- Támogatja a legújabb Windows frissítést az új AIDA64
- Fürge M.2 2230-as SSD-vel jelentkezett az IRDM
ph Az AD102 GPU-ra épülő típus 4,5 slotos, viszont ebben benne van a radiátor és a megszokottnál 90 százalékkal rövidebb csövezés is.
Egyre több európai használja a Telegramot, ezért megkereste az EU
it Hamarosan sokkal szigorúbb szabályozás alá esik az EU-ban a Telegram, mivel egyre több a helyi felhasználója.
Oliverda
SB750 ügy:
The 790FX is already available, and implements the AMD OverDrive overclocking utility. It launched late last year with the SB600 southbridge, which was replaced in Q1 with the SB700.
However, the SB750 also supports what AMD is calling "Advanced Clock Calibration" which, according to a company document seen by Spanish-language site ChileHardware, can "enable greater performance tuning margin for the AMD Phenom Black Edition CPUs".
"The optimal gain can be seen in configurations that use high-end CPU cooling solution in combination with elevated CPU core voltage value," it adds.
Related stories
Suitable motherboards don't simply require a 790FX or 790GX plus the SB750 - they also need a direct connection between the southbridge's seven GPIO pins to the Socket AM2+ processor's CPU pins. The link must be mediated by a 1.8V-3.3V level shifter circuit, the document states.
Implement all this, the correct Bios code and AMD's AOD Extreme utilty, and - potentially - a CPU that struggled to reach 3GHz before could now stretch to 3.2GHz, we hear. Not that AMD's guaranteeing anything, mind, but that's par for the overclocking course.Érdekes.
"Minden negyedik-ötödik magyar funkcionális analfabéta – derült ki a nemzetközi felmérésekből."
Oliverda
"In the fourth quarter of the present year AMD company is intended to present two four core models ( 45 nm deneb processors ) , which will work in the frequency 2.4-2.8 GHz, and in this case it will preserve TDP value not more than 95 W. The cache capacity in the third level will be increased from 2 to 6 mb.
Propus processors without cache in the third level will also pass to the 45 nm technology . It is known that their frequency range will lie within the limits 2.3-2.6 GHz, TDP level will not exceed 65 W. Propus will present the first four core AMD processor with TDP level not more than 45 W. "[ Szerkesztve ]
Oliverda
válasz HarryPotter #2540 üzenetére
A Deneb (4mag+6MB L3) jön elvileg Q4 végén, a Propus (4mag L3 nélkül legyártva) pedig Q1-ben. A 3 magos az a Heka lesz istentudja hogy mikor.
Oliverda
Oliverda
válasz leviske #2547 üzenetére
Nem rossz. Bár gondolom biztos nem leszel pipa ha tényleg beigazolódik hogy az SB750-el szerelt lapokkal tényleg kihozható az a +200MHz OC.
Most néztem, a Foxconn legújabb lapját már ezzel (is) reklámozzák. Kurzorral rá kell állni a déli hídra.
Oliverda
Oliverda
válasz csatahajós #2574 üzenetére
Te tudod hogy mit szeretnél, döntsd el te.
Nem rossz, fél év alatt csináltak rá egy jó BIOS-t.
Oliverda
Oliverda
A DVI kivezetés nem riser kártyával hanem egy egyszerű szalagkábeles kivezetéssel lesz megoldva. Ott a csatlakozó az NB felett/mellett: [link]
Oliverda
válasz csatahajós #2582 üzenetére
Majd kiderül. Mondjuk szerintem ezzel csak az a baj hogy az ilyen szalagkábeles monitor kivezetéseknél általában romlik a minőség. Amúgy a RAM chipnek ott van a helye az NB alatt/mellett.
Oliverda
Oliverda
válasz Calibos #2673 üzenetére
A legutolsó 2001-es BIOS-t rakd fel és vegyél bele egy 9850BE-t.
"Add 3 options for DRAM Ganged/Unganged mode item, Auto, Enabled, Disabled."
Érdekes.... pedig ez egy sima AM2-es lap...[ Szerkesztve ]
Oliverda
válasz Calibos #2677 üzenetére
Jó kérdés, passz. Ha mind a 4 mag huzamosan 100% megy (ami azért elég ritka) akkor 55-56 fokig megy fel így nyáron a melegben.
Mondjuk nem tudom hogy az AMD esetleg mennyire optimalizálja a saját VGA meghajtóit a saját processzoraira.
Oliverda
Advanced Clock Calibration by AMD
klambi: Ilyen nincs Phenom-hoz.
