ASUS WL-500G Premium
Intruder2k5
MODERÁTOR
Ha már itt tartunk, akkor kérdezek én is egyet. :-)
Mi az a "minimum number of peers" és a "minimum number of seeds" ?
Mi van akkor, ha én megadok minimum seed-ernek 10-et, és nincsen csak 3? :-)
Akkor nem indul el a torrent letöltés?
Szóval ezen többször gondolkodtam már, de még nem értem...[ Szerkesztve ]
Intruder2k5
MODERÁTOR
válasz nandris #8105 üzenetére
Azért mappákat lehet listázni mc nélkül is :-)
root@INT-ROUTER:/tmp/home/root# cd /
root@INT-ROUTER:/# ls -l
drwxr-xr-x 2 root root 452 Jun 13 08:23 bin
drwxr-xr-x 2 root root 3 Jun 13 08:23 cifs1
drwxr-xr-x 2 root root 3 Jun 13 08:23 cifs2
drwxr-xr-x 1 root root 0 Jan 1 1970 dev
lrwxrwxrwx 1 root root 7 Jun 13 08:23 etc -> tmp/etc
lrwxrwxrwx 1 root root 8 Jun 13 08:23 home -> tmp/home
drwxr-xr-x 1 root root 0 Jul 1 22:10 jffs
drwxr-xr-x 3 root root 137 Jun 13 08:23 lib
drwxr-xr-x 2 root root 3 Jun 13 08:23 mmc
lrwxrwxrwx 1 root root 7 Jun 13 08:23 mnt -> tmp/mnt
drwxr-xr-x 16 root root 4096 Jun 24 23:39 opt
dr-xr-xr-x 54 root root 0 Jan 1 2000 proc
drwxr-xr-x 3 root root 20 Jun 13 07:12 rom
lrwxrwxrwx 1 root root 13 Jun 13 08:23 root -> tmp/home/root
drwxr-xr-x 2 root root 598 Jun 13 08:23 sbin
drwxrwxrwx 10 root root 320 Jul 1 19:43 tmp
drwxr-xr-x 7 root root 79 Jun 13 08:23 usr
lrwxrwxrwx 1 root root 7 Jun 13 08:23 var -> tmp/var
drwxr-xr-x 2 root root 1781 Jun 13 08:23 www
root@INT-ROUTER:/# cd /opt
root@INT-ROUTER:/opt# ls -l
drwxr-xr-x 2 root root 8192 Jun 6 20:47 bin
drwxr-xr-x 3 root root 4096 Apr 12 15:30 doc
drwxr-xr-x 5 root root 4096 Jun 20 20:32 etc
drwxr-xr-x 9 root root 4096 May 12 00:14 include
drwxr-xr-x 2 root root 4096 Apr 12 15:48 info
drwx------ 2 root root 4096 Apr 19 20:07 ipkg-OMa5o2
drwxr-xr-x 12 root root 8192 Jun 20 20:32 lib
drwxr-xr-x 4 root root 4096 Apr 12 15:54 libexec
drwx------ 2 root root 16384 Apr 12 12:13 lost+found
drwxr-xr-x 3 root root 4096 Jun 5 21:02 man
drwxr-xr-x 2 root root 4096 Jun 24 22:21 sbin
drwxr-xr-x 19 root root 4096 Jun 20 20:32 share
drwxr-xr-x 3 root root 4096 Mar 10 14:42 usr
drwxr-xr-x 4 root root 4096 Jun 20 20:32 var
root@INT-ROUTER:/opt#vagy így is lehet bármelyik mappából:
root@INT-ROUTER:/# ls -l /opt
drwxr-xr-x 4 root root 4096 Jun 20 20:32 var[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Intruder2k5
MODERÁTOR
válasz nandris #8116 üzenetére
Minek kellek én ahhoz? Google a barátod. :-)
Itt van pl. az általad ajánlott verziószámú Ghost:http://www.ziddu.com/download/4794740/Symantec.Ghost.v11.5.0.2113.Corporate.Edition.zip.html
http://www.filedownloadfull.com/forums/f2/symantec-ghost-v11-5-0-2113-corporate-edition-631022/
http://w17.easy-share.com/1700711546.html
Na és persze...
