Az olcsóbb szegmens felé fordul az Apple virtuális szemüvegével
ph A Vision Pro még többet tudó, még drágább Pro 2 utóda helyett inkább valami olcsóbb variánst tervez piacra dobni az Apple.
Több Redmi, mint kolbász
ma Újabb premier készül, a Redmi 13 5G-n a sor.
Malibutomi
afelaldozhat #18048 üzenetére
Fentebb linkeltem, 2016 elejen kezdik gyartani a chipeket, ez altalaban megelozi bo 6-8 honappal a kartyak megjeleneset.
Malibutomi
Ez vegre olyan APU lehet amilyennek lennie kell, a kisebb csikszelesseg miatt mehet erosebb GPU, a HBM meg ad eleg savszelesseget.
Malibutomi
Amd announces Polaris architecture - GCN 4.0
Tomorrow AMD will unveil its new architecture called Polaris. This is a major upgrade in Radeon architecture since first 28nm GPU.
The GPU design was modified to include new logical blocks. What’s new is Command Processor, Geometry Processor, Multimedia Cores, Display Engine and upgraded L2 Cache and Memory Controller.
Last but not least, the new architecture has 4th Generation Graphics Core Next Compute Units (aka. GCN 4.0).
Malibutomi
füles_ #18069 üzenetére
Mi ertelme lett volna kihozni GDDR5-el?
Akkor amellett hogy lassabb mint a Ti meg sokkal tobbet is fogyasztana. Az lett volna legnagyobb hulyeseg. Amugy meg a NaNo-Fury-FuryX gyakorlatilag egy kartya ilyen szempontbol. A nehezseg az interposer+HBM volt, az meg ugyanaz mind a harmon.[ Szerkesztve ]
Malibutomi
Little information was shared and or is known about the new GCN iteration 4, however the Polaris GPU hardware is showing the architecture’s potential, in a recent event we attended AMD had a prototype on display. In a Star Wars: Battlefront head-to-head demo at 1080p, medium settings at 60 FPS, the Polaris GPU uses only 86 Watts, 61 percent less than the 140 Watts needed for the same experience on a GTX 950. Though that is comparing apples with oranges, at least from a perf/watt point of view, things look good.
GCN 4th Generation "GCN 1.3/2.0" - GPUs of the Arctic Islands-family will be introduced in 2016 with AMD Radeon Rx 400 Series branded graphics cards. Any Arctic Islands-chip will be produced on a 14nm FinFET process. Currently the code-names that we know of to be used are Ellesmere Island, Baffin Island and Greenland.
An overview of key 4th gen GCN architecture relative to product changes are:
Primitive discard shader
Hardware schedulers
Instructions pre-fecter
Improvised shader efficiency
Memory compression
Next gen HDMI 2.0a and DP 1.3
Multimedia h.256 main 10 decode up to 4k / 4k h.265 at 60 fps encode.[ Szerkesztve ]
Malibutomi
In the live press demonstration we saw the Polaris system average 88.1W while the GTX 950 system averaged 150W. Meanwhile in RTG’s own official lab tests (and used in the slide above) they measured 86W and 140W respectively. Keeping in mind that this is wall power – PSU efficiency and the power consumption of other components is in play as well
88W teljes rendszer fogyasztas. Jo lesz ez.
Malibutomi
In any case, the GPU RTG showed off was a small GPU. And while Raja’s hand is hardly a scientifically accurate basis for size comparisons, if I had to guess I would wager it’s a bit smaller than RTG’s 28nm Cape Verde GPU or NVIDIA’s GK107 GPU, which is to say that it’s likely smaller than 120mm2. This is clearly meant to be RTG’s low-end GPU, and given the evolving state of FinFET yields, I wouldn’t be surprised if this was the very first GPU design they got back from Global Foundries as its size makes it comparable to current high-end FinFET-based SoCs. In that case, it could very well also be that it will be the first GPU we see in mid-2016, though that’s just supposition on my part.
For their brief demonstration, RTG set up a pair of otherwise identical Core i7 systems running Star Wars Battlefront. The first system contained an early engineering sample Polaris card, while the other system had a GeForce GTX 950 installed (specific model unknown). Both systems were running at 1080p Medium settings – about right for a GTX 950 on the X-Wing map RTG used – and generally hitting the 60fps V-sync limit.
