Nyárköszöntő hardverszemle
gyugyo79
Az a baj, hogy nincs időm olvasni rendesen utána csak pld.: beleolvasgattam a fórumba (https://forums.plex.tv/t/plugins-removal/312587/5)
De komolyan nem lettem okosabb, hogy mit akarnak pontosan.
Mert ha én jól értettem akkor nem mindent akarnak "megszüntetni" pld.:
"While support for browsable plugins is being discontinued, nothing is happening to scanners and metadata agents with this announcement." ForrásSzóval én kb félig értem csak, hogy mit is akarnak pontosan, de nem értem mi értelme van ennek mert szerintem nem teljesen jól van lekommunikálva még akkor se ha jó az irány (bár ami nekem eddig lejött az alapján nem jó) ...
Keksz
uuuuuu, évekig vártam erre...
megy a Direct Play iphone-on, Infuse nékül, a hivatalos iPhone App-ban....
PRODUCT Plex for iOS
PLAYER iPhone
QUALITY Original (2.5 Mbps)
STREAM Direct Play
CONTAINER Direct Play (MKV)
VIDEO Direct Play (H264 720p)
AUDIO Direct Play (EAC3 5.1)
SUBTITLE Direct Play (SRT)Pár infó az új kisérleti lejátszóról:
What’s changed?
With this new video player, the apps will be able to play many more video formats without transcoding. This also includes a new custom video player UI in the Apple TV app that adds support for seek thumbnails, proper audio & subtitle switching during playback, and some other things we’ll add in the near future. We also gained more control over our playback stack.Basically, with these changes, the apps will try to use the new video player based on mpv when possible, with a few exceptions:
LiveTV playback
News and Web Shows
HDR videos
Interlaced videos
Transcoded and Direct Streamed videos. This means that when a certain video cannot be Direct Played by mpv and needs any kind of conversion, it will be converted to a format compatible with AVPlayer and played with it.
In all these circumstances the app will use the old player. We’re working as we speak to reduce that list of exceptions.
There are two other exceptions where Apple’s AVPlayer is needed: when using AirPlay and Picture in Picture (on devices which support it). In those scenarios, when enabling those features the app will switch to the old player (meaning, it could require transcoding).
Finally, due to some performance and compatibility issues we found, for now the new player will be available only for devices with iOS 11 and newer.
It’s also worth mentioning that this doesn’t affect Sync right now. That means, your media will still be transcoded to the same format in order to be compatible with the old player.
What are those supported formats?
Right now, the new player can direct play the following formats:Supported containers: mkv, mov, mp4, mpegts, mpeg, mpegvideo, avi, flv, ogg
Supported audio codecs: aac, aac_latm, ac3, alac, flac, dca, vorbis, opus, eac3, mp1, mp2, mp3
Supported video codecs: h264, hevc, vp8, vp9, h263, mpeg1video, mpeg2video, mpeg4
Supported subtitle codecs: ass, dvb_subtitle, vobsub, eia_608, pgs, microdvd, movtext, ssa, srt
What’s in development?
We’re actively working on:Improving performance.
Adding support for HDR playback.
Adding support for tone mapping when playing HDR videos in SDR displays.
Improved controls/gestures in the Apple TV video player.
Increasing device compatibility.
Keksz
1080p is megy neki simán iPhone-on:
PLAYER iPhone
QUALITY Original (15.1 Mbps)
STREAM Direct Play
VIDEO Direct Play (H264 1080p)
AUDIO Direct Play (DCA 5.1)
SUBTITLE Direct Play (SRT)LOCATION WAN
BANDWIDTH 31.6 MbpsJelenleg még csak Plex Pass usereknek lehet aktiválni!
apezka
BonFire
Ezen csak ennyi van, amit látsz. Se menü, se törlés, se áthelyezés...
Nagy nehezen megtalálom a Playlistet, amit tegnap este létrehoztam, el van ásva a filmek közé: Movies, All movies ► Collections ► Playlists ► Nemrég megjelent filmek... Nemrég hozzáadott filmek... meg még egy csomó hülyeség. Önállóan ő kategorizál mindent összevissza. Többet akar tudni, mint én. Mik a legnépszerűbb filmek? Bah! Ne ő döntse már el IMDB vagy bármi más idétlen besorolás alapján.
Most az van, hogy van egy webes felület, desktopon van kétféle, egy asztali és egy tévés nézet, plusz van egy mobil nézet, amely négyféle nézet semmilyen köszönőviszonyban nincs egymással, mindegyik ad hoc van kialakítva, mindegyiken minden máshol van, vannak dolgok, amelyeket csak itt, vagy csak ott lehet megtalálni.