Intruder2k5
MODERÁTOR
Bár, ha jól tudom Tomato kezeli az ext2-t is, de az ext3 az ami kipróbált, és amit (szerintem) mindenki használ. Ha van elegendő helyed a pendrive-on, vagy winyón, akkor célszerű az
1 GB-os partició az /opt mappának
512 MB a swap számára
és a fennmaradó minél nagyobb hely az /opt/etc/samba/Share vagy /mnt részére.Ha kevés a hely, akkor a szükséges minimumok:
256 MB az /opt mappának
128 MB swap
és a fennmaradó rész itt is ua.Az első és a harmadik legyen ext3, a középső pedig logikusan swap típusú.
HA megy, akkor csinálhatod a leírás alapján konzolból is, ha nem akkor Windows alatt is lehet minden további nélkül, megfelelő programmal. Például a Paragon Drive Copy 9-et próbáltam, az kezeli a PenDrive-ot is. Sajnos a PowerQuest Partition Magic tudomásom szerint csak a HDD-ket látja.Sok sikert, ha elakadsz kérdezz bátran.
(bár én többnyire csak kora estétől késő éjjelig vagyok itt, de azért lesz aki segít majd)[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Most nem nagyon van időm keresgélni (melóban vagyok), de google biztosan tudja.
Mellesleg 600-ast az asus honlapján nem is említik, és nem tudom, hogy a custom fw-k támogatják-e...?! DD-WRT biztosan nem, annak lehet leggyorsabban megnézni a support listáját :-)) Esetleg nézz utána a többinek is. OLEG, Tomato...[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Intruder2k5
MODERÁTOR
Intruder2k5
MODERÁTOR
IP címet kap a gép a routertől? És a többi dolgot is ellenőrizd le, hogy minden jó legyen. Alhálózati maszk, alapértelmezett átjáró, DNS szerver címe. Ha valamelyik nem jó, próbáld kézzel konfigurálni, és nézd meg, hogy úgy megy-e?! Titkosítások vannak aktiválva? WPA, WPA2, WEP? Ha igen, próbáld ideiglenesen kikapcsolni ezeket.
Esetleg ajánlanám még az Administration -> Configuration -> Restore Default Configuration -> Erase All Data In NVRAM Memory menüt...
Még egy kérdés: Eddig is Tomato volt fent?
Intruder2k5
MODERÁTOR
Igen, eddig rendben van a dolog... Bár a konverziót nem tudom mire vélni, de várjuk ki a végét. Ha esetleg nem működne, majd akkor visszatérünk rá, de mondom, még ha valóban konvertálta is, akkor sem biztos, hogy probléma lesz, mert Tomato elvileg kezeli az ext2-t.
Ellenőrzésnek majd megteszi az éles próba. :-) -
Intruder2k5
MODERÁTOR
válasz mcfly13 #8152 üzenetére
Az se rossz... TFTP kliens Windows-ra:
http://www.brothersoft.com/d.php?soft_id=122473&url=http%3A%2F%2Ffiles.brothersoft.com%2Finternet%2Fftp%2Ftftpc_free.exe -
Intruder2k5
MODERÁTOR
Egyébként tökéletesen megfelel a firmware restore tool, sőt, mivel nincsenek "egyéb" beállításai mint a fenti proginak, így elrontani is kevésbé lehet vele. Ezt csak úgy érdekességképpen tettem be. :-) Persze aki érti, az használja nyugodtan a fenti TFTP klienst. De különben a restore tool is egy butított, speciális tftp kliens. Inkább a beállításokat ellenőrizd még egyszer, és mennie kell annak az asus programjával is.
