webserver with minimal memory footprint.
mc - 4.6.2-1 - Midnight Commander File Manager
ncurses - 5.7-1 - NCurses libraries
ncursesw - 5.7-1 - NCurses libraries with wide char support.
openldap-libs - 2.3.43-1 - Open Lightweight Directory Access Protocol
openssl - 0.9.7m-5 - Openssl provides the ssl implementation in libraries libcrypto and libssl, and is needed by many other applications and librari
pcre - 7.9-1 - Perl-compatible regular expression library
perl - 5.8.8-20 - Practical Extraction and Report Language.
php - 5.2.10-3 - The php scripting language
php-fcgi - 5.2.10-3 - The php scripting language, built as an fcgi module
php-gd - 5.2.10-3 - libgd extension for php
php-mbstring - 5.2.10-3 - mbstring extension for php
procps - 3.2.8-1 - PROCPS System Utilities
readline - 6.0-1 - The GNU Readline library provides a set of functions for use by applications that allow users to edit command lines as they are
rtorrent - 0.8.5-1 - rtorrent is a BitTorrent client for ncurses, using the libtorrent library.
screen - 4.0.3-2 - A screen manager that supports multiple logins on single terminal
slang - 2.1.4-1 - S-Lang is a multi-platform library designed to allow a developer to create robust multi-platform software.
spawn-fcgi - 1.6.2-1 - spawn-fcgi is used to spawn fastcgi applications
sqlite - 3.6.16-1 - SQLite is a small C library that implements a self-contained, embeddable, zero-configuration SQL database engine.
termcap - 1.3.1-2 - Terminal emulation library
uclibc-opt - 0.9.28-13 - micro C library for embedded Linux systems
wget - 1.11.4-1 - A network utility to retrieve files from the Web
xmlrpc-c - 1.11.00-3 - A library providing modular implementation of XML-RPC for C and C++.
zlib - 1.2.3-3 - zlib is a library implementing the 'deflate' compression system.
root@INT-ROUTER:/tmp/home/root#[ Szerkesztve ]
Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
mgrincs #9399 üzenetére
Nálam is létezik az /opt/etc alatt profile, és van is benne PATH.
Jelenleg ez:PATH=/bin:/usr/bin:/sbin:/usr/sbin:/home/root:/opt/sbin:/opt/bin:/opt/etc/init.d:
Ha a Tiedből kiveszem az mmc-s mappákat (amit én nem használok), és az /opt/usr/bin valamint /opt/usr/sbin mappákat (amik nem is léteznek) akkor teljesen megegyezik az enyémmel...
Intruder2k5
MODERÁTOR
Ezt olvastad már?
http://wl500g.info/showthread.php?t=7789Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
"Klónoztam a gépembe a router MAC címét"
Nem fordítva? A géped IP címét kell a routerre klónozni... Na de ez most mindegy is."és a gép sem kap ip címet"
Ezt úgy érted, hogy a router kihagyása nélkül sincs már neted?
Vagy pedig a gép nem kap belső IP címet a routertől?Ha úgy gondolod, hogy a router beállításaiban rontottál el valamit, akkor:
Administration -> Configuration -> Restore Default Configuration -> Erase All Data In NVRAM MemoryÉs kezdheted elölről a beállítást...
Intruder2k5
MODERÁTOR
Kitakat #9412 üzenetére
Szerintem se jó ötlet ha "álcázod" (már amennyiben egyáltalán lehetséges), mert egyes általános iskolás, tizenéves adminok azonnal csalónak kiáltanak ki, és kitiltanak a trackerről... Némelyikük sajnos nagyon tudatlan. Van ahol felismeri a tracker, és van ahol nem. Maximum írd be az adatlapodra, hogy "Linux / rTorrent", és szerintem még így jársz el a legjobban.
Intruder2k5
MODERÁTOR
Szerintem inkább így:
#!/bin/sh
iptables -D INPUT -j DROP
iptables -A INPUT -p tcp --dport 51777 -j ACCEPT
iptables -A INPUT -p udp --dport 51777 -j ACCEPT
iptables -A INPUT -j DROPDe egyébként az ecaddict féle S99rtorrent, megnyitja a szükséges portot, a torrent indításakor, és ha esetleg leállítod, akkor zárja is. Persze mivel általában nem szokás leállítgatni a torrentet a routeren, ezért maradhat így, fixen is. Szerintem a többség így használja. Én is...
