Amazon Fire TV Stick 4K Max
lo A Müncheni Országos Bíróság helybenhagyta a Nokia keresetét. A panasz szerint jogsértést követett el az Amazon. mert...
Három részletben lesz látható az Arcane második szezonja
gp A napokban érkezett egy új trailer, amellyel együtt végre megtudtuk mikor láthatjuk az új évadot.
Kidobja a Slacket a Disney
it Miután több mint 1 TB céges adatot szivárogtattak ki egy hackertámadás után, a Disney úgy döntött, hogy beszünteti a Slack használatát.
A jól bevált formula, ezúttal a II. világháború tengeri legendáival.
0.8.9 Patch Notes
Magyar WoWs Discord Közösség
Ajánlott Buildek
I Battleships I Cruisers I Destroyers I Aircraft Carriers I
TESCO-Zsömle
0.4.1.1 PATCH NOTES
-Inactive players now get disconnected after 1 hour of inactivity in the Port.
-Fixed an error that lead to server names not being displayed correctly in the login screen after an inactive player has been disconnected from the server.
-Fixed an error which caused damage to not be registered properly, after the superstructure and stern of USS Iowa have been destroyed.
-Fixed bot’s navigation paths on New Dawn and Fault Line maps.
-Fixed an error on Myoko that lead to incorrect damage being received when the citadel was hit.
-Fixed an error which lead to lack of anti-aircraft modernisations for Myogi and Wyoming.
-Fixed an error that lead to spotting aircraft being able to attack squadrons (We made the pilot aware of such inappropriate behaviour and he promised to never ever do it again).
-Decreased the horizontal angle during a ship´s turn.
-Fixed an error that lead to fire continuing after the fire indicator timer ran out.
-Fixed an error that lead to damage effects (hull penetrations) not being properly displayed.
-Fixed an error that lead to two-digit (or higher) numbers not being displayed properly in the "Summary" tab in the player's profile.
-Fixed camera settings for Kongo on the "C" hull, when switching to camera from the turret.
-Fixed an error that lead to reload time of the "Defensive AA Fire 2" consumable being the same as the reload time of the "Defensive AA Fire 1" consumable on Yubari.
-Fixed the battle experience numeration in the “Summary” tab: the number now includes all available modifiers (premium account, first win of the day, battle actions, etc.).
-Colour scheme of ships silhouettes has been changed.
-Fixed invisible obstacles on "New Dawn" map.
-Fixed incorrect spawn points on "Strait" map.[ Szerkesztve ]
Sub-Dungeoneer lvl -57
Chris0321
TESCO-Zsömle
Tévedtem, csak az amcsi oldalon van kint a 3x XP meg a 250 dublonos survey, az EU oldalon mindössze annyi szerepel, hogy megjelent...
(#3861) Malibutomi: Igazad van, a light tank csak láthatatlanul spotol és a mögötte ülő semmi vág beléd hirtelen 2000-et...
(#3863) sith7: Usák oldal szerint hétfő reggelig marad is.
capulet75
A Nagato nagyon darál, legalábbis ha én összepattanok egyel, az elpicsáz simán. A Colorado, és a másik BB-m a Fuso is úgy szór mint egy sörétes puska. Visszasírom a NM-Kongo párost. Főleg a Kongo-t.
Intelligencia kell ahhoz hogy egy ember belássa a tévedését. És gerinc, hogy be is ismerje.
CHaooSS
Nagyon undorító.. főleg, hogy japánokkal megyek azokkal meg nehéz kerülni.
Az előbb betámadott egy Isokaze aztán egy pillanat alatt elhulltam majd ment a másik csatahajóra..