Tehát akkor még egyszer a firmware frissítés menete, nem csak Tomato firmware-hez:Először is egy fontos dolog:
Aki WiFi-t használ, az erre az időre tiltsa le, (vagy dobjon rá egy ólom mellényt :-))), de még véletlenül se kezdje WiFi-n át friisíteni a firmware-t.- Gépen Helyi kapcsolat (Local Area Network) fix beállítása.
IP cím (IP Address): 192.168.1.10
Alhálózati maszk (Subnet Mask): 255.255.255.0
Ez a kettő a lényeges, a többire elvileg semmi szükség, hagyhatod üresen. XP-nél régebbi oprendszer esetében valószinű, hogy újra kell indítani a gépet. Bár, volt mikor az XP is kérte már ezt.- Ezek után a routeren Hard Reset-et nyomsz.
Hátulján a Reset gombot nyomva kell tartani 5-6 mp-ig, bekapcsolt állapotban, míg újra nem indul.- Majd állítsd Restore módba a routert.
Minden kábelt húzz ki a routerből, csak egy darab LAN madzag maradjon az első csatlakozóban, aminek a másik vége a gépedben legyen. Nyomd le a Reset gombot, tartsd nyomva, dugd be a routerbe a táp kábelt, és amikor villogni kezd a Power LED (2-5 mp), akkor elengedheted a Reset gombot.- Firmware Upgrade.
Most indíthatod el az ASUS Firmware Restore Tool programot, betallózod az új firmware file-t, és mehet az upload. Amikor végez, (elvileg) magától újra fog indulni a router (kb. 1 perc elteltével)Ha minden sikerült, akkor most kedvenc böngésződdel itt be tudsz lépni az admin felületre:
http://192.168.1.1
Felhasználónév és jelszó a firmware-től függően változó, általában admin/admin vagy root/admin párosok egyike.Sok sikert hozzá!
Intruder2k5
MODERÁTOR
Én OLEG-re tettem rá a Tomato-t, azzal nem volt gond, simán felment a restore tool-al.
Esetleg próbáld meg feltenni az új OLEG-et, annak fel kell mennie webadmin felületen is, és hátha arra sikerül majd a Tomato-t feltenni.
A beállításoknak valóban törlődni kellene a Hard Reset után, hiszen erről szól a Reset... Nem igazán értem, hogy neked hogy maradt meg, de ezek szerint valamit nem jól csináltál. -
Intruder2k5
MODERÁTOR
válasz Fooler89 #8167 üzenetére
Nem, nem... Ne formázz semmit.
Kapcsold ki az automount-ot, és tedd be ezt az "Administration - Scripts - Init" részbe.sleep 10
swapon /dev/discs/disc0/part2
mount /dev/discs/disc0/part1 /opt
i=0
while [ $i -le 30 ]
do
if [ -d /opt/etc ]
then
break
fi
sleep 1
i = `expr $i+1`
done
mount /dev/discs/disc0/part3 /opt/etc/samba/Share
i=0
while [ $i -le 30 ]
do
if [ -d /opt/etc ]
then
break
fi
sleep 1
i = `expr $i+1`
done
/opt/etc/init.d/rc.unslung[ Szerkesztve ]
Intruder2k5
MODERÁTOR
válasz Fooler89 #8171 üzenetére
Asus Theme letöltése itt.
Be kell kapcsolni hozzá a JFFS-t.
(Administration -> JFFS -> Enable -> Save -> Format -> Save)
Ezután a letöltött zip file tartalmát másold be a /jffs mappába, és a /www/ext mappába is, de utóbbiba csak a 3 file-t ami benne van, az ASUS Theme mappát nem.
Tehát a /jffs-be mappástól, a /www/ext-be pedig csak a file-ok.
Az Administration -> Scripts -> Init részbe tedd be ezt a sort:cp /jffs/ASUS Theme/* /www/ext
a sleep és a swapon közé, majd nyomj egy Save-t.
Ezután az "Administraton -> Admin Access - > Color Scheme" részben válaszd a "custom"-t, majd megint Save. Ezzel ez meg is lenne, elvileg reboot után is megmarad.vnstat-ot nem kell kivenni sehonnan, mivel azt csak a cron indítja...