Intruder2k5
MODERÁTOR
Nemrégen (2-3 hete talán) volt téma itt a topicban, hogy a torrent elég gyakran használ UDP protokollt is, így nem árt azt is megnyitni... Volt aki határozottan állította, hogy így több kapcsolatot hoz létre. Én személy szerint nem tesztelgettem, de betettem a firewall scriptbe, végülis elfér.
A többi sor pedig az alap (DROP) szabály miatt kell, az állítja be, hogy minden kapcsolatot eldobjon, kivéve azokat, amik lentebb direkt meg vannak nyitva.
Intruder2k5
MODERÁTOR
ljungberg #9426 üzenetére
Én ezt így raknám össze:
insmod ipt_recent
iptables -A INPUT -p tcp --dport 443 -j ACCEPT
iptables -A INPUT -p tcp --dport 6880 -j ACCEPT
iptables -A INPUT -p udp --dport 6880 -j ACCEPT
iptables -A INPUT -p tcp --dport 51777:51780 -j ACCEPT
iptables -A INPUT -p tcp --dport 65534 -j ACCEPT
iptables -t nat -A PREROUTING -i vlan1 -p tcp --dport 443 -j DNAT --to-destination 192.168.1.1:443
iptables -A INPUT -j DROPAz SSH-nak, és az FTP-nek nem kell külön iptables szabály, ha a webes felületen engedélyezed a távoli elérést, akkor az már intézi a továbbiakat, és ha majd egyszer kikapcsolod, akkor törli is a szabályokat. Ugyanez vonatkozik az SSH és FTP brute force attack védelmére, ezt szintén érdemesebb a webes felületen beállítani. Valamint, nem tudom, hogy mire használod a 51777:51780 port tartományt, és a 65534-es portot... De ha Te sem tudod, akkor töröld ki az erre vonatkozó sorokat is még. Ebben az esetben ez lesz a végleges:
insmod ipt_recent
iptables -A INPUT -j DROPHirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
Én nem használok fstab-ot, egyelőre maradok a bevált Init sciptnél, abból mountolok.
flashfs save, commit, enable nincs a Tomato-ban, helyette a jffs-t használjuk. Oda bemásolod az fstab-ot, és az Init scriptbe beteszel egy sort ami indításkor visszamásolja a helyére. Szerintem így működik...Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
1. Administration -> JFFS -> Enable -> Save
2. Administration -> JFFS -> Format / Erase -> SaveEzután már írható lesz a jffs mappa, és konkrétan 4 MB helyed lesz ott. Ezt kell beosztani :-)
Én úgy oldottam meg, hogy csináltam a jffs mappába egy rootfs mappát, és ebbe teszek minden olyat, amit vissza akarok másolni indításkor a filerendszerbe.
Ha jól csalódom, akkor az fstab a /tmp/etc alatt van, tehát akkor csinálj egy /jffs/rootfs/tmp/etc/fstab file-t, és az Init scriptbe (Administration -> Scrrpts -> Init) tedd be ezt:cp /jffs/rootfs/tmp/etc/* /tmp/etc
Persze az útvonalakat úgy alakítod, ahogy neked tetszik, ez csak egy példa volt, esetlegesen később, több file esetén, így jobban átlátható, hogy mi, hova megy.
Intruder2k5
MODERÁTOR
Intruder2k5 #9437 üzenetére
A másolási parancsra visszatérve, lehet "recursive" is, így nem kell mindent külön másolgatni, ha esetleg később más is kerül bele.
cp -r -f -p /jffs/rootfs/* /
Így mindent kimásol, ami a jffs/rootfs alatt található.
Intruder2k5
MODERÁTOR
Ezt én értem, csak azt próbálom elmondani, hogy ha bizonyos trackerek felismerik )márpedig ez látszik a screenshot-on), akkor a többi is felismerhetné, hiszen ezek szerint ott van benne a "peer ID", és korrekt is, mert amelyik felismeri, az helyesen ismeri fel. Viszont tény, hogy sok tracker "unknown client"-ként jelzi, de ezek szerint ez az ő hibájuk, mert a lehetőség adott az azonosításra. Bár nem tudom, hogyan is működik pontosan egy tracker, de mivel nem konkrétan "rtorrent/0.8.5/0.12" a "peer ID", hanem csak egy rövidebb kód, ezért gyanítom, hogy a tracker oldalon van egy kódtáblázat, amiben benne vannak a "peer ID" + kliens párosok, és ebből a listából (talán mert ritkán használt) hiányzik az rtorrent, és ezért jelzi ismeretlen kliensnek. Ha "gyárilag" nincs beforgatva a "peer ID", hanem ezt utólag kellene megcsinálni ha valaki igényt tart rá, akkor egyes trackerek hogyan azonosítják? Ha nincs "peer ID" akkor az csak rtorrent/0.8.5/0.12 lehet?
