- Vezetékes FÜLhallgatók
A játéktelefonokat is megbabonázza az AI
ma Remélhetőleg a mesterséges intelligencia ránéz a Red Magic 9S Pro hőkezelésére.
Minisforum dokkoló OCuLinkkel
ph Ezzel szinte bármilyen VGA-val kiegészíthetjük mini számítógépünk hardverét.
siddis
makoj30 #5655 üzenetére
12-28-2023
* build/make
725e928d8f Merge pull request #44 from Terminator-J/14.0-test3
* frameworks/av
7edf3e25f4 Merge pull request #39 from kondors1995/14.0
* frameworks/base
781f5d7db08c VolumeDialog: Ensure proper resource release
03cda3f0f664 Revert "VolumeDialog: Ensure proper resource release"
de37d2521b2b fixup! base: Initial SenseProvider for FaceSense service
1188cfbc2487 Fixed process can't start because of mPendingStart is true problem
7423c7d63c6d Add patch to ensure window ready before PIP mode
acba12daf089 SystemUI: Prevent OOB when reinflating QS panel with notifications
* packages/apps/Aperture
a220a54 Aperture: Update CameraX to 1.4.0-alpha03
* packages/apps/Launcher3
194520727f Launcher3: Improve GSA enabled check
38719b77ee Launcher3: Prevent hotseat QSB crash with google stub
bc40a2a623 Launcher3: Make music search icon dependent on google search
* system/core
1c0b26622 Merge pull request #14 from kondors1995/14.0
12-27-2023
* android
8799565 manifest: Track system/hardware/interfaces
* bionic
7a3e801f8 libdl: do not disable LTO
* frameworks/av
a68eef5f3d Revert "media/libaaudio: disable LTO as workaround:"
a797f56b0f Revert "media: disable lto on some modules for runtime workaround"
* frameworks/base
e54fc065b8e3 hwui: enable whole program vtables
8baa018f126a PixelPropsUtils: Allow devices to opt out gms/gapps
* hardware/qcom-caf/common
d04fa78 memtrack: Return appropriate error code for unsupported operations
de7b9e7 memtrack: Fix copyright year
374e313 memtrack: Change memtrack ndk library dependency
4a43ab7 memtrack: Switch to AIDL service for Graphics
195c7fd64d Fix kotlin nullable errors in Launcher3
6bda7f351a Don't open PiP when freeform is opened from recent
* packages/apps/crDroidSettings
64e8630 New Crowdin updates (#1099)
* system/hardware/interfaces
c66f3c4 media/latest_android_media_audio_common_types_cpp_target_shared: enable whole program vtables optimization
12-26-2023
* frameworks/av
2b7852d93b C2BqPool: Do not call cancelBuffer() after invalidated
4c96f5b267 AudioFlinger: Fix timestamp advancing interval constant
f819925d35 update scale mode to MediaCodec under NuPlayer::instantiateDecoder
b0529e6b1b Revert "media/libaaudio: disable LTO as workaround:"
4087bef4ca Revert "media: disable lto on some modules for runtime workaround"
44ba90cb45 Reexport operator!= overloads in the derived type to avoid ambiguous base class lookups
* frameworks/base
e25704bde29b Fix potential NPE in isDefaultIme
35a9def95c0a Notify recent task to remove split-screen when exit PIP
* frameworks/native
92fb603fb2 SF: fix redundant assignment operation.
* hardware/interfaces
464e0ed0d Merge 'lineage-21.0' into 14.0
* packages/apps/Messaging
360c8c5 Merge 'lineage-21.0' into 14.0
* system/core
85aa55a32 Revert "snapuserd: opt out of Global ThinLTO to workaround segfault"
-- Aux armes, citoyens --
siddis
Ahogy a nagy Les Grossmann mondta a Trópusi vihar című filmben : Speedman egy kihunyt csillag útban a fekete lyuk felé.. Szóval hogy van ebben a telefonban még annyi.?!
siddis
Megint van új crDroid 10, nem linkelem, akit érdekel úgyis megtalálja..
siddis
siddis
crDroidAndroid 10.1 | OFFICIAL
Changelog:
• Bumped to 10.1
• January Security Patch
• Allow using Face Unlock for App Lock
• Fixed tile shade for QS reflected panel style
• Few performance optimizations and fixes
• Upstreamed kernel to 4.14.335-- Aux armes, citoyens --
siddis
Frissült tegnap a teljes NikGapps-paletta..
siddis
crDroid Android 14.0 2024.01.28 -- teljes újratelepítés ajánlott az aznapi Recovery-vel.!!!!
28th January, 2024
!! Clean Flash with New Recovery (recovery-20240128.img or above) Recommended !!