A cron-t úgy tudod kivenni, hogy az /opt/etc/init.d mappában lévő S10cron file-t átnevezed, hogy ne S betűvel és számokkal kezdődjön a neve, vagy egyszerűen áthelyezed valami másik mappába. Esetleg leveszed róla a futtatható attributumot. Ugyanis az rc.unslung file azokat a file-okat indítja el, aminek a neve Sxx-el kezdődik ebben a mappában. Szerintem ugyanígy letilthatod a samba-t is, mivel a webadmin-os jobb a Tomatoban. Inkább azt állítsd be.[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Egy újabb variáció Tomato feltöltésére... Itt beállítja az átjárót is a router IP címére, és a Linksys-ekhez való TFTP klienssel tölti fel az FW-t.
Intruder2k5
MODERÁTOR
És ez milyen szerintetek? :-)
http://sven.killig.de/openwrt/slugterm_dl.html -
Intruder2k5
MODERÁTOR
válasz Intruder2k5 #8173 üzenetére
És itt van egy batch file is, ami állítólag feltölti tftp-n a tomato-t. (nem próbáltam ki)
Az fw file-t ha minden igaz, akkor "tomato-ND.trx" névre kell keresztelni, mert így keresi.De ha mégis inkább a manuális verzió mellett döntesz, akkor a tftp parancs:
tftp -i 192.168.1.1 put fw_file.trx
Intruder2k5
MODERÁTOR
válasz Fooler89 #8176 üzenetére
Az ASUS nevezetű gép szerintem az optware-s samba miatt van, csak le kellene azt állítani, vagy még "emlékszik rá" az XP, de mivel nincs már ott valójában, ezért nem tudsz belépni. Windowsnak vannak ilyen anomálijái :-)
Igen, a képen jók a beállítások. Így az MSHOME munkacsoportban (ebben van a géped is?) ott kell lennie a routernak, és abban a "router" nevű megosztásnak. Gépigényben nem igazán van különbség, ftp egy kicsit gyorsabb mint samba, de szerintem körülményesebb a használata. Nálam legalábbis a samba megosztások fel vannak csatolva hálózati meghajtónak, de windowsban ez ftp-vel nyűgösebb :-)szerk: Az autoshare all usb partition-t kapcsold ki!.
Intruder2k5
MODERÁTOR
válasz Intruder2k5 #8177 üzenetére
Bocsi, most nézem, hogy itt is ASUS a routered neve...
Ha végképp nem akar menni a samba, akkor adj más nevet a routernak (legalább ideiglenesen). Client Codepage-t teheted 852-re, bár ez nem oka annak, hogy nem működik. -
Intruder2k5
MODERÁTOR
Amint látom van ott még olyan is, ami ellenőrzés alatt van... Tehát még mindig hash-el. Feltételezem, hogy GB-ban mérve sem kevés az a néhány torrent... Amelyiknek végez a hash-elésével, az elindul, a többi pedig várakozik. Ennyi.
Ezt legközelebb úgy kerülheted el, hogy leállítod a torrenteket mielőtt újraindítod a routert.
Intruder2k5
MODERÁTOR
válasz khorvat #8189 üzenetére
Tomato-ban egyszerű beállítani a jelszavas védelmet, de ott is az a problémám vele, hogy ha bekapcsolom az autentikációt, akkor az mindenre érvényes, nekem pedig kell egy publikus mappa is. Most úgy oldottam meg, hogy csak a publikus megosztás látható, a többi az el van rejtve. Ez már majdnem felér egy autentikációval, hiszen itthon a családban úgysincsenek hackerek, a véletlen odatévedés meg ezzel is ki van védve, hiszen a megosztás neveket csak én tudom.