Ezért írtam, hogy szerintem első sorban a tracker oldalon lennének teendők.
Remélem így érthető volt :-)[ Szerkesztve ]
Intruder2k5
MODERÁTOR
OLEG alatt sem maguktól indulnak el, hanem az rc.unslung indítja el őket, ami szintén abban a mappában van, azt pedig a post-boot hívja meg. Mivel itt nincs post-boot, így az "Administration - Scripts - Init"-be kell betenni ezt:
/opt/etc/init.d/rc.unslung
Intruder2k5
MODERÁTOR
Laca 012 #9451 üzenetére
Ezt sajnos nem tudom mitől van, de nekem meg olyanokat csinált anno a vnstat, mikor használtam még, hogy teljesen spontán kiugrásokat tett a forgalmi statisztikába, de olyanokat, ami fizikai képtelenség volt :-)
Pl. az én 256 kbit-es feltöltésemmel egy nap alatt (szerinte) feltöltöttem 6 GB-ot, de úgy hogy a torrent le volt korlátozva 16K-ra... Elég zavaró volt, hogy nagyjából hetente egyszer eljátszotta ezt, és akkor kiugró értékek maradtak a statisztikában. Néhány napig 1-1,2 GB, aztán egyszer csak 6 GB :-)Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
Mert az Init script elejére szoktunk rakni egy ilyen sort:
sleep 15
Vagy 10, vagy 20, vagy amennyi másodperc szükséges ahhoz, hogy megfelelően inicializálni tudja a lemezt. Valószínűleg hamarabb lefut a script, mintsem a diszket felismerné a firmware.
Intruder2k5
MODERÁTOR
ritkamadár #9465 üzenetére
Tomato-t első alkalommal nem lehet webes felületen feltenni. Ilyenkor sajnos nincs más út, mint a firmware restoration tool, vagy tftp. Később, frissíteni már fogod tudni webesen át.
optware telepítés Tomato alá itt. De egyébként ha van meglévő rendszered, amit OLEG alatt használtál, az működik tovább Tomato alatt is, némi alakítással.Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
ritkamadár #9467 üzenetére
Sajnos fstab ügyben teljesen láma vagyok, sosem próbáltam még, így nem tudok segíteni.
rc.unslung ügyben annyit tudok tenni, hogy beteszem ide azt, ami nálam most is működik:#!/bin/sh
# Start all init scripts in /opt/etc/init.d
# executing them in numerical order.
for i in /opt/etc/init.d/S??* ;do
# Ignore dangling symlinks (if any).
[ ! -f "$i" ] && continue
case "$i" in
*.sh)
# Source shell script for speed.
trap - INT QUIT TSTP
set start
. $i
# No sh extension, so fork subprocess.
$i start
esac
doneHirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
ritkamadár #9472 üzenetére
Arra ügyelj, hogy mikor a vágólapról beilleszted az SSH (PUTTY) ablakba, akkor hajlamosak az idézőjelek módosulni :-) Szóval mire beilleszted a scriptet, addigra már nem az lesz, mint amit kijelöltél... Ha esetleg nem menne, akkor ilyen szemmel nézd át a dolgokat.
Intruder2k5
MODERÁTOR
Kitakat #9477 üzenetére
De, eléred simán, mint eddig is, http-n keresztül is. Én úgy oldottam meg, hogy kintről csak https elérés van engedélyezve iptables-ben, bentről ugyan elérem a 8081-es porton, de itthon, LAN-on is https-t használok.
