- Ősszel jönnek az új Intel chipek
- Alacsony profilú RX 6400 az ASRocktól
- A KINGPIN kártyák visszatérnek a PNY égisze alatt
- SONY LCD és LED TV-k
- ASUS ROG Ally
Kezünkben a Razr 50 Ultra
ma Félmillió forint felett indít a csupa képernyős modell, nem olcsó a társa sem.
Premier előzetesen az Until Then
gp Némi halasztás után végre elérhető lett a játék teljes kiadása.
Formabontó vezetékmentes klaviatúrák jöttek a Keychron műhelyéből
ph Egy 60+ százalékos ortolineáris, valamint egy 65 százalékos "tört" modellel gyarapodott a cég portfóliója, amiket QMK-val szabhatunk végletekig testre.
Mielőtt kommentelsz, olvasd el az Összefoglalót!
(Frissítve: 2020.05.31.)
Воланд
"•Do you want to continue as a Windows Insider and keep getting preview builds after 7/29?
•Or do you want to upgrade your Genuine Windows 7 or Windows 8.1 system that has been getting Windows 10 Insider Preview builds to the 7/29 release and stop being an Insider?“I want to continue as a Windows Insider!” If you want to continue as a Windows Insider past 7/29 there is nothing you need to do. You’re already opted in and receiving builds in the Fast or Slow ring depending upon your selection. This is prerelease software and is activated with a prerelease key. Each individual build will expire after a time, but you’ll continue to receive new builds so by the time an older prerelease build expires you’ll have received a new one. Since we’re continuing the Windows Insider Program you’ll be able to continue receiving builds and those builds will continue to be activated under the terms of the Windows Insider Program. We provide ISOs for these builds for recovery from any significant problems, but they are still pre-release software. As part of the program we’ll upgrade Insiders to what is for all intents and purposes the same build as what other customers will get on 7/29, but that will be just another build for Insiders, and those who stay in the program will simply get the next build after as well.
“I want to opt out of the Windows Insider Program on 7/29.” If you decide to opt-out of the program and upgrade to the 7/29 build you will be subject to exactly the same terms and conditions that govern the offer* that was extended to all Genuine Windows 7 and 8.1 customers. This is not a path to attain a license for Windows XP or Windows Vista systems. If your system upgraded from a Genuine Windows 7 or Windows 8.1 license it will remain activated, but if not, you will be required to roll back to your previous OS version or acquire a new Windows 10 license. If you do not roll back or acquire a new license the build will eventually expire.
" [link]"Woland egy fura sátán, nem Isten ellenfele, hanem afféle küldötte, végrehajtója egy megromlott emberi világban, csak annyi rossz van benne, amennyi itt rátapadt."
Воланд
JamesHun #7163 üzenetére
"most komolyan fel kéne tennem az otthoni gépre egy friss windows 10 buildet, hogy a win8-at legálisan frissíthessem win10-re?"
nem.
Воланд
JamesHun #7171 üzenetére
eredeti windows 7-rol es windows 8-rol lehet ingyen frissiteni eredeti windows 10-re, mas os-rol nem. az insiderek csak tesztrendszert kapnak.
Воланд
#58000384 #7176 üzenetére
If you decide to opt-out of the program and upgrade to the 7/29 build you will be subject to exactly the same terms and conditions that govern the offer* that was extended to all Genuine Windows 7 and 8.1 customers. This is not a path to attain a license for Windows XP or Windows Vista systems. If your system upgraded from a Genuine Windows 7 or Windows 8.1 license it will remain activated, but if not, you will be required to roll back to your previous OS version or acquire a new Windows 10 license. If you do not roll back or acquire a new license the build will eventually expire." [link]"Woland egy fura sátán, nem Isten ellenfele, hanem afféle küldötte, végrehajtója egy megromlott emberi világban, csak annyi rossz van benne, amennyi itt rátapadt."
Воланд
#58000384 #7181 üzenetére
gondolom valahol csak tarolva van a regi aktivacio es nem veletlenul mondjak, hogy igy is ki lehet lepni az insider programbol.
Воланд
#58000384 #7184 üzenetére
ertem en, hogy ketled, de ettol meg a blogposztban ott van feketen feheren, hogy ha insider vagy es eredeti win7-rol, vagy win8-rol frissitettel, akkor rtm utan kilephetsz a programbol es aktivalva marad a rendszer.
Воланд
Bandi8bácsi #7233 üzenetére
aztan szerintem van olyan tores, ami ezt is atveri.
Воланд
King Unique #7310 üzenetére
en amugy sose ertettem ezt az sfc futtatasi maniat...
Воланд
FoxiestFox #7351 üzenetére
nem.
Воланд
FoxiestFox #7353 üzenetére
akkor visszaallitod a win7-et.
Воланд
King Unique #7383 üzenetére
az a szep a xxi-dik szazadban, hogy annyi adat erheto el/tarolhato, hogy mar keptelenseg annak feldolgozasa esszeru idon belul. megfigyelest csak es kizarolag celzottan lehet vegezni, vagy tomegesen, de akkor kulcsszavak alapjan. ha te azt hiszed, hogy azoknak a csunya, harombetus cegeknek van egy magikus adatbazisuk, melynek keresojebe beirjak random atlagpolgar nevet, majd a lekeres megadja a cipomeretet, meg az altala latogattot felnottfilmes oldalak listajat, akkor sulyosan tevedsz.