Intruder2k5
MODERÁTOR
Különben meg az első sort cseréld le erre az új S99rtorrent-ben, és menni fog:
#!/bin/sh
Sorry... de az előbb figyelmetlen voltam, most néztem csak pontosan, hogy mi a gondod, és az valóban nálam is gond volt.
root@INT-ROUTER:/tmp/home/root# /opt/etc/init.d/S99rtorrent stop
Stopping rtorrent: rtorrent.
root@INT-ROUTER:/tmp/home/root# /opt/etc/init.d/S99rtorrent start
Starting rtorrent: rtorrent.[ Szerkesztve ]
Intruder2k5
MODERÁTOR
Nem, ez nem az ecadicct féle, lecserélte az egészet a frissítés... De működik.
S99rtorrent file-om:#!/bin/sh
#Optware package of rtorrent uses non-standard layout of directories. ##
#Uncomment the following line to switch to the default layout of rtorrent.##
#dirlayout="RTORRENT_DEFAULT"
###<Notes>###
# This script depends on screen.
# For the stop function to work, you must set an
# explicit session directory using ABSOLUTE paths (no, ~ is not absolute) in your rtorrent.rc.
# If you typically just start rtorrent with just "rtorrent" on the
# command line, all you need to change is the "user" option.
# Attach to the screen session as your user with
# "screen -dr rtorrent". Change "rtorrent" with srnname option.
# Licensed under the GPLv2 by lostnihilist: lostnihilist _at_ gmail _dot_ com
###</Notes>###
##Start Configuration##
# You can specify your configuration in a different file
# (so that it is saved with upgrades, saved in your home directory,
# or whateve reason you want to)
# by commenting out/deleting the configuration lines and placing them
# in a text file (say /home/user/.rtorrent.init.conf) exactly as you would
# have written them here (you can leave the comments if you desire
# and then uncommenting the following line correcting the path/filename
# for the one you used. note the space after the ".".
# . /etc/rtorrent.init.conf
#Do not put a space on either side of the equal signs e.g.
# user = user
# will not work
# system user to run as
user="root"
# the system group to run as, not implemented, see d_start for beginning implementation
# group=`id -ng "$user"`
prefix="/opt"
# the full path to the filename where you store your rtorrent configuration
if [ "${dirlayout}" = "RTORRENT_DEFAULT" ] ; then
config="${prefix}/home/${user}/.rtorrent.rc"
else
config="/opt/etc/rtorrent.conf"
fi
# set of options to run with
options=""
else
options="-n -o import=${config}"
fi
# default directory for screen, needs to be an absolute path
base="${prefix}/home/${user}"
else
base="/opt/share/torrent"
fi
# name of screen session
srnname="rtorrent"
# file to log to (makes for easier debugging if something goes wrong)
logfile="/opt/var/log/rtorrentInit.log"
###END CONFIGURATION###
PATH=/opt/bin:/opt/sbin:/usr/bin:/sbin:/bin:/usr/sbin
DESC="rtorrent"