Én már nagyon régóta keresgélek médiaszerver alternatívát helyette, mert ez így ebben a formában használhatatlan. Létrehozok egy playlistet, belepakolom az évad epizódjait, és összevissza, random sorrendbe rendezi. De nem lehet ám csak úgy ABC-rendbe rakni (mert akkor ugye az epizód szám alapján egy kattintás volna. Nem! Kézzel kell ide-oda húzigálni a sorokat egymás fölé-alá, mint a YouTube-on, csak ott van egy gomb hogy a Tetejére, vagy az Aljára, és viszonylag könnyű rendet csinálni. Egy 23 részes sorozat playlistjét elkészíteni ne legyen már 30 perc, könyörgöm!
De nincs helyette alternatíva, külöben úgy vágnám ki a pcsába, hogy csak úgy repülne.
A Prohardveren nem olvasok privátot! Csak topikban vagy a publikus e-mailemen adok tanácsot.
Harpagon
Igazából a Plex fele az vitt hogy a synology beépített media szerverét használva a régebbi LG TV-n ( LA691 ) akadozott a film lejátszás míg a másik LG 4K (UF777) Tv-n ment minden gond nélkül. Ezért gondoltam kipróbálom a Plex-et hátha a gyári media szerver a ludas. Most ott tartok hogy az ideg megesz mert telepítve a TV-re a plex appot először ment minden aztán kiírta hogy nem elég erős a szerver a átkódoláshoz és azóta semmit sem játszik le bármit indítok..
Ami a végtelen érthetetlen számomra hogy egy ezer éves WD MyBookWorld NAS-om volt előtte pont négyszer gyengébb hardverrel. Azon minden TV-n minden mobilon akadás nélkül vitte a full hd tartalamat és soha semmit nem kart átkódolni közben. Szóval ez a csere óriási visszalépés lett.
Milyen nem gyári megoldásra gondoltál? -
forest_ns
WaterWave
WaterWave
Gondolom amugy ez olyan megoldás, hogy nem tölti le a csomagkezelési központban a plexet, hanem docker megnyit, nyilvántartás - plex - linuxserver/plex...
ezt pattintja fel, a 32400-as port ugyanaz marad, csak lehet dockerben igy másképp fut...• PlayStation 5 • PSN: waterwave0122 • Thinkpad X1 Yoga • LG 48 OLED C1 • Samsung Galaxy S9+ • Tp Link AX6000 • Marantz SR8015 AV Receiver • Synology Nas 718+ 6GB • Klipsch R-28F 7.1.2 Dolby Atmos •
morpheus133
Melyik feliratnál nem megy? Én most nem láttok vele hibát.
bazar::
Nem hinném hogy gyorsan javitják.
Semmi mást nem csináltak csak áthúzták a subzeroban lévő fájlokat.
Illetve az áthúzás nem sikerült elsőre mert az LXML-t libraryt nem adták hozzá így pár provider köztük a magyarok sem működtek.Mondjuk igaz ott azt ígérték hogy nem kell majd hónapokat várni ahhoz hogy a javítások bekerüljenek.
konigjanos
Egy kis segítséget kérnék szépen: a 24 sorozatot nem kezeli értelmesen a plex, és semmi nem segít. A mappában azonosan vannak elnevezve a videók, minden évadnál látja az összes részt, kivéve az első évad, ahol ráadásul az elnevezés is fura. a 8. részig jó, utána megváltozik.
mappa nézetben ott vannak a hiányzó részek: -
Stehe
Köszönöm ezt próbáltam végül én is! Ennek mi a legegyszerűbb módja?
Én az alábbival próbálkoztam, jó is lett az eredmény, de 5 órába került a konvertálás:
- Wondershare Video Converterrel a DTS audio sávot leszedtem ac3 fájlba az eredeti MKV fájlból (kb. 40 perc)
- Mkvtoolnix progiba beimportálta az eredeti MKV fájlt és az ac3 fájlt, illetve beállítottam, hogy az output csak ac3-t tartalmazzon (240perc)Igaz nem mai a gépem, de a mergelésnek nemcsak egy néhány perces feladatnak kellene lennie?
mackosajt
Köszi, de perpill ott tartok, hogy a plex server webes felülete el sem érhető... Ha fejem tetejére állok, akkor sem.
A syno saját videó station meg hibátlanul fut, csak épp hiába választom ki benne a magyar feliratot, az LG tv nem teszi ki.