To that end RTG also plugged each system into a power meter to measure the total system power at the wall. In the live press demonstration we saw the Polaris system average 88.1W while the GTX 950 system averaged 150W. Meanwhile in RTG’s own official lab tests (and used in the slide above) they measured 86W and 140W respectively.
Malibutomi
Malibutomi
Yllgrim #18113 üzenetére
Nincs ebben benazas, az amd-nek minden szegmensben novelni kell az eladasokat, piaci reszesedest. Ha a kis gpu mar kesz, kidobjak amilyen hamar lehet, abban a szegmensben akkor az lesz a csucs, amig nincs NV valasz.
Ez az ev szerintem errol szol a 14/16nm-el, hogy megelozzek a masikat az uj kartyakkal. -
Malibutomi
Petykemano #18128 üzenetére
Ugy tunik nem tokolnek sokaig.
Malibutomi
Legyszives fejezzetek be ez nem az AMD fikazos hanem a talalgatos topic
Malibutomi
The enthusiast version of AMD's next-gen Polaris spotted at CES 2016
CES 2016 - During our CES 2016 travels, we spotted a big GPU - the big version of Polaris. Not the 1080p 60FPS version that the company showed off in Sonoma at its RTG Technology Summit, but the enthusiast version of Polaris.
Malibutomi
Sokkal tobb es olcsobb freesync monitor van mar most is. Ha nem is hal ki a gsync, csak egy nagyon kis reteg lesz. Elobb utobb nv is tamogatni fogja a freesyncet szerintem.
Malibutomi
daveoff #18182 üzenetére
Akik kisebb kartyakat vesznek ahol 50k az egesz kartya azok nem fognak viszont +50k-ert gsyncet venni. Viszont a freesync szinte minden mostantol megjelent monitorban benne lesz.
Ezert gondolom hogy elobb utobb az NV is kenytelen lesz tamogatni. Onnantol viszont a gsyncet sokkal kevesebben fogjak megvenni. -
Malibutomi
#85552128 #18185 üzenetére
Viszont egyre tobb lesz.
Mivel gyakorlatilag csak firmware-en mulik, logikus hogy gyakorlatilag minden uj monitorban lesz freesync. AOC-nak mar a 100£-os monitorjaban is van.
Kartyaval igazad van, de most lesz generaciovaltas onnantol a teljes szeria tudni fogja.Dave nagyon olcson vannak mar freesync monitorok. [link]
Malibutomi
En ha valtok akkor 27", IPS freesync, es ha lehet 144hz veszek. De egyelore van mas amire koltsek.
(#18193) daveoff
Nyilvan ennyiert olyan is, csak arra mutatom ezt, hogy gyakorlatilag mindenbe rakjak.[ Szerkesztve ]
Malibutomi
Erdekesseg hogy Roy Taylor azt nyilatkozta VR kapcsan, hogy a minimum kovetelmegy (290/970) meg mindig sokaknak draga, de a 14nm Polaris kartyakkal, ez a teljesitmeny kedvezobb aron megkaphato lesz, igy tobb ember engedheti meg maganak a VR elmenyt.
Hat kivancsi leszek az arazasra.[ Szerkesztve ]
Malibutomi
leviske #18243 üzenetére
Mindegyik (vagy majdnem) kartya helyett lesz uj, a lenyeg itt azon van, hogy ha igaz a mostani teljesitmennyel egyenerteku kartyat kiseb fogyasztassal, olcsobban kapjuk meg.
Vagyis ha igaz nem szallnak el az arakkal.
(#18246) Pepeeeee
Rebrandra az esely kb 0%, mivel csikszelesseg valtas van. Gondolkozz mar mielott irsz.[ Szerkesztve ]
Malibutomi
#45185024 #18253 üzenetére
6xxx-7xxx csaladnal volt rebrand? Nem mert csikszelessegvaltas (meg architektura valtas is) volt.
Itt sem lesz. Eddig azert volt mindket oldalon mert nem volt valtas, soksok eve a 28nm-en vannak.
Hova adnak ki a 250wattos kartyakat, mikor egy 150 wattos kartya gyorsabb lesz naluk?Maximum nv oldalrol tudnek elkepzelni maxwell atnevezest, de arra sem latok szinte semmi eselyt.
Malibutomi
leviske #18269 üzenetére
Harom gpuval le lehet fedni az egesz palettat.
