Tesztkonfiguráció és memóriasebesség
Processzor | Athlon 64 3800+ Athlon 64 3500+ |
Athlon 64 3400+ Athlon 64 3200+ Athlon 64 3000+ Athlon 64 2800+ |
Opteron 146 | Athlon XP 3200+ Athlon XP 2800+ Athlon XP 2400+ |
P4 3,2 GHz Prescott P4 3,2 GHz Northwood P4 3 GHz Northwood P4 2,8 GHz Prescott |
Órajel | 2400 MHz 2200 MHz |
2200 MHz 2000 MHz 2000 MHz 1800 MHz |
2000 MHz | 2200 MHz 2250 MHz 2000 MHz |
3200 MHz 3200 MHz 3000 MHz 2800 MHz |
Cache mérete | 128 KB L1; 512 KB L2 |
128 KB L1; 1 MB L2; 1 MB L2; 512 KB L2; 512 KB L2 |
128 KB L1; 1 MB L2 |
128 KB L1; 512 KB L2; 256 KB L2; 256 KB L2 |
20 KB L1; 512 KB L2; 28 KB L1; 1 MB L2 |
Szorzó / FSB (MHz) | 12x / 200 11x / 200 HT: 1 GHz |
11x / 200 10x / 200 10x / 200 9x / 200 HT: 800 MHz |
10x / 200 HT: 800 MHz |
11x / 200 13,5x / 166 15x / 133 |
16x / 200 16x / 200 15x / 200 14x / 200 |
Alaplap | MSI MS-6702E | MSI K8T Neo-FIS2R | ASUS SK8V | Gigabyte 7NNXP | ABIT IC7 |
BIOS-verzió | 3.0B10 | 1.1 | 1002 | F17 | 24 |
Chipset | VIA K8T800 Pro | VIA K8T800 | VIA K8T800 | NVIDIA nForce 2 Ultra 400 | Intel 875P (Canterwood) |
Chipset-driver | VIA Hyperion v4.51 | VIA Hyperion v4.51 | VIA Hyperion v4.51 | NVIDIA Unified Driver 4.14 | Intel INF Update 5.1.1002 |
Memória | Corsair TwinX1024-3200C2Pro - 2 x 512 MB | 2 x 512 MB OCZ PC3500 EL ECC. Reg | Corsair TwinX1024-3200C2Pro - 2 x 512 MB | ||
CAS Latency | 2 | 2 | 2 | 2 | 2 |
Precharge Delay vagy RAS Active Time |
5 | 5 | 5 | 5 | 5 |
RAS to CAS Delay | 3 | 3 | 3 | 3 | 3 |
RAS Precharge Time | 2 | 2 | 2 | 2 | 2 |
Videokártya | Gecube ATI Radeon 9800 Pro 128 MB (400/350 MHz) | ||||
Videokártya-driver | ATI Catalyst 4.1 (Doom 3-hoz Catalyst 4.7) | ||||
Merevlemez | Hitachi Deskstar 7K250 160 GB (Parallel ATA; 7200 rpm; 8 MB cache) | ||||
Operációs rendszer | Windows XP Professional Service Pack 1 + DirectX 9.0b SE |
Tesztprogramok
Szintetikus benchmarkok
Lavasys Everest v1.10
SiSoftware Sandra 2004
Tömörítés
WinACE v2.5
WinRAR v3.3
7-Zip v3.13
Konvertálás-kódolás
MainConcept MPEG Encoder v1.4.1
XMpeg v5.03 és DivX 5.1.1
Dr. DivX 1.0.5
Windows Media Encoder 9
L.A.M.E. Ain't MP3 Encoder v3.95
OGGEnc v1.0.1
Renderelés
Discreet 3ds max 6
NewTek Lightwave 3D 7.5
Cinebench 2003
Pov-Ray v3.5
Játékok
Quake III Arena v1.32
Wolfenstein Enemy Territory
Doom 3
Unreal Tournament 2003 v2225
Unreal Tournament 2004
Splinter Cell v1.02B
Tomb Raider: Angel of Darkness v49
Halo Combat Evolved v1.04
Far Cry
FutureMark 3DMark2001SE B330
Tesztjeinket kiegészítettük a Dr. DivX filmkonvertáló program, illetve az UT2004, a Far Cry és a nemrégiben megjelent Doom 3 eredményeivel is. Az újonnan elvégzett tesztekben nem szerepel minden, a korábbiakban nálunk járt processzor eredménye, csak azok, amelyeket lehetőségünk volt utólag még egyszer lemérni.
Ami a tuningot illeti, a tesztelésre kapott Athlon 64-es processzorokkal nem jártunk szerencsével, ugyanis 228 MHz-es FSB-nél mindkettő kifulladt. Ez 2280 MHz-et jelent az Athlon 64 3000+ esetében, néhány tesztet lefuttattunk ezen az órajelen is.
Memória-sávszélesség
A memóriasávszélesség-mérések során az egycsatornás memóriavezérlővel rendelkező Athlon 64 processzoroknál megszokott kép fogad minket, a processzor a maximálisan elérhető 3200 MB/s-os sávszélességet csakugyan majdnem eléri, köszönhetően az integrált memóriavezérlőnek, amely radikális mértékben képes lecsökkenteni a memóriaelérések késleltetéseit. Korábbi tesztünkből már kiderült, hogy nem is kell túlságosan szomorkodnunk a kétcsatornás memóriavezérlő hiánya miatt, az Athlon 64-ek egyelőre csak minimális mértékben képesek profitálni a megduplázott memória-sávszélességből.