NAME=rtorrent
DAEMON=$NAME
SCRIPTNAME=/etc/init.d/$NAME
# Do not proceed unless some apps are available.
test -x /opt/bin/screen || ( echo "screen not found." | tee -a "$logfile" >&2 ; exit 2 )
test -x /opt/bin/su -o -x /bin/su || ( echo "su not found." | tee -a "$logfile" >&2 ; exit 2 )
checkcnfg() {
exists=0
for i in `echo "$PATH" | tr ':' '\n'` ; do
if [ -f "$i/$NAME" ] ; then
exists=1
break
fi
done
if [ $exists -eq 0 ] ; then
echo "cannot find rtorrent binary in PATH $PATH" | tee -a "$logfile" >&2
exit 3
fi
if ! [ -r "${config}" ] ; then
echo "cannot find readable config ${config}. check that it is there and permissions are appropriate" | tee -a "$logfile" >&2
exit 3
fi
session=`getsession "$config"`
if ! [ -d "${session}" ] ; then
echo "cannot find readable session directory ${session} from config ${config}. check permissions" | tee -a "$logfile" >&2
exit 3
fi
d_start() {
[ -d "${base}" ] && cd "${base}"
stty stop undef && stty start undef
su -c "screen -ls | grep -sq "\.${srnname}[[:space:]]" " ${user} || su -c "screen -dm -S ${srnname} 2>&1 1>/dev/null" ${user} | tee -a "$logfile" >&2
# this works for the screen command, but starting rtorrent below adopts screen session gid
# even if it is not the screen session we started (e.g. running under an undesirable gid
#su -c "screen -ls | grep -sq "\.${srnname}[[:space:]]" " ${user} || su -c "sg \"$group\" -c \"screen -fn -dm -S ${srnname} 2>&1 1>/dev/null\"" ${user} | tee -a "$logfile" >&2
su -c "screen -S "${srnname}" -X screen rtorrent ${options} 2>&1 1>/dev/null" ${user} | tee -a "$logfile" >&2
d_stop() {
if ! [ -s ${session}/rtorrent.lock ] ; then
return
fi
pid=`cat ${session}/rtorrent.lock | awk -F: '{print($2)}' | sed "s/[^0-9]//g"`
if ps | grep -sq ${pid}.*rtorrent ; then # make sure the pid doesn't belong to another process
kill -s INT ${pid}
fi
getsession() {
session=`awk '/^[[:space:]]*session[[:space:]]*=[[:space:]]*/{print($3)}' "$config"`
echo $session
checkcnfg
case "$1" in
start)
echo -n "Starting $DESC: $NAME"
d_start
echo "."
stop)
echo -n "Stopping $DESC: $NAME"
d_stop
echo "."
restart|force-reload)
echo -n "Restarting $DESC: $NAME"
d_stop
sleep 1
d_start
echo "."
echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2
exit 1
esac
exit 0 -
Intruder2k5
MODERÁTOR
válasz khorvat #8205 üzenetére
Nem is azért mondtam, hogy válts... :-) Majd ha akarod megteszed magadtól is...
Csak megjegyeztem, hogy ott megy az authentikáció, de hiába, mert úgysem jó, úgy ahogy van... Legalábbis nekem nem.
De a rejtés OLEG-ben is működik. Persze tudom, ez csak félmegoldás.[ Szerkesztve ]
Intruder2k5
MODERÁTOR
válasz khorvat #8208 üzenetére
A rejtes az browseable = no sorral allithato be ugye?
Igen erre gondoltam.igy TC-bol tallozhato a router
Ez alatt mit értesz? Nem rejti el a megosztást?smb.conf webes szerkeszteset lehet vele megvalositani
Hát majdnem... Képek
Amúgy a routeren nekem sem sikerült beizgatni, csak asztali gépen. Még régebben OLEG alatt próbálgattam. -
Intruder2k5
MODERÁTOR
válasz Intruder2k5 #8226 üzenetére
Csak arra ügyelj Te is, hogy olyan editort használj, ami nem teszi tönkre a file-t.
Pl. Midnight Commander, esetleg Windows alatt Notepad++ -
Intruder2k5
MODERÁTOR
A ruTorrent "csak" egy WebUI, vagyis egy kezelőfelület az rtorrent programhoz. Az rtorrent az, ami a tűzfal beállításaitól függően aktív vagy passzív módban fut. Amennyiben van erre vonatkozó iptables szabályod, úgy valószínű, hogy aktív a kapcsolatod, ha nincs, akkor pedig passzív. Az rtorrent.conf file-ban meg kell adni egy (vagy több) portot, és ezt meg is kell nyitni természetesen. A szabály valahogy így nézne ki a post-firewall-ban.
iptables -A INPUT -p tcp --dport 6881 -j ACCEPT
A korlátról meg annyit, hogy azért ne feledjétek azt se, hogy korlát ide, vagy oda, a router soha nem fog olyan sebességgel tölteni, mint egy mai asztali pc. Tehát ha némileg lassabb a letöltés a routeren, nem kell rögtön pánikba esni, nem biztos, hogy le vagytok korlátozva, csak egyszerűen "ez erre képes, ennyit tud..."
● Olvasd el az összefoglalót!