Vagy az lesz hogy a legkisebbek nem frissulnek csak a nagyobbak, vagy a kicsi es kozepes(ami a mostani top korul/felette van teljesitmenyben) jon eloszor, a legnagyobb chip meg kesobb.
De majd meglatjuk.A Fijit szerintem sem fogjak gyartani, mikor egy fele akkora chip hozhatja a sebesseget, raadasul tobb vrammal.
Malibutomi
Kerdes az okosokhoz:
Vajon a kisebb savszel (illetve a Finfet valtas) hozhat-e magasabb orajelet, vagy epp ellenkezoleg? Nem ilyen 1500+-ra gondolok, de latunk-e ujra olyat mint anno a 7970-nem, hogy altalanosan elerheto az 1200+ .[ Szerkesztve ]
Malibutomi
Nekem az is eszembe jutott, hogy a Fury X2-vel nem a HBM2-re vartak-e, aztan azt dobaljak az interposerre.
Malibutomi
velizare #18281 üzenetére
nincs értelme, attól az interposer még ugyanúgy nem bírna többet, és a hbm2 előnyei kihasználatlanok maradnának.
Ez mondjuk tevedes, a HBM2 legnagyobb elonye ennel a dual gpus kartyanal nem a sebesseg (persze a HBM2 sebessege sem artana) hanem a kapacitas lenne. Szerintem 2x8GB memoriaval sokkal hasznalhatobb, es kelendobb lenne. Bar a kelendoseg ilyen aru termeknel elegge viszonylagos.
Ez persze tisztan brainstorming, Szinte 0% eselyt adok annak hogy emiatt varnanak vele, csak ez is szoget utott a fejembe
Malibutomi
velizare #18284 üzenetére
A Fiji kapott hideget-meleget pont azert mert csak 4gb, es mar elore megkapta az x2 is hogy hiaba a nagy teljesitmeny, a nagy felbontasokon emiatt hatranyban van. A 2x8GB mindenkepp elony lenne ra.
Az mas kerdes hogy mivel jarna jobban az AMD hogyha kiadta volna elobb 4GB-al, vagy ilyen kozel az uj kartyakhoz 8GB-al. Ez utobbinak akkor lenne ertelme ha (ahogy ez most kinez) a csucskartyak tenyleg utoljara erkeznek nagyon 2016 vegen-2017 elejen. Akkor meg van majd egy eve futni (ketto is ha azt szamolom mikorra lehet utana ujabb dual gpu).Hangsulyozottan ez csak spekulacio.
Malibutomi
robertosz91 #18290 üzenetére
Olyan draga biztos nem lesz.
Most van a 390 100k felett, Roy szerint ezt a VR belepo szintet olcsobban akarjak hozni az uj kartyakkal, igy a 80 koruli ar akar igaz is lehet.
De majd meglatjuk. -
Malibutomi
velizare #18294 üzenetére
Ugye a merlegnek ket oldala van, amit te leirtal a kiadas...van egy beveteli oldal, ahol meg azt kell matekozni hogy mennyi ideig tarthato piacon a termek.
Dual fiji alap koltsegek X eladas + X piaci ido vs alap koltseg+adalek koltsegek: X+Y eladas + X+Y piaci idoAzt nem tudom hogy ha a HBM2 magasabb frekvenciat nem akarjak kihasznalni, csak a nagyobb kapacitast kellene-e uj interposer.
No mindegy ertelmetlena brainstorming valoszinu nem terveztek at semmit, csak szoget utott a fejembe minek halasztgatjak, mert az hogy a VR-re varunk szerintem egy hulye kifogas.
Hawaii-rol pont ugy gondolom hogy repulni fog, nem jatszanak meg egy harmadik atnevezest. Foleg hogy annal sokkal egyszerubb volt 8GB-ost csinalni belole, gyakorlatilag csak ra kellett rakni a chipeket es uj biost irni.
Senki nem venne meg egy 250W felett zabalo kozepkategoriat, mikor minden mas kartya ehehz kepest nevetsegesen keves fogyasztassal beeri.[ Szerkesztve ]
Malibutomi
velizare #18296 üzenetére
Sokat nem is koltottek a hawaii-ra, mar a 290x-bol is voltak 8GB verziok. Kanape alol kikapart apropenz amibe kerult a hawaii frissites egy uj gpu fejleszteshez kepest.
a biosmoddolt 290ek is dekára ugyanazt az fps-t hozzák (már amelyik elindul vele).
