  • Zalacsek
    válasz Csádám #6238 üzenetére
    hello.
    nagyon egyszerű beállítani a megosztást ha kábelen veszed a netet a gépeden,
    de én már osztottam meg wifi hálózatot is wifi-re két wifi kártyával.
    itt az angol leirás hozzá:
    1. Intenet megosztás engedélyezése:
    Enabling Internet Sharing on the Internet Connection of the ICS Host Computer
    To enable Internet sharing on the Internet connection of the ICS host computer, do the following:
    From the Windows XP desktop, click Start, click Control Panel, click Network and Internet Connections, and then click Network Connections.
    Right-click the Ethernet network connection that is used to access the Internet, and then click Properties.
    On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box and clear the Allow other network users to control or disable this shared Internet connection check box.
    Click OK to save changes to your connection.
    You might be prompted with a Local Network message box that explains how your computer's configuration is being changed. Click Yes to enable Internet sharing
    2. Virtuális Wifi Hálózat létrehozása XP(SP2) alatt:
    To create an ad hoc wireless network to share Internet access with the other WLAN computers on a computer running Windows XP with SP2 or Windows XP with SP1 and the WPA Wireless Security Update in Windows XP, do the following:
    Right-click the wireless network connection, and then click Properties.
    Click the Wireless Networks tab.
    In the wireless network adapter properties dialog box, click Add under Preferred networks.
    On the Association tab, type the name of your ad hoc wireless network in Network name (SSID). For example, you could name your wireless network AdHocInternet.
    Select the This is a computer-to-computer (ad hoc) network check box and clear the The key is provided for me automatically check box.
    In Network Authentication, select Open.
    In Data encryption, select WEP.
    In Network key, type the WEP key. The WEP key should be a random sequence of hexadecimal digits or numbers, letters, and punctuation.
    In Confirm network key, retype the WEP key.
    Click OK to save changes to the wireless network.
    Click OK to save changes to the wireless network adapter.
    Bocsi, hogy nem fordítottam le...
