Strand vagy hűvös szoba? A hardverek tudják a választ!
ph Asztali gépek, alkatrészek, perifériák és kiegészítők szeretnék elkerülni a napszúrást.
OneSport OT05 - finomhangolás
Malibutomi
980toi review vegszavak:
Anandtech:
As for this moment, the high-end video card market is essentially in a holding pattern. The GeForce GTX 980 Ti is a fine card for the price – a GTX Titan X for $649 – however with AMD’s new flagship card on the horizon buyers are likely better off waiting to see what AMD delivers before making such a purchase, if only to see if it further pushes down video card prices.Hexus:
Within two weeks we'll bear witness to partner-clocked cards that tease the most out of the second-generation Maxwell architecture, and we fully expect the cream of this crop to be faster than the reference Titan X in every regard. Whether such speed will be good enough to hold on to the single-GPU crown in the face of imminent upcoming competition from the Fiji-infused Radeon R9 390X is one of the more interesting debates in the premium PC graphics space.Bit/tech:
With the R9 390X expected by the end of June, there's little reason to part with your cash right now if you're shopping for a high-end GPU. This is clearly an awesome card, but nonetheless our advice is to take note of the various GTX 980 Ti cards that come out and then see what AMD brings to the table before making your choice.TPU:
And then there is the big unknown variable in form of AMD's upcoming Fiji cards, which could change things dramatically, so definitely wait on purchase until those cards are released.Lehet tudnak mar valamit vagy nem...de majd kiderul
Malibutomi
válasz Ren Hoek #12144 üzenetére
Ha most jol megcsinaljak a huteseket a gyartok, akkor nemlesz semmi gond ezekkel a kartyakkal. Jo aron eros kartyak lesznek sok rammal.
Ha a Fiji Pro meg 200 alatt lesz, arban a 980 es a Ti kozott az ott jo helyen is lenne, doleg hogy a Ti-hez lesz kozel teljesitmenyben. Vagy pont ott ha igaz amiket hallottunk rola.
Malibutomi
Radeon R9 Fury X will be the flagship video card, a watercooled part based on the Fiji XT GPU. Under that, we'll have the Radeon R9 Fury, which should be based on the Fiji PRO architecture, with an entire restack of current cards. Under these two new High Bandwidth Memory-powered video cards we'll have the Radeon R9 390X, Radeon R9 390, Radeon R9 390, R9 380, R7 370 and R7 360.
The Radeon R9 Fury X will be a reference card with AIBs not able to change the cooler, but TweakTown can confirm that it will be the short card that has been spotted in the leaked images. The Radeon R9 Fury will see aftermarket coolers placed onto it, so we should see some very interesting cards released under the Radeon R9 Fury family.
Malibutomi
válasz Menthirist #12235 üzenetére
oc.uk-n mar kitargyaltak ezt, hogy eleg nagy hulyesegek vannak benne.
Egyreszt hogy 45%-al tobb shaderrel, 1.2gcn-el, meg egyeb josagokkal nem tud 35-40%-al jobb lenni mint a 290X az furcsa lenne, masreszt hogy nincs rajta bios, meg az amd dolgozik az orajeleken...a kartyaknak reg dobozban kell lenniuk kiszallitasra keszen ha ket het mulva bemutato. Sot a tesztoldalakhoz lassan ki is kell kuldeni szerintem.Azt el tudom esetleg kepzelni hogy a kis Fijirol van szo sebessegileg, bar a tobbi arra is all.
Na mindegy ket het es vegre megtudjuk.
Malibutomi
válasz Menthirist #12237 üzenetére
Most neztem az eredeti cikket a hardwareluxx-on..tipikus clickbait..
Everything about the Radeon Fury X continues to be based on hearsay. Especially any information relating to performance has to treated with caution. AMD certainly will still be able to improve numerous details. Neither BIOS or drivers are likely to have been finalised.
Magyarul ha total ellentete igaz annak amit irtunk, akkor sincs rajtunk felelosseg
Malibutomi
válasz Menthirist #12241 üzenetére
Fiji epp a TX alatt Ti szinten, 8Gb augusztusban
Ez alapjan, akkor kb. oda arazzak ahol teljesitmenyben vannak.
