Tekken 8 - Nyáron érkezik Lidia Sobieska
gp A lengyelek karatézó vezére lesz a franchise nyolcadik részének legújabb DLC karaktere.
Dobhatja a Google az Exynost és a Samsungot
ma A Tensor G5-öt önállóan fejlesztheti és a TSMC-vel gyárthatja, a G4-et viszont még koreai partnerével.
Újabb robottaxis balesetekre derült fény
it Az USA biztonsági vizsgálatot indított a Waymo önvezető autói kapcsán, és újabb balesetekre derült fény.
ASUS RT-AC68U (Kétsávos, Wireless-AC1900 gigabites útválasztó)
kisbalazs83
ASUS RT-AC68U Firmware version 3.0.0.4.386.46065
2022/01/27
Security
- Fixed string format stacks vulnerability
- Fixed cross-site-scripting vulnerability
- Fixed informational vulnerability.
Thanks to Howard McGreehan.-Fixed SQL injection vulnerability
-Fixed json file traversal vulnerability
-Fixed plc/port file traversal vulnerability
-Fixed stack overflow vulnerability
Thanks to HP of Cyber Kunlun Lab-Fixed authenticated stored XSS vulnerability
Thanks to Luke Walker – SmartDCC-Fixed LPD denial of service vulnerability
-Fixed cfgserver heap overflow vulnerability
-Fixed cfgserver denial of service vulnerability
Thanks to TianHe from BeFun Cyber Security Lab.Added more ISP profile
Digi 1 - TM
Digi 2 - TIME
Digi 3 - Digi
Digi 4 - CTS
Digi 5 - ALLO
Digi 6 - SACOFA
Maxis - CTS
Maxis - SACOFA
Maxis - TNB/ALLOFixed AiMesh guest network issues.
Fixed DDNS issues where the WAN IP is IPv6
Fixed UI bugs in Administration --> feedback.
Fixed time zone error.[ Szerkesztve ]
65JZ1000, 65PUS7506, 55OLED754, FTXF42D
kisbalazs83
Verzió 3.0.0.4.386.48262 2022/03/25 92.71 MBytes
ASUS RT-AC68U Firmware version 3.0.0.4.386.48262
1. Fixed OpenSSL CVE-2022-0778
2. Added more security measures to block malware.
3. Fixed Stored XSS vulnerability. Thanks to Milan Kyselica of IstroSec.
4. Fixed CVE-2022-23970, CVE-2022-23971, CVE-2022-23972, CVE-2022-23973, CVE-2022-CVE-2022-25595, CVE-2022-25596, CVE-2022-25596,
5. Added 3rd party DNS server list in WAN --> DNS to help users enhance the connection security.[ Szerkesztve ]
kisbalazs83
386.7 (xx-xxx-xxxx) Merlin Alpha build
Asuswrt-Merlin 386/NG Changelog
- UPDATED: Merged with 386_48823 GPL.
- UPDATED: openssl to 1.1.1o.
- CHANGED: dhcpc-event now has a second parameter that will contain "4" or "6" depending on the IP protocol of the event (dave14305)
- FIXED: JFFS backup/restore functions not working on XT12 and GT-AX6000.
- FIXED: CVE-2022-0934 in dnsmasq (backport)
- FIXED: CVE-2022-26376 (reported by Cisco Talos, fixed by Asus)Kicsit le volt maradva a gyárihoz, de ez az új GPL most nincs még egyik modellnél se. Nem próbáltam.
forrás: https://www.snbforums.com/threads/386-7-alpha-build-s-testing-available-build-s.78901/
kisbalazs83
válasz kisbalazs83 #6786 üzenetére
Feltettem NVRAM törlés nélkül a gyári 3.0.0.4.386.48262 -re. Eddig semmi probléma vele.
kisbalazs83
Asuswrt-Merlin Changelog
========================386.9 (6-Jan-2023)
- NOTE: 386_xx release are only for Wifi 5 (802.11ac) models.
- NEW: Merged with GPL 386_50757.- UPDATED: getdns/stubby to 1.7.2/0.4.2.
- UPDATED: zlib to 1.2.12 + backports.