Ahogy vargalex is mondta, ha eltérő webroot-ot adsz meg a https-nek, akkor majdnem olyan, mintha két webszervered lenne... Másik porton, más tartalommal. Ha viszont a webroot közös, akkor a tartalom azonos, csak két porton is eléred ugyanazt. Remélem így már érthető... :-)
Intruder2k5
MODERÁTOR
Kitakat #9479 üzenetére
Nem tudom, nekem nem volt gondom OLEG alatt sem az iptables-el, és most sincs.
Mondjuk szerintem ha ott van az említett utolsó sor, akkor el kell, hogy dobja a kapcsolatot, de ha valami egyéb oknál fogva mégsem, akkor írj egy sort külön arra, hogy a 8081-es (vagy amennyi kell) porton jövő kéréseket dobja el. De én nem hiszem, hogy erre szükség lenne...[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Kitakat #9482 üzenetére
Először is, 9483
Másodszor, sokat lendítene a dolgon, ha láthatnánk azt a post-firewall file-t :-)
Harmadszor, gyanítom, hogy a webadmin felületed a 80-as porton fut, és ki van engedve WAN felé, a webes felületről (ez is egy lehetséges ok)[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Kitakat #9489 üzenetére
Ahogy ezt én csinálnám...
1. A "Brute Force Attack" elleni védelmet a webadmin felületen állítanám be.
2. Szerintem fölösleges egyes portokat külön DROP-olni.
3. Nem nyitnák 100 portot a torrentnek, ugyanúgy működik 1-el is.Szerintem ennyi elég is lenne a post-firewall-ba:
#!/bin/sh
insmod ipt_recent
modprobe /opt/lib/modules/2.4.37.5/kernel/net/ipv4/netfilter/ipt_TARPIT
iptables -A INPUT -p tcp --dport 6881 -j ACCEPT
iptables -A INPUT -p udp --dport 6881 -j ACCEPT
iptables -t nat -A PREROUTING -i "$1" -p tcp --dport 443 -j DNAT --to-destination "$4":443
Intruder2k5
MODERÁTOR
Én azt gondolom, hogy ez swap (memória) hiba...
Amivel próbálkozni lehet:1. Próbáld meg újraformázni a swap particiót.
2. Próbálj meg más eszközt használni swap tárnak. (másik pendrive, vagy HDD)
3. Imádkozz, hogy ne a RAM legyen a hibás :-)Valamint próbaképpen esetleg tiltsd le a swap-et, indítsd újra a routert, és kevés (1-2) torrenttel próbáld meg, hogy akkor is előjön-e a hiba. Elvileg el kell mennie swap nélkül is, ha csak 1-2 darab kis méretű torrent van a kliensben, akkor amúgy is minimális a swap használat.
Intruder2k5
MODERÁTOR
Egy rövid ötlet: Itt keresgélj :-)
Intruder2k5
MODERÁTOR
Először is hagyjuk ezt a masterezést, nem vagyok én senki...
Másodszor, természetesen jöhetsz ide, bizonyára lesz is aki segít majd, de az nem én leszek sajnos... Sosem raktam fel OLEG-ra vsftpd-t. Nekem Tomato-m van jelenleg, és abban a webes felületen konfigoljuk az ftp-t. :-)Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
CPU Load Tomato-ban:
Így már érthetőbb? :-)
1, 5, és 15 perces átlagos értékek ezek...A UPC-s dologra annyit, hogy én szerencsére nem vagyok az előfizetőjük, de töltök egy torrentet, ahol össz-vissz két seeder van, az egyik UPC-s, és ma nagyon gyengén jönnek a byte-ok tőle... Tegnap sokkal gyorsabb volt. Jó, jó, tudom, hogy ennek ezer más oka is lehet, de mindenesetre érzem a sebességcsökkenést. Amúgy ha érdekel bővebben, és még nem olvastad, itt is szó van a UPC korlátozásairól.
Intruder2k5
MODERÁTOR
Hát 30-50 torrentet nem fogsz egy időben futtatni rajta, mint ahogy nem igazán szereti a 100 GB-os torrenteket sem. :-) Az átlagos torrent felhasználónak tökéletesen megfelel, 10-20 db torrenttel vígan megbirkózik. Nagyjából ez az, amit várni lehet egy ~250 MHz-es, 32 RAM-mal felszerelt géptől. Cserébe viszont 24/7 üzemel és töltöget, teljesen csendben, és az áramfogyasztása is elhanyagolható. Az USB-je ugyan kicsit lassú, nagyjából egy PenDrive sebességével egyezik meg (~3500 kbyte/sec), dehát ennyi pénzért ne akarjon senki egy bivalyerős home-szervert. Én mindenesetre nem bántam meg, hogy megvettem, és gondolom, hogy sokan egyet értenek velem.