Воланд
Воланд
Воланд
az van az osszefoglaloban, hogy "Minden Windows 7, Windows 8 és Windows 8.1 tulajdonos ingyenesen frissíthet Windows 10-re."
na ez igy nem igaz. windows 7 sp1-rol es windows 8.1 update-rol lehet ingyen frissiteni.
Воланд
JamesHun #7522 üzenetére
"Microsoft Account notifications
If you don’t have your Microsoft Account (MSA) connected to your PC, starting in the next build you’ll start seeing notifications asking you to do so. You’ll need to connect the MSA that you registered for the Windows Insider Program with (and accepted the “Microsoft Windows Insider Program Agreement”) in order to continue receiving new Windows 10 Insider Preview builds (both Fast and Slow rings) from Windows Update. If you already have your MSA connected to your account on your PC, then you’re all set. We’re introducing new infrastructure in Windows Update to help us deliver new builds more effectively to Windows Insiders, and ensure that we’re flighting builds to people who have registered and opted in to the program. Connecting your MSA also allows seamless access to Windows Insider-only functionality in the Windows Feedback app and Insider Hub too.
This change is for the Windows Insider Program ONLY, and is specific to how we’re delivering the Insider Preview builds. Once available on July 29th, you do not need an MSA to upgrade Windows 10 on your Windows 7 or Windows 8.1 PCs if they are not receiving Insider Preview builds. You will not be required to use an MSA on new PCs that come with Windows 10 preinstalled or clean installed from media. Some features in Windows 10 do require an MSA to use, such as downloading apps in the Windows Store.
""Woland egy fura sátán, nem Isten ellenfele, hanem afféle küldötte, végrehajtója egy megromlott emberi világban, csak annyi rossz van benne, amennyi itt rátapadt."
Воланд
dredjudge84 #7542 üzenetére
igen, igaz.
Воланд
Milestone2 #7547 üzenetére
a kell azert az tulzas. olvasd el az insider program eulajat.
Воланд
netpeti98 #7551 üzenetére
ezt kb minden egyes build utan leirom, hogy nem jo a teljes kepernyos start menu es nem artana, ha kicsit kozelebb lenne az uj megoldas a windows 8-ban meglevo start screen-hez, de valahogy nem kapkodjak el ezt sem.
Воланд
Воланд
nekem ma delutan 5-re jott ra, hogy van uj build. ugy, hogy 9 ota ment a gep es kb orankent rakerestem a frissitesekre.
Воланд
#32839680 #7582 üzenetére
mindent magatol fog leszedni es telepiteni. mondjuk azt en sem ertem, hogy a drivereket miert kellett igy megoldani.
Воланд
ha esetleg valaki sokallta volna eddig a ket build kozott eltelt idot.
Воланд
tatararpad #7587 üzenetére
tobb, mint 300 bugfix.
Воланд
Воланд
1.: xp-vel, vistaval, nem eredeti win7-el, win8-al rendelkezo felhasznalok nem kapnak ingyen windows-t. az insider program kereteben az eula szerint csak tesztelesre lehet hasznalni az os-t.
2.: aki az elso egy evben frissit, annak az egy ev letelte utan sem kell fizetnie erte. nyilvan oem-et nem vihet at masik gepre.
3.: ne olvass tech temaban hvg-t."Woland egy fura sátán, nem Isten ellenfele, hanem afféle küldötte, végrehajtója egy megromlott emberi világban, csak annyi rossz van benne, amennyi itt rátapadt."
Воланд
serverbol nincs ujabb verzio? mert erre a hibara a rendszer-visszaallitas, ujratelepites vonalon ki is merul az eszkoztar.
Воланд
"Ugye nem fog automatikusan letöltődni?"
a blogpostban az van, hogy le fog automatikusan toltodni.
"Mi lesz olyankor ha telepítem és kipróbálás után azt mondom nem kell és visszavonom?"
semmi. a settings-ben vissza lehet allni a regi os-re.
"Erre mi lesz majd a megoldás?"
semmi informacio nincs errol.
Воланд
ott majd az lesz az erdekes, ha ezek ellenere felmegy a frissites, aztan ujraindulas utan csak a fekete kepernyo lesz.
Воланд
talan majd a kovetkezo foverziot jobban eltalalja az ms. a windows 8 osszesegeben jobb volt erintokijelzon, a windows 10 osszesegeben jobb hagyomanyos desktop pc-n. mert ez a tablet mod egy nevetseges, oszver megoldas.
Воланд
Keeperv85 #7807 üzenetére
ha kliensrol akarod elerni a servert, akkor az autentikaciot a servernek kell kernie, hiszen az adna meg a megfelelo hitelesito adatok fejeben a hozzaferest. szoval hibauzenet, esemenynaplo, stb.
• OFF topik
• TILOS a warez!
• Windows 10 frissítési kisokos
- Game Pass Ultimate előfizetések 1 - 25 hónapig azonnali kézbesítéssel a LEGOLCSÓBBAN!