- UPDATED: openssl to 1.1.1s.
- UPDATED: inadyn to 2.10.0.
- UPDATED: nettle to 3.8.1.
- UPDATED: openvpn to 2.5.8.
- UPDATED: dropbear to 2022.83.
- UPDATED: dnsmasq to 2.88.
- CHANGED: Rebranded DNSFilter as DNS Director. This will prevent
confusion with the company sharing the same name, and
also better describes what the feature does.
- CHANGED: Setting an OpenVPN client to redirect all traffic while
in "Exclusive" DNS mode will now force redirect ALL
DNS traffic just like in VPN Director mode.
While this will allow redirecting clients with
hardcoded DNS servers, it also means that your whole
LAN will lose the ability of doing local name
resolution. It might be best to use VPN Director
in that case to control which client should
be involved in the DNS redirection, or use
DNSFilter instead of Exclusive DNS mode.
editing VPNDirector rules.
- CHANGED: Switched generated self-signed certificate to an
EC certificate.
- CHANGED: Disabled DSS key support in Dropbear SSH.
- FIXED: Wrong temperatures used by the temperature graphs
(386.8 regression)
- FIXED: Guest Network clients couldn't route through VPN
(regression in 386.4 following a GPL merge).
- FIXED: Clients connected to Guest Network 1 aren't
redirected to the router's NTP if NTP interception is
enabled.
- FIXED: Name was truncated to 31 chars when enabling OpenVPN
client's Server Certificate Name Validation.
- FIXED: CVE-2022-37434 in zlib.
- REMOVED: Interface selector on Speedtest page (no longer
working, possibly due to an ookla client update)65JZ1000, 65PUS7506, 55OLED754, FTXF42D
kisbalazs83
kisbalazs83
ASUS RT-AC68U Firmware version 2023/03/02
Version 3.0.0.4.386.512551.Fixed HTTP response splitting vulnerability.
2.Fixed Samba related vulerabilities.
3.Fixed cfg server security issues.
4.Fixed Open redirect vulnerability.
5.Fixed token authentication security issues.
6.Fixed security issues on the status page.
7.Fixed XSS vulnerability.
8.Fixed CVE-2022-26376
9.Fixed CVE-2018-1160
10.Fixed IPv6-related bugs.
11.Added a new login URL http://www.asusrouter.com to fixed the login issues.
12.Optimize the AiMesh web interface
13.Fixed network map UI bugs
14.Fixed bugs related to Wi-Fi calling.
15.Supported web history record exported.
16.Fixed IPSec VPN server compatibility with Windows 10 VPN client.
17.Improved AiMesh connection stability.
18.Fixed IPTV issues.65JZ1000, 65PUS7506, 55OLED754, FTXF42D
kisbalazs83
ASUS RT-AC68U Firmware version 3.0.0.4.386.51665
2023/05/11
Bug fixes and functionality modifications:
-Resolved the issue with login and password changes.
-Fixed the issue where Traffic Analyzer sometimes couldn't record data.Security updates:
-Enabled and supported ECDSA certificates for Let's Encrypt.
-Enhanced protection for credentials.
-Enhanced protection for OTA firmware updates.
-Fixed DoS vulnerabilities in firewall configuration pages. Thanks to Jinghe Gao's contribution.
-Fixed DoS vulerabilities in httpd. Thanks to Howard McGreehan.
-Fixed information disclosure vulnerability. Thanks to Junxu (Hillstone Network Security Research Institute) contribution.
-Fixed CVE-2023-28702 and CVE-2023-28703. Thanks to Xingyu Xu(@tmotfl) contribution.
-Fixed null pointer dereference vulnerabilities. Thanks to Chengfeng Ye, Prism Research Group - cse hkust contribution.
-Fixed the cfg server vulnerability. Thanks to Swing and Wang Duo from Chaitin Security Research Lab.
-Fixed the vulnerability in the logmessage function. Thanks to Swing and Wang Duo from Chaitin Security Research Lab C0ss4ck from Bytedance Wuheng Lab, Feixincheng from X1cT34m.[ Szerkesztve ]