Oliverda
válasz #65675776 #2692 üzenetére
Gondolom hogy az az IMC nem az Integrated Memory Controller szavaknak a rövidítése. Na meg ha chipset-ben lenne akkor már nem is IMC lenne, a déli hidba meg főleg nem raknak semmiféle memóriavezérléssel kapcsolatos egységet.
"SB750 has PLL integrated in itself,but has no IMC .There might be additional logic in there,which AMD may call SB750 IMC, but it's not the integrated memory controller..."
Oliverda
Oliverda
válasz leviske #2704 üzenetére
"Not adjusting the voltage we were able to hit 3GHz stable, a new high for Phenoms, but adjusting the voltage to 1.425v we were able to hit 3.2GHz stable and reach 3.3GHz though it blue screened in 3DMark."
Ezt a 9850-em is tudja.
Oliverda
válasz Madmax81 #2710 üzenetére
Ha régebb óta nézegetnéd ezeket a számokat akkor tudnád hogy már volt ennél rosszabb is ráadásul akkor amikor nem volt se 48xx-es ATI, se Puma, se Opteron a porondon csak egy TLB bugos Phenom és akkor sem mentek csődbe.
Oliverda
válasz leviske #2719 üzenetére
Ahogy daa-raa is írta úgy van. A roadmap szerint első AM3-as lapok a ma is forgalomban lévő 790FX+SB750 párosra fognak épülni. Ez nagy vonalakban annyit jelent hogy lecserélik a CPU és RAM foglalatokat meg módosítják a BIOS-t és kész is az AM3-as lap.
Amúgy nem tudom hogy milyen számottevő újdonságot hozhat majd az RD890 az RD790-hez képest ha leszámítjuk a csíkszélességet. Szvsz nem sokat.
Oliverda
Oliverda
Deneb AM3 chips will work in AM2+ socket
Na ez így már némileg logikusabb.
AMD is working on PCIe 3.0 support
Az RD890+SB800 páros elég kellemesnek ígérkezik eddig.
Oil prices hurt Nvidia, Intel, AMD
"Nvidia fell from $25 in early June to $18.85 as of yesterday. This is a 32 percent loss in about a month's time."
AMD’s market share dropping in short term
Még most kell venni AMD részvényeket.
Oliverda
válasz - = Zk = - #2771 üzenetére
Legújabb BIOS legyen fent. A 9850 megvan már?
Oliverda
válasz HarryPotter #2837 üzenetére
Év vége, és passz.
Oliverda
válasz HarryPotter #2839 üzenetére
Egyeltalán minek a 4870? A 4850 kevés?
Oliverda
válasz HarryPotter #2841 üzenetére
Szerintem nem éri meg a 4870. Többet zabál, drágább, jobban melegszik és olyan borzasztóan sokkal nem gyorsabb.
Még nem láttam sok tesztet 4870-ről, de 9950-ről sem. Majd kiderül.
Oliverda
válasz HarryPotter #2848 üzenetére
Mégis nálad mit jelent a proci limit? Nem kapsz 3dmárkban qrvasok pontot?
Amúgy meg cserélj procit 9950-re, rakd fel 3GHz-re és ennyi.
Oliverda
válasz HarryPotter #2852 üzenetére
Hát a 20000 ez szerintem kissé túlzás. Max. 16K körül lenne.
Nem tudom hogy mekkora lenne a különbség, de itt egy eredményem 3.1GHz-en egy kissé húzott 3870 mellett. [link]
Nem biztos hogy a lap a ludas, sőt. 9500-9600ból elég sok az ami megál 2.5-2.6 környékén. Én is találokoztam ilyennel.
Oliverda
válasz HarryPotter #2854 üzenetére
Hát szerintem ilyenre ne nagyon számíts.
Oliverda
válasz HarryPotter #2858 üzenetére
Új a 9850? Alkudd fel/le 25re.
Oliverda
válasz HarryPotter #2860 üzenetére
Hát ha vadi új és bontatlan a cucc és legalább 25re (vagy inkább még kicsi lefele) le tudod tornászni akkor megérheti.
Szvsz +22-23K lenne a teljesen reális amit rá kellene dobni. Monjduk ha valami kereskedővel biznicelsz akkor megértem a 27et.
- ÚJ, Bontatlan AMD Ryzen 7 7800X3D
- Intel Core i5-8400 6-Core 2.80GHz LGA1151 Processzor- Számla + Gari, Ár alatt! BeszámítOK!
- Beszámítás! Intel Core i9 11900KF 8mag 16szál processzor garanciával hibátlan működéssel
- Beszámítás! Intel Core i7 4790K 4mag 8szál processzor garanciával hibátlan működéssel
- Beszámítás! Intel Core i9 9900KF 8mag 16szál processzor garanciával hibátlan működéssel