Ezmutatja is hogy nem volt valami nagy koltekezes.
Csak azert frissitettek, hogy valamivel kihuzzak a 14nm-ig, ha mar a 22nm bedolt.
14nm kartyak mellett semmi keresnivaloja mar. -
Malibutomi
#45185024 #18309 üzenetére
Az szinte biztos ogy az NV a nagy chipre koncentral, legalabbis eddig ugy tunik, az AMD meg a kicsi es kozeppel indit. Utobbi szerintem jo dontes, mert ott lehet sok kartyat eladni.
Datumok szerintem hasrautesszeruek, en nyar elott nem varnek kartyakat, de majd kiderul.
Az eddigiek alapjan valahogy az az erzesem, hogy az NV valamit sumakol es nem jo ertelemben, vagy csuszasban vannak, vagy valami felresikerult, de tul nagy a csend. Legalabb valami melldongetes kellett volna miutan az AMD mar bemutatta a Polarist.
Az meg tenyleg igaz, hogy nagy kulonbseg van a "mukodo, jatekot futtato, driverrel mar megtamogatott chip", es a "meg egy chipet sem mutatunk helyette remeljuk nem veszik eszre hogy maxwellt lobogtatunk" kozott.Persze ha tenyleg a nagy Pascal jon eloszor, akkor az nekik presztizs, de az AMD-nek most sok eladas kell.
NA meg kerdes, hogy ha kijona "nagy" Pascal, akkor miutan minden rajongojuk megvette eszukbe jut-e, hogy ja van am nagyobb isLehet a kasszahoz faradni ujra
Mindenesetre erdekes egy ev lesz. De en tuti csak akkor cserelek ha ketszer erosebb kartyat kapok mint a 390-em.
Malibutomi
füles_ #18313 üzenetére
Szerintem az elso is alaptalan ha a 11 980 szintu lenne a 12 meg a nagyagyu (legalabb 1.5x 980ti teljesitmeny), akkor ott maradna egy hatalmas ur.
A 12 szinte biztos hogy sokkal erosebb lesz mint a 980 ti. Akkor a 11 a 980ti es 980 koze kellene essen, illetve talan a vagott kozelebb a 980-hoz. A 10 viszont akkor inkabb 970-960 szint kellene legyen. (Valoszinu erosebb is mint ahogy demoztak, 60fps lockkal stb.)
Lentebbrol egy-egy szint kieshet.[ Szerkesztve ]
Malibutomi
#45185024 #18317 üzenetére
Az biztos hogy az also-kozep kategoria a cel az AMD-nek, ott siman visszanyerheti a piaci reszet.
A kerdes az milyen kartyak jonnek iden, mert hatalmas keveredes is lehet. GDDR5-GDDR5X-HBM2
Lehet lesz olyan szgmens, ahol kulonbozo rammal ellatott kartyak feszulnek egymasnak. Az egyik olcsobb lesz, a masik tobbet fogyaszt valamivel...ki mire szavaz majd a gyartok kozul. Erdekes lesz.Bar oszinten szolva szerintem iden nem lesz GDDR5X kartya, nyaron lesz tomegtermelesben, es akkor mar kb jonnek a kartyak szoval elegge el van csuszva.
Malibutomi
#45185024 #18325 üzenetére
Nekem azt mondja, hogy a 490X meg nem a csucs vga.
5120 core vs 4096 (Fury X) ez nem stimmel ha azzal vetem ossze hogy a csucs GPU-ra kb. ketszer annyi tranzisztort (~15-18milliard) lehetett hallani mint a Fury X-nel (8.9milliard)
Persze nyilvan mas felepites, erosebb front end, meg tobb feature, de akkor is.
Egyebkent remenykedem, hogy most kicsit megszaladnak az orajelek AMD oldalon is, nem vegletekig kitolt technologiaval.
Malibutomi
Ha mar videocardz:
Malibutomi
A topik témája:
Az AMD éppen érkező, vagy jövőbeni új grafikus processzorainak kivesézése, lehetőleg minél inkább szakmai keretek között maradva. Architektúra, esélylatolgatás, érdekességek, spekulációk, stb.
- E-roller topik
- Milyen notebookot vegyek?