Intruder2k5
MODERÁTOR
Nem, Tomato-ban sem 1 a "Full". Pontosan én sem tudom, hogy mennyi, de az biztos, hogy pl. samba másoláskor 2 - 2.5 körül van a load. Szerintem talán 5 a max... De ez csak tipp. :-) Amúgy SSH-ban kiadott "uptime" parancsra kapod válaszul a load értékét.
Intruder2k5
MODERÁTOR
Kitakat #9554 üzenetére
Régebben tapasztaltam én is, de egy jó ideje már nem...
Talán még az 1.8 - 2.0 verziók környékén előfordult nálam is.
Szoktad frissíteni, a legfrissebb verziót használod?
Ha nem, akkor innen megteheted.
Csak letöltöd az aktuális verziót, bemásolod a webroot alá, a régit felülírva (vagy előtte törlendő), és készen is van. Bár sosem csináltam ilyet, de esetleg próbálkozhatsz azzal, hogy miután mindent beállítasz, vedd el az írásjogot a konfigfile-ról, vagy végülis szerintem az egész mappáról elveheted. Hátha segít... Más ötletem nincs.[ Szerkesztve ]
Intruder2k5
MODERÁTOR
sz.gergely #9556 üzenetére
A vacsorádat ne főzze meg? :-)
De komolyan visszatérve a kérdésre, pinget mérni szerintem egy viszonylag egyszerű néhány soros scripttel lehet, ami pl. egy log-ba írja a kimenetet, majd ezt ütemezed tetszés szerinti időközönként. IP csere is simán kikereshető a log-ból,ez elég feltünő szokott lenni. Tomato firmware-nek szerintem egyik erőssége a forgalom statisztika. Ilyen grafikonokon nyomon követhető az elmúlt 24 óra forgalma, interface-ekre lebontva, 2 perces mintavételezéssel. De ha úgy tetszik nézegetheted a real-time verziót is.
Persze lehet, hogy létezik egyéb megoldás is, de én nem tudok róla...
(ez persze nem jelent semmit)Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
sanzi89 #9570 üzenetére
A csomagfrissítésre, két parancs szolgál, ebben a sorrendben egymás után:
ipkg update
ipkg upgradeElőtte ajánlatos lementeni az S99rtorrent file-t, mert időközben volt egy olyan frissítés, ami szó nélkül felülvágta. Majd a frissítés végeztével másold vissza. A konfig file-okra rákérdez, hogy megtartsa, vagy kéred az újat, itt értelemszerűen válaszolsz majd, és nem csinál problémát. Ha jól csalódom, akkor a régi megtartása a default válasz, és neked is ez kell. Ezek szerint Te még azóta nem frissítettél, tehát ne lepődj meg, eltart majd egy darabig, de valóban rá is fér már. :-)
NFS-t sosem próbáltam.
Intruder2k5
MODERÁTOR
Böngésztem a neten egy film leírását keresve, és mit találtam...?!
Ezek itt ellopták az AEGA menüjét ;-)Hirdetéseim: https://shorturl.at/L8E51
Intruder2k5
MODERÁTOR
Intruder2k5
MODERÁTOR
sanzi89 #9588 üzenetére
Laca 012 topiktárs hűtésmegoldásai:
http://img7.tar.hu/budavaril/img/37560060.jpg#3
http://img7.tar.hu/budavaril/img/37559718.jpg#3
A teljes galéria itt.[ Szerkesztve ]
● Olvasd el az összefoglalót!
- Eladó hibátlan Sony PlayStation 5 (PS5) Slim Konzol (1TB), 2 Kontroller (+ Diablo IV opcionálisan)
- AMD Gamer PC / AMD Radeon RX 7900 XTX / AMD Ryzen 7 7800 X3D
- iphone 14 Pro Max 128gb, független, makulátlan, 100% akku
- iphone 15 Pro Max 256gb Natur Titanium,független,bontatlan
- ÚJ Bontatlan APPLE MACBOOK AIR 13 - M2 (MLY33MG/A) ÉJFEKETE - 8GB/256GB SSD- Magyar - 3 év Garancia
