- Autóhifi
- Google Chromecast topic
Befutott a Destiny 2: The Final Shape premier előzetese
gp Néhány nap múlva befut a játék legújabb nagy DLC-je, amely pontot tesz egy hosszú évek óta tartó harc végére.
Fürge M.2 2230-as SSD-vel jelentkezett az IRDM
ph A lengyel cég 6 GB/s-os írásra képes újdonsága 2 TB-ig nyújt alternatívákat mobilgépeink tárkapacitásának bővítéséhez.
TRÓNOK HARCA
LendvaiFeri1
válasz gyuromoj #18871 üzenetére
Lehetetlen megmondani.
t first glance the following seems like an unassuming Iron Throne room shot, and perhaps it is. We can see Cersei on the Iron Throne, with Qyburn and Gregor at her sides, as well as two other Queensguards. But the queen is receiving two people, both looking up at her. One’s right in the middle, in front of Cersei, and the other to our right, or Cersei’s left. The long gown of the figure on the right has many speculating she could be Sansa, which would place this much later in the season. Or it’s Yara, others say!
However, the golden-clad figure in the middle looks very much like it could be Harry Strickland, in which case he’s most likely accompanied by Euron, with a more typical Greyjoy tunic instead of his rocker outfit. Sansa is a juicier alternative, but to be honest I believe the simpler answer is most likely: this is a continuation of the earlier shots in which we saw Euron ferrying the Golden Company and Cersei seeing them arrive, in a pretty direct parallel to Euron’s first arrival to King’s Landing last season.
In-Depth Breakdown of Game of Thrones Season 8 Trailer! Spoilers and Speculation!!
So lock up your daughter, lock up your wife, lock up your back door and run for your life
[CS]Blade2
válasz gyuromoj #19369 üzenetére
Ha hű marad magához a sorozat, akkor pont, hogy a jó emberek fognak hullani. Bronn halála majdnem benne van a trailerben, szerintem ő 100%. Sansa tényleg jó eséllyel kinyiffan. A rajongók nyomására nem maradhat ki a cleganebowl, bár én oda Sandor halálát tenném, vagy egy olyan döntetlen, hogy mindkettő meghal.
Az egész sorozat lényege, hogy megkapod amit akarsz, pl. Dany megérkezik megmenteni Jon-ékat, várod, hogy mit tud a 3 sárkány egyszerre, majd 5 másodpercre rá az egyiket ledobja az éjkirály, mint a büdös sz*rt.
Gregor vs. Oberyn: megkapod, hogy a kis mitugrász nyer, és bumm... akkor vág oda egy fordulattal, amikor már megkaptad, amit szeretnél. Ez nagyon fontos. Ez alapján írtam a fentit.
Gonosz karaktert csak azért vesznek ki, hogy egy még gonoszabbat hozzanak be helyette. Itt kérem, ha Martin bele tudott szólni, akkor itt nem lesz olyan, hogy a rossz megkapja méltó büntetését.
Inkább egymással fognak meccselni, amíg nem szív rá mindenki. Az egész sorozat tanulsága, hogy az emberek birkák.