Most minden oldal elszabadul ugy latszik, osszevissza hirek lesznek meg ket hetig
Malibutomi
WCCF:
Update: Our sources close to AMD have reported that any reports of performance issues at this time are pointless. We have concrete confirmation that the GPU will launch at E3 – so we have something to look forward to very soon and will get a chance to see its final performance as well -
Malibutomi
válasz Komplikato #12273 üzenetére
Ma mar ketszer volt....
Malibutomi
Uj teaser: [link]
Malibutomi
Most eloszor hallottuk (elvileg hivatalosan) hogy nem fog tobbet fogyasztani mint a 290x.
Malibutomi
Powercolor 390X hibrid
Ez a fenyes resz eleg bena rajta szerintem.
Malibutomi
Malibutomi
válasz Bugfix1984 #12321 üzenetére
Most esett le...
a 390X és a Fiji Pro és Fiji XT lesz itt az újdonság
A 390X is?
Malibutomi
válasz KillerKollar #12342 üzenetére
A 880 es a 400$ kozott meg van minimum egy kartya a Fiji Pro
Malibutomi
válasz Menthirist #12345 üzenetére
A 800$-os az a csucs vizhuteses ezt mar tudjuk egy ideje.
A Pro meg lesz elvileg a leghuteses, szerintem azt megkapjuk 200 korul -
Malibutomi
válasz Menthirist #12349 üzenetére
Lassuk meg az arakat, a multkor a 8gb XT volt irva 850, a 4gb ra mar csak 750, a Pro-ra meg 650
Malibutomi
válasz #45185024 #12368 üzenetére
Ezek szerintem elmennek indulo arnak, aztan mindegyik lejjebb csuszik egy tizessel minimum.
Ja es igy:
74.000 (199) R9 380 4gb
109.900 Ft R9 390 8gb
149.900 Ft R9 390x 8gb224.00 (749)Fiji pro 4gb hbm 649$280.000 (849)Fiji xt 4gb hbm 749$
329.900 Ft (849) Fiji xt /xtx 8gb hbm
520.00 (1399)Fiji vr 2x8gb hbm[ Szerkesztve ]
Malibutomi
válasz Menthirist #12384 üzenetére
Malibutomi
Egyetlen esetben lehet a 390 dragabb mint a 970 es a 390X dragabb mint a 980 ha tenyleg csinaltak valamit, esa tobb ram melle legalabb ugyanolyan gyorsak mint az ellenfeluk (vagy gyorsabbak tekintve hogy a maxwell jobban fogyaszt)
Kerdes mit takar az enhanced
the entire 300 series is rumored to be based on enhanced versions of existing 200 series GPUs
Malibutomi
Smile
Malibutomi
válasz FasirTrisa #12415 üzenetére
Ez a leall a gep es nem indul csak a tap aramtalanitasa utan tipikus tap hiba.
En gyorsan lecserelnem mielott tonkreteszi az egesz gepet. Milyen es mikori tap? -
Malibutomi
Most jutott csak eszembe gbors...
Nem biztos hogy a Fijibe szukseges a 128ROP hogy jo legyen a teljesitmeny...ha ugyanugy 64ROP mint a hawaii, de megkapta a Tonga ujitasait, akkor azzal is eleg durva lehet.
A Tonga elveri a Hawaii-t pixel fillben hiaba van azon ketszer annyi ROP -
Malibutomi
válasz Menthirist #12444 üzenetére
Kerdes az erdemes-e, mert ha a Tonga ROP legyen mondjuk ~70%-al hatekonyabb, akkor mar 64ROP mellett is nagyobb a novekedes mint a GPU tobbi reszen ~45%.
Erre varok igazabol valami valaszt gborstol, o a szakertoDe azert remelem hogy mindenbol beleraknak minel tobbet.