* Fixed up device level safety net attestation
* Added Auto-schedule AOD service (crdroid > UI > Ambient display)
* Added vibration pattern customization (settings > sound)
* Added in-call vibration options (crdroid > sound)
* Added customization for flashlight blink on incoming calls (crdroid > notifications)
* Removed split shade notification to fix notification heads up in landscape mode
* Fixed unable to login in Google translate app
* Improved A11 style QS tiles layout
* Various Launcher improvements and fixes
* vayu: Completely rebase and reworked kernel
* vayu: Removed sdcardfs support and switched to FUSE passthrough
!! Clean Flash with New Recovery (recovery-20240128.img or above) Recommended !!-- Aux armes, citoyens --
siddis
Van 10.2-es februári crDroid, de nem linkelném, amíg nem lesz "official" belőle..
siddis
crDroidAndroid-14.0-20240210-vayu-v10.2.zip ..már official..
siddis
Project Matrixx v10.3.0 OFFICIAL Android 14 -- crDroid-alapú custom ROM, Gapps-al..
LinkDevice changelog:
• Initial official Release
• Add Leica Cam
• Add Dolby Atmos
• Full changelog-- Aux armes, citoyens --
siddis
Van mai kiadású 'official' crDroid.. BitGapps is frissült pár napja, illetve a NikGapps-ok is..
siddis
zsizsef #6077 üzenetére
https://sourceforge.net/projects/nikgapps/files/Releases/NikGapps-U/07-Mar-2024/
vagy
https://github.com/BiTGApps/BiTGApps-Release/releases/
Neked az x64 kell (plusz a megfelelő Android verzió betűjele) minél nagyobb a .zip, annál több hülyeség van benne, én mindig a core-t használom..-- Aux armes, citoyens --
siddis
Frissítettek BITGapps-ék.. Kellemes Nyuszit mindenkinek..
siddis
BÉTA
BÉTA
BÉTA
crDroid Android 14.0 20240401 v10.3 BETA
BÉTA
BÉTA
BÉTA-- Aux armes, citoyens --
siddis
A mostani már NEM BÉTA..
siddis
Egy hibát találtam eddig, a csengőhangoknál a csengetési hangerő növelése-funkciónál eddig két csúszka volt a kezdő és a teljes hangerőt lehetett itt állítani -- most csak egy ikon van, amire ha kattintasz nem történik semmi.. mondjuk sose használtam ezt..
Illetve ez a menüpont angolul is van.
Az alkalmazások akkumulátor-kezelése is megváltozott, az eddigi optimalizálás helyett -ahol három lehetőség közül lehetett választani - most csak egy "futtatás engedélyezése a háttérben - rádiógomb van.-- Aux armes, citoyens --
siddis
Tegnap fenn volt egy ideig a CrDroid 10.4-es verziója - aztán letörölték, szerencsére nálam mindig van mentés
Az egyel korábbiban egy idő után 'kifagyott' a képernyőzár, csak az újraindítás segített - ahogy látszik is a képen ebben nem a Sigma-kernel hanem szerintem a Franxx(?)(openLA)..
siddis
crDoid Android 14 v10.4 2024-04-09
* Android QPR2 Update + April 2024 Security Update
* Fixed blank notifications in landscape mode
* Removed system-wide App lock due to incompatibility
* Various fixes and improvements
* vayu: Upstreamed kernel to v4.14.340 stable release
* vayu: Updated Moto Dolby mod-- Aux armes, citoyens --
siddis
Mindjárt kinn a májusi crDroid 14..
siddis
ma Nem ügyeskedtek túl sokat a Poco X3 NFC-vel, tettek bele egy frissebb lapkakészletet, illetve több és gyorsabb memóriát. És ennyi pont elég ahhoz, hogy a szerényebb kamerák ellenére még mindig kiemelkedő ajánlat legyen a kategóriában.
- EAFC 24
- pfSense - Avagy az okosított házirouter
- Samsung Galaxy S21 FE 5G - utóirat
- Ukrajnai háború
- Samsung Galaxy S24 Ultra 12/512GB / 1 év garancia / CSAK KIPROBÁLT SZINTE ÚJ
- Hibátlan Független Samsung Galaxy Z Flip 5 512GB !! 3 Hó GARANCiA
- Karcmentes Független Apple iPhone 13 Pro Max 128GB Gold !! 1Hó GaranciA
- Apple iPhone 15 128GB, Kártyafüggetlen, 1 Év Garanciával
- Szép Samsung Galaxy Z Fold 4 512GB !!! Beige ! 1 Hó GARANCiA
- iPhone 13 mini MagSafe szilikontok pomelópink
- Minőségi Next One Magsafe szilikon tokok 40%-os áron Iphone 7,8,SE2,11,11pro,12,12pro,12mini
- Minőségi Next One kijelzővédő fóliák 40%-os áron Iphone 7,8,11,11 pro,12,12 pro-hoz
- Samsung Galaxy S24+ Plus 5G 256GB Dual SIM Cobalt Violet Gyárilag független Csere/beszámítás is!
- Galaxy A54 makulátlan