Lassan kompletten újra húzom inkább az egészet, csak előbb lementem a filmeket.http://www.opelforum.hu http://hkv.hu "Zuzuval társalogni olyan volt, mint sajtreszelővel rejszolni. Enyhén szórakoztató, de leginkább fájdalmas." by Ford Fairlane
ElGatto
Valahol mintha olvastam volna vagy hallottam valakitől, hogy pl. feliratot keres letölt a fimhez a program stb., de igazából még egy bővítmény listát sem találok. Nyilván az xboxon futó programhoz azon belül kellene keresgélni de az annyira egyszerű mint egy fakocka. kb. elindít, leállít, megnéz ennyit tud semmi mást.
petack
Újratelepítettem a win10-et, felraktam a plex-et, de ugyenezt csinálja.
Pedig szimpatikus program.
Honnan lehetne rájönni, mi lehet a baj?
Kodi-t nem találtam a tv-hez. (Samsung UE55NU8002)
Ha a hálózattal lenne gond, a PC-n nem csinálná ugyanezt.
Egyébként cat5e kábel van a router (5Ghz) meg a pc között, a tv pedig wifin csatlakozik. Jah, és a router meg a tv egy szobában vannak. -
Sanya200
Sima tplink router nem jó? Az talán van korábbról.A mobilnettel az a gond hogy csak telefonba vagy tablettbe használhatom.Nekem még a hello data csomag van ami korlátlan de nem tehetem a simet ruoterbe vagy ilyen hordozható wifi-be.100 mbit szokott lenni a feltöltés van hogy több is de a feltöltés nincs annyi.
Jó lenne biztosra menni,mondjuk egy ilyen router se olcsó ,de biztos működne? Pc-ről is próbáltam de nincs hdr pl meg nehéz beállítani..stb Érdekes higy a plex viszi rendesen,mármint van hdr minden a többivel meg annyit kéne szarakodni...mpc-hc meg madvr meg lav filter meg ..áh -
Krip75
Kedves Keksz és mindenki!
Szeretnék segítséget kérni Plex server témában, mivel előbbi hozzászólásodban említed, hogy: "már régóta távoli plex serverem van" amire felkaptam a fejem.
Az lenne a kérdésem, hogy ezt, hogyan kell elképzelni és mik a feltételei/költségei? (nem akarok indiszkrét lenni)Azért kérdezem mert nekem jelenleg adott 1 PC (i7-6700k+gtx 1060 +windows+ plex server + média= minden egyben, egy gépen) amely tökéletesen megfelel a feladatra de ez a személyes gépem is amit használok.
A helyzet így nem optimális mert sokszor kell távoli elérés (2 helyen lakom) többször pedig transcode mert nem elég a net (upc 500le/ 22fel)Egyrészt szeretném szétválasztani a kettőt, a gépemet használni + másik eszköz/szolgáltatás/ bármi = plex szerver és média tárolás (kb 3-6 tb közötti méret) amely esetleg több klienst is elbírna (megosztanám még kb 2-3 emberrel max).
Gondolkoztam NAS-on, saját szerver építésen de ezek a korlátolt net miatt nem érnék meg (jellemzően 1 klienst tudok kiszolgalni jelenleg de a net miatt néha az is megakad 14-20 mbps 1080p. Távoli szerver lenne a legoptimálisabb de nem találtam semmi okosat ebben a témában viszonylag normális áron. Minden megoldás érdekelhet.
Mindenkinek köszönöm aki egyáltalán elolvassa ezt a hosszú bejegyzést, akár segít is!
Sanya200
Helyit szeretnék nekem az megfelel.Van sima routerem megpróbálom azzal.Csak segítsetek beállítani a plexet meg hogy mit hova dugjak próbálom megoldani úgy hogy ne kelljen külön venni se okosítót se mást.A plex jó lenne csak ugye pufferel úgyhogy ha segítettek megpróbálom összekötni a pc-t meg a tv-t úgy hogy köztük a router.
sugarforce
Nekem nagyon ritkan van ilyen gondom, hogy fix matchelni kelljen, pedig nem nevezgetek at semmit, max regi sorozatokat, amikbol csak ezer eves releasek vannak rossz elnevezessel.
Mondjuk az is hozzatartozik az igazsághoz hogy a legtobb release alapbol a film angol cime.evszam elnevezest követi, ezert sincs dolgom vele. Max a verpistikes valtozatok térnek el ettol, azokat szimplan a minoseguk miatt le sem toltom.[ Szerkesztve ]