Malibutomi
válasz #85552128 #12431 üzenetére
Computex 2015 – As we are live at Computex, we wanted to find out of the leaked photos actually were of the upcoming AMD Radeon R9 390X or not. So we caught up with PowerColor and asked them some questions to find out.
And we now know it for sure and sadly have to debunk the previous news. The pictured card is NOT the new R9 390X, nor is it an official cooling design.
The representative at the PowerColor booth confirmed this. Underneath the beefy cooler is an AMD Radeon R9 290X card and it is equipped with a prototype DEVIL 13 Hybrid cooling solution. So sadly, this is neither a finished new card nor the highly expected Radeon R9 390X card.
Malibutomi
válasz #45185024 #12473 üzenetére
Normalis hutes kell ra, nekem az osszes 290X-em 1100-ra volt belove napira, egyik sem volt kulonosebben hangos, es meleg sem... 80 fokot sem ertek el.
Probald mar meg hasznalni azt a nyamvadt "valasz erre" gombot, mert nem lehet tudni kinek irogatsz...
Malibutomi
Asus (780 huto csak racsapva, nincs ramhutes), XFX, MSI-nel is valami el van tolva mert nekem pl 75 fokon uzemelt masnak 95 fokon, a giga sem szerepel tul jol, es hangos is.
Nyilvanvalo, ha vannak jo hutesek is, amik konnyeden lehutik a 290-et, akkor a tobbinel amik nem jok nem vegeztek jo munkat a mernokok. Ennyi. Ott volt a kartya, ismertek voltak az adatok, nem csinaltak meg jol.
Pont a kepekrol latszik, ranezesre nincs nagy kulonbseg egy tri-x/vapor-x meg egy giga kozott, mukodesben/hofokban/hangban megis ossze sem lehet hasonlitani oket.
Egyaltalan hogy fordulhat elo hogy egy csucskategorias kartyanal lemarad a VRAM vagy a VRM hutes mikor 250-300W-ot vesz fel a kartya?
Malibutomi
Azert mert nalam 3 fele kartyabol egy sem melegedett.
Tovabbra is ez egy csucskartya volt, ilyet nem lehet csinalni szerintem hogy racsapunk a polcrol valamit. Meleg neg hangos, ugy latszik nem eleg ra, sebaj irany a bolt ugyis megveszik.A szuper szellozesrol annyit hogy 690-II hazam van, nem csucskategoria, a H110-en kivul ket befujo, egy kifujo ventivel, mindegyik csontra leszabalyozva hogy ne lehessen hallani. Nem epp ipari szelcsatorna.
Malibutomi
A melegedes relativ...a 970 persze hogy kevesbe melegszik kisebb fogyasztassal. A 780 majdnem ennyit evett, de azon mukodott a hutes mert ott hozzaertek a hocsovek a gpu-hoz.
De az Asust inkabb hagyjuk, ezt a gagyit kepesek voltak rarakni a csucs matrixra is....meh
(#12484) rocket
En akkor mazlista vagyok, harom kartyabol mindegyik tok jo volt.[ Szerkesztve ]
Malibutomi
válasz nubreed #12492 üzenetére
Ez megint eleg hulye hozzaallas.
Van ket opcionalis feature - aminek most csinalt egy kulon levelt az MS (12.1) - amit nem tamogatnak az amd 2 eves (vagyis vagy 3 eve tervezett) kartyai.
De ahogy ez lenni szokott mivel az nv tamogatja hirtelen ez lett a vilag ket legfontosabb feature-je.
(#12497) nubreed
Valaszd lasd fentebb...gondolkodni kellene a frocsoges helyett.
Malibutomi
A topik témája:
Az AMD éppen érkező, vagy jövőbeni új grafikus processzorainak kivesézése, lehetőleg minél inkább szakmai keretek között maradva. Architektúra, esélylatolgatás, érdekességek, spekulációk, stb.
- Üzleti vita és megbeszélés
- Villanyszerelés
- Renault, Dacia topik
- Megérkezett Magyarországra a Samsung új OLED gaming monitora
- Xiaomi - Mi AIoT AC2350
- ASUS routerek