De azért a csapat is egy vicc, hogy szarnak a fejemre pedig mondtam, h jöjjön már valaki mert le fognak támadni, de semmi..[ Szerkesztve ]
A zene szubjektív. Nem vagy köteles szeretni mindent, amit hallasz, de ha szeretsz valamit és megmozgat, nyertél. Tehát ne engedd senkinek, hogy megmondja, mi a menő vagy a gáz, vagy mit hallgass. (...) A zene a tiéd. Daniel Nathan Leone
h1mpi
Ehhez nem kell jó tanács Ez az ág adja magát Annyival lesz jobb a Hatsuharu a Mutsukihoz képest, hogy lehet az ágyúkra is hagyatkozni. Elképesztően pontos és simán 30-40 lövést is belehet vinni. Sajnos kicsit rosszabb az álca és a manőverezhetősége, de azért el lehet lenni vele. Majd mehetünk szakaszba még megvan a 6-os
Fully electric lifestyle!
Enzolord
Lehet rosszul játszani, de lélektelenül soha! Van úgy, hogy az embernek rossz napja van és a pályán semmi nem sikerül. Nem számít, a lényeg az, hogy lássák rajtad az emberek, hogy megszakadsz a klubért, a szurkolókért és akkor a vereség is meg van bocsátva. Ilyen egyszerű!”
Chabe89
Pont ma volt egy köröm Two Brothers-en, hogy áttöltöttem Colorado-val HE-ra, mert volt egy DD kb hét kilométerre, de bemenekült a sziget mögé. Erre nézem, hogy jön egy Cleveland 13 km-re na mondom rálövöm akkor arra, 33K viszlát! Amúgy elég idegesítő tud lenni mikor nem tudsz kimenni a lőtávjából és állandóan gyújtogat, de kb. ennyi.
Chris0321
Évek óta wot-ozom, szenvedtem nem egy tierben használhatatlan tankkal, a Kacsát is free xp nélkül húztam ki. Engem ilyesmi nem zavar, nekem kell egy Iowa a kikötőmbe és meg is fogom szerezni. Abban igazad van, hogy egy tier 4-est könnyeben átlépsz mint egy hetest, de minden ágon van egy hajó/tank ami miatt szerez az ember pár ősz hajszálat.
Chris0321
Nem tudom, én a +16% lőtávot adó felszereléssel nem érzem úgy, hogy hátrányban lennék a japán hajókkal szemben pedig játszom az Albany-val is mivel azzal húzok legénységet a Cleveland-nek, na azzal minden csatában az van, hogy várom az ellent és a többiek már rég lövik míg én még csak nem is látom a hajókat. A lőtávja 6.3 km mikor a Chester-é alapból 8.4 és az Erie-é 9.6. Lényegében ha egyedül maradok végem mert meg sem látom ki lő apró darabokra.
Kitartás a Colorado-hoz, remélem hamarosan én is vele szenvedek.[ Szerkesztve ]
Szőrös
CHaooSS
Hajrá!
De aztán utána jöhetne a nerf a rombolókra..
ledgeri
// #ublockO-HardMode // anti-blockadblock-er // PH! új arculat: 1/ 500 // szeksziboj -nálam van egy pirospontod! // Találtam sárga fényű lézert! (kézit, ceruzaelemest) https://youtu.be/XQnmMjYHgcM //
- Lenovo Thinkpad X395, 13,3" HD, AMD Ryzen 5 Pro 3500U CPU, 8GB DDR4, 256GB SSD, WIN 10/11, Számla, G
- Lenovo Thinkpad X13, 13,3 " FULL HD IPS, I5-10310U CPU, 16GB DDR4, 256GB SSD, WIN 10/11, Számla, Gar
- Lenovo Thinkpad T495, 14" FULL HD IPS, AMD Ryzen 5 Pro 3500U CPU, 16GB DDR4, 256GB SSD, WIN 10/11
- Lenovo Thinkpad T490, 14" FULL HD IPS, I5-8365U CPU, 8GB DDR4, 256GB SSD, WIN 10/11, Számla, Garanci
- 100% AKKSI I FÜGGETLEN I iPhone 12 Pro I 6/128GB
Cég: Ozeki Kft
Cég: Ozeki Kft
